IMPORTANT ELECTRICAL INFORMATION (Long!)
Old Aug 11, 2007 | 03:40 PM
  #381
71C3Vette's Avatar
71C3Vette
Default Thanks
As I am new to the C5 world I am finding out the imporntance of information. My 71 is very simple, my 99 as I am finding out is anything but. Thank you for the information.
Old Aug 11, 2007 | 11:02 PM
  #382
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Originally Posted by Nver2loud
well, i soldered the wires, started it up, thought everything would be cool...shut it down, went to leave work and now it says service abs, service traction control, but no reduced engine power this time, which is odd because they used to all come together...shut off car and checked codes, got a 1225h, and a u 1096, 1064 and 1016, and ive gotten these before...any ideas????
" replaced at one time and butt splice connected "
Holy Crap! No wonder your were having reduced power issues.
The other DTC 1225 is a wheel speed sensor issue. That most likely an easy fix. Im on vacation in Up State NY and as soon as I get home, Ill give you some info.
BC
Old Aug 12, 2007 | 05:17 PM
  #383
Rays Vet's Avatar
Rays Vet
Hey Bill, Could you tell me where the ground for the tac module would be?
Old Aug 13, 2007 | 09:16 PM
  #384
Nver2loud's Avatar
Nver2loud
any ideas on the wheel speed sensor? also, my key fob loses programming quite a bit, my car battery is good and new, and i watch the dash display while cranking and it doesnt go below 11.2
Old Aug 13, 2007 | 10:33 PM
  #385
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Yep! As easy as it may be to change the wheel hub and be done with it, 9 times out of 10,,,,that is NOT thee answer. I have had this issue on my 02 Z and been through every senniro you can fathom on repair of the issue. Theres been only one person on the forum that I know of who has been to this level of trouble shooting! So,,,,,speeking from the wallet and expierence, you need to start with the simple things first!!! Dont just jump to changing the HUB/sensor!
GM buys the LOWEST BIDDER product! The connector pins in some GM connectors seem to be of good quality but have a distinc defect. The part of the FEMALE connector PIN that makes the connection with the MALE pin looses it spring tension easily thus looses connection inside that circuit.
The wheel speed sensor circuit is a PRIME example of this theory!
Here is a very comprehensive post on the subject:
http://forums.corvetteforum.com/show....php?t=1745355
BC
Old Aug 13, 2007 | 10:43 PM
  #386
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Once you read that post,,,check the wheel speed sensor connector, the JUMPER HARNESS and te harness connector onn the frame for tat sensor.
BC
Old Aug 25, 2007 | 04:12 PM
  #387
Independence's Avatar
Independence
3rd Gear
Default Electrical gremlins strike again.
Bill, just started having issues with my '99 convt. It just stopped on the interstate, but restarted and the dealer couldn't find a problem code. Soon thereafter I noticed the headlights and dash lights would flicker when I hit the dimmer switch and now NOTHING works - as if the batter has been removed. Fairly new battery, kept on a battery tender, so I think it might be a connection issue. Can you send me any more info (pictures would be great) on how to get the the ground connectors? Any other suggestions.
Stan
Old Aug 25, 2007 | 07:58 PM
  #388
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Stan
Stan
I can only guess as to the exact cause but here are some things that you should check.
The battery as new as it is could be bad. Unlikely but it happens. If the battery checks out, look at the following:
Connections to the battery. The Batt cables MUST be correctly torqued to the battery. Torque the connection bolts to 11 ft/lbs
Use a volt meter and read the battery voltage at each fuse box. There are battery connections at both fuse boxes. They look like this:
You must have a solid 12 VDC at both connections. If the voltage at either fuse box connection is interrupted, your car will die.
BC
Old Aug 27, 2007 | 04:08 PM
  #389
raserguy's Avatar
raserguy
Default reduced engine speed
Just want to give my input in case it might help others with the same problem.
I have a 97 and experienced the infamous 'service traction system' , 'reduced engine power', check engine light etc. I cleaned all grounds, changed the battery, and installed a new TAC module, but in the end it seems to have been the throttle position sensor. After replacing it the car runs fine.
I also want to thank everyone for taking the time to respond, I would have been lost without this site.
