Sponsored by: Wheel Design
C8 problems
Old Aug 6, 2025 | 08:11 PM
  #3341
4camV8's Avatar
4camV8
Originally Posted by kellyreno
do you have one
Does who have one what??
Old Aug 15, 2025 | 05:24 PM
  #3342
Rock-it Man's Avatar
Rock-it Man
Originally Posted by Casey10s
Well, I took my car in for a slow leak on a tire. It had a nail in it and it will need replaced. They did not have one in stock and the temporary patch wouldn't work. I had to leave the car there until the tire comes in. This is the second tire that had to be replaced. The first tire picked up a ratchet extension and left a good size hole in the tire. The car has just a little over 2000 miles on it. I never had this many tire problems in such a short time.
At least they gave me a ride home. I live about 20 miles from the dealer..,
So I thought I was the only one ever to have a rachet extension puncture a tire! Obviously it made a good sized hole, although it was 1/4" drive.
As luck would have it, I was literally 1/2 mile from my go-to tire store, so I pogo-ed my way there. Yes the extension went in radially, came to rest on the rim, and almost an inch protruded, so kathump-kahump-kathump.
It was no problem getting the tire repaired, which is why, over the years, this had become my go-to shop. The "secret" is, they took the tire off the rim, plugged the hole, trimmed the plug on the inside, and put a nice big patch on the inside. It was this shop's policy always to patch punctures from the inside after plugging them. That is what a real tire repair looks like.
Old Aug 23, 2025 | 03:15 AM
  #3343
Texan1Z06's Avatar
Texan1Z06
Sounds like Discount Tire
Old Sep 3, 2025 | 01:30 PM
  #3344
i007spectre's Avatar
i007spectre
Got in some heavy stop and go traffic yesterday and the car just didn't drive/shift very smoothly, maybe because the car always tries to shift through 1-3 so quickly.
Is this normal or may I possibly be looking at the start of transmission problems? I have just under 1000 miles on the car. Thanks.
Old Sep 3, 2025 | 06:27 PM
  #3345
qwazipsycho's Avatar
qwazipsycho
I've driven through a lot of heavy traffic and have never noticed anything other than smooth shifts.
Old Sep 3, 2025 | 06:32 PM
  #3346
i007spectre
Oh great. Not what I want to hear. Guess I need to research other symptoms of the transmission issue to look out for.
Old Sep 3, 2025 | 06:46 PM
  #3347
qwazipsycho
What mode were you in? Did you try switching to manual? I've heard a few say that it won't shift into odd or even gears. Either 1,3,5 or 2,4,6. Most have said it throws a CEL and goes into limp mode. Keep in mind, the vast majority of cars have no issues.
Old Sep 3, 2025 | 07:00 PM
  #3348
i007spectre
I was in mymode, with most settings set to sport except exhaust set to track and suspension set to tour. Mine shifts through all the gears and I don't have any issue at highway speed or even normal city driving.
Old Sep 3, 2025 | 07:28 PM
  #3349
qwazipsycho
Eh, play with it. I think you'll find different settings may do the trick. Other than that, drive it till it does something definitive.
Old Sep 4, 2025 | 01:20 AM
  #3350
etc123's Avatar
etc123
For me, the stop-and-go traffic is Ok but I did experience some transmission roughness and when I park on an incline and then try to go slowly (creep up) up the hill. More precise, my driveway is at a mild incline and I’ve learned to let my wife out at the bottom of the driveway and then somewhat accelerate and drive into the garage much faster than I should. In all fairness however, I’ve only experienced a rough transmission shift a couple of times on the incline and I’ve had the car for one year and 5 months with about 19k miles presently. Somehow, I don’t think Tremec did a good job to account for going slow up inclines (I would hope that’s a software setting where the the transmission should keep the low gear a lot longer for inclines instead of changing to a higher gear right away).
Old Sep 4, 2025 | 10:54 AM
  #3351
Mr. Jonathan's Avatar
Mr. Jonathan
Veteran: Space Force
I think there is a “hill assist” function with this DCT that you are experiencing when starting creep on an incline.
