** C7 Reported issues and resolutions thread **
Corvette customer support feel free to weight in.
You A6 guys may not want to hear about it any more, but as you can tell from the posts, we M7 folks are fed up with it. It needs to be fixed.
Rat
Just thinking the same thing! This is a crazy thread anyway with a mixture of issues and solutions all jumbled together! That is why I posted the 3 workarounds I use for the common issues I have for the new folks just getting their Vette’s!
Rat
It's just a matter of someone handling that.
In the meantime, I'm wondering if anyone has run into any issues with the seat memory changing.
I've noticed the seat does not return to exactly the same place. Instead, over time, the seat returns to "nearly" the same spot but what may seem like a hair further back. After a while, I have to reposition the seat closer and resave the position, after which time the seat will start to move further back again over a period of maybe a week. I'm 99.9% sure I'm not shrinking. I'm 100% sure I'm not sitting closer and closer to the wheel.
I've also noticed that sometimes the memory doesn't want to save. I'll hit the set + 1 buttons together over and over. Sometimes it beeps and most of the time it does not.
Rat
Sad but the memory seat in my 2006 GMC truck are far better and easier to use.
Easy exit works fine every time. However recall to position one is hit or miss. Some times only press 1 and release and it works, other times it does not, doing the exact same steps. No reason I should have to hold 1 untill everything gets to position, do not have to in my 06 GMC or any other vehicle I have owned since.
Rat
BTW the car is OUTSTANDING...
Rat
UPDATE: Easy Exit does work. After re-reading threads and the manual, I was thinking easy exit meant the seats, etc. would move BACK so I could get in and out of the car easily but based on what I read, that's not the case.
As for the details:
12/9 - Purchased car
12/18 - Car goes in for Low Rear Diff Recall. No issues found for me.
1/7 - Car needs HVAC Flash update
- Needed my heated seats checked (they still suck post HVAC update -- dealer said the HVAC update might make my seats warmer. I don't think they did
- Needed my the seat cover replaced on my drivers seat. I got a piece of clothing caught on the Corvette emblem near the headrest and it broke. Apparently you can't just buy this emblem (I bet it costs like a nickel to make). Instead, they needed to replace my entire seat cover. This is ludicrous if you ask me
- I found two chips under my mirror. More details in this post (http://forums.corvetteforum.com/c7-g...r-mirrors.html)
Dealer fixed these issues and repainted my mirrors. Car was gone 8 days.
1/15 - Went to pick up my car, looked at the mirrors, and saw the White paint they used didn't match the body color of the car. Dealer said GM has used the same paint code for Arctic White for 22 years. Dealer h Had to reschedule to drop off again
1/21 - Dropped off car with expectation to pick up on 1/24 with correctly painted mirrors
1/24 - Dealer says the paint code from GM doesn't match the paint they mixed to match the car. The need to keep my car another week while a rep from Dupont comes out, uses a special camera to analyze, match, and then order a custom batch of Arctic White to match my car. Finally got my car back just after the Super Bowl.
Glad I don't need to do anything for the Easy Exit, but now that I get it, I see why people are upset at the feature. It's *** backward.
