IMPORTANT ELECTRICAL INFORMATION (Long!)
Old Apr 9, 2008 | 12:36 PM
  #501
coolcat9's Avatar
coolcat9
5th Gear
Do you have a picture of EXACTLY where the grounds are on drivers side near the door (1 and 2)? They are hard to find.
Old Apr 12, 2008 | 09:33 PM
  #502
VetteDawg's Avatar
VetteDawg
My DIC lit up like a christmas tree on me today....and neither window would go down. I had the window thing happen to me once just before I stored the car last November, but the next morning all was fine.
Today, went to Radio Shack and all was fine. Put the window up before getting out of the car. When I got back in the car and started her up the windows wouldn't go down. So I drive off. Didn't get out of the parking lot and the Service Traction Control came on...followed by Reduced Engine Power...Check Tire Pressure....Check Tire Pressure Monitors...Low Washer Level (I get that now and then...never use the washers)...Low Fuel (gas gauge went to zero - more than 3 quarters in the tank)...during the ride home the gas gauge went back to normal but all the other things kept coming up.
When I got home I put the tender on the battery. It's been about 3 hours, went out and wiggled the driver's side ground behind the headlight (mine's a nut on a threaded shaft and I don't have the correct deep socket - it's bigger than 3/8 but smaller than 7/16). With the battery tender still connected I put the key in and turned it to accessory and hit the window down button and down the window went. I don't know if it's because the battery tender lifted the battery power or the wiggling of the ground coupler (I popped one side of the coupler back a little with a screw driver but not being able to get the nut off I couldn't remove the coupler completely).
Old Apr 13, 2008 | 09:53 PM
  #503
VetteDawg's Avatar
VetteDawg
Well, today I checked the gang grounds behind the headlights. Both looked pretty good. Driver's side looked great...wire brushed everything (ring terminals & fingers) anyway and used dieleltric grease. Passenger side was just a bit oily on the ring terminals...cleaned everything, wire brushed and dielectric grease.
Started the car up and everything seemed ok...except the windows didn't work...opened the driver's door and tried the window and it worked...closed it and it didn't. Shut the car off and watched the rest of The Masters golf tourny. After the event I started it up and everything worked, windows and everything. Took it for a 7 mile ride. Everything ok. Next weekend I'm gonna check out the window wire couplers.
Old Apr 14, 2008 | 12:50 PM
  #504
buckdog06's Avatar
buckdog06
vettedawg-
the connector for the wireharness that goes thru the door needs attention. I'll look for my post to fix this
Here it is:
I've been lurking for weeks trying to self diagnosis my problem. What happened about three weeks ago all the warnings came on and it said check tire pressure, low power mode, check active handling. Had no power windows, what a mess. So being the do it yourselfer I am, I disconnected the battery and it temporally fixed it for the last 1,000 or so miles. And now it.
's back, can't clear it what ever I do it keeps coming back. Also lots of trouble codes, I mean LOTS! Like 24.
I notice that when it was sort of working ok the memory seat doesn't always work every time, also when I drove it at dark in the morning about 1/2 mile from home the lights would dim slightly for a brief moment then be ok. If I need a PCM where's a good place to get it from. I did clean and check the grounds under the hood, 4 of them and they were super clean to begin with. The car has 30,000 miles and is in terrific condition. when I relearn the PCM clear the codes it runs great, then it starts usually with the buttons not functioning on the drivers door, then the active handling light coming on then after a few sec's everything goes REAL WACKY. I need help TIA Dan from MI
Hi All- on the way to work this morn it did it again. After clearing all codes the dr door switches were still inoperable. So I opened the door and grabbed the wires in the dr opening and moved them back and forth while pushing the buttons and then the switches started working. I think the dr door harness is where the problem is? I talked to a service eng. at GM this morn and he said that’s the place to start if it was a BCM it wouldn't be intermittent like I'm having. He said harnesses that pass thru doors is a big problem.
His fix for me:
Power door lock or power window may be inoperative or intermittently may not work from one of the doors.
Recommendation/Instructions:
While attempting to operate the function, grab the conduit of the C201
connector and move it back and forth. If the function now operates, check
corresponding connectors to ensure that all of the connector pins are fully
seated and are free of any corrosion.
Care should be taken to check for a deformed (too large internal diameter)
female pin. Replace loose/damaged female terminals in connector. Usually
terminals A, B, C (power and/or ground) C200 and C201 are located in
corresponding "A" pillar just inboard of door hinge area harness
conduit/pass-through.
-It's fixed, good as new
Old Apr 14, 2008 | 06:49 PM
  #505
VetteDawg's Avatar
VetteDawg
Originally Posted by buckdog06
Usually
Thanks muchly!
