** C7 Reported issues and resolutions thread **
Old Jun 27, 2014 | 11:51 PM
  #1761
tmh68528's Avatar
tmh68528
Cruising
Default metal rattle in front end
I have a C7 convert with an off and on like metal dragging noise in front end. Sounds like metal a loose fan hitting a fan cage. Does not do it all the time, just once in a while and at no particular speed or up or down hills. Just random.
Anybody have anything like this?
tmh68528
Old Jun 27, 2014 | 11:57 PM
  #1762
pbarrows's Avatar
pbarrows
2020 C8 of the Year Finalist - Modified
Default iPod Issues
I am having an issue where my iPod freezes and I have to hard reset the iPod to get it to work again only to have it freeze again. That was an iPod classic. I tried an iPod touch and have the same problem. Both are current generations. Both the classic and the touch work fine in my 2015 Tahoe. It looks like there have been similar problems but not exactly. I guess I will take it to the dealer and see what they can do. There aren't any problems with Bluetooth streaming. Hmm..
Old Jun 28, 2014 | 03:23 PM
  #1763
Stangslayer's Avatar
Stangslayer
Originally Posted by Stangslayer
Vin - 1115
Mileage - 4,138
I originaly had this DIC warning the first week of driving this car back in October. Would reset to normal after shut down. Dealer checked codes - checked and "topped off" differential fluid level - cleared code.
Now warning comes on at every start. Dealer checked and found "no communication to rear differential module". Dealer is ordering new module. Also, lost ability to access different "tract" modes. Dealer thinks it is an issue with the differential module that is being ordered.
Hope this fixes the problem for good.
Not hearing this is problem with other forum members!
Dealer replace eLSD control module yesterday!
Now all is well with the world.
Service Rear Axel warning is no longer coming on.
Track Modes are available.
Thanks,
MacMulkin & GM
Old Jun 28, 2014 | 08:51 PM
  #1764
Chet Ciccarelli's Avatar
Chet Ciccarelli
Cruising
Default Vibraton/rattle/noise
I have a 2014 Stingray. I drove it from Kerbeck (Atlantic City) to CA to ship to Hawaii.
Shortly after picking up car and driving it in HI, I noticed that between 1200-1500 rpm with very slight throttle, there was a noise that sounded like a vibration from under the hood. This occurs in all driving modes. It will not do it if the engine is simply rev'd in neutral. It will not do it under full throttle. Since at highway speeds in HI (55) this is where the rpm is and is very annoying. It is not constant. It only occurs when cursing at this rpm and light throttle is applied.
Could this be detonation?
Old Jun 28, 2014 | 08:55 PM
  #1765
Chet Ciccarelli
Cruising
tmh68528
I just posted a similar issue that occurs between 1200-1500 rpm under light throttle. It is a metallic sound.
Old Jun 28, 2014 | 09:27 PM
  #1766
LIE2ME's Avatar
LIE2ME
Veteran: Marine Corps
tmh68528
I had the exact same issue on my 2014 C7 vert, but it seems to have resolved itself....
Old Jun 29, 2014 | 03:17 PM
  #1767
Vette-Pilot's Avatar
Vette-Pilot
Originally Posted by drs906
At about 5000 miles, started smelling gas fumes when my 2014 Corvette Stingray was garaged overnight. Diagnosis by local Chevrolet dealer working with GM Tech via phone indicates that the fuel vapor cannister is clogged. Replacement requires dropping the transmission to get to the cannister. Repair is estimated to take three days. Has any other owner of the 2014 Corvette eexperienced this problem?
Mine had gas smell at 200 miles. Leaking injector. Replaced by dealership with no further problem.
Old Jun 29, 2014 | 06:20 PM
  #1768
PAmotorman's Avatar
PAmotorman
maybe cylinder deactivation
Old Jun 29, 2014 | 08:23 PM
  #1769
BlueFinn's Avatar
BlueFinn
Originally Posted by vetehead
Vin 1356 ...z51 2lt nav npp manual magride ...