Old Aug 30, 2007 | 09:05 AM
  #390
AColbe01's Avatar
AColbe01
Default How To Pull Codes from the Computer using the DIC
Originally Posted by TAZZVETTE
Turn the key to the ON position, but don't start the engine. Clear any present messages by pressing the RESET button. Hold the OPTIONS button down, and press the FUEL button 4 times. This will get you into the CODES section of the DIC. The computer will automatically display all the codes your car has created. It will cycle through each code every 3 seconds. Any code that ends in H is a history code (something that has occurred in the past) but is fine now. Once the computer has finished going through all of it's codes, press RESET to enter Manual Configuration mode. It should start with a module and show "NO CODES" or "# CODES".
To optionally reset the codes once in manual mode, press and hold RESET until it displays "NO CODES". Press OPTIONS to go to the next module. Repeat the steps in this paragraph until you have reset the codes in all the computer modules. NOTE !! Only reset the codes IF you want to - it is NOT necessary to do this. :Chevy
For us guys new to the C5s.
Thanks, TAZZVETTE!
Andy
Old Aug 30, 2007 | 09:11 AM
  #391
AColbe01's Avatar
AColbe01
Default List of Computer Codes
Originally Posted by PeteZ06
I've noticed a large amount of posts from members wanting to know what a certain code translates to. Not sure if we already have a list of codes but this might be good as a sticky.
10-PCM - Powertrain Control Module
P0101 Mass Air Flow (MAF) System Performance
P0102 Mass Air Flow (MAF) Sensor Circuit Low Frequency
P0103 Mass Air Flow (MAF) Sensor Circuit High Frequency
P0107 Manifold Pressure (MAP) Sensor Circuit Low Voltage
P0108 Manifold Pressure (MAP) Sensor Circuit High Voltage
P0112 Intake Air Temp (IAT) Sensor Circuit Low Voltage
P0113 Intake Air Temp (IAT) Sensor Circuit High Voltage
P0117 Engine Coolant Temp (ECT) Sensor Low Voltage
P0118 Engine Coolant Temp (ECT) Sensor High Voltage
P0118 Engine Coolant Temperature (ECT) Excessive Time to Closed Loop Fuel Control
P0131 Heated Oxygen Sensor (HO2S) Circuit Low Voltage Bank 1 Sensor 1
P0132 Heated Oxygen Sensor (HO2S) Circuit High Voltage Bank 1 Sensor 1
P0133 Heated Oxygen Sensor (HO2S) Slow Response Bank 1 Sensor 1
P0134 Heated Oxygen Sensor (HO2S) Circuit Insufficient Activity Bank 1 Sensor 1
P0135 Heated Oxygen Sensor (HO2S) Heater Circuit Bank 1 Sensor 1
P0137 Heated Oxygen Sensor (HO2S) Circuit Low Voltage Bank 1 Sensor 2
P0138 Heated Oxygen Sensor (HO2S) Circuit High Voltage Bank 1 Sensor 2
P0140 Heated Oxygen Sensor (HO2S) Circuit Insufficient Activity Bank 1 Sensor 2
P0141 Heated Oxygen Sensor (HO2S) Heater Circuit Bank 1 Sensor 2
P0151 Heated Oxygen Sensor (HO2S) Circuit Low Voltage Bank 2 Sensor 1
P0152 Heated Oxygen Sensor (HO2S) Circuit High Voltage Bank 2 Sensor 1
P0153 Heated Oxygen Sensor (HO2S) Slow Response Bank 2 Sensor 1
P0154 Heated Oxygen Sensor (HO2S) Circuit Insufficient Activity Bank 2 Sensor 1
P0155 Heated Oxygen Sensor (HO2S) Heater Circuit Bank 2 Sensor 1
P0157 Heated Oxygen Sensor (HO2S) Circuit Low Voltage Bank 2 Sensor 2
P0158 Heated Oxygen Sensor (HO2S) Circuit High Voltage Bank 2 Sensor 2
P0160 Heated Oxygen Sensor (HO2S) Circuit Insufficient Activity Bank 2 Sensor 2
