View Full Version : C1 & C2 Corvettes
- >>>>>>> St Jude Auction #47 One of a kind fixed blade knife <<<<<
- Fair Price for 1966 BB exhaust manifold set
- Ringo Starr
- '67 Hardtop weather strip set
- Brighter lights for C2 instrument cluster
- Shorty Headers
- Super-Newb needs some help on possible purchase
- Fuel gauge troubleshooting:
- What to do with undercarriage
- Brake lights don't work!
- 1965 L76 engine 365hp/327 cam spec
- 63 327 turbo fire valve cover decals
- Sidepipe Upper Trim Attachement
- Wipers and windshield washer not working
- First timer at Thunderhill 3 mile open track!
- Update on misaligned pulleys & thrown belts.
- Carter carb help please !
- How to check rear end bearing play
- Head gasket
- new member wiw 57 f.i.set-up
- Front Suspension Make Over
- Back to electrical question/problem? C1
- Alternator took a dump, which one to buy?
- Bought new parts, installation blues
- What do u do w/your dash plaque collections?
- I can't believe it's gone
- Outboard Carb Flooding on my '67
- 1962 factory tach rebuild
- 1960 Dual Carbs
- Rust Prevention on C-1 frame ...Kroil?
- Corvette enthusiest....we are very lucky!
- 1963 Coupe Hood Question?
- seat installation - guidance
- C2 Stainless Steel Windshield Mouldings
- C1 Engine/transmission
- Pin Up Photos
- Rebuilt 58's
- Barn find Corvettes
- Hitting the road for a little 2000 mile drive in my '62 :)
- Weber 4 side set up for Vette
- By-pass Hose removal??????
- 67...Opinion, what would you do?
- Installation of lifters - L79
- Picture of BB rad support A/C seals?
- Correct date engine block
- Windshield Post Seals
- Watch that first Turn
- New to forum & Need some advise
- Tank Sticker
- satisfied customer / CC
- Fuse size amperes for cigarette lighter
- Newbie needs help with possible 67 C2 purchase
- Alternator powered in "Accessory" position
- 1953-54 distributor, vacuum advance
- Heater box and bolts for battery access panel
- help 327/300 hp postive crankcase ventilation
- Keys and Locks
- C1 Steeroids installation with many photos
- 327 exhaust info
- Door Fit – Need Advise
- Battery Drained...
- Alternator/voltage reg wiring
- what is your C1 floor temperature
- Anyone in Orlando who could check a C6 for me?
- AC centre bezel
- PG, Turbo Glide, Turbo Hydramatic
- 61 wiper transmission saga...
- Its Friday:Time for a smile
- Borgeson Steering Hitting Lower Control Arm
- Tank Sending Unit '64
- HELP!!!! Hard to crank when hot
- C2 Radio upgrade.
- Corvette at Carlisle 1st time to show vette
- Brake fluid leaking
- 1961 Clutch 'creaking'
- AAARRRGH - Part Inventoring SUX
- 61 From Above
- C1 - Resetting Rear Leaf Springs
- Sources for deep groove pulleys?
- Trans jack from Harbor Freight
- parts fair value SWC
- NOS 327 crate short block - photos
- Considering front disc conv need advice.
- JET-Hot Coatings Sale!!!!
- NOT Corvette, but very interesting.
- 25 amp fuse in 20 amp socket
- 1963 Corvette from Harry Mann
- The journey begins 48 States
- Changing door glass rear and upper channel 64 Coupe
- spark plugs
- Anyone deal with Harborvette in PA.
- Project 396 Road Trip
- Vinyl seats are horrible....ya think!
- Question about Carlisle
- 67 steering damper bushing
- C1 carb questiion
- Spicer U-Joints - How To Install?
- Cutting Corners Does Not Pay Off
- Need help with Suffix Code
- C2 audio
- C1 corvette painter NY area
- Race Ramps Group Buy
- How can I tell if Power Steering was factory original?
- Looking for Joe Fisher, or an answer to charging problem
- Radiator Hose
- Radiator Hose
- 66 Electrical Help Please
- Jay Kline Chevrolet
- Gravity bleeding the brakes
- May be an old question on tach drive dist
- NHRA Drag Races @ Infineon 7/3/10 fun pics
- Throwout bearing problem?
- NCRS National Meet
- what is a fair price for clutch replacement?
- Control Arm Shaft - Backwards??
- 66 under hood insulation?
- Hollander Manual anyone?
- Pic of heat markings on my hood at Infineon Raceway
- Front coil over conversion
- Flops Then - Collectible Now (No Corvettes)
- do you have a puke tank for your BB radiator?
- Verifying previous ownership of 64 Vette
- Body lift straps
- AFR Tuning
- How do you remove the shifter arm from a Hurst shifter?
