I just installed the block kit in my c6. No improvement at all according to on line dB meter. Did I do something wrong? I installed it right. The piece behind the seat sticks up???? 80dB @ 65 mph before and after
Reason: added a photo
Call me crazy but Im guessing its suppose to go under the carpet. Also I can't see it making much difference. I'd go to real sound deadening material if your trying to cut cabin noise. Even that probably wont make as huge of a difference as you think it will though.
You're crazy, but you're right. A piece of foam on top of the carpet won't do anything, no matter how well you market it
I can understand the desire for a quick, easy, inexpensive noise reduction. It exists too! It's called tires.
This BLOCKIT sure got a lot of great reviews on this site. That's why I bought it. And I called TKO performance and they said just lay that piece right behind the seat. Some much for great reviews...
For those thinking it is just foam, it's not just a piece of foam; it is a butyl (rubber like) layer with pieces of foam on each side and then a black liner. You have it installed fine.
The block-it kit certainly reduces some noise, but how noticeable it is will be very dependent on road surface. It is not nearly as noticeable as getting new tires for instance. I ran these mats for many years until they fell apart. Unless they changed their foam or glue, those pieces of foam will disintegrate after many years of being in the car and exposed to heat cycles.
If you want to significantly cut down on road noise and heat, a full under carpet insulation kit is absolutely worth it. The Crazy Cowboy C6 kits are excellent. It is a bit of work to install everything but it makes a huge difference. The kit doesn't include anything for the insides of the doors but you can just use some Dynamat or Noico. I used the Noico equivalent of dynamat as well as some of the closed cell foam Noico.
Add in some good tires and the interior will be significantly more comfortable for both noise and heat. And the car will just feel more solid overall.
From: ★ Performance Parts & Accessories ★ 1800 778 9898
St. Jude Donor '07-'08-'11-'12-'13-'14-'15-'16-'17
It's actually 4 layers. But, the middle is a barrier however we chose to not use butyl. It all works together to absorb plus suppress unwanted interior noise.
Yes, certain areas like TX, CA, FL...etc their concrete & or certain black top roads have those tires roaring way worse than others.
There was a change in the manufacturing a while back where glue is no longer used. Each layer is bonded via a unique infusion method which helps eliminate separation!
Originally Posted by laserred
I just installed the block kit in my c6. No improvement at all according to on line dB meter........
The Blockit will absolutely help lower down interior noise.
It would be no shock if you received low to no "reading" using a cell phone type meter. The phone itself has built in low and high pass filters. These filters stop and or cancel certain frequencies. So the measurements taken will be highly inaccurate because the overall sound level is dominated by frequencies that a cell phone will not be picking up.
If its an actual hand held meter, make sure its on the proper settings. When we originally tested, we used a Bruel & Kjaer ( #1 in sound and vibration equipment) Model 2250 Type 1 Sound Level Meter and it was ran by a trained engineer. The results were very good.
But more important, you should go by your ears. But don't take our word for it. Here are just some of the positive quotes from mostly members here on the forum.
Originally Posted by gnawbone
Got mine a week or so ago - put me down as another happy customer! This is the 2nd C6 I've put a Blockit! in and they are awesome! When I sell my current C6, regret selling it, and then buy another I'll definitely get a 3rd kit!
Originally Posted by patentcad
This stuff works. When I first got my 2017 Z51 coupe, I noticed the tire noise coming from the rear hatch area was much louder than the 2007 C6 coupe I traded against it. It made all the difference. Install time < 2 minutes which suits my limited mechanical skills.
Originally Posted by breakskeet
Amazing how this works! Makes a convertible even quieter Highly recommended.
Originally Posted by BradT
I have these in my 2017 GS and it is a great low effort way to cut down on the interior noise. Once they are in you forget they are there because they look so OEM.
Originally Posted by azvetteguy
Absolutely incredible how quiet the car is now. GREAT PRODUCT!!!
Originally Posted by Kenpokev
Hey, just a quick shout out for a good product. I installed this in my '16 Z-06 and I'm very pleased with the product quality and sound. I still clearly hear the lovely rap of the exhaust, but not a lot of the tire noise on our nasty worn roads. Very pleased with this product.
