View Full Version : C1 & C2 Corvettes
- L72 intake manifold refinishing/reproduction options
- C2 Parts
- looking for nice ride .
- I'm thankful and grateful for the help I have received from the members of this forum
- Harmonic balancer
- VB&P mystery spring rate
- C2 66 427/390 correct bellhousing
- Right Side Mirror Alternative
- Points/Cap/Rotor Inspection Pics
- AC Delco points Heads Up
- 1964 corvette trim tag
- 1963 GM Corvette Promo Film
- SVRA event at Watkins Glenn - Corvette Featured
- 66 450hp l72...
- Pulling rear end
- Heater Control Valve
- Ballast Resistor. Think it's toast?
- 57 posi rear end
- 327/300 4-Speed Dyno Results
- C1 Your senior experience
- C2 fan shroud support
- C2 1963 Roadster - Keep Period Correct-ish Or Restomod?
- Need mechanic
- C2 Fuse Panel Replacement
- C1 59 Vette
- 67 Stinger hood vinyl instead of paint
- Installing battery in C1
- C2 no headlights or tail lights or park lights
- New to me 64 Coupe
- Spark plugs
- Smoking on right side
- C2 Charging Issue
- 1966 Power Steering Pump Bracket Attachment Position To Engine Mount
- 2x4 carb wcfb accelerator pump adjustment question
- Somebody looking for old tires for display?
- C1 Water in door
- Door Panels - how to identify year
- C2 Real Knock Offs vs Bolt On Look Alikes
- 1955 Gauge removal
- Rear tire movement
- C2 Installing 63-67 License Light / Lamp Assembly - try not to laugh
- C2 63 SWC Finally Arrived!
- 61 trunk drain tubes wrong size
- C2 Automatic transmission Fluid
- Wiper Switch Catastrophe
- C1 high oil pressure
- Help Identifying a Wittek Clamp
- C2 K66 coil
- C2 Quick Help with 63 dash harness
- C2 427 Casting number
- C2 headlight adjustment wheel lock washer
- Supporting vendor
- why does my 54 corvette keep eating speedometer gears
- Online Burnout Contest
- C2 New Wheels, New Tires, Hangin' with Some Cool Cars
- C2 Big Block with side pipes and TI cold start
- C2 Shifter installation problems stock Muncie
- Got Gass ? Wylde 63' Gasser from Mongoose . . .
- Yenko corvette question
- Big thanks Dash and door rails recover
- C2 7th Hole in 327 Block--Bellhousing??
- C2 Fender Question
- C2 1967 Coupe teal interior question
- C2 Past owners of my 1966 Corvette
- C1 Considering buying a 56. Is 57 better choice cuz of this
- C1 62 Back on the road
- C2 Big Block Casting ID
- C2 Finally took some pictures of my '64
- Electrical Issue Found (Wire Short) Q's
- C2 427 pad numbers & broach marks help
- C2 Is this the correct power antenna
- Rocker Panel Restoration
- Brake Spring help
- C1 54 Real Pennant Blue - paint update -
- 67 wiper switch question
- C2 Does 65 have the vin stamped on powerglide?
- Problems after Distributor rebuild
- C2 Rear License Plate Area Aluminum Bezel. Original or Repro?
- C2 Worn Carpet
- C2 Ammeter/ battery gauge removal
- Whether to install harmonic balancer sleeve
- C2 C2 Muncie rebuild or swap
- C1 Third arm bearing
- C2 Do awards really matter in the end?
- C2 Dent in glove box door
- Filler tube hiding with aftermarket tank
- C2 Gift To Myself - UPGRADES
- C1 Oil pressure conundrum
- C2 SPAL Fan Temp Sending - How To Also Connect to Temp Gauge?
- '60 bellhousing
- C2 A-arm help
- C1 Honored the previous owner of my car today
- Old enough to laugh and cry
- 65 L79 Coupe Project - Thinking of Selling - Thoughts on Value?
- 1963 Red / Red convertible 340 hp
- Forum complaint:
- Size and type threads on the bolts that holds the battery tray with factory AC
- C2 1966 aft wheel well and # 3 body mount questions.
- c2 control arm bushings
- C2 Typical time between bb block casting and production
- Hardtop Anchor (3)
- C1 Help identifying hose clamps
- Conversion back to rear exhaust
- C1 Opinions on what my '60 might be worth, please.
- C1 Vin
- C2 tie rod sleeve clamp install question
- C1 Air cleaner for 5 1/8 carb
- Engine head
- 59 door panels
- Need state of the art tire info.
- C2 Steve Stone. “Back to 50’s”
- Question on power windows for 67 Coupe
- 66 Nose emblem placement
- 1966 expansion tank cap
- how do you install the trans cooler on 1963 Roadster
- +-*+-*Friday Funnies +-*+-*
- No birthday party for my '64
- Steel Wheel I.D.
- 66 Dash removal
- C2 Which spark plugs to use with aluminum heads
- Converted from flat tappet to roller cam - what oil now?