P0161 Heated Oxygen Sensor (HO2S) Heater Circuit Bank 2 Sensor 2
P0171 Fuel Trim System Lean Bank 1
P0172 Fuel Trim System Rich Bank 1
P0174 Fuel Trim System Lean Bank 2
P0175 Fuel Trim System Rich Bank 2
P0230 Fuel Pump Control Circuit
P0300 Engine Misfire Detected
P0325 Knock Sensor (KS) System
P0327 Knock Sensor (KS) Circuit Front
P0332 Knock Sensor (KS) Circuit Rear
P0335 CKP Sensor Circuit
P0336 CKP Sensor Circuit Performance
P0341 CMP Circuit Performance
P0342 CMP Sensor Circuit Low Voltage
P0343 CMP Sensor Circuit High Voltage
P0351 Ignition Control #1 Circuit
P0352 Ignition Control #2 Circuit
P0353 Ignition Control #3 Circuit
P0354 Ignition Control #4 Circuit
P0355 Ignition Control #5 Circuit
P0356 Ignition Control #6 Circuit
P0357 Ignition Control #7 Circuit
P0358 Ignition Control #8 Circuit
P0410 AIR System
P0412 AIR Solenoid Relay Control Circuit
P0418 AIR Pump Relay Control Circuit
P0420 TWC System Low Efficiency Bank 1
P0430 TWC System Low Efficiency Bank 2
P0441 EVAP System No Flow During Purge
P0461 Fuel Level Sensor 1 Circuit Performance
P0462 Fuel Level Sensor 1 Circuit Low Voltage
P0463 Fuel Level Sensor 1 Circuit High Voltage
P0480 FC Relay 1 Control Circuit
P0481 FC Relay 2 and 3 Control Circuit
P0500 VSS Circuit (M/T)
P0506 Idle Speed Low
P0507 Idle Speed High
P0522 Engine Oil Pressure Sensor Circuit Low Voltage
P0523 Engine Oil Pressure Sensor Circuit High Voltage
P0530 A/C Refrigerant Pressure Sensor Circuit
P0562 System Voltage Low
P0563 System Voltage High
P0567 Cruise Resume Circuit
P0568 Cruise Set Circuit
P0571 Cruise Brake Switch Circuit (M/T)
P0601 PCM Memory
P0602 PCM Not Programmed
P0604 PCM RAM Performance
P0606 PCM Internal Communication Interrupted
P0608 VSS Output Circuit
P0650 MIL Control Circuit
P0654 Engine Speed Output Circuit
P0704 Clutch Switch Circuit (M/T)
P0705 Transmission Range Switch Circuit (A/T)
P0706 Transmission Range Switch Performance (A/T)
P0801 Reverse Inhibit Solenoid Control Circuit (M/T)
P0803 1-4 Upshift Solenoid Control Circuit (M/T)
P0804 1-4 Upshift Lamp Control Circuit (M/T)
P1111 Intake Air Temperature (IAT) Sensor Circuit Intermittent High Voltage
P1112 Intake Air Temperature (IAT) Sensor Circuit Intermittent Low Voltage
P1114 ECT Sensor Circuit Intermittent Low Voltage
P1115 ECT Sensor Circuit Intermittent High Voltage
P1120 TP Sensor 1 Circuit
P1125 APP System
P1133 Heated Oxygen Sensor (HO2S) Insufficient Switching Bank 1 Sensor 1
P1134 Heated Oxygen Sensor (HO2S) Transition Time Ratio Bank 1 Sensor 1
P1153 Heated Oxygen Sensor (HO2S) Insufficient Switching Bank 2 Sensor 1
P1154 Heated Oxygen Sensor (HO2S) Transition Time Ratio Bank 2 Sensor 1
P1220 TP Sensor 2 Circuit
P1221 TP Sensors 1, 2 Performance
P1258 Engine Coolant Over Temperature-Fuel Disabled
P1275 APP Sensor 1 Circuit
P1276 APP Sensor 1 Circuit Performance
P1280 APP Sensor 2 Circuit
P1281 APP Sensor 2 Circuit Performance
P1285 APP Sensor 3 Circuit
P1286 APP Sensor 3 Circuit Performance
P1380 EB (T) CM DTC Detected- Rough Road Data Unusable
P1381 Misfire Detected - No EB (T) CM/PCM Serial Data
P1415 AIR System Bank 1
P1416 AIR System Bank 2
P1431 Fuel Level Sensor 2 Circuit Performance
P1432 Fuel Level Sensor 2 Low Voltage
P1433 Fuel Level Sensor 2 High Voltage
P1441 Evaporative Emissions (EVAP) System Flow During Non-Purge
