** C7 Reported issues and resolutions thread **
Old May 19, 2014 | 12:22 AM
  #1601
Rossi6998's Avatar
Rossi6998
Originally Posted by Wormwood
I've had this same instance...
You might (in my case) be trying to make traffic light & give it a little too much throttle it downshifts quickly once & them drops once more. Hold on, because you committed yourself & your C7 to simulate a take-off from an aircraft carrier!! If you look at the center console & it will say something like,
"Performance shifting enabled"
Now, you've made the traffic light & you jump out of the throttle just as fast as you got in it, but the transmission won't come out of the gear it's in & the engine just hangs close to redline.
You have 2 choices, the first I don't recommend because it's harder on the engine, but that's to continue with the throttle progression to the next gear. Problem is if you let off the throttle at all, you'll hang at redline for an abnormally long time because the transmission hydraulics will need to build up the pressure again before it will upshift. Second choice is to manually shift up with the right paddle shifter & you can also pull & hold the right shifter for a couple of seconds & it will put the transmission back into normal automatic mode.
Wormwood
Does anyone have anymore information on "Performance Shifting Enabled?" I think the message is actually "Performance Shifting Active." It appeared on my DIC after I aggressively accelerated the car. Could not find anything about this in the manual or a search of the forum.
Old May 19, 2014 | 07:17 AM
  #1602
petemoss's Avatar
petemoss
Z51 Vin Number 24161 Build date 5/1/2015 Crystal Red Metallic, Chrome wheels. 174 Miles. Punch list:
Passenger door always fails to close, unless you bang it.
Somehow they bent and dented the driver front splash guard. I found that when I replace the stock ones with aftermarket painted ones. Looks like they hit something with it. Going to ask for a replacement.
My seat cooling seems to work and then stop working.
Scratch on back driver’s side seat.
Bump in leather dashboard.
Old May 19, 2014 | 08:04 AM
  #1603
salty4728's Avatar
salty4728
Originally Posted by salty4728
When I took delivery of my 2014 convertible, it had a defect in the paint on the fiberglass black convertible cover that closes on top of the convertible roof when the top is down. Chevy wants to repaint my cover. I wanted a new cover. They said it does not matter since even the new cover comes only primed. Is that correct??? Everyone keeps saying do not repaint it hurts resale
Regards
Can anyone help with my concern??
Old May 19, 2014 | 08:14 AM
  #1604
agapsdiver's Avatar
agapsdiver
Lumbar support. VIN 1459
Every time I start the car I have to reset lumbar support to maximum.
I turn off the car.. get back in and lumbar support needs to be set again.
Can this be changed with a software upgrade... or do I have to
adjust the lumbar support every time I start the car.
Anybody else have this problem... or am I unique??
If I'm unique I'll take it in to my dealer.. if everybody's car
acts this way I guess I can only hope for a "software" upgrade in the future.
Old May 19, 2014 | 01:17 PM
  #1605
hdrider1's Avatar
hdrider1
Since the panel comes in primer and its painted off the car with the factory paint, what difference does it make. And also, how is the next buyer going to find out its been repainted? I'd say 6 of one and a half dozen of the other. Either way would be fine.
Old May 19, 2014 | 03:13 PM
  #1606
eshrink's Avatar
eshrink
Default Confused over lighting issue
My son drove my C7 around the corner onto our street. He turned on the right turn signal, and I noted that the right running light was out.
As he pulled into the driveway ~50 yards later, with no turn signal, both running lights were on.
He reports that today, when he was in back of another vehicle with his turn signal on, and could see the front of his C7 reflected in the vehicle in front, he noted that the right running light was off.
I have been unable to replicate this in the garage or driveway.
Any thoughts about is occurring would be appreciated.
Thank you in advance.
Old May 19, 2014 | 03:16 PM
  #1607
pittperson's Avatar
pittperson
This is exactly how it is supposed to work. Blinker on, running light off; blinker off, running light on.
Old May 19, 2014 | 03:23 PM
  #1608
eshrink's Avatar
eshrink
Thank you, Pittperson.
It is not a defect; it is a feature.
I suppose it would call greater attention to the intended turn.
Much appreciated
Old May 19, 2014 | 04:45 PM
  #1609
bnall40's Avatar
bnall40
What mode R U in, and if track mode, what sub mode R U in?
Thanks,
Sam
Old May 19, 2014 | 05:58 PM
  #1610
Bigdog9586's Avatar
Bigdog9586
Some cars use an air bladder, not sure if Vette does but if it does it sounds like it isn't holding air.
Old May 19, 2014 | 06:21 PM
  #1611
Minnesota122001's Avatar
Minnesota122001
Do you reset your driver settings after making adjustments? If you make any changes to your settings you have to do the reset for them to stay.
Old May 20, 2014 | 08:55 AM
  #1612
0-60B4U's Avatar
0-60B4U
Default Burnt smell under acceleration
My C7 now has 3400 miles and has always had a Burnt Hair Smell after rapid acceleration. After the recommended break-in period, I noticed the burnt smell after hard acceleration. I took it to my Dealer who told me it was probably the exhaust system coatings burning off. The smell is getting worse and is present even after medium acceleration. I have never smoked the tires or got on the brakes hard.
Has anyone else had this problem? If so, what was the solution?
Old May 20, 2014 | 10:15 AM
  #1613
agapsdiver's Avatar
agapsdiver
I tought it was air too...and was leaking... but my dealer service rep says it is a metal band that rotates.
Old May 20, 2014 | 05:09 PM
  #1614
Old Yellow's Avatar
Old Yellow
Get another service rep!!!
He is dead wrong. It is an air bladder, and if he ever paid attention to one he could hear the air release when deflating.
Ed
Old May 20, 2014 | 06:35 PM
  #1615
Mike14's Avatar
Mike14
Build date 2/28/14 3LT 6AT VIN 117118
Chalk up another to loosing the cooling seat function. I have an appointment with the dealer this Friday so hope it won't be a major problem to fix.
Has anyone else who had the problem gotten it fixed? If so what did it entail?
Old May 20, 2014 | 09:15 PM
  #1616
HalfMoon's Avatar
HalfMoon
I have not had mine in for repair yet, but this should give you some answers: http://sandyblogs.com/techlink/?p=3229
Mine was built 2/13/2014.
Old May 20, 2014 | 10:49 PM
  #1617
Mike14's Avatar
Mike14
Interesting read. Thanks for the tip.
To ** C7 Reported issues and resolutions thread **
Old May 20, 2014 | 11:46 PM
  #1618
bnall40's Avatar
bnall40
Do you think maybe it's your neighbor's cat?
... Just kidding of course .... evil ideas pop in occasionally!
Old May 21, 2014 | 12:08 AM
  #1619
Frank A Ognibene's Avatar
Frank A Ognibene
Cruising
Default HVAC is very disappointing.
Nope...have "auto defogger" set to OFF.
The HVAC in my new C7 is weak in comparison to my 2005 C 6 that I have owned for almost 10 years. While the new Corvette looks fantastic, it is not as comfortable as the car it replaced. Unless some of these basic comfort issues can be resolved, I doubt I will keep this car long term.
Old May 21, 2014 | 12:25 AM
  #1620
Rossi6998's Avatar
Rossi6998
The C6's have what I would consider a carbon type smell when you jump on the accelerator hard. This was a normal smell with many (if not all) C6's. We used to call it the smell of pure power.
Is it that type of smell or is it a stronger smell similar to burning oil? I have only had my C7 for a few weeks, so I have not really had a chance to step on the accelerator to see if I get the same smell.
