My first rebuild
Old Dec 8, 2012 | 10:17 PM
  #341
scottyp99's Avatar
scottyp99
Faatcat, you have to learn to pay attention to details. The kit you ordered uses these pistons:
http://www.summitracing.com/parts/slp-h345acp30
Note that these pistons have a 1.548" compression height. This is .012" less than the stock 1.56" for a stock 350. They are going to add .012" to your piston-to-deck clearance, increasing your quench distance. Has Summit shipped it yet?
Scott
Old Dec 8, 2012 | 10:29 PM
  #342
FatCat's Avatar
FatCat
Scott
No, I just ordered..I can call them. I called and tried to talk to them about what I was doing and they really acted like I was just bothering them. Somewhere in this thread, I was told to talk to them when I ordered but I guess that didn't work out so well.
Old Dec 8, 2012 | 10:50 PM
  #343
sly vette's Avatar
sly vette
Seeing that you are spending almost $300.00 for a rebuild kit you have the right to "Bother Them" all you want.
Old Dec 8, 2012 | 10:51 PM
  #344
FatCat's Avatar
FatCat
On the phone with them now, I need to be at 1.56?
Old Dec 8, 2012 | 11:03 PM
  #345
FatCat's Avatar
FatCat
Here are some options they can still make the change. Would this work?
http://www.summitracing.com/parts/slp-wh345acp30
http://www.summitracing.com/parts/slp-wh345ncp30
http://www.summitracing.com/parts/sum-17350-30
Old Dec 8, 2012 | 11:59 PM
  #346
jays78's Avatar
jays78
I live about 3 miles from Summit, if they give you a hard time let me know I will go straighten them out for ya!
Old Dec 9, 2012 | 12:06 AM
  #347
FatCat's Avatar
FatCat
thanks jays78
Went with these...Scottyp99 talk to me!
Old Dec 9, 2012 | 01:20 AM
  #348
SuperBuickGuy's Avatar
SuperBuickGuy
practice this line for dealing with snooty tech people "I'm so sorry to bother you, is there anyone there who won't be bothered by my questions?" any answer other than "I'm sorry" simply say, "I'm having trouble talking to you, could I speak with someone else?"
and at Summit, should you reach more than one snoot, let me know, I'll put you in contact with someone whose job description includes performing attitude adjustments....
Old Dec 9, 2012 | 06:48 AM
  #349
Doug1's Avatar
Doug1
Scott
good call seeing that Scott!
Old Dec 9, 2012 | 10:34 AM
  #350
FatCat's Avatar
FatCat
Yes! Scott, I really appreciate that!
Old Dec 9, 2012 | 11:00 AM
  #351
hugie82's Avatar
hugie82
I don't see where the problem is? If he gets a thinner head gasket or small chamber heads he'll be fine. If it a little to low. i'm pretty sure hes not using the 76cc stock heads. Personally I think they'll fit right in with a .030 head gasket that comes with kit
Old Dec 9, 2012 | 11:13 AM
  #352
scottyp99's Avatar
scottyp99
Piston compression height is one of those little details that quite a few people are not even aware of. I just recently became aware of it myself, within the last couple of years. It's the distance between the center of the wrist pin and the face of the piston, in case anybody is wondering.
If your block has not been decked, you will probably want to go with the stock 1.56", in order to keep the piston-to-deck height at .025", so that you will be able to keep quench at ~.040" with a .015" head gasket (.015 + .025 = .040"). Quench is the distance between the face of the piston and the head at TDC.
The Devil is in the details, brother!
Scott
Old Dec 9, 2012 | 11:16 AM
  #353
FatCat's Avatar
FatCat
Iam posting this for future grasshoppers to read! HA
http://www.enginehones.com/technical.html
Old Dec 9, 2012 | 11:19 AM
  #354
FatCat's Avatar
FatCat
Scott
So did you guys see that I called Summit and changed the pistons? With this being the case, do I also need to change the head gasket?
Old Dec 9, 2012 | 11:21 AM
  #355
scottyp99's Avatar
scottyp99
Does anybody have some bail money for Jay? Ya know......just in case.....
Scott
Old Dec 9, 2012 | 11:24 AM
  #356
FatCat's Avatar
FatCat
Scott
No but I have some old pistons I can send him to throw at them from the getaway car...
Old Dec 9, 2012 | 11:27 AM
  #357
scottyp99's Avatar
scottyp99
I would say that you should get the bottom end assembled, then measure the piston-to-deck height, and then choose a head gasket thickness that will allow the quench distance to be as close to .040" as possible.
Scott
To My first rebuild
Old Dec 9, 2012 | 11:29 AM
  #358
FatCat's Avatar
FatCat
Scott
Well that sure takes the guess work out of it!
Old Dec 9, 2012 | 11:31 AM
  #359
scottyp99's Avatar
scottyp99
That is some great info, there!
Ummmm.......did anybody else get a little.......excited......when the English lady in the video started talking about how to stroke the tool?
Scott
Old Dec 9, 2012 | 11:33 AM
  #360
FatCat's Avatar
FatCat
Ummmm.......did anybody else get a little.......exited......when the English lady in the video started talking about how to stroke the tool?
Scott
HAHAHA!
I did notice the hone grit according to the numbers is 300-400 getting ready to go get one and start today> Hope I can find the right grit.
