Torque Management System - C6
Old Aug 3, 2006 | 05:58 PM
  #401
jschindler's Avatar
jschindler
Originally Posted by LS6dude
One time I went into Comp. mode, and the others it was all off. I don't feel any difference between them.
You might not always feel it, but I have very good reason to believe that even Comp mode can effect your performance.
Old Aug 3, 2006 | 06:01 PM
  #402
shurite44's Avatar
shurite44
Not as slow as I am coming out of the hole it won't. AH goes down and gets a hot dog when I am racing.
Old Aug 3, 2006 | 06:03 PM
  #403
shurite44's Avatar
shurite44
That reminds me, I plan to install a ported TB tomorrow if it arrives. I am hoping it will help my 60 foot a little.
Old Aug 3, 2006 | 06:21 PM
  #404
TMyers's Avatar
TMyers
Originally Posted by shurite44
Well if it is possible, when and if it becomes available to edit out I plan to leave in at least 25% of the TM to help protect my drive line. I just don't want it bogging on the launch the way it does. I would be happy with a 1.9 60 foot.
If I remember right you have about 10 more HP/Tq than I have and you also have a tune.
Did your tuner take out some of the TM on the engine side? Prior to my tune my best was a 2.07. My worst after the tune was 2.06 but out of the 5 runs made last Friday night I had 1.98 and 1.99. I'm still trying to find that perfect launch technique but I have been trying to find that all year and last Friday I have been doing what I always do. That is almost a tenth improvement.
Last Friday night this was my setup. 28psi cold in the rears. At the line load the rearend up, between 1000-1300rpms then squezze the throttle on the last yellow. Of course this is with an auto. Still trying to find the best launch rpms. Also may be able to improve it with lower air pressure.
While track prep may have been different I doubt it. The weather was very much like the last time I ran in June, maybe just a bit warmer, 5deg. It is always the same crew at the track. But who really knows. Anyway I'm happy with the direction the car is going in.
Old Aug 3, 2006 | 06:34 PM
  #405
jimman's Avatar
jimman
It does try a launch with your steering wheel turned a few degrees.
Old Aug 3, 2006 | 11:12 PM
  #406
Tommy D's Avatar
Tommy D
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16
St. Jude donor in memory of jpee '14
I probably should not use the term bog. It is more like a split second hesitation, but noticeable. Really with the gearing and power that car should cut a 1.8x 60 foot and I am consistently around 2.05.
On my A4 if feels like a prolonged shift and my 60 foots are around 2.0
Old Aug 4, 2006 | 09:06 AM
  #407
shurite44's Avatar
shurite44
Jimman that reminds me of the old joke about going to the doctor and telling him your elbow hurts when you do a certain thing. He slaps you and says "then don't do that". Remember HEE HAW.
Old Aug 4, 2006 | 10:04 AM
  #408
jimman's Avatar
jimman
When you do that the active handling kicks in and you have brake drag, that's what we've been trying to tell you all. That's why that tuner in New Jersey had that so called TM Module that just disconnected your ABS and called it Torque Management Elimination. In reality all it did was reduse drag and then all the games began. Again you all are trying to make a road race car into something it wasn't intended for and to take a 3200lb machine to go from 0 to something in almost time zero without something having to change is way out there. Do you think the rail dragsters with thousands of horse power pull timing to keep the wheels from spinning and braking a drive train.
Old Aug 4, 2006 | 12:35 PM
  #409
shurite44's Avatar
shurite44
No not really, just making a joke. I know how AH and ABS work. When I launch I do not engage those systems. I understand them enough that I know they don't slow me up.
I do not launch with lots of build up RPM's and spin. I run mostly for consistency, so in the C5 the best method seemed to be launch from idle. But I am having better luck with my C6 just loading up a little 900 to 1000 rpms. But my wheels are arrow straight and I don't spin so my AH is not doing much, if anything. My ET's with comp mode and everything off are identical.