Old Sep 5, 2025 | 02:06 AM
  #3352
etc123's Avatar
etc123
I did some ChatGPT on this and apparently a hill-assist feature is mentioned in the 2023 model but not 2024 (which is my model year). The recommendation was to switch to manual to keep the car in the 1’st or 2’nd gear (depending on the incline) without allowing it to shift.
Old Sep 16, 2025 | 02:36 PM
  #3353
Dave68's Avatar
Dave68
Generally-speaking, the maximum holes size that can be patched is 1/4-inch. But a patched 1/4-inch hole in a tire on a high-performance sportscar would worry the heck out of me. Maybe on a Camry that has a top speed of 115 mph and one that is driven at 70 max, that would be considered safe, but.........
Old Sep 16, 2025 | 02:46 PM
  #3354
Dave68's Avatar
Dave68
Originally Posted by shiumai
They're definitely becoming more common now. When I got my '20, it'd draw some attention but now there are four other C8's within a three block radius of my house. And I'm the only one that parks mine in the garage! All the others park in the street or driveways.
Thus far, about 170,500 C8s have been sold in the US since 2020. By comparison, 68,000 Porsche 911s have been sold.
Looking a step down in cost, there have been only 24,000 GR Supras sold. Here in Southern CA, these are very rare. C8s, it seems are everywhere.
Old Sep 18, 2025 | 06:53 AM
  #3355
cbc111atl's Avatar
cbc111atl
8th Gear
Another update - I must be snake bit with Corvette. This car has been in the shop for over a week for the third time. The second was to replace the right rear taillight assembly that had seal failure allowing moisture into the light assembly. This caused several module failures and required battery replacement. Warranty issue #3 currently being repaired is module failures that control the HTC, both seats and frunk. The service dealer has also ordered a replacement wiring harness while the car sets in the shop with the rear bumper removed. This $100k car is not yet one year old and is nearing 40 days out of service!!!! My 2023 was a Georgia Lemon Law car and the 2024 will be as well. Make no mistake, I love this car....... sick of issues though! The replacement process is no fun but I'm going to try one more time with a 2026 replacement.
Old Sep 18, 2025 | 02:03 PM
  #3356
rmorin1249's Avatar
rmorin1249
St. Jude Donor '15-'16,'18
You, sir, are much more forgiving than I.
Old Sep 19, 2025 | 03:13 AM
  #3357
Vette Lag's Avatar
Vette Lag
These failures, and many others, are due to GM's low standards in material choice, build quality and lack of customer satisfaction.
Let Lexus take over building the Corvette. Let a company with amazing customer service, excellent build quality, and serious design and engineering strategies take a crack at it.
GM has failed its customers that buy Cadillacs, Tahoe's, Camaro's and every other car they peddle.
The C8 is substantially over-priced. GM is recalling 26,000 C8's for fires caused by fueling issues.
Fueling issues?
A car priced at least $150,000 being recalled for fueling issues?
Anyone care to remember the LS7 fiasco?
GM has failed at building cars and providing a decent automobile to their customers.
I bought my first Porsche, a 911 turbo S.
Not quite the road warrior most Corvettes have been over the years, but a real warranty, customer service and customer satisfaction.
Plus, such a different feel this Porsche has over the Corvette; quality.
To C8 problems
Old Sep 19, 2025 | 08:07 AM
  #3358
Samuel Clemens's Avatar
Samuel Clemens
Fueling issues?
great choice buying a Porsche. I am also going back to a Porsche 911 for my next sports car. The C8 is just okay, nothing special and GM is Genuinely Mediocre (now you know where the came up with the GM moniker from). Sam
Old Sep 19, 2025 | 08:35 AM
  #3359
cmck0916's Avatar
cmck0916
Lol, you means VOLKSWAGEN Porsche. Good luck with the cylinder bore scoring issues, IMS bearing, cracked strut towers, PDK, GT3 engine failures, and a host of other issues that plagued entire models and generations of recent 911s and other Porsches.
Don't delude yourself.
And even Toyota has bad V8s prone to failure in their most recent vehicles.
Old Sep 19, 2025 | 11:16 AM
  #3360
johnodrake's Avatar
johnodrake
Moderator
Default Camshaft Position Sensor
If you feel a slight “shudder” this may be the problem - CorvetteForum - Chevrolet Corvette Forum Discussion