Originally Posted by Gymbow
I installed the 3 piece system and finally got a chance to do a test drive this evening. I was very pleasantly surprised how well it worked as the improvement was immediately noticeable. The noise level inside the cabin was reduced and I had to lower the radio volume since it was so much easier to hear. I can still hear the nice sound of the engine & exhaust, but without the annoying road noises. Very pleased with this purchase.
Originally Posted by djpatrick35
It definitely made a big difference for me. It took all of a minute to put in my car and did have a noticeable effect on the sound. Great product.
Originally Posted by thptrek
I installed the Blockit sound insulation mat and the behind the seat panels this weekend and I am very impressed. The mat just goes in the hatch area and the fit is excellent. I installed the two panels that go behind the seats behind the carpet. The carpet in that area is not tacked down so it is easy to do.
The mat looks very polished in the rear cargo area so I don't think that I will add an aftermarket cargo mat on top of it.
While commuting to work this morning on the freeway I really did notice a difference. I did not have to crank the radio way up and the voices and music were much clearer.
If you are looking for a real easy sound insulation solution I would recommend this product.
Originally Posted by C6Vette2009
Great product! It does work. I also bought the LLoyds cargo mat for the hatch and now the car is super quiet. It's worth the money!
Originally Posted by snowman0920
I just put one in my '05 coupe. The difference in interior sound was instantly noticable. After cranking it up I had to put the window down a little to make sure the engine was running OK.
Originally Posted by Joy c7
Worth it, made a big difference.
It did however, take me double the 30 second recommended install time, due to me flopping it in there upside down and then having to take it out and flip it over because I didn't read the instructions.
Originally Posted by casting kid
I install on my 2005 and could tell a difference immediately. Now I know when the wife is in the car!Great product, does what Ed claims.
Originally Posted by RtStuf
Very pleased w this addition!
Originally Posted by Brian@RPT
I have had mine over a year and love it.
Originally Posted by barduch
Very evident reduction of noise level. Easy install under the factory carpet behind the seats as per the instructions and the rear mat was cut to perfection. Well worth the $ spent.
Originally Posted by vince48
Ed,
I finally received my Block It yesterday. Install was less than 10 minutes and YES it does make a differents. Well worth the wait.
Vincent
Originally Posted by fattiremike
I purchased a "blockit" for the road noise coming from the back of the car. It really helped a lot. I also have a Lloyds cargo mat sitting on top of the blockit as well………….
Originally Posted by Nick996
I got mine yesterday and installed it last night.
First drive to work this morning and I can tell you it makes a big difference. Those that say it doesn't must have some really frickn' loud exhausts.
It took the resonance away that the road puts through the rear hatch area (hatch floor, plastic) and the road noise from the tires is probably cut in half.
There's also a noticeable "quietness" inside the rear now that I never had before. I always had that "white noise" behind my head from all the noises coming from the rear hatch area. Now it sounds like the entire car is quieter.
It made such a difference I am no longer worried about putting dynamat or peel and seal in my car. I will however still do the peel and seal on the floor boards under the car because now that the rear is so much quiter I hear road noise from under the car... lol.
Overall, it's a great buy and I'm glad I bought mine!!
Originally Posted by iridelow
To start with, I am not a vender and do not sell these things, but WOW! What a difference. I have an 05 vert with borla stingers and love the sound. But on the interstate and highway speeds, the car is just kind of loud. Not just from the exhaust, but from road noise. So I bought the new "blockit' insolation kit sold here on the forum. Not the kind that requires you to remove the carpet or anything. Just put two pads behind the seats and one pad in you truck, or cargo area for a coupe. I drove my car at 70+ MPH for a good ways last night and WOW!!! Much smoother and peacefull sound. The stereo sounded better and the car just seems so much quieter in the cab area. I have had a C6 coupe and now have a C6 vert, and I promise you, this thing works! Just wanted to shout out a nice mod.
Originally Posted by BB 2005
installed yesterday, wife noticed the difference! Works for me. Seems to work despite the lack of software or complex electronics
Originally Posted by C607RF
I received the BLOCKIT from TKO Performance just in time for
me to test it on a run to NCM. Install was a snap.