Hatch closing issue...software bugs with with the following:auto memory recall does not seem to work properly as well as easy exit recall. Remote left in vehicle seem to chirp 3 times with car running and I get out of car with remote in my left pocket..... every time??....I will update here if I find anything else.
This same problem has just started for me. Have you any further information?
Old Jun 30, 2014 | 12:24 AM
  #1770
Richard C7's Avatar
Richard C7
Navigator
I just started noticing that same rattle/metallic sound at around 1,400 rpm.
What have you done to resolve it?
I have 2,300 miles on my C7 Z51
I am taking it to the dealer tomorrow.
Penske Chevrolet in Indy diagnosed it with a bad belt tensioner.
Apparently it is pretty common. I have not gotten the car back to see if that fixed it though.
Old Jun 30, 2014 | 06:00 PM
  #1771
V RED 08's Avatar
V RED 08
Default noise 1200- 1500 RPM
I have the same problem from 1200 to 1500 RPM! Just traveled 1300 mi. and it is getting louder. I am not on my home computer so could someone in Customer Service please contact me on this blog.
Old Jun 30, 2014 | 06:16 PM
  #1772
No Shot's Avatar
No Shot
So I was washing my 7 month old C7 3LT Z51 on Saturday and got sick when I saw a spidering crack at the rear edge of the driver's door, about 1/3 down from the top. Today, I immediately went over to the body shop I've used for years - a very high end shop that does almost exclusively Benz, Ferrari, etc. Believe it or not, the owner told me to take the car to Chevy. He thinks the composite material failed? He saw no signs of an "impact" or chip in paint and showed me with a straight-edge that if something had hit the door, it would have hit the door at the "high" spot, which this is not. I'm so upset, but wondering if anyone else has this problem? You can clearly see that it is a very thin area of composite.
Just sick about it...
Old Jun 30, 2014 | 06:32 PM
  #1773
Chet Ciccarelli
Cruising
Default engine bay vibration
Originally Posted by pittperson
Coming from the engine bay? I have this and just assume its the nature of the beast.
I have a vibration?/rattle? noise that occurs between 1200-1500 rpm with very little throttle (at all speeds). Someone else said that they had this problem which to them sounded like the blades of a fan hitting a fan cage. That sounds about right. They also said that this went away on its own. Still don't know what it is or what to do about it. Could it be pre-detonation? Doesn't sound like it, but what else would just go away.
Any recommended gas treatment for this.
I live on Big Island of Hawaii and gas is lousy.
Old Jun 30, 2014 | 07:56 PM
  #1774
Sallye M's Avatar
Sallye M
22 Hypersonic Grey HTC
I had this issue and it was a faulty belt tensioner. There's a bulletin the dealer can pull up. Search this forum for belt tensioner for more info.
The noise occurred for me when in V4 at those rpm's.
BTW-Congrats on your new C7! Was just on Maui and didn't see any C7's.
Old Jun 30, 2014 | 08:30 PM
  #1775
Chet Ciccarelli
Cruising
Default Engine Bay vibration/rattle
Originally Posted by haroldholeman
vin#835. I have a noise coming from the engine compartment when engine is at idle. The only reason that i mention it is the car is so tight and quite. It does not seem to fit with the overall quality of the build. The engine also produces a noticeable vibration at idle. What have others observed? Thanks. Ps: I have 3500 miles on the car and do not remember having this noise/vibration initially.
vin 7069
there is a distinct vibration/rattle that occurs at approximately 1200-1500 rpm
it occurs in all driving modes
it occurs when the car is cruising & there is a slight acceleration
which is right where it is on the highway
it will not occur if the engine is simply rev’ed in neutral
Old Jul 1, 2014 | 10:36 AM
  #1776
j14152's Avatar
j14152
Default Oil pressure fluctuation after shifting
My oil pressure "jumps" (a momentary pressure rise lasting several seconds) about 10 psi to occasionally 15 psi AFTER, not during, upshifting, as the engine warms. It happen slightly after (maybe a second after, maybe a little less) the next gear is fully engaged and will remains high for a second or two before dropping. The fluctuation seems to be higher in the lower gears, where the difference in engine speed is greater.
