View Full Version : C6 Scan & Tune
- Suggestions MPVI Pro upgrade to a MPVI3 ?
- FLASH SALE! One Week / Many Brands!
- Turn Ignition on without starting - HOW
- Throttle response devices
- Tech2 MDI MDI2 for 2005 Corvette programming
- How soon will I see CELs
- C6 tuners?
- BCM Tuning
- Flex fuel display of ethanol content
- Tuners, please step in
- P2548
- Pressure Control Solenoid C&E stuck off
- Columbia, SC area Tech 2
- LS3 Coolant Temp Sensor
- Driving modded car to get dyno tuned.
- LS3 A6 tune
- Emissions Harris county Texas
- Dyno Tune Scam?
- Infamous P0106 code on our 08 Z06
- Help w/ E-force LS2 tune: Torque converter randomly unlocks and AFR leans out at WOT
- Tampa tuning
- Tampa tuning
- MAF Tuned?
- 2005 C6 with E40 ECM - E85 Support?
- P1SC procharger help
- completely dead battery
- SPS2 + Acdelco
- Supercharger Sale! A&A, Magnuson,ECS, Procharger, Edelbrock.. 2YR 0% Financing!
- Running 93 octane BP gas in my 2011 LS3
- Multiple Tunes on Stock ECU?
- RPM Transmission 2005 C6 Corvette Performance Upgrade Differential
- How to tell if car has been tuned
- 2008 with ABS Issues
- HP Tuners MPVI3 - Smog Monitor Readiness
- ADDING CATS to tuned CAM CAR
- Download the tune w/o the engine, how to ?
- Oil temp logging with HP Tuners - C6 Z06
- Brakes for your Corvette - KNS Brakes
- C6/A6 Trans tune questions
- Corvette LS3 Tuner around Atlanta Georgia area!
- Bench Testing an 05 E40 ECU.. anyone?
- Tech 2 clone and Techm
- Need help with base Tune ls3/ A&A
- Tune Help
- HP Tuners Prolink+ Question
- Tuning help
- TPS End of Year Sale-Headers, Superchargers, Coilovers, Rollbar, Seats, & much more..
- My Obd port won’t connect for inspection.
- C6 rcldr
- Help .. no start no doors no fob baffled
- HP Tuners 4.8.7 software
- tuner required?
- Cyber Monday Deals-A&A/ECS Superchargers-$5399, Procharger & AWE-15% off, and more...
- Ned help!!
- Stainless work headers sale
- P071, P074, P300 codes
- Black Friday Deals-15% off Superchargers, 50% off wheels, & more...
- Transmission tune via Tech 2?
- tpms not reading
- Tune for GM Performance Parts Kit 19301990
- Lingenfelter tune
- TPS Motorsports Brake Upgrades as low as $325.95
- TPS Motorsports Suspsension Packages as low as $499.99
- HP Tuners and 6L80 Shift point, my data doesn't make sense
- Fpcm question
- Idle Spark Coast Down table
- Procharger Tune Question
- Engine overheats following rebuild
- Remote hp tuners?
- Tuner question
- Creaking noise from first gear
- How to change cammed idle?
- p0121
- AEM wideband analog output.
- A6 in Drive shifts down to 2nd at stop
- Relocation to Arizona from Illinois...tune concerns?
- Fuel System Help on 08 Z06
- Getting confused on tuning, where to go and what to have done
- First tune
- Ls2 to ls3 maf tune on diablo
- Wanting to change spark plugs
- Flex fuel E85 tune?
- Tuning 101 for Stock C6 with HP Tuners (Part 1 video)
- C6 automatic shifting too early
- Accelerator Pedal Position Pinout
- alternator control with hp tuners?
- 2005 LS2 HP Tuners Help
- Revert vehicle to stock using ho tuners.
- Need help with body control module and pcm programing
- LSD for base vette
- Adjusting tune for ethanol
- Picoscope 2205a available 4sale
- 2008 Z06 BCM Replacement
- C6 Corvette Reduced Engine Speed
- Californians with tune!
- HP Tuners Repository Lookup Request
- Spinmonster cam tune questions
- What do you guys do for tuning multiple vehicles in regards to wideband sensor?
- John Reed plug and play
- Good Tuner Cincinnati area?
- Fuel Trim # Interpretation Help Requested :-)
- AEM 30-0334, OBD Passthru?
- Oregon Tune shop
- school me on tuning please
- Cam Swap
- Trans tune/paddle shift question
- HP Tuner needed in Orange county N.Y.
- HPTuners MPVI Pro for sale
- Actual Scan best product ....
- Pro Tuning Orlando FL
- Really good dyno tune results
- C6 ZR1 scan review
- Is Brian D Kennedy here, with a 2006, that contacted me for custom tune?
- Torsen vs Clatch Pack
- LS7, V-3 Removed, tuning changes needed?
- Local Tune Shop
- Need help with electrical gremlins
- Diablo ??
- Please review my C6 Z06 tune
- Hp tuners questions
- DTC P0171 and P0174
- Issue with fuel system wiring.