Good product, promptly shipped,
The noise difference is very noticeable and makes the Bose sound better. I am very happy with this
purchase.."
Rich, Cinn. OHIO
Originally Posted by Wass
I was at Carlisle and the Blockit was sold out, so I bought the demo kit that was inside the Corvette parked under the TKO tent. In my opinion, it was worth it because it works. My C6 is very loud, as it is cammed, etc., with headers & NPP. It has an annoying low rpm drone. With muffler flaps open it is unbearable for cruising below 1,950 rpms. Even with flaps closed, the drone was very annoying below 1,950. Most of my cruising is between 1,700 and 1,950 rpms in 6th gear with 4.10 gears. With the blockit installed, the drone is gone at these rpms with flaps closed. Not just reduced, but gone. Below 1,700 drone is reduced to a bearable level.
With muffler flaps open the drone is reduced with the kit, but still louder than my comfort level. But it's a moot point now.
Originally Posted by LOUSVETTE
Worth the couple of bucks it costs
Originally Posted by okbkvette
Did it myself last week. Like it. I also put the pieces behind the seats UNDER the carpet. Cleaner look.
Originally Posted by Dif
I have it also and give it a
Glad I got it and it makes a nice difference
Originally Posted by T's C6
Originally Posted by laread
I bought it from TKO as part of the group purchase. I think it is well worth the investment. It really reduces cabin noise from the Goodyear run flat tires.
Originally Posted by Jakeross
I have had mine installed about a week. The noise difference is very noticable and makes the Bose sound better. I am very happy with this purchase. Not able to tell about the cabin heat since it has been in tthe 100's here.
Originally Posted by 9C1
I'm happy with my BLOCKIT drop in kit. I have had it on several road trips and it does work. Easy install too. I can't say about the heat. It was relatively cool last few weeks. Now Summer is here.
Originally Posted by rpoz06
Having had Blockit in my Z06 - I thought it did a great job reducing noise so I added it to the C7 - Z51.
It arrived packaged well. Easy install with a precise fit. I was able to use the rings and shade. I found it able to make a nice noise reduction on all surfaces around Little Rock including interstate and different road surfaces including concrete and asphalt.
I'm very happy with the product!
Originally Posted by doopoco
…..On rough pavement we can actually have a conversation without yelling. Stereo sounds great but we can still hear and feel that awesome exhaust!
Thanks TKO
Originally Posted by Boiler2
Installed on my C7 Z06. TRANSFORMATIONAL! The reduction in tire noise is astonishing. Being an engineer I had planned to use my laboratory dB meter to measure noise levels with and without the TKO Blockit kit. As it turns out there is no need to do so because the noise reduction is truly dramatic. This kit is a "must have" for all but deaf C7 owners. I had a '14 Z51 which had hellacious tire noise. I was exhausted after driving it for 3-4 hours. The '15 Z06 was significantly quieter and rides more smoothly....think Chevy vehicle engineers softened the suspension bushings. Seems to be well known that the '15 is a quieter car. Just can't believe how such a relatively inexpensive and easily installed kit can be so effective. I could now drive the car across country....yes, it's that good.
Originally Posted by Spinny
I have used this product on my C6 and C7 and am very satisfied. It works as advertised.
Originally Posted by tome
Well, I had a chance to test drive my car on some roads that previously had some serious tire noise due to the road conditions. For the ease of installation and simpleness of the product; I'm very pleased with the it. I was able to lower my radio volume from where it used to be, and hold conversations without raising my voice. In fact I am now aware of other noises that I hadn't previously heard.
So bottom line: I'd recommend(your hearing my vary) .
I can't say it's equal to the kits that require full interior dis-assembly since I didn't do that, but I definitely feel there is value in the product. If you are in Southern Calif and want to try in your car, come by and we'll throw it in and you can hear for yourself. Or just take my car for a test drive.
Tom
Originally Posted by C7X46
I installed these two items to help with road noise and was blown away at the difference it made. The reduction in noise from the rear of the car is staggering, I highly suggest it if you are annoyed by tire noise. Be careful in touring mode you might fall asleep.