...just trying to envision the "A" pillar. When I think "A" pillar I think up at the rear of the windshield.
Old Apr 16, 2008 | 11:59 AM
  #506
zr2lang's Avatar
zr2lang
Default Found my electrical issues
All I cleaned the grounds and still had the same issue. So I was starting to look and all of my wires that are near the exhaust and found that the main harness going to the starter and to sending units on the block and the oil pan were melted together. So I pulled the passenger header off and the starter and pulled apart the individual wires and most of them were showing (COPPER).
I guess my 1st question is, Is there any heat resistant material I can use to place my wires in.
2nd question is should I replace the melted wire with a heavier gauge wire.
Old Apr 16, 2008 | 12:49 PM
  #507
TOOGECKO's Avatar
TOOGECKO
I assume you have aftermarket headers? I was under my car last winter and noticed that I was starting to see some melting on the main wire harness insulation as well. I went down to the auto store and bought some muffler tape as a quick fix. I think after seeing this that I am going to order some header wrap and cover those wires before I have the same problem...
Old Apr 16, 2008 | 01:03 PM
  #508
zr2lang's Avatar
zr2lang
Yes i do have aftermarket headers(kooks) brothers with a 3" collector. I zipped tied all of the wires away from the header as best as I could. there is a lot of heat so I would recommend a header rap. Or just the collector.
Old Apr 16, 2008 | 07:08 PM
  #509
MongoosC5's Avatar
MongoosC5
[QUOTE=TheeMike;1564491331]I am amazed at the response time!QUOTE]
...me too.
Old Apr 21, 2008 | 01:48 PM
  #510
zr2lang's Avatar
zr2lang
Default NEED HELP WITH ELECTRICAL ISSUES part 2
All, I have read Bill Curlee thread up and down. I went to my 02 Z06 and cleaned all of the grounds. I cleaned them and most of them were in pretty good shape. The car is rarely driven in the rain or snow. I live in St.Louis MO. I did find some frayed/melted wire going down to the starter. I replaced the wires and shielded them. Went to start the car after all of the repairs and got the dreaded service traction control, low voltage, reduced engine power,and service ABS. I turned car off and then it started just fine. I know this sound like the grounding issue. The check engine light come on is the one for the throttle body getting low voltage. I clear the code and the car starts and runs fine. I drive the car somewhere park it and then when I return it does the dreaded lights flickering on and off for a few seconds then starts. I can't figure it out. Any help would be great because I hate to see my Z just sitting in my garage with the car cover on it.
Thanks ALL.........
Old Apr 21, 2008 | 09:55 PM
  #511
talon46's Avatar
talon46
Default something else to make it better
In the electric world, they make this cool stuff called heat schrink only draw back is the larger diameter the more expensive it is. look like the connectors are about 2 inches, you can buy a long strip before you take them apart, do all of your cleaning then slip it over the connector, put it back together, apply a little heat, it will schrink up nice and tight and should prevent further corrosion, especially if you use somekind of anti corrosion as well. just some food for thought.
Old Apr 22, 2008 | 07:55 PM
  #512
vettenut71348's Avatar
vettenut71348
Cruising
Default Electrical power interrupt 99 Coupe
I too have the infamous "Reduce Engine Power" etc electrical faults in my '99 Coupe, auto trans, 41,000 miles. Just a brief description of events. While driving along at 30 MPH (school zone), I lost power to both doors, radio, gages went wild, and DIC flashed about every warning known to man. Having just read Bill Curlees post about poor or compromised chassis grounds, I'd like to check out grounds G201 (left side 'A' pillar) and G202 (right side 'A' pillar) as they are related to the door modules. Does anyone have experience accessing these two ground points? Does it require fussy removal of body panels or interior shrouds? Or am I heading down the wrong path? All comments are appreciated.
Old Apr 22, 2008 | 11:30 PM
  #513
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Yep! Wrong path! Go STRAIGHT to the wiring harnesses in the door accordion tube! If the doors lost comms, that the MOST LIKELY cause of your problems! Go there first and PLEASE let me know what you find and how you had to repair the problem. Look foe damaged wires and seperate EACH connector and examine each female pin.
BC
Old Apr 23, 2008 | 09:08 AM
  #514
rayc1968's Avatar
rayc1968
Cruising
would that make dic work only when it want to?
