IMPORTANT ELECTRICAL INFORMATION (Long!)
Old Mar 5, 2010 | 08:15 AM
  #841
JAXRWILD's Avatar
JAXRWILD
On A 2004 Keeping The Hood Light Unplug , Help Or Hurt?
Old Mar 5, 2010 | 02:23 PM
  #842
si2956's Avatar
si2956
7th Gear
Default electrical question
When I turn the key to accesory nothing happens, I checked the fuse and it's good, it has a after market radio in it. Does anyone know if the radio should play with the accesory on, also there is a little red light on the drivers side door, is this for thr anti-theft system and how to change the buld or LED.
Old Mar 5, 2010 | 09:49 PM
  #843
99 hardtop 08's Avatar
99 hardtop 08
Great job Bill I have been experiencing turn signal issues my new turn signal switch will be in monday so I am going to try this over the weekend .
Old Mar 5, 2010 | 09:51 PM
  #844
99 hardtop 08
Great job Bill I have been experiencing turn signal issues my new turn signal switch will be in monday so I am going to try this over the weekend. Thank you!
Old Mar 6, 2010 | 08:53 PM
  #845
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Yes it should. Check out this POST!
- http://forums.corvetteforum.com/c5-t...ch-repair.html
I bet this will address the issue!
Good luck and let us know how you make out.
BC
Old Mar 7, 2010 | 03:59 PM
  #846
MrBeauJangles84's Avatar
MrBeauJangles84
Bill,
I'm pulling 3 codes on my 2000:
C1221- LF wheel speed sensor input signal is 0
C1225- RF Excessive Wheel Speed Variation
C1232-LF Wheel Speed Circuit Open or Shorted
Service ABS/Active Handling Lights are illuminated
Any advice would be GREATLY appreciated.
Beau
Old Mar 7, 2010 | 04:26 PM
  #847
rustyguns's Avatar
rustyguns
Originally Posted by MrBeauJangles84
Bill,
Beau
BAD SPEED SENSOR OR BAD WIRE TO SENSOR OR BAD CONNECTOR TO SENSOR..........OR BAD GROUNDS!
Old Mar 7, 2010 | 07:01 PM
  #848
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Bill,
Beau
I have never seen a wheel speed sensor go bad unless there was some sort of mechanical damage. There pretty bullet proof. I have seen the pig tail or connector have issues.
Most of the time, the problem is a bad female pin or corrosion in one of the connectors. The FRONT WSS connects to the chassis connector thru a jumper cable. It is a well known problem area.
Pull ALL the wiring connectors apart and inspect the female pins in EACH connector. Look for female pins that are spread like the one in this picture:
The connector on the right has two bad female pins:
I use an old spare male pin to test each female pin. If the make pin is loose in the female pin, thats your issue. You can bend down the little tong in the female pin but, its only a temp fix.
The wheel speed sensor circuit does not use a common chassis ground. It uses a circuit card LOW REF and a signal wire that goes directly to the EBTCM
You can disconnect the main connector on the EBTCM and read each wheel sensor from there. That test will not pin point a problem that happens when the wheel sees shock and vibration.
You can set the meter to Volts AC and spin the wheel and read the output of the sensor. The faster you spin the wheel, the more AC Volts you will see.
Old Mar 7, 2010 | 07:25 PM
  #849
boterre2471's Avatar
boterre2471
I changed the battery, cleaned the ground connections,removed the battery box and checked all the wires under the box. The car is showing the same problems still Looks like a christmas tree. Could it possibly be the BCM? If not any otherideas? Thanks in advance...
Old Mar 7, 2010 | 07:48 PM
  #850
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
If the BCM is WET or the back of the board is corroded, it can give these symptoms. Check the BCM and the area around it for water or moisture. See if there is any dampnedd unde the carpet.
Pull the board out of the box anc check for corrosion. Disconnect the battery first!
BC
Old Mar 7, 2010 | 08:22 PM
  #851
MrBeauJangles84
Thanks Bill! I'll give it a try this weekend and let you know how I make out.
Old Mar 17, 2010 | 08:42 PM
  #852
C5Bagger's Avatar
C5Bagger
Default Bill you was right, wrong code
Bill you was right I gave you the wrong code, the correct code is C1234 left front wheel speed circuit open, this happenned right after I changed out the battery. From what I can understand is it could be a loose conection or the sensor, sorry for providing the wrong code.
Old Mar 18, 2010 | 11:19 PM
  #853
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Refresh my memory on the real DTCs and symptoms
Old Mar 19, 2010 | 06:20 AM
  #854
C5Bagger's Avatar
C5Bagger
While I was installing a new battery I heard a couple of fairly loud snapping noises coming from the rightside engine compartment, when I started the car I had a host of codes, c1234, c1241, c1248 and c1283, all clear by reseting with the exception of C1234. The dash looks like a Christmas tree with the traction, brake, and ABS light on. I have put about a 1K miles on since this happenned without the driver aids but I would love to get this straightened out. Thanks Bill.
Old Mar 19, 2010 | 08:58 PM
  #855
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Anytime you reconnect the battery, unless you do it VERY QUICKLY, your going to see an arc. There are a couple of power hungry circuits that get reennergized and there is about an eight amp draw for a millisecond or so and then it drops down to around 2 amps and once the BCM times out and gets into sleep/security mode, finial draw is 0.02 amps.
DTC C-1234 has nothing to do with connecting the battery unless you fried the EBTCM. Its the left rear wheel speed sensor. Most likely a bad female pin the the connector for the chassis side of the wiring harness. Don't be duped into installing a new wheel Hub.. Unless theres damage to the pig tail connector, Ive never ever seen a Speed Sensor go bad. Like I said, check the connections at the plug.
BC
Old Mar 20, 2010 | 06:54 AM
  #856
C5Bagger's Avatar
C5Bagger
Thanks Bill I checked the conections and they looked a little sketchy as in very loose going into the conector, If the EBTCM was fried would everything else clear except DTC-1234? Thanks for taking the time with us less mechanically inclined, well at least myself.
Bagger
BC
Old Mar 20, 2010 | 04:47 PM
  #857
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Bagger
The EBTCM is most likely OK. You just need to find the connection issue between the WSS and the EBTCM main plug.
if you can use a Volt/OHM/AMP Meter, I can post some test and resistance/voltage readings your suppose to get.
All the other issues should clear. If not, post the DTC.
BC
To IMPORTANT ELECTRICAL INFORMATION (Long!)
Old Mar 20, 2010 | 10:11 PM
  #858
C5Bagger's Avatar
C5Bagger
Bill that would be a huge help if you could post some test and resistance/voltage readings, I have a meter and this would give me a clue on what wires or cables to repair or replace, you have been a huge help, Thank you so much Bill.
Bagger
Old Mar 21, 2010 | 10:33 PM
  #859
salsvette's Avatar
salsvette
6th Gear
Bill,
Thanks for your posting. I constantly deal with electrical issues in my 99. I have a #s
matching 72. When I want to drive my c3, I just start it and go. When I drive my 99,
I bring along an ohm meter. I did not realize their were so many ground points. I have plugged and unplugged virtually every connection that I thought would throw a code including the battery ground connections. The codes are reset and a month later, the codes are back. I am going to give your method a try. I don't believe that there is a component malfunction and that it is a ground problem. The codes return after hitting a small bump in the road.THANKS AGAIN!!
SV
Old Mar 21, 2010 | 10:55 PM
  #860
mickey_7106's Avatar
mickey_7106
part number for this cable? it plugs in to the MAF
http://forums.corvetteforum.com/c5-t...0538-help.html