P1514 TAC System MAF Performance
P1515 Command vs Actual Throttle Position Performance (PCM Module)
P1516 Command vs Actual Throttle Position Performance (TAC Module)
P1517 TAC Module Processor
P1518 PCM to TAC Module Serial Data Circuit
P1539 A/C Clutch Status Circuit High Voltage
P1545 A/C Clutch Relay Control Circuit
P1546 A/C Clutch Status Circuit Low Voltage
P1571 ASR Desired Torque
P1574 Stop Lamp Control Circuit
P1575 Extended Travel Brake Switch Circuit High Voltage
P1626 Theft Deterrent System Fuel Enable Circuit
P1630 Theft Deterrent System PCM In Learn Mode
P1631 Theft Deterrent System Password Incorrect
P1635 5 Volt Reference #1 Circuit
P1639 5 Volt Reference #2 Circuit
P1644 Delivered Torque Output Circuit
P1652 Powertrain Induced Chassis Pitch Output Circuit
28-TCS - Traction Control System
C1214 Sol Valve Relay Contact or Coil CKT Open
C1217 BPMV Pump Motor Relay Contact CKT Open
C1221 LF Wheel Speed Sensor Input Signal is 0
C1222 RF Wheel Speed Sensor Input Signal is 0
C1223 LR Wheel Speed Sensor Input Signal is 0
C1224 RR Wheel Speed Sensor Input Signal is 0
C1225 RF Excessive Wheel Speed Variation
C1226 LF Excessive Wheel Speed Variation
C1227 LR Excessive Wheel Speed Variation
C1228 RR Excessive Wheel Speed Variation
C1232 LF Wheel Speed Circuit Open or Shorted
C1233 RF Wheel Speed Circuit Open or Shorted
C1234 LR Wheel Speed Circuit Open or Shorted
C1235 RR Wheel Speed Circuit Open or Shorted
C1236 Low System Supply Voltage
C1237 High System Supply Voltage
C1241 Magna Steer Circuit Malfunction
C1242 BPMV Pump Motor Ground Circuit Open
C1243 BPMV Pump Motor Stalled
C1255 EBTCM Internal Malfunction
CEBCM Internal Malfunction
C1261 LF Inlet Valve Solenoid Malfunction
C1262 LF Outlet Valve Solenoid Malfunction
C1263 RF Inlet Valve Solenoid Malfunction
C1264 RF Outlet Valve Solenoid Malfunction
C1265 LR Inlet Valve Solenoid Malfunction
C1266 LR Outlet Valve Solenoid Malfunction
C1267 RR Inlet Valve Solenoid Malfunction
C1268 RR Outlet Valve Solenoid Malfunction
C1273 RF TCS Master Cyl Isolation Valve Malfunction
C1274 RF TCS Prime Valve Malfunction
C1276 Delivered Torque Signal CKT Malfunction
C1277 Requested Torque Signal CKT Malfunction
C1278 TCS Temporarily Inhibited By PCM
C1281 Steering Sensor Uncorrelated Malfunction
C1286 Steering Sensor Bias Malfunction
C1287 Steering Sensor Rate Malfunction
C1291 Open Brake Lamp Sw Contacts During Deccel
C1293 DTC C1291/C1292 Set Curnt/Prev Ign Cylce
C1294 Brake Lamp Switch Circuit Always Active
C1295 Brake Lamp Switch Circuit Open
U1016 Loss of Communications with PCM
U1255 Generic Loss Communications
U1300 Class 2 Circuit Shorted to Ground
U1301 Class 2 Circuit Shorted to Battery
38-RTD - Real Time Damping
C1650 ESC Module Malfunction
C1658 EEPROM Calibration Malfunction
C1710 LF Shock Absorber Solenoid (Short to Voltage)
C1711 LF Shock Absorber Solenoid (Short to GND)
C1712 LF Shock Absorber Solenoid (Open Circuit)
C1715 RF Shock Absorber Solenoid (Short to Voltage)
C1716 RF Shock Absorber Solenoid (Short to GND)
C1717 RF Shock Absorber Solenoid (Open Circuit)
C1720 LR Shock Absorber Solenoid (Short to Voltage)
C1721 LR Shock Absorber Solenoid (Short to GND)
C1722 LR Shock Absorber Solenoid (Open Circuit)
C1725 RR Shock Absorber Solenoid (Short to Voltage)