- rear cluster decal
- C2 Looking for anodizer in CA or midwest to strip, polish & anodize some rocker panels
- C2 Trailing Arm Refurbishment
- Need Engine shipped
- C2 Diamondback Touring vs SS
- Ceramic Coating/Paint correction
- Help with a 1965 Corvette
- C2 TRIM 898B on 1963, what interior is that?
- 1965 Coupe with LS2 no sell on BAT
- C2 Paint protection advice needed for long road trip
- 1963 convertible top 1st Bow
- Newly acquired 63 Vert - What to do?
- Jump Starters
- Need to buy 67 Convertible Top Frame
- tach cable routing on a '61Fuelie
- 64 exhaust vent fan
- Early vs Late 1963
- Adapting Fiero seats to 67
- Sleek 1958 Corvette Restomod Looks Like the Past and Future
- A Beauty
- C2 Original Teak Wheel Yes or No
- Pargon and Corvette Central joint forces
- inop. 40083 fuel pump
- 63 roadster WIW
- C2 Odometer Question
- C2 VIN Tag Location
- C2 1966 Mosberg Green: Help with Value Assessment
- New owner, 1965 barn find vert with factor air
- Frame stencil assistance
- C1 Front Main Seal Change Question
- Trans Line Up Dowel?
- Another Article in Vette Vues!
- C2 How to edit an existing post for parts
- Shifting Into Reverse
- C2 to those of you with a TKX, etc.....which handle?
- C1 To paint or not
- C2 Vansteel rear trailing arms
- Quick jack 5000TL questions
- Return 1967 automatic back to original 4 speed
- C2 1964 Coupe Exhaust fan
- And again- car will not stay running.
- C2 Looking for rear bumper installation tips (Question #2)
- 59 Vette
- 63-64 kelsey hayes knock-off Wheels
- C2 body mounts
- I'll never use a pickle fork again!
- Seized bolts
- C1 Al Knoch Soft top choice question for 57
- C1 1962 Corvette Trunk Liners
- C2 Ballast Resistor
- Anniversary celebrations in the UK
- C2 Rear exhaust hangers
- 1954 valve adjustment And push rod removal
- C2 BB starter for 1966 & solenoid
- 1967 SB Tach Cable
- Happy Father's Day
- C2 raised dot on hood surround trough
- C2 Pors15 on floorboard?
- Glass on the grass
- Anyone know what this noise is??
- C2 Exhaust Heat Riser Gasket Issue
- Back to the Fifties - 2023
- C2 Parts ID
- C1 Packing a FI unit
- c1 corvette hardtop stainless exterior trim?
- C1 Headlight Gemlin
- C2 circlip & washer on '67s carpet came from where?
- How to apply vinyl refinisher
- C2 Rear blower control location?
- C2 Ignition shielding
- C1 ignition switch
- C2 Instrument Cluster Cut Out / Notch
- 'very wobbly inside rear view mirror on my "58
- C2 When they say caliper lip seals "relax"... Wow!
- C2 Happy 58th Birthday!!
- C2 Muncie choices
- C1 Tremec TKX install tips needed
- full blown chassis or update original?
- 1965 Barn Find Convertible Questions
- C1 Vintage Racing
- Asking For Your Opinion on This 63 300hp 4-Spd. Roadster
- Damaged frame, advice needed
- Battery gauge and wiring help reguired
- C2 Muncie heat
- 62 Maiden Voyage - Of Sorts
- Induction heater tool
- C2 fuel gauge
- C2 63 seats
- 67 Fuse Box/Block Replacement Q's
- would you rather have Original Paperwork or the Original Mortor for your car?
- 67 Harmonic Balancer Fins or Not
- C1 USA made third arm bearing??
- RPI's Summer Kickoff Sale! Enjoy a fantastic opportunity to save 10% & free s
- C2 Identifying a 65 396 Oil Dipstick
- Diamondback redline tire ??
- Battery Dead Overnight
- Coil differences 202, 087,091 etc
- C2 What's the best black paint to use when restoring 1967 rocker covers?
- 63 Fuelie High RPM "miss/stumble"
- C2 Need help identifying a Carter AFB Carb
- 64 L84 - #202 coil?
- Numbers Matching? Why should I care?
- C2 Instrument Cluster Tape
- C2 Adding AC
- C2 Let’s see your C2 projects
- Is This a Re-stamp?
- Bellhousing dowel removal
- Differences between SB Winters intake manifolds?
- C2 67 bolt on wheel cap comes off when driving
- Hei coil
- ignition switch
- Mold rubber hose with tubing bender & heat
- C1 Front end adjusting
- Ohio Inspector
- C2 Bottom panel tab.
- C2 Bill Mock's water pump business
- C1 Aftermarket power window question
- C2 "Big" cams, cam advance, timing, and balancer walk
- C1 wiper WASHER squirts once, must unhook to reset
- 1962 Restomod hydraulic clutch
- C2 Radio
- C2 Happy 56th birthday
- temp gauge switcheroo 64 vert
- Dan Young Judging School
- 67 Distributor wiring. Its there a Ballast Resistor?
- C2 1966 SB Correct Air Cleaner
- Panel unbonding
- C2 Disc brake pads and brake dust question
