My first rebuild
If your bearings are fine, leave em.
Putting them in is easy - it really is, but do check your work and understand you may need them line honed once they're in place.
I hate HF's website, half the stuff they have in the store isn't online, and half the stuff online isn't in the store... that said, I've seen bearing dies in HF up here.
Now here's the ringer... I don't hone, nor do I pound bearings in (except in Buick 455s, but that's because no one can seem to get them in right and they're expensive to replace). It costs very little to have it done by a machine shop, who has the 300.00 (guess) Snap on tool
http://www.summitracing.com/parts/aa...make/chevrolet
I'm sure your machinist will want more than that to replace them.
Cam bearings do not usually need to be replaced as often as main and rod bearings. Remember, the cam only spins at half the crankshaft rpm, and that's all it does is spin, there are no real reciprocating forces on them like there are on main and rod bearings, so they don't wear out nearly as fast. That being said, if you don't like the looks of one of the bearings, go ahead and replace them.
If you decide to replace the cam bearings yourself, let us know before you try it, it's not that hard, but there are a couple of things that are critical, like the orientation of the hole in the bearing, and the order that the bearings go in.
Scott
One of the guys at the shop said he uses Scotchbrite pads on mating surfaces and showed me what he does on a car we had in the shop.
What say you? Do these surfaces look good enough?
Or should I polish with 180 grit Scotchbite from here?
There are several imperfections like this in the head mating surfaces. Are they a problem? Sorry this one is a little blurry.
Here is an example of what I am looking at on the cam bearings.
Or shoud I polish with 180 grit Scotchbite from here?
There are several imperfections like this in the head mating surfaces. Are the a problem?
As for that nick on the edge of your cylinder, it's not gonna kill the project, but that bottom cam bearing photo is a little worrisome. I think I'd replace at least that one. If you leave it in it will likely cause some loss of oil pressure...
As for that nick, it's not gonna kill the project...
Scott
I'm concerned about that nick on #6 cylinder right on the fire ring
. Can you get a clearer pic of that?
