Legendary Problem Solved....
Old May 13, 2011 | 05:36 PM
  #121
gpracer1's Avatar
gpracer1
Originally Posted by doje
Glad to hear I'm not crazy.
LOL.
I fix the machines that make microchips.
Old Jun 25, 2011 | 01:40 AM
  #122
kingrobby25's Avatar
kingrobby25
Just like to say another satisfied Corvette owner with a working FOB again thanks to the solution in this forum!!!!!
I was having issues of phantom lock/locking after using the FOB to lock or unlock the door. The passive system was OFF since I bought the car so this was not the issue. Also, the trunk release on the FOB was only working from right next to the gas filler door.
Took the soldering iron with a tiny bit of solder to the 2 big chips on the circuit board and all their contact points and now the FOB works without having to crush the buttons and the trunk releases from across the garage when pressed.
Thank You Corvette Forum & the OP
:roc k:
Old Jul 8, 2011 | 01:22 PM
  #123
gst20psi's Avatar
gst20psi
Thanks guys! I was having this issue, and was about to try a new Fob or bcm, but I just re-solderer the board and its working perfect! My connections looked ok but I just did it anyways and im glad I did.
Old Jul 9, 2011 | 11:27 AM
  #124
blzvette's Avatar
blzvette
3rd Gear
Just opened mine up and what do ya know, the two points are broke on one side Anybody got a iron?
Picked up a iron at Radio Shack, 8$ Kit with everything. The FOB works now! Thanks, yall saved me about $130!
Old Nov 22, 2011 | 11:53 PM
  #125
pro1955's Avatar
pro1955
Two fobs, both inop won't hold memory or work at all. Soldered both in the 6 places shown, both fobs work like new. Thank you for the info.
Old Feb 9, 2012 | 11:17 PM
  #126
99BlkVette's Avatar
99BlkVette
Originally Posted by tstar
OK guys someone took me up on my offer to repair one so I could play with it. Here's the photographic journey, I applogize in advance I'm not a great photographer and do not have a Macro lense.
Disassembled
Here's one problem, the Top Two Carbon buttons on the faceplate were very dirty as were the corresponding contacts on the board
Oh yeah, I took the Passive Switch out and scrubbed it. It was filthy as they all get
OK crappy pics time. I probed each and every joint on the board and only two had cold solder joints, the Top and Bottom legs on the far right
On the operating table!
All fixed
So I recommend tearing the fob down completely and cleaning the Carbon buttons and contacts for the faceplate, checking the contacts for the battery for allignement and cleaniness and probing for cold/broken solder joints. There was evidence of some moisture behind the faceplate so that may explain the diry carbon buttons/contacts.
We'll have to see how long it lasts, I've asked the owner to step in to keep us up to date.
I've had same issues everyone has talked about. I found what looks like a small capacter located at the top left was loose. I resoldered the joint but the piece rattles now. Does anyone know what this piece is or what you can replace it with? The part in this photo has a blue mark on it. I'll post pictures of mine if no one chimes in. Thanks.
Old Feb 11, 2012 | 03:57 AM
  #127
tstar's Avatar
tstar
St. Jude Donor '11-'12-'13-'14-'15
That's the "Rattle Can" and is supposed to do exactly as you have described. From what I've gathered it's what allows the Passive feature to operate by activating the FOB anytime movement sets it off...
Tim
Old Feb 14, 2012 | 10:29 PM
  #128
rstyles's Avatar
rstyles
6th Gear
read this post, went to walmart to get a solder gun (never done solder, ever). Quickly realized that I have a drinking problem while trying to hold my shaking hand straight on the tiniest piece of crap known to man. Gave it a test run and I'llllll be. It works. Thanks.
Old Feb 15, 2012 | 04:26 AM
  #129
tstar's Avatar
tstar
Good job Alky...