Old Apr 23, 2008 | 11:50 AM
  #515
TheeMike's Avatar
TheeMike
That just sounds BAD... (and way too easy)
Old Apr 23, 2008 | 03:20 PM
  #516
LesLong's Avatar
LesLong
Default Dice13
Bill - I have a 2002 Z06 and may have this problem. 3-4 minutes after start, bells, warning lites, all gages go to full deflection or zero, display cycles thru all warnings. I stop the car, turn it off, wait a minute and restart. Usually goes away but it is happening more frequently. Does that sound like ground problems or a module??? Thanks. Les - Dice13
Old Apr 23, 2008 | 07:07 PM
  #517
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Normally when mulitple modules are effected,,the fault is the serial data buss. A ground or short to another signal wire can and will cause it to FREAK OUT. The only reason I suggest the door harness is that LOTs of people have this very issue and that causes the problem. There have also had simular problems with the drivers seat control module connector (has the same serial data wire in there too )
Another place that will cause TONs of lights, bells, whistles and codes is the Body Control Module (BCM).
If it gets wet / damp/ or gets corossion on the back of the circuit board (yes they do corrode if you have a wet passengers foot well) the car will freak out.
So,, your mission is to figure where the serial data wire is having issues.
I start at the door accordion tube. Its easy and quick!
BC
To IMPORTANT ELECTRICAL INFORMATION (Long!)
Old Apr 24, 2008 | 10:13 AM
  #518
oogiemaster's Avatar
oogiemaster
2nd Gear
Originally Posted by Bill Curlee
I suck at doing FANCY web stuff! I may try to make this into a TECH TIP. I would have posted more pictures but the forum would not let me! I have more info and pictures if anyone need them! Just e-mail me
bill327@msn.com
My 98 electrical issues are 98% solved!!! The only thing that is still kicking my A$% is a Fuel Level Sender problem. After I drive it for a while it goes to empty and I get DIC codes P0461 & P1431
I suspect it is a fuel level sender issue BUT is it the left or the right sensor?? The left one is $400. and the right one is $300. My luck it will be BOTH that are bad!!
To figure it out without using a TECH II, I have to remove both senders and do a resistance check on a full sweep of the float assembly!
Anybody else had this issue??
Bill
About the fuel sender, I was advised of the solution to this issue. I solved thesame issue on my C5.The problem starts when i fill up and my fuel goes below 3/4 tank then my guage suddenyt drops to empty. I had to set my trip meter before each fill-up just to make sure that I did not ran out of gas.I started adding Chevron with techron gas additives. I did this for bout 4 times in two months using the 20oz. bottle and emptying it before filling up the tank. I also use Chevron with techron gas station as much as possible, ( I'm not advertising, I promise!), In the first month I tried it I noticed a dramatic effect and at the end of the second month the problem totally dissapeared. I was releived. I hope this works for you and for everyone!
Old Apr 24, 2008 | 10:26 AM
  #519
Humy's Avatar
Humy
Originally Posted by Humy
I'm back... I read through all the posts.
Here are the codes I wrote down early this week and then cleared them...
10-PCM
P1571H ASR Desired Torque
28-TCS
C1277H Requested Torque Signal CKT Malfunction
60-IPC
B0521H Tachometer Signal Circuit Malfunction
80-Radio
U1016H Loss of communication with PCM
LDCM
B2285H Battery #2 Fault
B2282H Battery #1 Fault
B2284H Battery #2 Fault
U1064H Loss of Communication with BCM
U1160H
I was only getting "service traction system" (only - ABS was fine) before, when I pressed down on the brake to shift out of park or reverse. A few days ago, I was driving on a bumpy road and got service traction system and ABS inactive , so the warnings came on for the first time while I was driving.
Just checked the codes again and here are the ones that are there now...
10-PCM
P1571 H C ASR Desired Torque
28-TCS
C1225H RF Excessive Wheel Speed variation <----------NEW ONE
80 Radio
So, based on reading this thread I should check the sensor that is on the RF wheel hub and make sure the connection is good - where on the inner hub is the wire with the connector? Top, bottom, towards the front of the Vette, etc? The pics show the hub removed from the Vette. I am not going to disconnect the battery, hopefully, that is OK. How about the other three codes, 2 noting torque - any ideas?
Also, I found this thread with a guy with a 97 A4 like me and is getting the same codes - I pm'd him too - hopefully he'll respond.
http://forums.corvetteforum.com/show...ighlight=P1571
What should I be looking for in regards to the PCM and BCM connections? These are under the battery right? I have an optima red top, so I don't think my battery is leaking.
So do you guys agree that the P1571, C1277 is a problem on 97s that can not be fixed?
Old Apr 25, 2008 | 10:23 AM
  #520
rayc1968's Avatar
rayc1968
Cruising
does anyone have dic for sale i cant even clear change oil message