- Car runs lean at random times
- 2008 c6 ls3 programmer and tune.
- Mamo ported MSD 60lb injector tuning
- DiabLew Intune after Header Install?
- Service Traction System @ 100-110 MPH
- Rear End Walking/Shimmy
- Your #1 Parts Dealer for your Corvette!
- Tech2, nano or ?
- How do I log on access to Techline Connect ?
- Rebuilt 6L80 won't fast learn
- Shift points after torque converter change
- MPVi3 and a Mac
- Remote Tuning Corvette Tuner in Tampa Orlando
- Looking at a Z with p-420 % p0430 with CEL ON
- Need Tuner Advice - Kentucky
- tuner or hand held?
- Factory E38 ECM Fuel Pump PWM Signal?
- CA SMOG check readiness issue
- Replacing an E40 ECM
- Tuning Packages at DSP Performance Motorsports
- HP Tuners MPVI3 In Stock at DSP Performance Motorsports
- Looking for an HPTuner to turn off fuel gauge issue
- Knock issue, please help!
- 2023 New Year SALE!
- Ride Height Sensor Data C6ZR1 (HELP!)
- 2006 Coupe - EBCM Wiring?
- Trans tune needed
- I need a good LS7 Tuner
- Replacing E38 ECM
- Christmas Sale-Twin Turbo Supercharger Headers, Wheels, Brakes, Wide Body Kit, & more
- Do I need a tune with these mods?
- TampaTuning.com
- Can I flash EBCM or other modules with Tech 2?
- TPS Black Friday Sale-Coilovers/Headers/Supercharger/Body Kit/Wheels & more...
- EBCM 2010-2013 CAN bypass
- Intune install. (Ignition power question)
- Would like to buy a Tech 2
- DIC and HUD customization
- Pre HP Tuners Suite v5
- Cam and Headers installed... now this...
- Tech2Win software question
- just got this tune, how does it look?
- 2006 Corvette LS2 KR with only 18.5*
- 2010 C6 GS: "Service Charging System"
- Vxdiag nano candi tech 2
- Service Active Handling System C0196
- New guy tuner question
- OBDII dongle interference issue
- Speed Limiter??
- Rear wheel Tq 646 lb.ft/Delivered Eng. Tq 456 lb.ft
- ABS codes I wouldn't know where to begin... U codes
- Engine Failure - 585HP TSP crate engine
- P0300 and Service Traction System
- p0172, p0175 codes
- Tuning a 2010 GS
- 06 auto gear change
- 2005 c6 giving Codes again
- OBD port not communicating with scanner
- P0306/Active Handling/ABS litght
- Duoe
- schpenxel MIA?
- Labor Day Sale-Superchargers, Headers, Monster Clutch, Wheels, Coilovers, Body Kits..
- Data logger
- Dyno numbers questions
- new guy with lots of questions
- Programing?
- 2008 LS3 ECU and reading ethanol content
- check engine light on intermittently
- p0606/p1516/traction control
- HP Tuners “Burble” Tune
- Reprogram ECU?
- TCU not Communicating no 12V key on to TCU
- Anyone here got an A&A V2 Vortec C6?
- Service active handling
- Looking for HP Tuner MPVI2+
- Diablo Transmission tune
- Ladedruck C6 ZR1
- Supercharged LS3 Power Gains From Timing
- '07 OBDII no comms
- Limp mode
- Charge Temp Table Question
- Change Traction Control Default Setting
- 2005 C6 Fan Settings
- Just an FYI for the forum, ECS will no longer offer any mail order tuning
- Cam tune
- Problems after installing Big TB on LS2
- P0106 Bad Baro?
- Dyno question.
- Tuner in Central Florida
- A4 Trans Tune
- Tech2/VxDiag/Tis confusion???
- Advice needed for hp increase
- Newest Dashlogic firmware version? C6
- Help with Diablo i2 (still married?)
- P2135&P2176&P060E best source for parts?
- Generator 3-wire connection help.
- HP Tuners for Dummies
- Another Diabo question.
- Need Help on HP Tuner VCM Scanner Logs
- Select a gear in "Sport" mode then auto shift
- HPtuners MPVI Pro value
- Northern VA Tuner
- Drive with faulty knock sensor?
- Can I pull error codes from my '07 C6?
- Diablo i2 questions
- Tuner in san fran bay area
- Opinion on Dyno sheet - C6 A6 - 495whp/412Tq
- Max and Min values from HPTuners Logs
- How much harder is tuning with an aftermarket cam?
- 2008 Corvette HP Tuners help
- Delivered Engine Torque
- Stock Tune Log wanted
- Advise needed
- Diablo Predator P2
- Tune ?????
- Looking for a good tuner (South Florida)
- High long term fuel trims at idle >
- Diablo OTS tranny tune shifts too hard
- Bricked TCM? 2007 C6 A6
- New UK owner - O2 fault codes
- 2005 TPMS Tune out
- radio question
- 4 to 5 Shift Speed vs % TPS
