Convertible Sub Section
Old Mar 3, 2019 | 05:19 PM
  #1041
F4 Phantom's Avatar
F4 Phantom
My handy man got white paint on my top just now. What's the best way to remove it without damaging the top?
Old Mar 3, 2019 | 05:24 PM
  #1042
pkincy's Avatar
pkincy
Water based paint, I hope. If so, soapy water works. If oil based that is a harder problem as you need to use solvent. But get it before it dries in either case.
Old Mar 3, 2019 | 05:25 PM
  #1043
owc6's Avatar
owc6
Latex paint or oil-based? Thick glob or thin smear? Color of top?
Old Mar 3, 2019 | 06:06 PM
  #1044
F4 Phantom's Avatar
F4 Phantom
Black top. Little spots. BEHR Premium Plus 2-8050 Hi-Gloss Enamel acrylic-based
Old Mar 3, 2019 | 06:15 PM
  #1045
owc6's Avatar
owc6
As was said in the other thread, try lifting it off first.
Old Mar 3, 2019 | 06:19 PM
  #1046
F4 Phantom's Avatar
F4 Phantom
It won't lift off.
Old Mar 3, 2019 | 06:37 PM
  #1047
owc6's Avatar
owc6
It won't lift off.
If this was on the paint, then the solution is easy (actitone), but the fabric top may discolor (or worse) if anything is used that can dissolve the house paint. Have you posted this in the care and cleaning sub-forum? Some of those guys know stuff that amazes me regularly.
Do you have a steamer/cleaner (not a carpet/upholstery vacuum extractor). Approaching in and heating it up from underneath may allow you to lift off the paint, because it is essentially plastic at this point.
Good luck!
Old Mar 3, 2019 | 06:45 PM
  #1048
F4 Phantom's Avatar
F4 Phantom
Good luck!
I'll try that. Thanks.
Old Mar 3, 2019 | 06:55 PM
  #1049
dyoung's Avatar
dyoung
I used a product called Goof Off when I drove through some paint. Didn't notice it for a few days.
Worked great on the body, didn't hurt the paint..Got it at the local hardware store..
Try a small spot first.
Old Mar 3, 2019 | 07:12 PM
  #1050
F4 Phantom's Avatar
F4 Phantom
This is on a convertible top, not body paint.
Old Mar 3, 2019 | 07:45 PM
  #1051
dyoung's Avatar
dyoung
I know it is on the top. The Goof Off says it works on fabrics also..
Old Mar 14, 2019 | 10:40 AM
  #1052
GS583's Avatar
GS583
My Z06 arrived yesterday and I got to be the first to drive it off of the transport!
Old Mar 14, 2019 | 10:49 AM
  #1053
Roastum1's Avatar
Roastum1
Old Mar 14, 2019 | 05:16 PM
  #1054
BDASSZO6's Avatar
BDASSZO6
Default 2019 Vert top replacement
A detailer used a steamer on my top to remove creases and this is the result. Wont wash out. Possibly discoloration or canvas damage. Will replace if unable to correct. Cost of a new top 19 ZO6??
Old Mar 15, 2019 | 08:03 AM
  #1055
DALE#3's Avatar
DALE#3
Rut Roh.That's awful.Hopefully not completely dry?What the Hell.Is the Detailer suggesting any thing?Cloth is funny.
I was pricing garment steamers and reading about wrinkles.Was gonna ask the dealer about it and what They suggest? I posted about this not to far back here.
May try a warranty but they probably suggest chasing detailer.
Or I would say you were just washing it..Then WTF
You ain't got to many options which Sucks.
Old Mar 15, 2019 | 08:12 AM
  #1056
jimmie jam's Avatar
jimmie jam
Was the top REALLY clean before he started?
Old Mar 15, 2019 | 10:55 AM
  #1057
Rebel Yell's Avatar
Rebel Yell
My suggestion, mild soap, warm water, and a fine bristle brush. Scrub it easily all the while hoping that it will level the color out. As JJ above pondered, it could be the guy didn't get all the dirt out. Good luck, I know you don't want to have the top replaced. I had that done on a C6......the installer dropped the framework on the tonneau cover. That wasn't pretty.
To Convertible Sub Section
Old Mar 15, 2019 | 10:59 AM
  #1058
BDASSZO6's Avatar
BDASSZO6
Will do. If not, the cost of a replacement top from GM will run $1136.00. Not the end of the world
Old Mar 15, 2019 | 11:00 AM
  #1059
BDASSZO6's Avatar
BDASSZO6
Plus installation.......
Old Mar 16, 2019 | 09:29 AM
  #1060
Bondojohn's Avatar
Bondojohn
It’s my understanding that the alarm won’t be activated unless the windows are up. This is the same for the coupe Try it and les us know.
