IMPORTANT ELECTRICAL INFORMATION (Long!)
Old May 20, 2009 | 08:02 AM
  #681
bob3868's Avatar
bob3868
Bill,
I just read your post on electrical information on your corvette. I own a 2003 corvette and I am having electrical issues that I can't seem to get someone to fix. Here is what happens to my car. I will be driving along and all of a sudden my gauges stop working, my radio and AC goes off, bells starts sounding and all the messages that could possibly displayed are displayed. However, the car still runs good. A little later it will pop back on again! If I turn off the engine and restart it, it will be ok. I might drive for another 6 hours before it happens again.
It is now at a Chevy dealer and they had the car going on the 3rd day and can't find anything wrong with it. I am going to print off your post and take it to them this morning and hope it will help them. They also contacted a support group at GM. They said there was a bulletin put on saying something could be wrong with the wiring under the seats. They checked it out and all was fine..
It sounds like from your post that your issue was just the error messages being generated..?? Mine the whole computer stops working....
Thanks for your post! I hope that it will help me out!
Bob
Old May 20, 2009 | 11:40 AM
  #682
mstromquist's Avatar
mstromquist
2015 C5 of the Year Winner
Read this a few days ago. Might be something you can check.
http://forums.corvetteforum.com/c5-g...lem-found.html
Old May 21, 2009 | 11:48 AM
  #683
Scoobi_FreeBSD's Avatar
Scoobi_FreeBSD
Originally Posted by bob3868
Bill,
Search this thread for "accordion" and "door wiring harness", sounds like the bare (uninsulated) wire in the driver door wiring harness. $10 fix.
Old May 22, 2009 | 07:47 AM
  #684
Rick Perkins's Avatar
Rick Perkins
Bob, I had almost the exact same problem with my 99. I would be driving down the road and all of the sudden, gages would peg out, windows and radio would shut off. I would get reduced engine power + many other alarms.
There were actually 3 things I did and the problem is gone. First. I changed the ignition switch. My key would almost come out driving down the road anyway. That cleared the security light on the dash. I cleaned all the chassis grounds I could get to. (did accordian door tubes too) The main culprit for me was the wiring harness under the drivers seat. It was damaged. After I repaired the harness all the problems went away.
Hope this helps a little.
Rick
Old May 22, 2009 | 08:12 AM
  #685
astoner3's Avatar
astoner3
Cruising
Default 99' Vert Battery won't charge
Anyone have an idea of why my battery won't charge? The battery and alternator were replaced recently. My gauage shows it is charging at 14 Volts. When I drive it for an hour or more the battery needs recharging when I get back.
Any ideas?
Old May 23, 2009 | 08:39 AM
  #686
bob3868's Avatar
bob3868
Bill, your the greatest....
I want to let everyone know how great Bill was in pinpointing an electrical problem I was having. I had my car to two places telling them of my electrical problem and neither one of them could find the problem. The problem I was having is when driving my car the computer would just quit working. All my gages would go crazy and tons of error messages. I saw Bills post and he got a hold of me and said look at the wires between the doors and the body. You will find a clear wire there. Tape it up and it should fix the problem.
I then drove my car home from the dealer and did just that. At the time I thought I would never find out what is wrong with my car. I looked at the wiring and sure enough, there was a clear wire and right where it goes into the connection and where it comes out of the connection there was about a quarter of an inch of BARE wire showing. I taped it up and I have not had an issue yet. I think the problem is solved!!
Thanks Bill for everything!!!!
Bob from St. Louis
Old May 23, 2009 | 08:46 AM
  #687
bob3868's Avatar
bob3868
Rick,
When I had my car in with the same problem you were having, the dealership call GM and was told that there was a bulletin put out on a problem with the wiring under the seat. For me they couldn't find anything wrong.
You can see my post where Bill ID the problem. It was the wiring between the doors. I had a bare wire about a quarter of an inch going in and out of the connector. Taped it and all is fine.
Thanks for replying.
Bob
Old May 23, 2009 | 06:18 PM
  #688
sbontrag@hotmail.com's Avatar
My cigar lighter, next to ashtray, does not work. The fuse is good, checked both # 1 & 7. Where would I find ground? Or if anyone has an idea I would appreciate. Thank you.
Old May 23, 2009 | 08:52 PM
  #689
clif's Avatar
clif
St. Jude Donor '09-'10
Default Gas gauge not working!
I have a new electrical issue!