- new brake lines C1 front disks and rear drums
- Any Experts Near Chicago?
- 1972 Chevelle Help
- Car polish / wax
- Casting dates and broach marks
- Heat sink issues on 64' 327-365?
- C1 with power steering, Thanks Speed Direct
- Spare tire fit question -
- Body Mounting Diagram
- Thanks Tom at Wilcox
- OK, so what's the weather looking like for Bowling Green next week???
- 1967 Baldwin-Motion, You know the drill on "barn finds"...............
- Long tube headers and ground clearance
- WIW 1960 Corvette
- What and Where Are The Rules ?
- Would like picture of panel behind 66 seats
- Front to rear brake line
- Hooker Sidemount Headers & Sidepipes Installation Complete
- Starter armature
- Typical mpg for a '57 with 2x4 carb.
- painting sidepipe covers
- My Vette - The Early Years
- Blue Flame short blocks
- L79 Fuel Pump
- Help 1959 Wipers wont turn off
- Head Lights on a 56/57
- I give up
- Muncie tail housing leak
- The expected 5 can answer any question
- Removing Rear Rotor Rivets
- 67 Turn Signal Switch Help
- BB starter heat shield
- My 62 in Church
- 64 Coupe partial car cover
- C2 Hood Removal Question
- I agree with Al
- Should I need a claw puller to remove the crank sproket?
- headliner fell
- Ballast Resistor Measurement
- Fan blade and spacer on a 62
- Pacific Northwest Historics pictures
- T-350 question
- Vintage Races (photos)
- 327 in my 59 runs hot
- 53-54 Speedo Drive Gear Help
- used 1960? door arm rests - FREE TO GOOD HOME
- Cerv1. Did Corvette almost enter Indy car or Formula 1?
- 1958 fuel tank install
- start up after long sit...?
- This year's B/G Auction
- Ignition Shielding
- C1 - steering box "I feel that tingle down my leg"!
- Here's the Blue.. Who's got red and who's got white? Cool Picture of my 67 Sting Ray!
- Help...I cannot find the cause for missing
- 6 Tail Lights
- 1967 Windshield gasket replacement in Chicago
- 1962 front parking/signal lights - Repair or Replace?
- how to lead a proper parade
- Master Dave, I disagree.
- New owner of an old Vette? Please buy these books...
- Corvette Expo in Houston tx.
- coil
- Happy 4th
- Console Cup/Junk Holder
- Carburetor Replacement Recommendations
- lower LH vertical shield bracket
- Where does this electrical connector attach
- Mecum - Fiberglass Body Keeps the Heat In The Car???
- Installed M&H Electronic Ignition, won't start!
- Previous Post On Dash Covers / Protectors
- Trans lube recommendations.....
- Rubber Fuel Line from Tank
- Doing a 69 top, Advised no H2O in the Radiator
- Heater Box ...Will It Fit ?
- What calk is best for sealing the gas tank cover panel on a 60?
- It's on the road!
- '59 lost front end lights
- '63 coupe windshield weatherstrip
- Ever heard of a Corvette Centurion?
- Early PCV breather question
- Strange Story
- Car Inspection in Detriot
- Check out the HOE
- Looking for anyone from Cleveland/Parma area
- tach install 1958
- Corvette Carlisle swap spots available-Reduced cost!
- L79 cylinder head locating dowel pins
- What a pain...need some help...
- No vette auction at Carlisle again?
- Parts washer solvent type
- Best place to take IR reading??
- 1968 425 question?
- Maroon 1965 396
- suspension question
- Corvette Central - Wish List???
- Re-size larger?
- Insurance
- I know! I know! Ford Guy with a Corvette Side Pipe Question?
- 63 Fuelie Hood Grill pin above Fuelie unit
- Battery cutoff.
- Tuning FI with Wideband O2 sensor
- Anyone in Talahassee to check a car out
- C2 Hardtop headliner removal
- Hammer the balancer on?
- if you're attending Corvettes at Carlisle this year
- An early start to FRIDAY FUNNIES!
- Tailight assemblies
- Probable water pump seal leak 1964 327 convertible
- Setting the clock problem
- 327 shortblock question
- AC temp
- 63 Coupe Door Pt. # ?
- Best Interior Packages?
- Elec. Questions
- Classic Car Insurance
- OMG, What have I done...Electrical Problems
- '63 SWC fulie barn find
- Car show pics from last weekend
- GS Replica On Ebay
- Anyone Have Any Info On This 66 For Sale In Monee IL?
- Seat Guide Reinforcements
- Grand Sport 1963
- Pictures of inner fenders wanted
- Radiator flush to remove brown sludge
