IMPORTANT ELECTRICAL INFORMATION (Long!)
Old Aug 25, 2011 | 06:00 AM
  #1141
914eener's Avatar
914eener
After replacing the battery and cleaning the grounds my swps fault codes have not reappeared. It's been 3 weeks now.
Old Aug 25, 2011 | 05:58 PM
  #1142
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Originally Posted by 98amethyst
Hi Bill,
I skimmed through the 57 pages and wanted your thoughts on my problem as it did not appear to be stated yet.
We have been having the intermittent problem with the passenger window, works, doesn't work, works, so I will have to try the wire issue between the door next time.
Check the POWER PLUG for damaged pins:
Lately, when I turn the headlights on, they light up, but do not raise. I then turn the switch to off, and then back on and almost always, they will raise on the second try. This is very puzzling. Car has 68k miles.
The steering column MUTIFUNCTION SWITCH is most likely at faut and meeds to be repaired or replaced. See this post:
- C5 Multifunction Switch repair - http://forums.corvetteforum.com/c5-t...f-replace.html
Also, during the day with the lights off, I have noticed that the blue MPH display is bright then fades to dim, then gets bright again. Tonight, sitting at idle in a parking lot and while driving, ALL of the lights, dash, interior, headlights flicker - go dim and then bright. (they dim for about a second or two, stay bright for 30 to 45 seconds). I might guess that the voltage regulator is going bad in the alternator, but I am not getting any of the strange DTC codes that most of this post talks about with the ground problems. We live outside chicago and the corvette is parked in the garage all winter. It has not seen snow.
I SERIOUSLY DOUBT your alternator has any part in the lighing issue. Theres a LIGHT SENSOR that controls the intensity of the background lighting in the IPC. Turn the lights on and see if that changes the symptoms. Put a Digita Volt Meter on the battery terminals and I bet you a dollar the votage is STABEL at 14.0-14.5 VDC If not,, the connection on the starter solenoid is loose/corroded or burnt up.
Just hoping for a little insight before I jumped at the grounds or replaced the alternator. Car has had a replacement battery, and I use a battery tender during the winter when the car is in storage.
On a side note, the fuel sender issue you describe has been an intermittent problem and the key FOB does not work at all. Thanks.
Run some Chevron Techron Fuel Syetem cleaner in a couple of tanks of fuel and see if that helps.. Also check chassis ground G-401 (ground stud in the drivers rear wheel well on the side of the frame)
Old Sep 3, 2011 | 04:47 PM
  #1143
Ruidoso Bill's Avatar
Ruidoso Bill
A big thanks from one Bill to another. Had the crazy faults pop up on mine like others have mentionsed. Put in a fresh battery (didn't fix the issues), did the two connecters (looked clean) and the main battery chassis ground under the hood and the door connectors and problems seem to be gone. Scary when the gauges all go crazy besides the service warnings. I think I may still get rid of the connectors and go with eyelets. By-the-way, if anyone else is doing the door connectors make sure you remove the accordian boot from the body side, connectors on mine are actually tucked inside the body, I removed the door side first and cound't even get to the connectors.
Thanks again.
Old Sep 3, 2011 | 09:40 PM
  #1144
c5 lifer's Avatar
c5 lifer
great info BC ! IM SAVING THIS
Old Sep 16, 2011 | 11:10 PM
  #1145
tartaglione88's Avatar
tartaglione88
6th Gear
I've only had my 2002 C5 Coupe 2 1/2 months now. Took a 2 hour ride and on the way out I was getting service brake and traction controll messages. When I parked at our destination and tryed to start it up an hour later, nothing. No clicks, no lights... nothing. I checked fuses and pushed on any electrical connection I could find. Kept trying to start, nothing, but just when I though about calling a tow truck, I tried again and it started. I'll have to try the ground cleaning as Bill said. Does anyone have additional ideas. Thanks, Charlie
Old Sep 17, 2011 | 12:26 PM
  #1146
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Charlie
Grounds are very important and can cause some very strange and annoying issues BUT,, you issue seems like its something other than a ground issue.