My car was in the shop for two month, getting a lot up updates. I had a new RSI Dual pump installed in the left tank, with a brand new fuel level sensor installed. I did verify it was readinf 40 ohms at one end, and 200+ Ohm on the other end (I dont remember exactly what the top was). Well, the gas gauge shows empty! The shop put 5 gallons in it, and it did not move. They took it to a gas station and filled it up, still showing empty. They ran through all the diagnostics that is in AllData, and now they think the PCM is bad, and wants to replace that.
My question is, how can the PCM just go bad? The gas gage was working when I brough it to them.
Has anyone else experienced this kind of issue?
Old May 23, 2009 | 09:45 PM
  #690
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
The CIG receptacle is connected to 12 VDC with a small female connector. I recommend removing the center console and making sure that that connector is on correctly. They get knocked off easily or even forgotten to be connected when the console is out.
BC
Old May 23, 2009 | 10:20 PM
  #691
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
That sounds retarded to me. Tell them if there so sure it's the PCM, if it isn't the dime is on them!!
You need to get the volt meter out and start taking some readings
Do you have the following:
- Fuel tank connectors RIGHT, Pin A= 5 VDC reference Voltage
- Fuel tank connectors LEFT, Pin C= 5 VDC reference Voltage
- Fuel tank connectors RIGHT & LEFT, Pin B= sensor ground PCM Common
- Pin D = Chassis ground and that is Chassis ground G-401 in the rear wheel on the frame.
If you go to the PCM and read the PCM connector to the fuel pump the pins read like this:
Right tank connector =
A = PCM C2 pin 44,
B = PCM C1 pin 75
C = PCM C1 pin 12
Left tank connector =
B = PCM C1 pin 75
C = PCM C1 pin 12
Read pin A on the right sensor to PIN C on BOTH sensors and you should see 243 ohms
Read the DIC diagnostic routine and see if there are any PCM DTCs set for the fuel system.
Will you be doing this or will the shop be doing this????????
Bill
Old May 24, 2009 | 06:31 AM
  #692
clif's Avatar
clif
A = PCM C2 pin 44,
B = PCM C1 pin 75
C = PCM C1 pin 12
B = PCM C1 pin 75
C = PCM C1 pin 12
Bill
Thanks, Bill. I am holding the shop responsible for this. I am taking it back to them on Wednesday. I am going to send them your post!
Clif
Old May 24, 2009 | 05:10 PM
  #693
Mike Yeager@Eastcoast Performance's Avatar
0Mike Yeager@Eastcoast Performance
Former Vendor
What about the EVAP system??? Its been unpluged at the motor, correct Clif. Can that cause any fuel gauge problems?
Old May 25, 2009 | 01:06 AM
  #694
JOEY CARTEE's Avatar
JOEY CARTEE
Default Thanks Bill!!
That sounds retarded to me. I appreciate the IQ level Test!!!LOL Tell them if there so sure it's the PCM, if it isn't the dime is on them!! Hi Bill, we should clerify the facts and test already performed!!! Correct!!!
You need to get the volt meter out and start taking some readings We have. Customer didnt!!!!
- Fuel tank connectors RIGHT, Pin A= 5 VDC reference Voltage Yes!!!!
- Fuel tank connectors LEFT, Pin C= 5 VDC reference Voltage Yes!!!!
- Fuel tank connectors RIGHT & LEFT, Pin B= sensor ground PCM Common Yes!!!
- Pin D = Chassis ground and that is Chassis ground G-401 in the rear wheel on the frame. Yes!!!!
And we have continuity between the connector pins for the common ground and the 5 Volt reference to the rear and the PCM.. with everything unhooked... And there is no short to ground or Power!!!!
The car was picked up per customer request after much testing had been done and not verified for the problem at 5:30pm./... Customer would return for further diagnosis next week...
Points and tests not spoken of....
1 Customer performed his own perfomance download on the PCM!
2) EVAP system has been Totally removed from the car per customer request!!!
3) code 1433 for a right hand high voltage etc.. was coming up in the PCM codes...
4) as was a high idle too long code for the idle, only 2 codes period!!!!
The 1433 also has a tie in to the Tank pressure system. which should be invalid now!!!!
There is continuity between the common ground from the PCM and the left and right fuel level sensors as also the tank pressure sensor behind the left fender well!
The left tank sensor has been replaced with a NEW unit and the wires were upgraded BY THE OWNER to an industrial type wire... This connector at the sender reads 183 Ohms............
