My first rebuild
Old May 14, 2013 | 02:24 PM
  #1461
FatCat's Avatar
FatCat
Originally Posted by AirborneSilva
You sure have your heart set on flames
Mamma said flames are a must and I am what you might call an adventurist!!! Hahah
Old May 14, 2013 | 03:05 PM
  #1462
AirborneSilva's Avatar
AirborneSilva
Well if Mamma said then you have your marching orders - git r done!
Old May 14, 2013 | 06:23 PM
  #1463
birdsmith's Avatar
birdsmith
Scott, I was thinkin (I know, that could be dangerous!)that if it's not too late and you want to save yourself a little work...just sand the front clip. Mask off the back half,just sand the front clip, do your flames, shoot a couple more coats of clear, and then color sand & buff. Save yourself the work of sanding the back half of the car twice...
Old May 14, 2013 | 10:21 PM
  #1464
FatCat's Avatar
FatCat
That certainly makes sense! I have a couple of questions. 1. What is the difference between wet sanding and color sanding or is it the same thing?
2. There are spots that don't appear to have as much clear as the rest of the car. How do I fix that? Can you spot shoot clear before sanding or is it an illusion from orange peel?
Thanks!
Old May 14, 2013 | 11:38 PM
  #1465
birdsmith's Avatar
birdsmith
I tried a couple spot repairs on mine; while they look ohhh-kaayyy I should have taken some folks'advice and re-cleared the whole panel. That's really the only right way to correct problems with clearcoat.
As far as the difference between wetsanding and 'color' sanding, color sanding is done with very fine sandpaper as prep for eventual polishing. I found that the only adequate way to color sand modern clearcoats is to go all the way to a 3000 grit finish. If you try to buff beforehand you'll be wasting your time. Typical progression is 1000-1200-1500-2000-3000, then first step buff and second step polish. A LOT of work, but nothing else does the job. With the old lacquer finishes you could actually polish with a finish as rough as 1200 grit...modern catalyzed urethane paints are a LOT less forgiving, and repairs are nearly impossible. Wetsanding is just the term used for sanding anything with "wet"-type sandpaper, it is useful between coats on a car paint job because the water carries away the sanding sludge and helps the paper last longer because it doesn't 'load up' with sanding debris.
Again, for what you're trying to do, you should wet sand the front clip with 600 grit paper just enough to get it 'flat', just enough to remove the orange peel, mask and spray your flames, then shoot two more coats of clear over the entire front clip.
Old May 15, 2013 | 12:38 AM
  #1466
FatCat's Avatar
FatCat
So with the rest of the car do I use 600 to get it flat as welll and then jump to 1000? I would say most all of my panels have a spot of OP on them. :-(
Old May 15, 2013 | 08:32 AM
  #1467
birdsmith's Avatar
birdsmith
Color sanding with 600 grit is pretty aggressive. You could go 600-800-1000-1200,etc.,etc.,but you could easily sand right through the clear if you're not careful. The reason I say use 600 on the front clip is that you're going to go back over it with two more coats anyway, and the 600 grit finish will give a better 'tooth' for the top two coats to bite onto. And, using 600 will allow you to cut through whatever orange peel you have a little more easily- less work, in other words.
If the rest of the car is pretty smooth, i.e., minimal orange peel,you can try starting with 1200. It's really about what takes the least amount of work to get you to a smooth, 3000-grit, ready-for-polishing surface with the maximum possible amount of material left on the car.
The reason for color sanding in steps is to save time. You could jump from 1000 to 2000, but you'd be standing there grinding away with 2000 grit for days trying to get rid of the scratches from the 1000. Much quicker (and easier) to go a step at a time.
Old May 15, 2013 | 11:21 AM
  #1468
Cygnus's Avatar
Cygnus
Originally Posted by sweeet76
FC, this is probably one of the most incredible threads I have read in all of the years on the forum.
Now finish it up, yank the tops off, crank the stereo up and get on the road
Old May 17, 2013 | 11:23 PM
  #1469
FatCat's Avatar
FatCat
So tomorrow I will make the final push! It took about 3 hour to tape these flames down and I am ready to get this thing done now!
Old May 17, 2013 | 11:53 PM
  #1470
birdsmith's Avatar
birdsmith
You appear to have an eye for symmetry, Grasshopper...this is really getting good!
Old May 17, 2013 | 11:57 PM
  #1471
FatCat's Avatar
FatCat
Thank you sir! I did freehand these, no stencils allowed!! I the morning I will shoot the pearl, re-clear and go buy a new sander/buffer for the fun stuff!
Old May 18, 2013 | 12:05 AM
  #1472
birdsmith's Avatar
birdsmith
Scott, you really should go on the road with Tony Robbins and market whatever kinda juice you're on to all the lazy, apathetic video game-addicted couch potatoes who can't seem to find the motivation yo work their way out of whatever hole they've dug themselves into. When did you start on this thing? 6 months ago?
Unbelievable...
Old May 18, 2013 | 12:09 AM
  #1473
FatCat's Avatar
FatCat
Hahaha! Thank brother! The first post in this thread was 11:09pm CST 11/20/12...
Old May 18, 2013 | 12:27 AM
  #1474
chstitans42's Avatar
chstitans42
TheCorvetteBen
Looking good my friend! Let me know when you are going to take that road trip down to Dallas to show me this car in person!
Old May 18, 2013 | 12:30 AM
  #1475
FatCat's Avatar
FatCat
If it runs good it won't be long. I promised my best friend I bring it down to Durant for a visit when I get done. Not far from Dallas.
Old May 18, 2013 | 09:43 AM
  #1476
hugie82's Avatar
hugie82
Looking good Fatcat!!! Your almost there
Old May 18, 2013 | 12:56 PM
  #1477
SuperBuickGuy's Avatar
SuperBuickGuy
looks good FC!
To My first rebuild
Old May 18, 2013 | 01:52 PM
  #1478
FatCat's Avatar
FatCat
Thanks guys! Just shot the pearl! Gotta pull the tape in a little bit and re-clear the front clip.
Old May 18, 2013 | 03:15 PM
  #1479
FatCat's Avatar
FatCat
Ok! Overall the flames turned out ok (pita) if anyone can help me though. One of the tips pulled up while taking the tape off. Can it be stuck back down?
Old May 18, 2013 | 03:34 PM
  #1480
FatCat's Avatar
FatCat
Never mind I clipped it off and will re-tape that tip and shoot again. Hahaha. Flames are a "B" ask me how I know. LOL