C1726 RR Shock Absorber Solenoid (Short to GND)
C1727 RR Shock Absorber Solenoid (Open Circuit)
C1743 Loss of Vehicle Speed Signal
C1760 LF Position Sensor (Out of Range)
C1761 RF Position Sensor (Out of Range)
C1762 LR Position Sensor (Out of Range)
C1763 RR Position Sensor (Out of Range)
C1768 Position Sensor Supply Malfunction (Overcurrent)
C1780 Loss of Steering Position Signal
C1786 RTD Control Relay Malfunction
C1787 RTD Control Relay Circuit (Open or Short to GND)
C1788 RTD Control Relay Circuit (Short to Voltage)
C1790 Ride Control Switch (Out of Range)
C1791 Ride Control Switch (Contact Malfunction)
40-BCM -Body Control Module
B0432 Rear Defogger Relay Circuit
B0433 Rear Defogger Relay Circuit
B0502 RH DRL Relay Circuit
B0503 RH DRL Relay Circuit
B0507 LH DRL Relay Circuit
B0508 LH DRL Relay Circuit
B0605 BCM Internal Memory Function
B0844 BCM Temporarily Inhibit ABS
B2403 Front Fog Lamp Switch Circuit
B2408 Rear Fog Lamp Switch Circuit
B2482 Backup Lamp Relay Circuit
B2483 Backup Lamp Relay Circuit
B2527 Horn Relay Circuit
B2528 Horn Relay Circuit
B2573 Hatch Release Switch Circuit (Short to Voltage)
B2578 RF Turn Signal Monitor Circuit (Short to Voltage)
B2583 LF Turn Signal Monitor Circuit (Short to Voltage)
B2587 Column Lock/Unlock Drive (A)
B2588 Column Lock/Unlock Drive (A)
B2592 Column Lock/Unlock Drive (B)
B2583 Column Lock/Unlock Drive (B)
B2597 Traction Control System Switch Circuit
B2721 PASS-Key Detection Circuit
B2722 PASS-Key Detection Circuit
B2723 PASS-Key Detection Circuit
B2735 PASS-Key Programming Mode Active
U1096 Loss of Communications with IPC
U1255 Serial Data Line Malfunction
60-IPC - Instrument Panel Cluster
B0516 Speedometer Signal Circuit Malfunction
B0521 Tachometer Signal Circuit Malfunction
B1512 DIC Switch 1 Signal Short to GND "FUEL"
B1517 DIC Switch 2 Signal Short to GND "GAGES"
B1522 DIC Switch 3 Signal Short to GND "TRIP"
B1527 DIC Switch 4 Signal Short to GND "OPTIONS"
B1532 DIC Switch 5 Signal Short to GND "E/M"
B1537 DIC Switch 6 Signal Short to GND "RESET"
B1542 Oil Temperature Circuit Short to GND
B1543 Oil Temperature Circuit Open
U1040 Loss of Communications with TCS
U1056 Loss of Communications with RTD
U1064 Loss of Communications with BCM
U1128 Loss of Communications with Radio
U1153 Loss of Communications with HVAC
U1160 Loss of Communications with LDCM
U1161 Loss of Communications with RDCM
U1166 Loss of Communications with SCM
U1176 Loss of Communications with RFA
80-Radio - Radio Not Found
99-HVAC - Heater, Ventilation, Air Conditioning
B0332 Outside Air Temp Sensor Short to GND
B0333 Outside Air Temp Sensor Open
B0337 Inside Air Temp Sensor Short to GND
B0338 Inside Air Temp Sensor Open
B0348 Sunload Temperature Sensor Open
B0361 Left Actuator Feedback Short to GND
B0363 Left Actuator Feedback Open
B0365 Right Actuator Feedback Short to GND
B0367 Right Actuator Feedback Open
B0441 Left Actuator Out of Range
B0446 Right Actuator Out of Range
B1016 Loss of Communications with PCM
A0-LDCM - Left Door Control Module
B2202 Left Window Up Switch Fault
B2204 Left Window Down Switch Fault
B2206 Right Window Up Switch Fault
B2208 Right Window Down Switch Fault
B2222 LT Mirror Select Switch Fault
B2224 RT Mirror Select Switch Fault
B2226 Mirror Right Switch Fault