Old Aug 4, 2006 | 01:20 PM
  #410
shurite44's Avatar
shurite44
That is good to know, I did not know that is what the module was doing. I really do not need that. My tuner told me he took out some TM in the engine.
I really do not know enough about it to tell you what he did to be honest. But I have enough runs in the C5 and C6 that I can feel it when I launch, and it is not the brakes, not on my launches. I know what you are talking about with AH can slow you down on a launch though. Not disagreeing.
Old Aug 4, 2006 | 08:09 PM
  #411
dennis50nj's Avatar
dennis50nj
thats why that tuner in new jersey has some of the fastest corvettes in the country
Old Aug 4, 2006 | 08:18 PM
  #412
Zig's Avatar
Zig
From: stafford country, va. Avatar: Me on turn 3 @ Bristol (The World's Fastest Half-Mile)
that's also why imo, the different modes (all on, comp, ah/tc off, all off) result in different effects/times/results.
Old Aug 4, 2006 | 09:54 PM
  #413
TMyers's Avatar
TMyers
The real problem with TM is I can't test it more tonight, no race until next Friday.
Old Aug 5, 2006 | 12:03 AM
  #414
dennis50nj's Avatar
dennis50nj
the only diference i seen was 1/10th 12.0xs to 12.1xs ah&tc off to ah&tc on before tm removed
Old Aug 5, 2006 | 01:36 AM
  #415
Wayne O's Avatar
Wayne O
CF Senior Member
Great thread! I just love these passionate and in-depth technical debates. I've learned a lot....I appreciate the benefit of everyone's experience and expertise.
Old Aug 5, 2006 | 01:42 AM
  #416
shurite44's Avatar
shurite44
My vette is starting to bounce of the limiter more often. 3 times now at WOT I have hit the rev limiter going from 2-3rd.
It is a little bit of a dilemma. My tuner did not touch the shift points or the rev limiter. He told me with HP tuner you can not tune them yet.
So now I am wondering what I can do about it. I may have to go to the dealer and see if he can move shift points. For that, I would normally have the stock tune put back in before I take it to the dealer.
Sucks.
Old Aug 5, 2006 | 10:53 AM
  #417
bunk22's Avatar
bunk22
I agree but as you know, it will save our butt when things get squirely down the track.
To Torque Management System - C6
Old Aug 5, 2006 | 11:25 AM
  #418
BEZ06's Avatar
BEZ06
I don't know about that (but, as this thread points out, I don't think anybody knows everything about TM).
Check out this link to that tuner's website (click on Torque Mang.):
Cartek TM Eliminator
If you notice, it says: "This unit is designed to help prevent the ECU from reducing timing and throttle angle (torque management) under hard driving conditions and fast shifts".
Now I don't expect them to tell us all their proprietary info on how everything they sell works, so if TM does do something with ABS, that may be part of what their module does.
Butt......if they are saying that their module does something to stop the car from pulling timing and reducing throttle, then I would guess they believe that timing and throttle are involved in whatever the General designed into TM.
Bob
Old Aug 5, 2006 | 02:12 PM
  #419
Ranger's Avatar
Ranger
Beezeye, wouldn't waste the key strokes trying to post any objective info on the Cartek TM-module. Several of the engineering-challenged squatters on this thread long ago ran off Julio, master-tuner and owner of Cartek. Julio attempted a little education. But the engineering-challenged hooted him off the thread because they "know far more" than Julio and demanded he reveal his proprietary technology.
Quite breath-taking behavior from non-engineers, non-racers, non-wrenchers. But that's all months ago and a period on the thread that's best not repeated.
Ranger
Old Aug 5, 2006 | 03:46 PM
  #420
glennhl's Avatar
glennhl
Ranger
I just have to know, I'm not trying to be a smart-a$$. Are you an engineer? If so, what are your credentials? Electrical, Mech, Civil? Registered?
I really don't mean to be rude, I am just very curious. I respect your postings and especially respect your ET's.
Thanks,
Glenn