Tim
Old Feb 15, 2012 | 08:36 PM
  #130
miltievette's Avatar
miltievette
Default Great write up
Wow I was so excited when I found this thread. I have been without the use of a fob for about 2 years, it started with distance then the window valet stop working. that's when I figured pull the window valet. re-sync the fobs and I should be good . I also replaced the batt. after working for a day it lost the Memory. I re trained it and it worked for less time. I bought a new/used fob from a forum member and had the same results.
So far I have had no luck. during the course of the years I have tried different things and at the point of FRUSTRATION. Then On Monday I ran into this, on Tuesday I went to my cousins tech shop. I took with me two fobs and one new battery. with a magnifying stand and a fine point soldering pen he and I inspected all 6 points nothing was broken or disconnected . we re-solder the six points anyway. at the end of work I came home couldn't wait to try it. it didn't work SH*T WTF. that's how I felt. and right now wondering what will be my next step. I wont be able to work on this until the weekend but I hope with a more calmer head and less excitement, I can retrain it and teach it to work.
would anyone know if a defective TPMS would keep the RFA from learning the fob? or keep it from working?
Thanks for Sharing I am most proud to be a member of this forum. You guys are really Great.
Old Feb 20, 2012 | 10:40 AM
  #131
miltievette
Default Back Again
Hello Im back again. over the weekend I wanted to see if I could get the fob to work. I re trained the TPMS then I moved on to the Fod training seson I was able to learn the first fob the 2nd one would not learn at all. I turn the key off and tried the 1st fob and it worked. while I was standing by the car. then I walked away for about 5minutes tried the fob again and it did not work. I cant get this thing to hold a memory. I did all of the cleaning and soldering that is explained in this thread. and I still cant get it to work. all of my TPMS are now working fine. any ideas?
Old Feb 21, 2012 | 02:25 AM
  #132
tstar's Avatar
tstar
It seems alot of people are only testing and resoldering the joints shown in the OPS original pics. Those just happened to have been the ones that were loose on HIS car, you may have different joints somewhere else on the FOB board. Probe each and every joint and reflow any that you suspect may be bad or just reflow each and every joint on the board!
Tim
Old Feb 21, 2012 | 06:01 PM
  #133
miltievette
Tim
I fail to mention, that I did touch up all of the other points. now I'm just wondering could it be in the car it's self? because I'm only able to temp train one fob.Then again I question myself why would it be in the car's equipment. maybe I should just break down and buy a new Fob and start over.
Old Feb 27, 2012 | 09:35 PM
  #134
Zerochad's Avatar
Zerochad
5th Gear
Did this myself and it fixed the FOB. I was going to mention the dirt I found between the button contacts and PCB, but it looks like that's already been covered.
Old Mar 26, 2012 | 06:41 PM
  #135
Kaploww's Avatar
Kaploww
Another satisfied customer... Hit the points the OP showed us to hit, and got nothing, pulled it appart again, hit all the points on the board, and it synced up just fine.
Thanks a million!
Old Apr 23, 2012 | 09:44 PM
  #136
Spatiality's Avatar
Spatiality
Add me to the list of satisfied customers
My car/fob has been losing it's sync overnight for years, I don't know why I never searched for a fix before now.
Old Jun 12, 2012 | 11:09 AM
  #137
99StormTrooper's Avatar
99StormTrooper
My Keyfob came with my 99 Vette it never worked and looks nothing like your FOBs I see in the posts here is mine. The back of the FOB reads GM:15008008 FCC ID: MYT3X6898B
To Legendary Problem Solved....
Old Jun 21, 2012 | 12:49 AM
  #138
99StormTrooper
no one?
Old Jun 21, 2012 | 07:22 AM
  #139
Kaploww's Avatar
Kaploww
Originally Posted by 99StormTrooper
no one?
Gotta ask a question to get an answer. lol
Old Jun 21, 2012 | 11:59 AM
  #140
99StormTrooper
Yes you do lol, I didn't even realize that I never asked if what I have is even the correct FOB but thats what I am wondering.
