View Full Version : C1 & C2 Corvettes
- Show time! Pictures!
- Engine Number
- 64 250 HP stumbles
- Picture of a shipping crate.
- New garage find in France !
- Fan clutch
- C2 Repair shops near Sugar Grove, IL ??
- bolt on knockoff question
- What happens when engine mounts go bad?
- Radiator support, shroud and radiator.
- didnt think it was possible
- Traveling tomorrow for '64 retrieval!
- Mid year hardtop header vinyl replacement
- Radio
- C2 wheel alignment
- Trim Tag Rivets
- Happy 4th!
- West coast info
- 63 swc a/c
- C2 restoration/repair shops Aurora IL area
- Not sure what's going on
- Didn't see Corvette on this list
- strut rods
- Bloomington Swap Meet
- Happy Independence Day
- 327/365HP Restoration Question
- Where to get a new interior installed??
- Another Holley replacement thread
- C2 vette vintage air 12V source question
- Need knowledgeable C2 person for inspection
- My YOM CA Black Plate and DMV Experience
- I will just keep my C1 & C2
- Need Help To ID Engine
- Gas in cylinders
- Noisy M20, torn shifter boot?
- Carpet oil stain 1959 Corvette RED
- How do you change out the battery c1 1959 Vette
- 58 - Holes for side trim question
- Carlisle sent me Booth space info today
- '56 exhaust bumper Removal
- 63 Doors Cut Up
- Vbp's july specials
- Painting manifold with silver paint?? 63 340 HP
- Happy 4th of july
- cleaning/re-dying dash pads
- Soft Top ?
- Detroit Area AC R12 help?
- '61 Soft Top Lid
- Shoulder strap guide install help, 3 Point belt conversion 63-64 convertible
- Willcox 4th of July Sale Starts Now!!!
- Need email contact
- Free Shipping Offer from Corvette Central
- What Engine Do I Have?
- Heritage Certificate
- Black phosphating at home
- 63 hardtop mounting
- Leaks
- hood and trunk question
- Pics of stock 64 radiator- L-75
- 66 side emblems
- Rookie question - out of state purchases
- Sidepipe covers
- c2 birthdate
- Autolifter/All American lift (need pulleys)
- '67 Centre parking brake on a '64?
- OK license Plate
- Your Opinion Please
- Dry Ice Blasting
- 3M Paint Defender
- Question about fan on 57
- Grand Sport #004
- throttle return spring attachment question
- Glassworks hardtops
- 67 Fan Clutch Restoration
- 63 PB/Metallic Brake shoes question
- convertible top replacement questions 1965
- Sand Blaster?
- 427 Hood numbers template
- Totally random, multi-year pictures from Bloomington Gold...
- Question about earlier HP ratings
- How difficult is it to explain your cars condition ?
- Evod wheels.For resto 60
- Looking for 3782870 block and other 1963 340hp stuff
- Corvette Club of Hawaii, 40th Anniversary...
- 63 is on a truck to Cali!
- Info on double Hump heads
- Trying to find some history on my 56
- Those with SRIII chassis builds in C2, where and how did you locate the battery?
- tach install on my 61
- Inspection help in Tampa?
- 66 Corvette Torq Thrust D's
- New C2 Owner with Resto Questions
- Shoulder harness reinforcement plate location
- Will Fiberglass melt at this Tempurature?
- early sept,oct 63 hood rivets for hood rear pins
- Old License # vin look up
- 1963 Grand Sport Racer at Bloomington Gold MANY PICS!
- 3855962
- C-1 Vin Tag Question
- LS Engine Mounts for Original C2 Chassis
- Weatherstrip adhesive on 63 doors ?
- 66 coupe rear windo reveal clip location?
- Front tires pitched out on top
- Searching
- What do these steel GM wheels fit?
- Just Joined
- Willcox Summer Sale
- New garage companion for SWC....
- Wiring problem
- L79 327 build up, what carb?
- insulation
- Vin tags and new frames
- My most personal design - Parents will understand.
- C1 body dolly specs / measurements?
- 67 coupe 16517 owner, I have some docs
- Adding 1958 fender reinforcements to 1960
- June 28, 1953 was when the first Corvette came off the line...
- Windshield glass repair
- Bloomington Gold where were you
- Steel valve covers to aluminum V.C. fittment issue
- Well.......
- What is the best oil to use in a rebuilt 327 ?
- No Start
- intake manifold oil leaks at center bolts - ??
- C-1 Zip out window
- Brake issue, and Q2, what is triangluar plate pass side under & how does it bolt up?
