View Full Version : C5 Scan & Tune
- Fuel Trims Gone Wild
- !!! North Carolina Tuner for 04 c5z
- Speedometer calibration
- Michigan Motorsports cam
- Connection issues with OBDXPRO-VX and PCM Hammer
- Dyno tune
- Stuttering/hiccuping "cam surge" help
- Adjusting cooling fan ON/OFF temps
- Ride Control Module 2004 #10339642
- Wonky dyno numbers?
- Base tune file in HP for AA kit?
- Will Exhaust Change Mean I Need a New Tune?
- Good tuner in the Midwest (Specifically IL)
- Tune options in central pa
- Moving target tuning for VE
- Trouble reading ECU via HPTuner
- Your One Stop Corvette Shop!
- STFT = 0 at high rpm
- ISO LS1 Dyno Tune Central PA
- How does the CA smog test work?
- Bucking in 2nd gear under 2k RPM
- California smog VS rear gear swap?
- Re-wire rear O2's for a Full Time Wideband
- Best way to tune transmission?
- Supercharger Sale! A&A, Magnuson,ECS, Procharger, Edelbrock.. 2YR 0% Financing!
- LS3 swapped C5Z in TB hell
- Stalls when cold in OL, runs great in CL
- 383 H/C/I/E knock retard
- Brakes for your Corvette - KNS Brakes
- Looking for tuner
- Car leans out while tuning
- TPS Motorsports END OF YEAR SALE !! ECS TUNER KITS AS LOW AS $4899.99
- Need vci cable that works w 04 C5 and techstream on windows
- Need a tuner
- HP Tuners 4.8.7 software
- Climate Control Unit
- Cyber Monday Deals-A&A/ECS Superchargers-$5399, Procharger & AWE-15% off, and more...
- Fuel Gauge not working after swapping in p59 from Tahoe into a 99 C5
- Questions about diablo/handheld tuners
- Holley Dominator EFI. What all does it replace?
- Black Friday Deals-15% off Superchargers, 50% off wheels, & more...
- Fuel tank gauge not accurate?
- Bose system and tune
- Open loop learning capabilities.....
- reduced engine power, no codes
- Tuners In Bay Area ‘98 C5 Base
- I made a very big change in tire sizes.
- AP Brakes On Sale Black Firday 10-15% OFF
- Mail in Tune for '98 after Headers
- TPS Motorsports Suspsension Packages as low as $499.99
- Looking for someone w/ LS1 Edit in South East Michigan (Detroit area is fine)
- New at Tuning
- looking for tuner or j tool in chicago suburbs
- Need help with a Tech 2 in Connecticut
- 2 bar MAP with stock OS
- Charged 99 vert. Performance tune HELP
- C5 2003 C1296 Error
- Rough running 84
- HPT experts, please...idle tuning driving me nuts...
- WB O2 Sensor placement
- Are these guys worth it?
- Email Tuning with Phil at Tampa Tuning
- 98 Corvette Tune Issues NEED Help
- OBDLink MX+ problems
- HPtuners, adjusting for increased airflow
- Tuning Parameters
- Boost NW102 on C5, occasional p1515.
- C5 & C6 Basic HP Tuners Tuning VIDEO
- EPA stepping back.
- Tuners South Miss
- Read my codes full depth scan
- Reputable tuners in Michigan that use HP
- Buying a Dual Wideband
- 1998 C5 custom tuning questions
- Getting odd bouts of REP Reduced Engine Power with 90mm Throttle Bodies. Unsafe
- HP Academy courses
- 03 C5 stock- want more HP
- help need tuner in Boston
- WB02 dead or bad placement?
- program shift
- dual tune
- injector drivers
- Tuning Out DTC 1214
- Exhaust smell at idle
- Two Tunes? 2003 C5 with F55 suspension
- Dyno tuning vs Street tuning
- Wideband or 2?
- East Texas or Louisiana tuner needed
- REALLY high fuel trims
- Plug & Play
- 98 corvette built 4l60e dies when put in reverse
- Local tuners?
- Tune Emission Crack Down?
- Memorial Day Sale-Superchargers, exhaust, suspensions, up to 20% off
- DIABLOSPORT tuner help shift firmness
- MPVI3 stand alone logging
- Tune Repository
- In need of Tech II scanner
- Tech 2 scanner "loss of communication" when saving
- How to eliminate Pull Key warning message - tried several options with no luck
- AFR lean under WOT
- A.I.R delete trouble codes
- DTC C0563 Code Error
- Trying to Pass AZ Emissions.
- LS6 swapped to LS3 Corvette Wiring Harness?
- I want more power
- 98 Corvette C5 Auto Dies when put in reverse after tune
- ANyone know of any reputable tuners with dyno
- Most Efficient Way to Tune Trans After Gear and Converter Swap
- Data Acquisition with Race Chrono
- Throttle position during WOT
- Supercharged C5 / Severe knock during tuning (HP Tuners)
- HP Tuners Communication
- P0103 code
- PCR chip
- Rear Diff and Converter Swap and Trans Tune
- pcm
- Inst cluster prob = No guages working
- Autel Scanner Issue
- 97 to 99 pcm swap help.
- Performance tuner for C5 near Long Beach/Torrance California
- Which Basic Systems to Change
- F55 delete.
