FYREANT's Instructional "How To:" guides
Hello all, just wanted to post all of the instructional How To threads I've written in one location so they are easier to find. As I write new content, this thread will be updated so feel free to bookmark this page! Also, if there is something you feel we need a How To thread on, please let me know and I can see about putting something together! enjoy! Brake-System: HOW TO: Adding Z51/Z06 Brake Cooling Ducts and Deflectors to Base Stingray https://www.corvetteforum.com/forums...-stingray.html HOW TO: Z51 Brake System Upgrade for Base Model Stingray https://www.corvetteforum.com/forums...-stingray.html Body / Aesthetics: HOW TO: Painting C7 Engine Bay Parts https://www.corvetteforum.com/forums...bay-parts.html HOW TO: Restore mirror finish to polished aluminum after a chemical mishap! https://www.corvetteforum.com/forums...al-mishap.html HOW TO: Installing JW Motorsports Side Skirts on a C7 https://www.corvetteforum.com/forums...s-on-a-c7.html HOW TO: Installing JW Motorsports Stage 2 (and Stage 3) Front Splitter on a C7 https://www.corvetteforum.com/forums...r-on-a-c7.html HOW TO: C7 Front Fender and Headlamp Removal https://www.corvetteforum.com/forums...p-removal.html Engine / Mechanical: HOW TO: Installing a new LMR 160° Thermostat and Housing https://www.corvetteforum.com/forums...d-housing.html HOW TO: EdgyVette C7 E85 Stealth Flex Fuel Kit Installation https://www.corvetteforum.com/forums...tallation.html HOW TO: Install Alky Control Meth Injection system in a C7 https://www.corvetteforum.com/forums...m-in-a-c7.html HOW TO: Add a new Windshield Washer Reservoir & Pump & Relocating them on a NON-Z51 https://www.corvetteforum.com/forums...a-non-z51.html HOW TO: C7 LT1 Complete Engine Removal Procedure Guide in 50 steps (on jack stands!) https://www.corvetteforum.com/forums...ck-stands.html HOW TO: Honing the Cylinders in your LT1 Block https://www.corvetteforum.com/forums...lt1-block.html HOW TO: Replacing LT1 Pistons / Installing Vengeance Racing Drop-In LT1 Pistons https://www.corvetteforum.com/forums...1-pistons.html HOW TO: File Fitting and Installing New Piston Rings and Checking Oil Ring Tension https://www.corvetteforum.com/forums...g-tension.html HOW TO: Check Main & Rod Bearing Clearances with Plastigage https://www.corvetteforum.com/forums...lastigage.html HOW TO: LT1 Camshaft and Cylinder Head Install Guide https://www.corvetteforum.com/forums...all-guide.html HOW TO: Installing a Cam Phaser Limiter https://www.corvetteforum.com/forums...r-limiter.html HOW TO: Degree Your C7 LT1 Camshaft! https://www.corvetteforum.com/forums...-camshaft.html HOW TO: C7 Rocker Arm Trunnion Upgrades https://www.corvetteforum.com/forums...-upgrades.html HOW TO: Installing a Fuel Pump Lash Cap in an LT1 and Checking for Proper Clearances https://www.corvetteforum.com/forums...learances.html Driveline / Transmission / Clutch: HOW TO: Install a Mantic Twin Disc Clutch and Flywheel in your C7 https://www.corvetteforum.com/forums...n-your-c7.html Tuning: HOW TO: Disable AFM Exhaust Valve Actuators with HP Tuners https://www.corvetteforum.com/forums...hp-tuners.html HOW TO: Connecting an Innovate Motorsports AFR/Boost Gauge to HP Tuners https://www.corvetteforum.com/forums...hp-tuners.html Other Member Submitted HOW TO: Guides: Theta's Master List of How-To Guides for C7 Corvette Stingray https://www.corvetteforum.com/forums...-stingray.html GT Seat to Competition Seat Conversion https://www.corvetteforum.com/forums...onversion.html Manual transmission and rear differential fluid service https://www.corvetteforum.com/forums...d-service.html How To: Tranny Flush with Mobil 1 Synthetic LV ATF HP without dropping the pan https://www.corvetteforum.com/forums...g-the-pan.html The Geezer's Navtool installation https://www.corvetteforum.com/forums...tallation.html How-To: Lower The Vehicle on Stock Bolts https://www.corvetteforum.com/forums...nd-photos.html How-To: Install Flex Fuel Sensor (In engine bay) https://www.corvetteforum.com/forums...r-install.html How-To: Convert/Swap Upper Interior Panels to Suded Microfiber https://www.corvetteforum.com/forums...th-photos.html How-To: Remove Rear Fascia (with Pictures) https://www.corvetteforum.com/forums...r-removal.html How-To: Remove Front Fascia / Front Bumper Cover (with Video & Pictures) https://www.corvetteforum.com/forums...val-video.html How-To: Self-Calibrate Stubborn TPMS Sensors https://www.corvetteforum.com/forums...ere-s-how.html How To: Image Lights C7 specific https://www.corvetteforum.com/forums...