Originally Posted by GizmoZ
I ordered two sets of the three piece kit-- one for me and one for my dad. We both agree that there is absolutely a noticeable difference after the mats were installed. The car is noticeably quieter at highway speeds. We're both happy with them!
We're still happy with ours. Definitely takes the edge off tire noise/rumble on the highway.
Originally Posted by MRHTRD
Received my set of sound deadeners yesterday and promptly installed them in about 10 minutes.
Started the car in my garage and could hardly hear the exhaust with the windows up. Backed it outside ( a lot of snow here now ) and tried the same thing, windows down ,windows up. I will not get to take the Z06 out until spring, but I can tell you that there is a substantial difference in the noise factor just sitting in the car and listening to it run.
Great product. Can't wait to do a more extensive test in the spring, but initially this seems to be a great product !!
Many thanks,
Dave
Originally Posted by txapezl1
Got mine in today. 5 minute install. Works great. Fit and finish on point. Nicely done. Highly recommend. Not a bad way to spend $220. (In my Toretto voice).
Originally Posted by griff122
I just installed mine (took about 2 min) and the difference is night and day. Definitely recommend.
Originally Posted by joemessman
I installed the basic 3 piece set and they really cut down on the road and noise.
Originally Posted by tr6drvr
3pc set with aftermarket carpet on top in hatch works great. Almost too great for exhaust sound.
I installed Mich A/S tires which helped a lot but the Block-it mats finished the job. Almost no road and tire noise. And I still have the deadmats to install if I want.
Originally Posted by iew
I can now carry a conversation and listen to radio. The Blockit Kit was super easy to install maybe 5 minutes. Amazing reduction of road noise.
Originally Posted by The Sea
Got mine for my 16 coupe and works like a charm..Very easy to install.
Jerry in Minnesota.
Originally Posted by zras01
I added the "blockit" to my 2008 C6 and it made a huge difference in the cabin noise. I can actually have a conversation and/or listen to the radio without the overwhelming road noise that is usually generated in the cargo area. Great Product.
Originally Posted by mtaxman
Just got my Blockit mats today and did a roadtest on the concrete I16 around Savannah and a couple miles on local black top.
Super easy install - drop in and forget it. I have a coupe.
Big rear mat had the slits for rings.
Put my Stingray logo rear carpet on top of the mat and also put the mats behind the seats.
I can tell a difference in noise ; can hear the radio better and believe a long cruise will be far more pleasant.
I have the Blockit mats. My wife can hear like you wouldn't believe. She is the perfect test for these. She stated to me that there was a significant difference in sound reduction. That's good enough for me. I thought there was a difference too, but I didn't want to rule out wishful thinking on my part so I had her listen before and after.
Originally Posted by NSC5
I put it in my 2016 Z06 last week and the difference is very noticeable. Less tire noise, radio volume setting is lower now and much more enjoyable. As another poster noted the exhaust sound now stands out more; my Z06 exhaust is normally set to track mode.
I did notice the action of the Bose audio pilot (auto volume compensation) is much more noticeable now and I turned it off.
Originally Posted by Travlee
obviously super simple to put install, in a 10 min trip to the store... noticeably quieter. i have LTH, high flow cats, and factory npp. to me it sounded like i had the flaps closed.. maybe even more quiet than that.
…… is it worth the $230?? to me yeah, because i am lazy don't want to pull all the carpet out.... so with that being said, money well spent to me
Originally Posted by peterg943
I received and installed my "Block It" order today. Took the car out for a ride when I was done and found it was much quieter. In my opinion, this stuff is fantastic. I do have to say that covering it with the mat completes the look.
Originally Posted by javenius
Received order and wrinkles were gone after laying out overnight.
Got a chance to "install" today and take a quick ride before the weather arrived. Pleased to say wife and I observed a noticeable reduction in road noise and it was easier to converse.
Thanks!
Jim
Originally Posted by TonyS45
Installed the three piece Block It in my 2003 coupe and found that it works very well to calm down the drum-like acoustical problem of the rear hatch area.