- Impossible
- Remote Tuning Corvette Tuner in Tampa Orlando
- C5 Bouncy MAF (Log Inside)
- C5 Z06 Smog in Central CA
- HP Tuners MPVI3 In Stock at DSP Performance Motorsports
- running procharger tune without the blower
- tuner for diff ratio change
- Any benefits to have a stock 03 z06 tuned?
- C5 Corvette Tune repository thread?
- Looking for reputable LS tuner in N Florida (Jacksonville)
- Christmas Sale-Twin Turbo Supercharger Headers, Wheels, Brakes, Wide Body Kit, & more
- LS swapped S10 lean maxing out o2 sensor
- Mail order tuning...
- Is this enough processor for logging?
- TPS Black Friday Sale-Coilovers/Headers/Supercharger/Body Kit/Wheels & more...
- Jet Dynamic Spec Tuner Stock Tune Files 03 C5
- Looking for advice on timing with cam
- Factory PCM tune
- MINT 2000 C5 fob stopped working after drop
- C5 gauges
- HP Tuners versions
- Stand alone ECU questions Holly Terminator
- 80 MPH limit
- Is it chipped?
- LS Tuner in Northern Virginia, DC or Maryland?
- Car wont run on the rollers
- Looking for California "Compliant" LS6 Cam Tune
- Talk to me about DFCO
- Tuning Packages at DSP Performance Motorsports
- Tune A4 99 C5
- Tune out secondary air pump check engine light
- Tuner suggestion
- PCM Hammer Seed Key algorithm
- Radio Clock and Gauge Issues while HPTuners Logging with MPVI-1 AND MPVI-3
- GM Tech 2 Scanner Equivalent?
- Disabling Column Lock in the Tune
- Target idle AFR with overlap?
- Labor Day Sale-Superchargers, Headers, Monster Clutch, Wheels, Coilovers, Body Kits..
- Can someone look at log please
- Which tuner is right for me?
- Seeking HP Tuner in Rhode Island Area
- Wide band
- F45 delete in maryland
- Can BIG injectors be tuned DOWN???
- Convert Volts to AFR in HPT - Need Math help
- Emissions tune
- Tuning from 2-bar MAP to 1-bar, some issues with results
- Purchase HP Tuners MPVI2+
- 2004 Z06 - Supercharged / cam, negative STFTs
- PLX SM-AFR users, a precautionary tale.
- Handheld tuners
- Dyno Tune or mail order tune around northwest Georgia area
- tuners
- WOT with new Diff hit the REV limiter
- looking for HP tuners
- What is needed for HP Tuner data logging?
- Need a good Dyno Tuner in South Florida
- Software for the OBDLink MX+
- Northeast Indiana Tune Help - 2mph Shutoff
- Just an FYI for the forum, ECS will no longer offer any mail order tuning
- question about adjusting LTFT using injector slope and adjusting WOT fuel using PE
- SC area (Midlands or close as possible) Tuner & Mechanic
- help water temperature problems.
- Need Help, AC Compressor went.
- PCM VIN Flash
- C5 Z06 intermittent power loss, what to look for on data logging
- PCM Swap Question
- A4 tune drive mode selector?
- c5z06 with ls2 stroker, tune ok?
- RICH and not money either
- Fuel Trim and O2 Issues on 99 FRC
- Kern County Tuner
- Looking for tuner to edit my tune file virtually.
- 2004 GTO LS1 in 2000 Corvette
- Pot Hole -> ABS issues
- Stalls/dies when coming to stop
- Tuning help dc area
- Tuner in Grand Rapids Mi
- "desired" MAF airflow 50% under "actual" airflow.....
- How's this look?
- Tune Help
- Making more boost than anticipated
- 2004 z06 will not accelerate after intake manifold/LS2 throttle body
- intune i3 93 octante tune - should I adjust any parameters?
- Tuning
- Fuel sensor readings using HPTuner
- 1998 PCM reputation
- Scary news out of Cobb - Any word from HP tuners about emissions compliance?
- 99 a4 coupe transmission tune
- Mods that require tuning
- ECU PID numbers
- Which PCM is in the 97-98 C5s?
- Require Bin file for 2000 C5
- does an ECU swap require dealer flash?
- I’m wanting an e-tune, options….
- Nick Williams 103
- Dyno Types?
- Engine full of carbon after fresh rebuild
- Memphis Tech II
- trouble Reading and clearing Dia codes
- TECH2 no comm
- Vats 2mph cut off location in hp tuners
- Unusual No Start Condition
- mail order tune
- Decel and light throttle low speed help
- wideband gauge
- Injector data for 12561462/LS6 injectors?
- Request: C5 ASA cam file
- How do i find a tuner that runs EFIlive?
- Good crank, slow to fire
- What does "scan & tune" mean?
- Any way to adjust engine coolant fan temperature settings?
- OE Cam Specs needed !!
- Things to Consider in New Tune
- DBW Throttle Speed Increase
- Does ecochip work or just a gimmick ?
- basic Tune for 3.15
- Very unusual A/C issue.......
- ls1 mail order tune
- Any way to read Odometer when Driver Information Center is blank? Scan tool?
- Cam and tuning in Bowling Green KY
- Tampa Tuning.......
- Where to get E85 tune for P59 PCM?
- Which fuel pump?
- Proflex E85 Kit and Water/Meth with Maggie??