-specific.html How To: Range AFM Disabler – No More Parasitic Battery Drain via Relay in Cord https://www.corvetteforum.com/forums...y-in-cord.html How To: Install a Leather Airbag Cover Yourself https://www.corvetteforum.com/forums...-yourself.html How To: Suede Z06 D shaped steering wheel WITHOUT Z06 logo https://www.corvetteforum.com/forums...-z06-logo.html How To: Install DSC Sport Controller https://www.corvetteforum.com/forums...ontroller.html Jet Vet's DIY wide body conversion project https://www.corvetteforum.com/forums...n-project.html Joemosfet's DIY widebody conversion project https://www.corvetteforum.com/forums...n-project.html How To: Add NPP Switch - True Manual On/Off Valve Control https://www.corvetteforum.com/forums...e-control.html How To: NPP Reverse-Engineered - Full Open/Close, Non-Factory-NPP Retrofit https://www.corvetteforum.com/forums...-retrofit.html How to install: DIY American Racing Mid-Length Headers https://www.corvetteforum.com/forums...h-headers.html DIY: Adding Z51 Sways to a base C7 https://www.corvetteforum.com/forums...a-base-c7.html How to remove your rear lower fascia / bumper cover for exhaust removal https://www.corvetteforum.com/forums...al-w-pics.html How-to: Add Z06 fender spats to a Stingray with APR / similar aero with canards https://www.corvetteforum.com/forums...h-canards.html How To: DIY guide to replacing steering wheel bezels https://www.corvetteforum.com/forums...el-bezels.html HOW-TO: Install larger '19 Z06 (Auto) radiator https://www.corvetteforum.com/forums...-radiator.html Informational: Race Fuels and how they compare to each other for power (E85, C85, & Meth included!) https://www.corvetteforum.com/forums...post1596294482 Stay tuned, this thread will be updated frequently as new material is created. :) Ant |
Nice, just checked out your write up on Painting C7 Engine Bay parts.
I'll have to book mark it for later. |
Made this a sticky thread.
Originally Posted by Zymurgy
(Post 1596093209)
Updated list and added:
HOW TO: Disable AFM Exhaust Valve Actuators with HP Tuners |
HOW TO: Installing JW Motorsports Stage 2 Front Splitter on a C7 |
nice!
Informational section created, first entry added for: Race Fuels and how they compare to each other for power (E85, C85, & Meth included!) |
Super clean car and super smart dude. Great work Anthony!
Originally Posted by Rich_Redline
(Post 1596301721)
Dude , this is awesome.
is there a DIY for removal of front fenders? |
Originally Posted by Cajun@Edgyvette
(Post 1596337737)
is there a DIY for removal of front fenders? Go to the section labelled: "Exterior Body Panels / Trim" Ant |
Originally Posted by FYREANT
(Post 1596337945)
Thanks, Cajun! There is still some DIY info in the older how to's in the tech section. Here is a link: https://www.corvetteforum.com/forums...-stingray.html
Go to the section labelled: "Exterior Body Panels / Trim" Ant Thanks. I see rear but not front fenders |
(Post 1596337986)
HOW TO: C7 Front Fender and Headlamp Removal https://www.corvetteforum.com/forums...p-removal.html Ant |
Man you are all over it!
Thanks man |
Anyone have the wiring diagram for the C7 Z MAF and O2 sensors. Tuning the new PTS single turbo and car wont go into closed loop. Thinking it is signal issue to MAF or O2s
Thanks |
(Post 1596382304)
Thanks |
Updated list
Added: How to remove your rear lower fascia / bumper cover for exhaust removal Ant |
Does anyone have an ECU pin out diagram for 2016 ZO6?
(Post 1596448548)
