** C7 Reported issues and resolutions thread **
Old Mar 17, 2014 | 09:01 PM
  #1321
Stein's Avatar
Stein
From: Yopper of 52'yrs presently reside in WI Wisconsin
Originally Posted by KenHorse
The fuel door shouldn't open on its own - it should simply unlock ALLOWING it to be opened.
Ken, you were the one who advised this link after I posted a thread as a few others had this issue as well and I thank you for that.
http://forums.corvetteforum.com/c7-g...ping-open.html
Old Mar 18, 2014 | 02:26 PM
  #1322
KNDVETT's Avatar
KNDVETT
Default BSD Question or updates
Originally Posted by LawyerJoe
In follow-up to my earlier posting, BSD has now happened 4 times since delivery 3 weeks ago. It has happened when I am on cell phone and it has happened when listening to music. When on the connected cell phone, the Bluetooth link between phone and car is lost. However, when listening to XM radio, the sound continues to play although there is nothing on the screen. I'm still convinced this is a programming problem and not a switch issue. However, I just drive these things, I don't program them!
Joe
I was informed a few months ago by GM Cust Service and my dealer a new or upgraded infotainment system would be ready late February or early March and they would replace my faulty unit with similar concerns you note above. Just happened to me at lunch today once again.
Just wondering if anyone has had this corrected successfully to this point? Thanks VIN 1631.
Old Mar 18, 2014 | 07:52 PM
  #1323
time2run's Avatar
time2run
St. Jude Donor '13-'14-'15
VIN 2498- I had my center console replaced last week and so far so good.
Old Mar 18, 2014 | 08:09 PM
  #1324
Hooter01's Avatar
Hooter01
5th Gear
Default "Backfire" during full throttle acceleration shifts
Has anyone else experienced a backfire or bang noise when shifting during full throttle acceleration with the six speed auto? Is that a problem with the software for the VVT? Can the program be "Re-booted" at the dealer or would an aftermarket chip adjustment take care of it?
Old Mar 18, 2014 | 08:18 PM
  #1325
SJVET's Avatar
SJVET
Not a big deal but wanted to mention the issue I was having with my memory seat. No, this is not the issue that the M7s have as I have an A6. The easy exit was working fine but all of a sudden it stopped setting back to the #1 position when I started the car. In fact it would jerk a little to move but then stop. Finally figured out that I reset the exit memory to recline the seat a bit more. When you fully recline the seat it rubs a bit on the back console/side. I think this was being detected as something in the way and would stop the memory seat from returning to the appropriate position. Once I tilted the seat forward where I could no longer hear the rub and reset the exit position, everything is back to normal. SJ
Old Mar 18, 2014 | 08:21 PM
  #1326
jfinkow's Avatar
jfinkow
Backfire. Less loud and noticeable now that I have 2000 miles on the car. The first time was really something! I did not seek any resolution. FYI, an aftermarket chip will leave it's mark behind. There is no way to avoid that. And that mark will void your powertrain warranty. Just sayin...
Old Mar 19, 2014 | 06:46 AM
  #1327
KNDVETT's Avatar
KNDVETT
Thank you for the reply. Just opened a case with Chevy Customer Service.
How long did the dealer need to have your car? Did they simply replace your unit with an upgraded one?
Again...thanks much.
Old Mar 19, 2014 | 06:49 AM
  #1328
KNDVETT's Avatar
KNDVETT
Yes had the same thing happen although I am sitting at 3,700 miles and does not seem to be quite as pronounced. Time will tell.
Old Mar 19, 2014 | 07:52 AM
  #1329
Op.TechC3's Avatar
Op.TechC3
Default Is she ready yet
Marissa,
Could you check on my girl RQBWHN TX.
Thank You.
Jack P.
Old Mar 19, 2014 | 08:25 AM
  #1330
time2run's Avatar
time2run
They had my car for 3 days. I'll assume part of that was waiting for the new unit to arrive. I can't tell you if the replacement unit is the same or an upgraded unit. It looks identical to the original unit but hopefully the bugs have been fixed.
Old Mar 19, 2014 | 01:04 PM
  #1331
Z51SlowMotion's Avatar
Z51SlowMotion
My Vin # 1533, purchased early Oct. Is there anybody on the forum that has vin's close to this one? If so what problems have you encountered so far? Any replies appreciated
Old Mar 19, 2014 | 01:25 PM
  #1332
Chevy Cust Svc's Avatar
Chevy Cust Svc
Originally Posted by Op.TechC3
Marissa,
Thank You.
Jack P.
Hi Jack,
Your girl has finally hit 3800-Produced! Please PM us your order number for your VIN and build date.
Marissa
Chevrolet Customer Care
Old Mar 19, 2014 | 01:59 PM
  #1333
fredmills's Avatar
fredmills
VIN 2392, mid Oct. Dim instrument lights and HVAC issues. Have not yet returned for fix. All else is well except for a couple of minor paint issues.
Old Mar 19, 2014 | 06:16 PM
  #1334
JJoeG's Avatar
JJoeG
Mine does it. Get the "pop" just before it shifts.
Old Mar 19, 2014 | 07:29 PM
  #1335
NickHall's Avatar
NickHall
Madison Wisconsin
Default New Owners Help Identify and Sollve Problems
I was just wondering....
Seems to me that this string would be a great one for GM-Corvette engineering to follow to see what people are seeing and thinking.
There is some dang valuable posts on this string. Does GM follow these?
Nick
Old Mar 19, 2014 | 10:03 PM
  #1336
Sallye M's Avatar
Sallye M
22 Hypersonic Grey HTC
Originally Posted by lottavettes
Be careful of the little emblems on the seat back. I was getting in the
car the other day and my elbow slid across the emblem which them broke in half and cut my arm real good. I now have half an emblem and a long scab on my arm.
You should be able to get the emblem fixed under your warranty. Thanks for the info.
Old Mar 19, 2014 | 11:04 PM
  #1337
NickHall's Avatar
NickHall
Madison Wisconsin
Interesting, I have seen this post a number of time. But my seat has no emblems that stick out on it. But I got stock seats also. This seems like a law suit waiting for a class action assembly of owners.
To ** C7 Reported issues and resolutions thread **
Old Mar 20, 2014 | 08:44 AM
  #1338
Sallye M's Avatar
Sallye M
Default Revs issue
Originally Posted by zackvette
Picked up Laguna blue Friday...On drive home, I noticed at idle, revs would drop (just a little) and then pick back up. At 23-25mph, car would bog down, NPP would shut off, and then would pick back up. Same thing happened at 43-45mph then resume OK. 2nd 14 Vette, (long story). Put 821 miles on 1st and it ran like a dream! Dealer seems stumped! I've seen 3 other similar post, but I haven't found any follow up on this forum. Any thoughts?
Did you find any solutions to your rev issue? Do you have M7 or A6? Our A6 may be doing same thing, vin 11808.
Old Mar 20, 2014 | 08:51 AM
  #1339
KNDVETT's Avatar
KNDVETT
Default Thanks
Feedback is much appreciated. I'll just have to wait and see and based on this not take the car in until all parts are at least at the dealership.
Have a good one
Old Mar 20, 2014 | 02:56 PM
  #1340
sccaracer46's Avatar
sccaracer46
VIN 00767 Took my car in Monday. They ordered the unit and installed it on Tuesday! I asked them how long they needed the car and they said an hour to an hour and a half. I returned in an hour and a half and car was done! After two days, it is working properly! Great service from Vann Gannaway Chevrolet in Eustis, FL!