Start with the battery terminals them selves. Remove the terminals and clean them, clean the battery POS and NEG post also with a wire brush. Spray the cable terminals out with brake parts cleaner. Reinstall them and make sure that they are properly torqued to the required 11 ft/lbs.
When you said that you didn't have any LIGHTS,, that tells me that the battery terminals are suspect. Before you do anything to them, examine them. CAN you move either the POS or NEG terminal by hand???? If they are loose, thats pretty much the issue.
Let me know how you make out.
BC
Old Sep 20, 2011 | 03:34 PM
  #1147
meadowz06's Avatar
meadowz06
St. Jude Donor '09 and '13
I am working on a friends 2002 vert and I am getting the dreaded 1214 failure code. Now here is the problem. The battery will not hold a charge, even overnight. I had the alternator checked, and it is fine. I got the ABS/trac light to go off one time when I spiked the electrical system. Any hints? I checked a couple of the grounds and they were fine. The car did sit up for a 4 month period.
Old Sep 20, 2011 | 05:24 PM
  #1148
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
The alternator has NOTHING to do with a battery running down over night. (unless the diodes in it are roasted! )
You have a an excessive battery current draw. Read your battery current draw and make sure it 25 milliamps or less. I bet your are close to 1 amp.
BC
Old Sep 20, 2011 | 06:14 PM
  #1149
meadowz06's Avatar
meadowz06
BC
How would I trace the draw? I really appreciate your help. I am in way over my head on this car! What could be pulling the battery down?
Old Sep 20, 2011 | 09:00 PM
  #1150
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Review POST# 590 in this post and it deals all about current and what is excessive and how to find the issue:
Old Sep 25, 2011 | 09:51 PM
  #1151
marcolin's Avatar
marcolin
Clean your grounds first and make sure your passsengers foot well and BCM is dry.
Old Sep 26, 2011 | 01:22 PM
  #1152
987mbm's Avatar
987mbm
1st Gear
Bill,
Great stuff. Does your documentation tell you which ground connectors is located at each of the 13 locations? Have "no brake" lights. Bulbs good, tail lights work, turn signals are good, but no brake lights or rear safety flasher.
Old Oct 9, 2011 | 12:52 PM
  #1153
canadian99c5's Avatar
canadian99c5
Default ground locations and where they go
thought was a good list to post again
engine ground strap top left frame behind left front wheel well
G101 left front frame (with SP101)
G102 right front frame (with SP100)
G103 left front of engine
G104 frame next to battery (with G108 & SP102)
G105 left lower engine block, engine ground strap & wire
G106 Battery negative pole
G107 Left rear head
G108 frame next to battery (with G104)
G201 bottom of A-pillar, left (with SP201 & SP203)
G202 bottom of A-pillar, rt, bolted at the bottom (with SP202)
G205 inside door pillar driver seat (with G301)
G301 inside door pillar passenger seat
G302 inside door pillar driver seat (with G205)
G401 left rear outer frame
G402 right rear inner frame
SP201 bottom of A-pillar, left (bolted with G201)
SP202 bottom if A-pillar, rt (bolted to G202)
SP203 bottom of A-pillar, left (taped to wire bundle, with G201 coming out of it)
G101: windshield washer fluid pump
Windshield washer fluid level switch
Brake fluid switch
Headlamp door assembly, left
G102: cooling fan, right
Cooling fan 3 relay 44
Horn assembly
Underhood lamp
Headlamp door assembly, right
Headlamp door control module
A/c compressor clutch
A/c compressor clutch diode
Secondary air injection pump
G103: Electronic brake control module (ebcm)
G104: battery negative pole
Splice pack SP102:
Marker lamp, right front
Marker lamp, left front