It only happens as the vehicle is warming up, during easy to moderate acceleration, in the lower gears, with a shift point at, say, under 3000 rpm. It may happen at much higher rpms or hard acceleration, but I don't normally drive it hard before its warmed up, so I don't know if it happens under those conditions.
The oil pressure does not always jump by the same amount, but there is a noticeable jump of 5 psi or more when I watch it under these circumstances. In other words, the magnitude of the jump is somewhat variable. What is more regular is that the jump (on average) is minor when the engine is colder, and as the vehicle warms, it increases (on average, to about 10 psi or more) then decreases again as the water temp reaches operating temperature.
It starts to happen maybe a half mile, maybe less, from home. If I continue driving for, say, five miles, when the water temperature reaches normal operating temp, the fluctuation disappears.
It also happens after the car has been warmed up, then parked for ten-fifteen-twenty minutes. When re-started, it happens right away with no additional warmup (remember, it's already somewhat near operating temps). On the restart, the jump may last for a minute or so.
Two notes here -
This is not caused by over-revving between shifts - it will happen with the rev matching engaged (I seldom use rev matching).
The vehicle voltage does not change when this happens - the voltage remains normal throughout.
Any ideas?
Old Jul 2, 2014 | 01:07 PM
  #1777
No Shot's Avatar
No Shot
Originally Posted by CaryKen
VIN #76
Non-Z51
Exposed CF roof, Arctic White, Base wheels, NPP exhaust, Black interior, 2LT package
CF ROOF PROBLEM:
Roof showed splotches in the clear coat that looked like a cross between hard water stains and adhesive bubbling. Dealer buffed out the roof and they went away, but dealer is ordering me a new roof panel anyway in case they weakened the UV protectant coating. Pictures in this post:
http://forums.corvetteforum.com/1585165740-post57.html
BACK HATCH INNER TRIM PROBLEM:
Hot glue spills, metal deformation, peeling paint on the inside of the back hatch where the black plastic insert (that holds the glass) is attached to the metal of the hatch. Not visible from the exterior. Dealer sanded, filled, and painted. Not picture perfect, but good enough to accept delivery. Pictures in this post:
http://forums.corvetteforum.com/1585165675-post78.html
USB MEDIA DEVICE SOMETIMES NOT RECOGNIZED:
USB memory stick with approximately 6000 songs and perhaps 40GB of content inserted in center console port. Usually plays fine. But occasionally upon starting the car, the audio display tells me that no media device is found. I cannot browse, skip, or pause the music that is still playing from the media device! Resolution is to turn off car and accessory power and then restart. Has happened twice so far. I have not reported it to dealer.
I have same prob. Dealer is going to disassemble, paint and reassemble.
To ** C7 Reported issues and resolutions thread **
Old Jul 2, 2014 | 03:38 PM
  #1778
relative velocity's Avatar
relative velocity
8th Gear
Default C7 vibration at 1900 RPM
C7, manual, Z51 with mag. sel. ride, VIN 8228, delivered Jun 20 2014, less than 100 miles.
A vibration is evident at 1900 RPM in the body and prominent in the shifter. Occurs in various gears when accelerating, decelerating, steady RPM and in neutral.
Anyone experience this?
Old Jul 2, 2014 | 05:00 PM
  #1779
EVL-C8's Avatar
EVL-C8
2600 miles clunking/popping maybe this metal sound everyone is talking about? Mine happens after 2500 rpms and car is down on power! VIN 21578. Car is currently at Dealer waiting to be tore apart to be diagnosed
This needs to be re-called!
Old Jul 2, 2014 | 07:24 PM
  #1780
Richard C7's Avatar
Richard C7
Navigator
tmh68528
Did you get this fixed?
I had a rattle at 1,400 rpm and it was a bad belt tensioner. It will be fixed tomorrow, hopefully!