B2228 Mirror Left Switch Fault
B2232 Mirror Up Switch Fault
B2234 Mirror Down Switch Fault
B2236 Left Door Lock Switch Fault
B2238 Left Door UnLock Switch Fault
B2242 Memory 1 Switch Fault
B2244 Memory 2 Switch Fault
B2252 Key Cylinder Switch Fault
B2262 Horizontal Position Sensor Fit
B2264 Vertical Position Sensor Fault
B2272 Left Mirror Motor Fault
B2274 Window Motor Fault
B2276 Door Lock Motor/Mirror Heater Fit
B2282 Battery #1 Fault
B2284 Battery #2 Fault
B2286 +5V Reference Fault
A1-RDCM - Right Door Control Module
B2203 Right Window Up Switch Fault
B2205 Right Window Down Switch Fault
B2237 Right Door Lock Switch Fault
B2239 Right Door Un-Lock Switch Fault
B2253 Key Cylinder Switch Fault
B2263 Horizontal Position Sensor Fit
B2265 Horizontal Position Sensor Fault
B2273 Right Mirror Motor Fault
B2275 Window Motor Fault
B2277 Door Lock Motor/Mirror Heater Fit
B2283 Battery #1 Fault
B2285 Battery #2 Fault
B2287 +5V Reference Fault
A6-SCM - Seat Control Module
B0846 Battery 2 Out of Range
B0851 Battery 1 Out of Range
B2002 Fore/Aft Seat Motor Open or Short to GND
B2007 Front Vertical Seat Motor Open or Shorted
B2012 Rear Vertical Seat Motor Open or Shorted
B2172 Seat Front Up Switch Shorted to GND
B2177 Seat Front Down Switch Shorted to GND
B2182 Seat Rear Up Switch Shorted to GND
B2187 Seat Rear Down Switch Shorted to GND
B2192 Seat Forward Switch Shorted to GND
B2197 Seat Reverse Switch Shorted to GND
B2605 Seat Front Vertical Position Sensor Failure
B2606 Seat Rear Vertical Position Sensor Failure
B2607 Seat Horizontal Position Sensor Failure
B0-RFA - Remote Function Actuation
B0605 Receiver Internal Memory Malfunction
B2805 No Transmitters Programmed
C2100 Left Front TPM Sensor Malfunction
C2105 Right Front TPM Sensor Malfunction
C2110 Right Rear TPM Sensor Malfunction
C2115 Left Rear TPM Sensor Malfunction
C2120 TPM System Malfunction (No Sensors Received)
C2121 TPM System Programming Malfunction (No Sensors Programmed)
U1000 Loss of Communication Undetermined
U1016 Loss of Communication with PCM
U1064 Loss of Communication with BCM
U1096 Loss of Communication with IPC
Thank You, PeteZ06 !
Andy
The best troubleshooting site relating to the codes> http://www.gearchatter.com/index.php
Last edited by AColbe01; Aug 30, 2007 at 09:14 AM. Reason: Added link for diagnostic help
Old Aug 30, 2007 | 12:10 PM
  #392
B TOPLIS's Avatar
B TOPLIS
1st Gear
Default Ground connector & Traction Control Failure
My 2000 is showing "Traction Control Failure" & I am trying to clean the various electical grounds. Does any one know which ground location in particular would apply to this warning?
Also I've removed the Ground Connector G-101 type as shown, but how the heck do you open it to clean inside?
Any help freatly appreciated!
Old Sep 1, 2007 | 09:48 AM
  #393
Highway Hawk's Avatar
Highway Hawk
Default Recurring P0137 and Other Codes
I've only had my car for a couple months now. It's a 2001 coupe and the only mods are air intake, exhaust, and brakes.
On Aug 18th the check engine light came on and after a few restarts and a few hours of driving it cleared. The codes I pulled were P0137, B2282, and B2283 all history codes. Since I did not know which of these was the current culprit I cleared the codes to see what might reoccur.
