My first rebuild
Old May 1, 2013 | 12:39 AM
  #1381
SuperBuickGuy's Avatar
SuperBuickGuy
Originally Posted by FatCat
Well crap! I will stress about that until I finish now. Hahaha
I used actual guide coat not paint why would they make guide coat not compatible with your paint?
to incentivize you to sand it all off.... you do know that the point of a guide coat is to sand it off, thus increasing the odds that your car won't be a parade car (so friendly, it waves at you).
Old May 1, 2013 | 08:59 AM
  #1382
FatCat's Avatar
FatCat
Yeah I know that and the plan is to get it all off for sure. I just hate the thought of I miss 1 very small drop it could ruin the all the work. :-)
Old May 1, 2013 | 09:39 AM
  #1383
SuperBuickGuy
Don't let perfect get in the way of done
Old May 1, 2013 | 09:42 AM
  #1384
FatCat's Avatar
FatCat
Well if the guide coat causes fisheye then it has to be perfect and that is why I said I am going to stress it now! Hahaha
Old May 1, 2013 | 09:56 AM
  #1385
SuperBuickGuy
So then you'll rub it back down to paint, which will interact with your new paint and cause fisheyes
you can't win - btw - I'm driving my Corvette today
I know, I'm a stinker
Old May 1, 2013 | 12:30 PM
  #1386
FatCat's Avatar
FatCat
It won't be long now brotha!!!! BTW I also fixed my dying/ running problem!
Old May 1, 2013 | 12:40 PM
  #1387
AirborneSilva's Avatar
AirborneSilva
What was the cure?
Old May 1, 2013 | 12:41 PM
  #1388
SuperBuickGuy
Originally Posted by AirborneSilva
What was the cure?
he cancelled his gym membership
Old May 1, 2013 | 12:43 PM
  #1389
AirborneSilva
Yeah, that will do it
Old May 1, 2013 | 12:50 PM
  #1390
FatCat's Avatar
FatCat
What was the cure?
Kinked fuel line! Ha
Old May 1, 2013 | 01:01 PM
  #1391
AirborneSilva
Cool deal FC, I ordered one of those "S" fuel lines, I think mine isn't allowing full flow and isn't keeping my fuel bowls full (say that 10 times real fast )...
Old May 1, 2013 | 03:56 PM
  #1392
augiedoggy's Avatar
augiedoggy
My bad! I thought you were using spray paint as a guide coat. As long as the stuff your using is compatible with the paint system your using....
Old May 1, 2013 | 04:02 PM
  #1393
AirborneSilva
Just a question: Could you use rattle can primer (black), over the grey primer as a guide coat then after blocking spray a sealer over it and if you didn't get all the guide coat off would it be ok with sealer, if all that makes sense
Old May 2, 2013 | 02:27 PM
  #1394
FatCat's Avatar
FatCat
I think (based on my conversation with paint store) as long as you use a primer that is compatible woith your primer, there would be no need for the sealer.
Old May 2, 2013 | 02:43 PM
  #1395
AirborneSilva
I've heard concerns of areas repaired with bondo bleeding through even if primer has been applied over bondoed area, if you don't use a sealer.
Old May 4, 2013 | 11:34 PM
  #1396
FatCat's Avatar
FatCat
Ok 12 hours solid today! Block sanded, filled small inperfections and scratches and spot primed the car. Tomorrow, final spot sand and shoot this baby!
Old May 5, 2013 | 08:04 AM
  #1397
AirborneSilva
Sweet, looking forward to pictures
To My first rebuild
Old May 5, 2013 | 08:30 AM
  #1398
1974ta's Avatar
1974ta
Default Sealer
You may want to double check. I am pretty sure a sealer is warranted to seal up not just the repairs but the threads in the original fiberglas as well.
Mine showed every fiber in the fiberglas when I bought it because a sealer was not used. The good news was it was easier to strip down to the glass.
Does the body shop know you are painting a corvette?
You have come way too far to cut corners at this point.
Just a thought
Bill
Old May 5, 2013 | 09:34 AM
  #1399
SuperBuickGuy
As long as your filler is well-buried in primer, you don't need to do a separate sealer coat.... of course, the only way you'll know if the filler is well buried is if you don't have dry spots in the paint...
Old May 5, 2013 | 11:56 AM
  #1400
FatCat's Avatar
FatCat
Just a thought
Bill
Hey Bill, they do know I am painting a corvette, they said I didn't need a sealer and what I have already painted seemed to turn out really good so I hope to be good at this point. I will post pix this evening!
