Sponsored by: Wheel Design
C8 problems
Old Jun 11, 2023 | 02:01 PM
  #2721
Carlover247's Avatar
Carlover247
My saga continues. I’m am now victim to one of the cables breaking on the convertible top. I’m not sure what it’s called but it’s the nancelles pad retracting cable on the passenger side. I had felt like the last two times we took the car out the top was not retracting as smoothly. This time I heard a loud snap and thought, yeah something broke. Went out for our drive anyway. Sure enough when closing it the obstructed alert popped up. I was able to get it closed and secure. I held the pad back and had my wife bump it down until it closed and was secure.
Im trying to take the car problems and bad dealerships in stride but man….this has been the worst car I’ve ever owned so far. If it can’t handle weekend drives I don’t know how I could ever track it.
Old Jun 11, 2023 | 09:52 PM
  #2722
Barfbag_vette's Avatar
Barfbag_vette
Welp....1100 miles, check engine light, and pulled the P0700 and P0868 codes from my scanner which leads to a transmission issue. Car/transmission seem fine for now driving wise... Going to make a call to the dealer. Not too happy about this.
Old Jun 12, 2023 | 05:06 AM
  #2723
LS WON's Avatar
LS WON
It's still a new Corvette just broken in. What gives?
Old Jun 12, 2023 | 11:14 AM
  #2724
SneedFeedAndSeed's Avatar
SneedFeedAndSeed
It's funny how if anything the 2023 is way worse in trans failure frequency than the 2022. 4 years and they cant figure it out? I'm suuure 2024 will be different
You can quote me on this, in the end you will get a new transmission. The only question is if they'll go through the fluid flush, TCU change, valve body change first and keep stringing you along
or do a fluid flush and immediate jump to transmission change when that fails
Old Jun 12, 2023 | 11:57 AM
  #2725
EricC7's Avatar
EricC7
C8 htc z51 3k miles. No audio from speakers. At dealer now and checking it out. Also loud scraping sound form rear brake? Wish I could buy a new car that didn't have problems.
Old Jun 12, 2023 | 12:09 PM
  #2726
Barfbag_vette
https://gmauthority.com/blog/2021/12...io-in-q2-2022/
I wonder if it has to do anything with this.... anyways I got an appointment scheduled and will drop off the car this afternoon.
Old Jun 12, 2023 | 12:54 PM
  #2727
SneedFeedAndSeed
I wish you luck, I'm at week 3 of waiting
Old Jun 12, 2023 | 10:03 PM
  #2728
LS WON's Avatar
LS WON
It's time to get a new car that is reliable.
Old Jun 13, 2023 | 11:35 AM
  #2729
Barfbag_vette
Update on the P0868 code. Check engine light went away as I was driving to the dealer. But the dealer put the car in service mode and was able to retrieve and confirm the code.
Turns out it was low on transmission fluid. They added 0.75L to it and cleared the code. Hopefully no further issues arise. Kind of wish they told me since I would have wanted to have an extra two quarts added to the transmission if I ever wanted to do more harder driving in the future.
Old Jun 13, 2023 | 12:04 PM
  #2730
RKCRLR's Avatar
RKCRLR
Adding the 2 additional quarts for track fill is a different procedure than topping off the DCT fluid. It would still have cost you the same for a track fill then or if you decided to do it now. The track fill is only needed for conditions encountered on the track that you won't encounter during street driving.
Old Jun 13, 2023 | 01:22 PM
  #2731
Barfbag_vette
Ah, got it! I had assumed it was the same fill process.
Old Jun 13, 2023 | 06:15 PM
  #2732
dohabandit's Avatar
dohabandit
It officially fills from the top and requires the trunk liner to be removed to access the fill plug.
Since your fluid was low, you really should watch for signs of a porosity issue, half shaft seal issue, or pan gasket, etc.
Old Jun 17, 2023 | 02:31 PM
  #2733
Brokenwings's Avatar
Brokenwings
With 380 miles on the car, I had a frozen infotainment screen. It was stuck on the PDR page. I did what I saw on one of Conti’s video. Turned off the car, opened the door for 5 min, and then closed the door. When I restarted the car, all was back to normal.
I hope this is the only problem I’ll have with the car.
Old Jun 17, 2023 | 03:33 PM
  #2734
MarkMeHopeful's Avatar
MarkMeHopeful
2022 C8 of the Year Finalist - Modified
Yes, that reset procedure seems to cure a wealth of computer-type problems. I do the same thing on my laptop.
Old Jun 17, 2023 | 04:28 PM
  #2735
LS WON's Avatar
LS WON
Computer problems They have made it so its now a necessity in these modern high tech. times. Love em or leave em. Update them then throw them away when the program is no longer supported and buy NEW again as it never ends$$$$.
"I owe so off to work I go".
Let's go back to old school maybe just a little with just a few less electronics, BCM's computers and PROBLEMS.
Right now it's the cure all to turn off and turn it back on. Reset.
What is my password to this account?
Old Jun 17, 2023 | 07:56 PM
  #2736
Brokenwings
Not to scare ya, but we do the same reset on the airplane lol
Old Jun 17, 2023 | 08:15 PM
  #2737
LS WON's Avatar
LS WON
To C8 problems
Old Jun 26, 2023 | 12:42 PM
  #2738
IrishSpuds's Avatar
IrishSpuds
St. Jude Donor '13-'14-'15-'16-'17-'18-'19-'20-'21-'22-'23
Please remember to shut the door before you take off. Thanks.
Old Jun 27, 2023 | 12:21 AM
  #2739
LS WON's Avatar
LS WON
Old Jun 27, 2023 | 06:19 AM
  #2740
Brokenwings
What door?!!! 😂🤣