Yesterday in driving around leisurely, check engine light came on again and has not cleared yet. Codes are P0137 (H and C) and B0521 H. Car is showing no driveability problems of any kind.
Can you recommend which ground connections or other connections I should be checking out and cleaning first? Thanks.
Regards,
Peter
Old Sep 1, 2007 | 10:25 AM
  #394
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Regards,
Peter
The DTC that you need to worry about is P-0137 DTC P0137 or P0157 HO2S Circuit Low Voltage
That indicates that your left rear O2 sensor (AFTER THE CATS) is not functioning properly
Old Sep 2, 2007 | 07:22 AM
  #395
Highway Hawk
Bill, is this something that's likely to be cleared up by checking and cleaning connections or is it more likely the sensor needs to be replaced? Also, how critical is it to fix this? I thought I read somewhere that some people even remove the sensors after the cats.
Thanks for all your help.
Regards,
Peter
Old Sep 2, 2007 | 09:14 AM
  #396
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Regards,
Peter
O2 sensors do fail. They can fail because they get contaminated or just wear out. They can become contaminated early because the heater circuit gets weak or the cat becomes weak.
The only way to really know is to measure the heater circuit voltage to ground and make sure its 12VDC. Then you can use a laser thermometer and make sure both cats are working correctly. Yes the ground circuit can cause them to fail prematurly. Just ask BULLDOG350. He was reading 7 VDC vise 12 VDC on the heater circuit due to bad grounds.
If you want to remove the rear O2 sensors you will have to purchase O2 Simulators (SIMS) or have them programmed out of the PCM via tuning software.
BC
Old Sep 5, 2007 | 01:14 PM
  #397
LostCauseZ06's Avatar
LostCauseZ06
just thought id let you guys know, i was having a problem with my headlights not working at all, they would turn on but wouldnt go up or down.
did what cajun dude suggested and tied all my grounds into 1 big weathertight ground and VOILA.. my headlights worked for the first time in 8 months
To IMPORTANT ELECTRICAL INFORMATION (Long!)
Old Sep 21, 2007 | 02:12 PM
  #398
FL_Dave's Avatar
FL_Dave
Default O2 Sensor Failure
Another common reason for O2 sensor failure is using silicone-based RTV on the downpipe gasket (between the headers & exhaust pipe). I had some "dum bass" (special kind of fish), use "sensor-safe" RTV on the downpipe gasket after fixing my "leaky butt". Not only did he not fix the butt, but after calling the engineer at the RTV manufacturing company I convinced them that exhaust gas can easily reach 1200 - 1500F, which is beyond the safe temp of the RTV.
Sensor safe RTV may be good on the intake side, but not on the exhaust. If you have this problem, clean it like crazy with a wire brush around the flange, use a new gasket, then wire brush the inside of the exhaust pipe. Otherwise, you'll be replacing the O2 sensor again -- don't ask how I know.
Old Sep 26, 2007 | 02:40 AM
  #399
thrasher64's Avatar
thrasher64
Great thread so far
I have been seeing the error "28-TCS - Traction Control System
C1281 Steering Sensor Uncorrelated Malfunction" on and off since I got the car but after leaving the key in the ignition over night (draining the battery) I am now getting all sorts of codes
The B0-RFA also will show "NO COMM" every few times when trying to check it.
I tried cleaning a few of the grounds this evening with no luck and will try the rest of them tomorrow but I was just wondering if you guys could pinpoint the issue or give me an idea as to where the hang up is.
I also took out the #2 fuse to get rid of the pesky running lights.. Will put that back in tomorrow just to make sure its not adding to the mess.
Old Sep 28, 2007 | 06:07 PM
  #400
docimastic's Avatar
docimastic
Default cheapest EBCM fix .. and GOOD
OK, just wanna post re ABSFIXER.COM ... Higly Recommend them. Ok, "him" ... Brandon. Great service, great communication (you'll get an email from him as soon as you pay -- giving you your order number, and then another the evening of the day he receives your ECBM, telling you that it will ship such and such date --- the next business day! Plus he gives a choice of shipping options.. want if 1day, 2-day, ground? no prob.. pick your speed, pick your price.) GAWD its nice not having the ABS/TC lights and messages!!