The right hand Sender is still stock,(was removed 2 times during the build) and replaced as it was functional )... BUT IT READS infinite now!!!!! 1.00000
PLEASE NOTE THAT A TEST WITH THE TECH 2 WAS PERFORMED AND THE GUAGE PERFOMED AS COMMANDED!!!!!!!!!!! Right tank connector =
A = PCM C2 pin 44,
B = PCM C1 pin 75
C = PCM C1 pin 12
B = PCM C1 pin 75
C = PCM C1 pin 12
(THIS HAS NOT BEEN PERFORMED!!! ALthough a Different sender was placed inline on the RH side and hooked up with the factory connectors and nothing changed...... Please note no connectors have been modified, and the PCM was never taken out of the car or serviced, only the tank level sensors were removed and replaced LH side, the plug ins were never disrupted....... Although the owner and an employee saw it move a couple of times after it got hot??????
Read the DIC diagnostic routine and see if there are any PCM DTCs set for the fuel system. Yes 1433!! we were at the 16 or 17th stage of the trouble tree.. This is were i told the customer that it may be a PCM problem after we used the replacemnent RH sender....
Any comments or diag might be worth your comment as i have lost a day in billable hours for the guage problem.....Thanks BiLL CURLEE
Bill
thanks bill if you can help with suggestions!!! Joey
Old May 25, 2009 | 07:47 PM
  #695
Bill, thank you. I will pull console again and see. Are both the CIG lighter and the accessary 12 volt plug in on the same circuit? The accessory plugin inside the console still works.
Old May 25, 2009 | 08:54 PM
  #696
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
WOW! I take back any and all criticism! Sounds like you have some very sound troubleshooting skills!! Thats RARE these days! Everyone wants to just easter egg in new parts and if they don't fix it, oh well.
It might very well be the BCM but,,,,doing all that work and testing, you trouble shot and pin pointed it to one area. Well Done!
If you have ant theories, run them by me.
Old May 25, 2009 | 10:31 PM
  #697
bob3868's Avatar
bob3868
Scoobi_FreeBSD That was exactly what it was. We just used some tape they use on the F15 and taped up the bare wire. Problem fixed thanks to Bill!! I have to admit, I did have to pay a Chevy dealer $89 to tell me they couldn't find anything wrong..
Bob
To IMPORTANT ELECTRICAL INFORMATION (Long!)
Old Jun 12, 2009 | 03:52 AM
  #698
BOUT X's Avatar
BOUT X
Corvette Cowboy
Default Freaky headlights please help
Help please I have a wierd issue with my head lights 2 months ago I replaced the gears in the head light with Rodney dickman brass gears. My passenger motor is alum. and my drivers side is plastic. Well about 2 days ago I released my e-brake car was in the garage and just my pass. side head light came up light came on. So I backed out in to the sunlight and the pass. side light went down light went off then all of a sudden I looked and the drivers side was up 1/2 way no lights on. I then turned on the headlight switch and the pass. side came on drivers side closed. So I opened my hood and lowered my drivers side so both light were down so now when I turn on my headlight just the pass. side comes up drivers side stays down. I have disconnected the battery changed the fuses tried all kinds of stuff like turn light on and manuelly lift other light un-plug light try to get them in sink. So nothing is right can you please help me.
Dale
Old Jun 24, 2009 | 02:37 PM
  #699
cjlaw73's Avatar
cjlaw73
Default This thread is the best - big thanks to Bill Curlee!
2 days since the BC fix and car runs perfectly. Hard to believe (or not) that such a simple fix addresses such a crazy problem.
Charlie
Old Jun 30, 2009 | 10:16 AM
  #700
hill536's Avatar
hill536
I've been waiting weeks before posting this because it's one of those things that’s best left when you say nothing, like watching a no hitter or a shutout,
I have been plagued by the 1214 DIC code and had it looked at by my dealer in Ft Meade, small town and very honest with great techs. It reset while there. On all occasions it would show at random intervals, mostly when starting the engine, hot, cold, rain or shine.
When you start some small aircraft its necessary to key the ignition and let the power come to the gauges. Thinking about that and computers in general I got into a new habit. I turn the key and allow the scroll message to cycle and have the warning lights make their cycle. Then I start it. Since doing that I have not had a light. I also noticed that after sitting several days the voltage on the DIC would read low, sometimes 11.6dcv (fairly new optima red top.) Prior to starting I'd see the voltage climb and settle.
What I have come to see after starting and at about the same random interval as the DIC 1214 alert is an alert that appears saying the active handling is warming up. So far in all cases after the warm up light goes away (couple seconds) it's normal. I've come to the conclusion that maybe the computers work a little better if they have a chance to warm up. After seeing a gazillion posts I hope some others can experiment with this idea and hopefully help someone else.
/Ken