Two thumbs up for this product.
Noticeably reduced the tire road noise reverberating through the rear compartment. When I first got the car I noticed that early on - the rear hatch area magnifying that sound of the big Z51 tires (my C6 was not a Z51). The Block It reduced that considerably.
Originally Posted by shot410ga
I bought the set from Blockit. It seemed to cut the exhaust roar down about 1/3. Worth the $229 I paid.
Originally Posted by DAC17
This stuff works! Put it in, didn't tell the wife and she said "is your car quieter than normal?"
I guess that's a good test of the sound-deadening ability!
Originally Posted by bonzo
Finally put the top up. Certainly can tell the difference. Car is a bit quieter, you still hear the roar at take off from dead stops and when u hit the gas. But when cruising it's a nice peaceful quiet. But even more important to me, my c5 is a daily driver and living in Fl it gets really hot. I've noticed that my trunk is a lot cooler. Every night when I leave work I put my laptop bag in the trunk and I think hope the heat doesn't kill this thing. Well since the block it install the trunk with the top up or down seems much cooler. Well worth the price of admission lol.
Originally Posted by mjdart
I ordered the 3 piece set for my Z06 and yeah it really works. I noticed a significant reduction in road noise. The pads are pretty heavy (dense) which I'm sure contributes to the effectiveness at reducing noise.
I got my sound deadening kit for my vert from TKO Performance. Kit came with a mat for the trunk and a piece for behind each of the front seats. Noticeable improvement.
Jim
Originally Posted by rblakeney
…..Another thing I did was add the Blockit sound deadening mats to the rear hatch area. These things actually work well to attenuate the wind and road noise so that the exhaust sound comes through. I am surprised how well they work for this and it was unexpected.
My car is an 89 with the L98 engine, ….
Originally Posted by dctex99
Received mine today; installed and drove; it really does make a difference; Thanks for making a great product; I personally wish Corvette would offer a "sound deadening" option as I would buy it even if it was somewhat costly!!! This works great and easy to install!!, Dwight Alexander
Originally Posted by PDXC7
.…the wait was worth it. They cut the sound down dramatically, and I can listen to music at a normal level without having to crank it up in order to drown out tire noise. Great product.
Originally Posted by jimmbbo
I dropped in a set of Block It sound mats (cargo area plus one behind each seat) in my C7 Stingray coupe.
Using the Decibel X Pro app, I measured 2 - 5 dB lower noise levels on varying roads at varying speeds, which was noticeable, but more importantly, the cargo pad cut down the reverberations from the drum head that is the cargo floor and reduced the noise spikes generated by road joints and seams... The 'Vette is now about as quiet as my '11 Mustang GT 5.0, my previous "touring" car...
The pads aren't cheap, and do add weight, but they attenuate much of the most annoying noise from the back of the car. IMO worth the money.
I bought one of these kits, and they work. I have a very loud ZO6 , and the kit reduced the noise level down considerably. As least according to my wife, who did not like the roar. Well worth the cash. Fits right in, took about 3 minutes to install and looks OK.
Originally Posted by twowinns
I received my Blockit kit last week and today I received it’s companion Lloyd’s cargo mat today. Everything fits and looks perfect. Best of all, I can really tell a noticeable improvement in road noise inside the cabin. I never measured the db’s before and after the install, but it certainly is quieter and more comfortable.
Originally Posted by WV Vette
Put them in my '17 Z06 vert and it made a difference in the road and tire noise. Sounds like a $100K car should have came from the factory
I put non run flat continental extremes on my 2012 Base along with a full layer of KILMAT ( cheap version of Dynamat) behind the seats, the entire back of the car ( under the carpet of course) and inside the doors. and it made a big difference, road conditions not withstanding. Even my wife noticed it the first time out.
I used it in both my 2008 Z06 and my 2010 ZR1, and I can attest to the fact that it does reduce some road noise and add bass back into the radio, but I always had (and still have) Lloyd's trunk mats that went on top of the Block-it, adding an extra layer. But nothing short of ripping out all the carpet and installing dynamat or similar is going to do anything drastic to reduce noise.