Park/turn signal lamp, right front
Park/turn signal lamp, left front
Turn signal lamp, right front
Turn signal lamp, left front
Splice pack SP208:
Body control module (bcm)
Instrument panel cluster (ipc)
Data link connector (dlc)
Inflatable restraint & diagnosis module
Inflatable restraint ip module disable switch
Park/neutral switch
Remote control door lock receiver
G105: fuel pump relay 35
Engine oil level switch
Heater O2 sensor, bank 1 sensor 1
Heater O2 sensor, bank 1 sensor 2
Heater O2 sensor, bank 2, sensor 1
Heater O2 sensor, bank 2, sensor 2
G106: battery negative pole
Ignition relay 42
Powertrain control modules (pcm, 4 wires)
Throttle actuator control module (tac)
Mass airflow sensor (maf)
G107: ignition control modules 1-3-5-7
Ignition control modules 2-4-6-8
G108: Electronic brake control module (ebcm)
G201: Splice pack SP201:
Air temperature actuator
Traction/suspension control switch
Driver door module (ddm)
Door latch, driver
Auxiliary power outlet
Windshield wiper motor
Steering column lock
Footwell courtesy lamp, left
Hazard switch
Telescopic actuator switch
Splice pack SP203:
Remote CD changer
Fuse block I/P
Speaker, right door
Speaker, left door
Radio
G202: Splice pack SP202:
Passenger door module (pdm)
Door latch, passenger side
HVAC control module
IP compartment lamp
Footwell courtesy lamp, right
Vanity mirror lamp, left
Vanity mirror lamp, right
Inside rearview mirror
Bose relay 45
Ignition switch
Blower motor relay c60
Blower motor control processor
Hood ajar switch
Cigar lighter
A/t shift lock control solenoid
G205: seat belt switch, driver
Seat control module (scm), driver
Seat pump, driver
Seat belt switch, driver
Seat relay center, driver
G301: defogger grid
G302: Splice pack SP302:
Seat relay center, passenger
Seat pump, passenger
Rear compartment courtesy lamp, right
Rear compartment courtesy lamp, left
Rear compartment lid latch
Rear compartment lid latch, right
Rear compartment lid latch, left
Folding top lid latch
Folding top release switch
Fuel door lock actuator
Radio power antenna
G401: Splice pack SP400:
Fuel pump & sender assembly, left
Fuel level sender, right
Tail, stop, turn signal, rear left
Tail, stop, turn signal, rear right
Center high mounted stop lamp
Backup lamp, right
Backup lamp, left
License lamp, right rear
License lamp, left rear
Marker lamp, left rear
Marker lamp, right rear
G402 electronic suspension control module (esc)
_
Old Oct 9, 2011 | 03:56 PM
  #1154
toddh44's Avatar
toddh44
Cruising
Default High oil pressure
I'm getting high oil pressure readings. 128-130 psi.
I am assuming an electric problem, because I get these readings with the key on, but the engine NOT runnining, as well as when driving.
I recently did the ignition switch rebuild and cleaned the grounds. That cured all my code, voltage, warnings messages.
But this new issue has me baffled.
Any help or suggestions is geatly appreciated
Old Oct 9, 2011 | 04:13 PM
  #1155
914eener's Avatar
914eener
Your oil pressure sensor has gone bad. Common LS1 issue.
Search is your friend.
Old Oct 9, 2011 | 11:35 PM
  #1156
toddh44's Avatar
toddh44
Cruising
Thank you so much.
I did run a search for high oil pressure and oil pressure sensor, but it returned a lot of stuff that did not appear to reflect my issue.
It did however give me results for replacing the sensor.
I will follow that and hopefully that will fix me up.
Thanks again.
Old Oct 14, 2011 | 09:36 PM
  #1157
Blue Blood's Avatar
Blue Blood
St. Jude Donor '08-'09-'10-'11-'12-'13, '15,'21
Without knowing a lot more info,,, it sounds like defective loose or dirty battery connection or an issue on the starter solenoid connection. Give that a shot first The battery terminal torque is 11 ft/lbs.