- hole in cross shaft seems to be oval
- 60 Restomod
- Shipping Parts From Carlisle Show
- Corvette B-Day
- Carburetor suggestions
- What did you pay for your 1st Corvette
- Need floor mats for my 67
- license plate restoration
- Hard Start - L76 - 327/340
- Thinking About Selling My Frame
- 57 vette radiator and vacuum advance test
- safe method to remove old tags from a license plate?
- gears
- 67 Adjusting Rear Ride Height
- Mecums Bloomington Gold Auction Results
- 56/57 rear bumper modifications sought
- alternative to evaporust
- Tach ?
- help diagnose overheating problem...
- Bloomington Gold show
- Header leak
- Keeping cooler with the soft top up c1 using straps with hook & eyes
- Vbp's discount for forum members
- Happy 60th Birthday Corvette!!!
- Parking Pawl problems
- 65 suspension and safety build help
- Idle Adjustment 1967 427/400
- My 1965 Steers Like a Dump Truck; Anyone Else on NO PS!
- 1966 TANKER....is it real????
- 1CoolC2 is For Sale again as a 63 ?
- first oil change
- Problem with new rotor/caliper rubbing on pads
- Need AC advice
- 1957 Corvette Fuelie up for sale at an Estate Auction Tomorrow in Minnesota
- GM Break in time of engine?
- Vinyl hardtop
- Anyone buy a yellow 65 in durham....
- 67 427/390 carb gasket and shim question
- Splash shields remove run cooler in a C1
- Dip Stick
- Project 63 Re-paint Progress
- Replace the chalk markings on my frame
- Door Latch Removal Help Needed Please
- 1965 327/350 carb gasket question
- Opinions on Grand Sport cars.
- Replacing Trailing Arms
- Do brake calipers with stainless steel sleeves leake?
- 11" clutch
- Another C1 door leak thread
- ***FRIDAY FUNNIES***for the weekend
- '67 steering column bearing change?
- Local Car Cruise in
- any pics of 63 hood weatherstrip installed?
- Hard hot start #2
- garage floor well for Mid lift Bendpack?
- Another wiring ??
- horn beeps when turning left
- Clutches..What do you recommend ?
- WTB 61 Corvette Carburetor
- Need 63 SWC Tach&Speedo Function Restoration
- 1955 #008 Restoration
- 1960 - radiator shroud
- C1 door adjustment
- Console/ seatbelt retainer
- fuel pump problem...no pressure
- Engine Paint ???
- Not the Usual 'Barn Find'
- New Owner of a 1964 Coupe
- Dash harness
- car SALE advice from my friends here PLEASE read
- Do i have a early or late model 1964 coupe?
- Video of 1964 concept car competes with the Corvette?
- Back to Bloomington
- The Ultimate Barn Find?
- Carpet Cutout question '66
- How to address Street Shop pulley system issues on LS3
- Engine Pad Numbers Opinions
- aluminum heads
- new to Corvettes (looking at a 54)
- For the 63 purists
- 63 SWC Stainless removel
- 400 sb crank install
- 1961 gen driven tach cable
- Motive bleeder
- Wheel Tire Fit
- How much does a C2 Body weigh?
- Rear Strut Rod Install Question
- Identify 67 Transmission Type
- Brett Vette Daddy 55 Pics you requested.
- 1955 heater core
- Need advice on Vacuum Advance hose on Holley 2818
- Bloomington Gold Update....
- A/C question
- Hello from a new guy looking at his first vette this week!
- 56/57 eska kiddie corvette pedal car
- Help needed from engine guru's- 66 L79
- 3:70 Standard rear convert to Posi??
- Leaking steering box
- Did You See The Newspaper....
- 1958 lower stainless to body gap
- L79 harmonic balancer
- Happy Birthday
- 1-3/4 headers for small block
- Lapping Watkins Glen in a 65 Corvette BP racer
- This can't be good.
- How to tell an original front clip from a jig fitted replacement?
- short block search
- C2 L79 Engine Stamp Confusion
- Teakwood wheel
- Seeking opionions on gear ratios - '64 365hp
- Mayber JohnH (Z) knows - Cluster Change
- paint question
- Pulling the Tach on the '64
- E-Brake cable connection
- half shaft caps and bolts
- how many straight axle projects out there?
- Need new wheels and tires for my 65'
- 1962 exhaust
- C-1 restoration chrome and Trim
- c1 gas tank differences
- Can you.....
- Treasure trove of low mileage Chevs (for auction)
