Top 10 most reliable used automatics by manufacturer
Manufacturer % of policies with a fault claim
1. Lexus 0.14
2. Aston Martin 0.26
3. Smart 0.33
4. Suzuki 0.47
5. Honda 0.50
6. Mazda 0.51
7. Toyota 0.53
8. Porsche 0.71
9. Skoda 0.81
10. Maserati 0.81
Least reliable used automatics by manufacturer
Renault 4.28
Fiat 4.20
MG 3.87
Chevrolet 3.30
Ford 3.14
________________________________________ ____
I have had 4 5 Lexii in the last 16 years; one was a definite lemon (RX300 - experimental model likely) that had the worst transmission I have ever experienced.
The other 3 4 are rock solid and bullet proof.
To put this into perspective, from the above stats, for every Lexus broken tranny, there would be 23+ broken Chev trannies.
GM has to do a much better job with the sturdiness of their transmissions.
Thanks, all we can hope for is that GM learns from these transmission problems and makes the correct and timely changes to their 2022 and beyond models.
So at risk of making a duplicate post, the frunk has twice now refused to open by normal means, ie door button, key fob button, and/or button under drivers headlight. Mechanism is not activating, didn't see any dash warnings, only way to get into the frunk (and reset the system) was to pull the manual frunk release cable. Anyone else?
1. Lexus 0.14
3. Smart 0.33
4. Suzuki 0.47
5. Honda 0.50
6. Mazda 0.51
7. Toyota 0.53
8. Porsche 0.71
9. Skoda 0.81
10. Maserati 0.81
Renault 4.28
Fiat 4.20
MG 3.87
Chevrolet 3.30
Ford 3.14
You do realize that GM does not manufacture the C8 transmission. Your statistics are not valid.
Not sure if it is buried in this thread somewhere but multiple people have had this issue. Warranty fix is to replace the frunk actuator.
GM has its contractors like all manufacturers: ZF, Ricardo for example. Tremec builds for many such as Ford, for example.
This does not invalidate any stats.
The data is almost three years old, September of 2018 (follow the link). Also, this data is cars sold in the UK. Considering there are no Chevrolet (except Corvette) cars sold in the UK since 2015, and the only Chevrolets sold prior to that were the compact cars like the Cruze, I would say yes, these results are really meaningless as they apply to the US market.
I would hope they make timely changes to 2021’s and beyond. Why wait till 2022?
I agree but that would depend on how quickly the problem is realized. Then how quickly a redesign can be drafted and then tested and then have the casting restructured for manufacturing.
I would be hoping that’s what the last 2 week shutdown was all about.
It would most likely be a QA/QC process correction as opposed to a full on redesign. Sad to say for those already produced, they'll probably get a coating ("sealer") treatment to plug the porosity.
It depends on the location(s) of the porosity causing the problem. The pictures I saw looked like porosity due to suck-back during casting cooling. If all the problems are in the same location than that can be addressed to a local modification of the casting. If they are in random locations then it is a different story.
2020 C8, currently has 3000 miles on it and in the shop. Found 2 puddles under the rear wheels, one was about an ounce of fluid, very dirty. Second puddle was about 6 ounces and clear, as if just poured out of the bottle. Taken in to the dealership this morning. Diagnosis is leaking transmission pan seal. This is the second time for this problem, first was at 1300 miles. Car is a daily driver. GM Tech is involved....so will see what happens. Current plan is to clean it up, reseal, drive till hot then let sit over night and evaluate in the morning. Will update as I find out more.
I took museum delivery of my 3LT C 8 on 2/7/2021 after waiting for 15 months. Shifting issues began with "Idle Creep Sensor Disengaged" warning, at 2900 miles, then rough shifts and finally, stuck in second gear. The dealer has diagnosed the problem as a transmission valve body failure. The factory tech team recommended part replacement. The part is expected in 8 days, then we will see what happens. Since no rental or loaner cars are available, GM has offered to reimburse up to $46.00/day for a rental. Currently, rental cars in Orlando are sunning $200.00/day