BC
The symptoms continue --- While driving, the power still on to everything else, but motor dies, then would refire when depressing and then dropping the clutch, or cranking with the key. At first it would not set any codes, but for the first time this week it set PCM 1637. I don't quite understand the explanation supplied in another forum (see below), but it seems to sound like something that would create this situation, am I on the right track?
If it is the starter solenoid, any tips on getting the right starter to replace with?
Thanks, Clint
DTC P1637
Circuit Description
The powertrain control module (PCM) uses the generator turn on signal circuit to control the generator. A high side driver within the PCM allows the PCM to turn the generator ON and OFF. When Generator operation is desired, the PCM sends a 5 volt signal to the voltage regulator via the generator turn on signal circuit. This causes the voltage regulator to begin controlling the generator field circuit. Once the Generator is enabled by the PCM, the voltage regulator controls generator output independently of the PCM by monitoring the battery positive voltage sense circuit. Under certain operating conditions, the PCM can turn Off the generator by turning Off the 5 volt signal on the generator turn on signal circuit. The PCM has fault detection circuitry which monitors the state of the generator turn on signal circuit. If the fault detection circuit senses a voltage other than what is expected, this DTC will set. The voltage regulator also contains fault detection circuitry. If the regulator detects a problem, the regulator will ground the generator turn on signal circuit, pulling the voltage low. This also causes the PCM to set the DTC.
To IMPORTANT ELECTRICAL INFORMATION (Long!)
Old Oct 14, 2011 | 10:43 PM
  #1158
Rick Perkins's Avatar
Rick Perkins
Default Another blinker question
Well here goes.. It all started when I walked away from the car with the passive on. When I got out of range the car locked and the alarm went off. I found that the only way i could get it to stop was to turn the passive feature off on the Key fob. Next I notice when I turn on a blinker it hyperflashes like a bulb is burned out but it's not. i push the hazard switch in and the hazards flash as they should. Turn on the blinkers and the fronts don't work but the rears hyperflash. Next i notice the DRL's are not working, but when I turn the blinker on both DRL's flash quickly and dim.
Next i notice that when I turn on the head lights both blinker indicators light up for about 10 minutes then they go out. blinkers still dont work in front and hyperflash in the rear. I research a little and decide i have a bad blinker switch. i order a new one and install it. No change. I have a spare hazard switch so i change it out while I'm in there. (That was easier than expected) Still no change. What else could it be? Am I looking at a BCM repair?
Apparently a previous owner had some issues because when I changed out the multi function switch I found the connector had a couple of melted spots on it and two of the wires had been cut and bypassed around the plug. I believe Lou99 has the exact same issue as me. If anyone has any ideas what to look for next I would appreciat the help. I'm about ready to remove the entire dash assembly and see what else a previous owner screwed up in there. I do know my check engine light is eather burned out or that wire has been cut too. I get an 0650 code on that circuit.
Thanks in advance for any ideas.
Rick
UPDATE>>>>> Looks like I found the problem. Codes indicated a problem in the blinker circuit. I pulled both bliners out and checked the wiring. All good. I checked the side marker lights, all good. I unplugged the harness and turned the passive feature back on and no alarms. Plugged the harness back in, walked away from the car and the alarm went off when the car locked. There is a splice pack in this harness. I pulled the splice pack apart and found one of the sockets where a spade connects was open and was not making contact. I put a thin bladed screwdriver down the slot and closed the gap. Plugged the harness back in and all works as it should. Blinkers work, running lights work, car locks without alarming and best of all no BCM codes for front blinkers.
Old Nov 3, 2011 | 11:31 AM
  #1159
245made's Avatar
245made
8th Gear
dielectric grease is the way to go. even if any connectors an any vehicle never get wet, condensation alwasy occurs in enclosed spaces, ie, inside the sealed connector cavity
Old Dec 6, 2011 | 05:03 PM
  #1160
DevilMan02's Avatar
DevilMan02
the pictures in the original post are gone.
