My first rebuild
Old Mar 30, 2013 | 11:14 PM
  #1241
FatCat's Avatar
FatCat
Originally Posted by AirborneSilva
Could you keep it running by working the gas?
Nope.
Old Mar 30, 2013 | 11:18 PM
  #1242
AirborneSilva's Avatar
AirborneSilva
Could be wrong, probably am , but I don't think it's the carb then
Old Mar 31, 2013 | 12:21 AM
  #1243
SuperBuickGuy's Avatar
SuperBuickGuy
Originally Posted by FatCat
I will try the cleaner tomorrow, should I put something in the fuel? It would start and then when it would idle down is when it would die.
generally speaking the idle circuit gets plugged. About 50% of the time, you can fix it with simply spraying carb cleaner. 25% of the time (of the remainder) you can fix it by pulling the carb apart and soaking it in carb cleaner overnight.... the other 25% of the time, it's something odd in the carb or something in the fuel supply system - e.g. failing fuel pump, blocked or collapsed line, plugged return line, or even a blocked vent
Old Mar 31, 2013 | 12:22 AM
  #1244
SuperBuickGuy
It could be a faulty input operation diaphram
Old Mar 31, 2013 | 10:08 AM
  #1245
FatCat's Avatar
FatCat
When u spray the cleaner, do you let it sit a while or start it right up?
Old Mar 31, 2013 | 11:01 AM
  #1246
SuperBuickGuy
doesn't really matter - use it like brake cleaner to blow the carbon off the venturi(s) and fuel inlets. The hope is you'll get whatever is blocking your idle ports to wash off.
Old Mar 31, 2013 | 01:02 PM
  #1247
AirborneSilva
Not trying to argue but understand so, what difference would it make to clean off the idle ports if when you work the throttle it still wont stay running?
Old Mar 31, 2013 | 06:47 PM
  #1248
SuperBuickGuy
valid question
if it won't idle, there is something blocking the ports (meaning the motor is too lean to run properly) - if it's cold (especially) when you work the throttle you flood the motor... in short, you go from too lean to too rich with the squirt of a booster.
the next step, if the spray doesn't work is see if the booster is working
Old Mar 31, 2013 | 07:08 PM
  #1249
hugie82's Avatar
hugie82
Some fresh gas and check the choke should fix it. Make sure the choke is moving freely and that its not staying shut too long. The weather is a little warmer and the choke may need a tweak.
Old Mar 31, 2013 | 08:01 PM
  #1250
AirborneSilva
valid question
Sounds reasonable
Old Apr 3, 2013 | 08:52 AM
  #1251
hugie82's Avatar
hugie82
What's the story on your car Fatcat? Just got back from San Antonio and I'm wondering how you made out???
Old Apr 3, 2013 | 08:56 AM
  #1252
FatCat's Avatar
FatCat
Sand sand sand! I have about 2/3 of it ready for primer and hope to be ready by next weekend . And then sand sand sand some more! I hope you had a great trip.
Old Apr 3, 2013 | 10:11 AM
  #1253
SuperBuickGuy
Just when you think you're done - do it twice more.... I HATE sanding, however, past indiscretions affect my ability to keep sanding for hours without morphine - so there is a bit of that in my hate.
Old Apr 3, 2013 | 01:44 PM
  #1254
FatCat's Avatar
FatCat
That doesn't sound like a good deal SBG! As previously stated I enjoy the sanding. Hahaha there is something about taking a rough surface and smoothing it perfectly that just does it for me... Hahaha anyway progress is coming!
Old Apr 3, 2013 | 05:18 PM
  #1255
SuperBuickGuy
I do that all the time.... blasting down the smooth track, into the sand trap.... err, I have it backwards... nevermind
Old Apr 8, 2013 | 01:45 PM
  #1256
HuskerBullet's Avatar
HuskerBullet
Default Valve Lash
Hey guys, just some quick info; if you ever need to readjust the valve lashes again, try this tool from this website. It is simply a magnetic vinyl strip with graphics that wraps around your harmonic damper and shows you each valve to adjust. It's pretty cool and cheap. I got one to use on my C6 after I replaced the OEM rockers with a set of Comp Cams rollers and the engine fired up quickly, ran smoothly with no noise, and I have never had to readjust them again.
Anyway, just thought I'd let you know that.
Old Apr 10, 2013 | 11:19 PM
  #1257
FatCat's Avatar
FatCat
Thanks for the input Husker!!!!
To My first rebuild
Old Apr 10, 2013 | 11:33 PM
  #1258
FatCat's Avatar
FatCat
OMG! Will it ever end!!!!!!! I am now getting exhausted with the prep work but continue telling myself "it's all about how well you prep" Ugh! Anyway, we are getting much closer, I have most of the car block sanded trying to get it as glass smooth as possible before shooting primer. I just spent a couple hours reading through Birdsmith personal paint thread and that helped me with a few questions that have popped up in my mind.
Trying to finish up along the bottom of the car all the way around, doors and jambs at this point. These areas are a real PITA but I will overcome! Ha! I would have posted some pics but nothing looks much diff than the last. I wish I could say I will be ready for primer this week but I have been saying that for several weeks now and not getting there when I set a goal so I will say when I get there I get there! It seems everyone is drawing on my time and slowing me down.
I have decided not to do a tricoat since I lost my painter but do plan on a metallic gray, I was thinking I still needed paint the car all together but I think Birdsmith painted his metallic in pieces so if anyone has some input there I would appreciate it.
Thanks!
Old Apr 11, 2013 | 07:13 AM
  #1259
AirborneSilva
Hey FC, yeah it is a boat load of work! If you wanted to paint the car together (with doors and hood on, you can pull the doors and hood, paint the jambs and the drip rail under the hood then put them back on to paint the car whole. I have heard that it's harder to get metalic and or pearl paint even if you have it blown apart, just a thought and I am certainly no painter...
Old Apr 11, 2013 | 08:59 PM
  #1260
FatCat's Avatar
FatCat
Thanks for the encouragement AS! After 8 months of steady work I am starting to wear down but need to finish and enjoy for the Summer!
Did a little tonight but I have to figure out how to take the doors off now! Hahaha
Must finish the car, must finish the car, must finish the car....
