- FLASH SALE! One Week / Many Brands!
- Z06 boost gauge cluster work on grand sport ?
- A&A V-3 TI Tuning Questions
- Alky meth kit
- 600whp on ‘17 Grand Sport
- 950 whp with maggy and factory rotating assembly?
- High side fuel pump lash
- A2A Race Procharger Intercooler With A&A Supercharger Kit
- Maf IAT / BARO breakout harness
- Doing a cam.. C5r or C7r timing chain ?
- 2017 grand sport lt1
- What’s the real deal with heat issues with a Magnuson on the c7?
- From SCAM to 1500HP Procharger F-1X
- 416 build
- Stingray w/ Superchager Traction
- Correct belt size for Magnusson 2650
- rear tire input
- Cheapest New Magnusson 2650
- On the fence
- CPR C7 Radiator tank's in stock!
- Turbocharger options/advice???
- Rear wheel/tires for 1200WHP
- Magnussen install while keeping custon headliner in place?
- Big bubba bov
- Oil ingestion issues and the proper way to address them
- Supercharger Sale! A&A, Magnuson,ECS, Procharger, Edelbrock.. 2YR 0% Financing!
- Swapping Tunes between Meth Injection and No Injection
- Anyone Running High Boost / HP with Stock Cats?
- Balancer Pulley incorrect for Procharger Install
- Is this supercharger still good?
- ECS Transmission cooler bracket HELP!
- North Carolina tuner
- Brushless fuel pumps and controlling them
- Dyno Stage 1 Edelbrock Supercharger #1570
- Procharger Race Inlet on A&A or ECS Kit
- Brakes for your Corvette - KNS Brakes
- LT4 Heads Different?
- What size throttle body for 2650?
- Front bumper fascia air deflector (belly pan)
- 2650 Pulley?
- Stingray ECS - Meth or no?
- Wiring a Lingenfelter to a Holley progressive controller.
- maggy 2300 bricks leaking
- V3-Ti and 416 setup
- TPS End of Year Sale-Headers, Superchargers, Coilovers, Rollbar, Seats, & much more..
- Adding a turbo to stock stingray,parts recommended?
- Vortech v13 supercharger
- Magnuson 2650 or A&A?
- Steps to 1000 Horsepower
- Cyber Monday Deals-A&A/ECS Superchargers-$5399, Procharger & AWE-15% off, and more...
- ECS black Friday sales 2023 are in full effect until December 1st!!
- How much WHP can I run “safely” on current set up
- Black Friday Deals-15% off Superchargers, 50% off wheels, & more...
- BLACK FRIDAY SALE is ON. $600 OFF!
- Two CPR Built C7's in the 7's!
- Enough crankcase ventilation?
- Attack Blue Air Filter
- hood replacement
- C7 LT1 Supercharger Only
- total cost to have SC installed on C7 ?
- AP Brakes On Sale Black Firday 10-15% OFF
- Finally broke 200mph in the 1/2mile
- Gates Belt Size for 2.3 upper and 18% Lower
- bigger light for methanol
- TPS Motorsports Suspsension Packages as low as $485.95
- Stingray Build
- Magnuson 2650 LT4 Corvette Z06 as low as $6840
- Primary O2 Sensor Wire Length?
- C7 LT1 With Maggy 2650, Meth, LT4 HPFP & Injectors
- Weld laguna beadlocks 18x10.5 r / 18x5 f (c5, c6, c7 narrow body)$2195
- Maggy 2650 Boost Pressure With Headers?
- How much power!?
- Magnuson TVS2650 Promo Video - Accurate Or False
- Are Long Tube Headers with X-pipe really worth it?
- IAT Location
- Mighty Mouse catch can installation w/ Procharger
- Procharger Pulley Size Question
- Catted X-Pipe With Forced Induction
- Billy Boat C7 Tri-Y 1 7/8" Long Tube Headers
- Air intake help on lt1 Magnuson 2650
- Are LT4 injectors sufficient for 600+whp with LT1 stock pump?
- Gauge for MAT or IAT.
- 2650 with 18% lower
- Engine code P129D and P12A6
- Big Red Bov Vs 2 50mm tial. “22-23psi”
- This weeks builds at ECS, forced induction for C5/C6/C7 & C8 Every gen we service!!!!
- A&A supercharger VS Warranty
- A&A install on 2016
- 693 whp on e50, SC, LT4 injectors/HPFP, no meth
- Belt? Heavy duty vs regular belt “Centrifugal guys”
- Air to water intercooler piping size ????
- Procharged Stingray spikes rich at 4500 rpm causing stumble/boost break up
- LT5 supercharger boost control
- Tire options for supercharged c7
- Lowered Compression LT1 Fueling & Questions/Advice
- alky Meth issue maybe ? 2016 Stingray LT1
- LTR has arrived...
- Procharger for Stingray Low Boost
- Turbo C7 Grandsport questions,
- 10 Rib procharger/a&a/Ecs etc. belt
- Red Maggie 2300 is back in the engine bay
- Vortech impeller damage
- Super Charger Opinion
- Sent my 2300 Maggie for a refresh/refinish, its awesome looking
- Magnuson 2650 pulley combo and 10 rib question
- Stock C7 Stingray
- 2300 heartbeat owners need some help !!!
- 14 Z51 Failure points
- Stock Z06 Supercharger Query - porting
- ProCharger F1A-94A Cooling on Z06
- Memorial Day Sale-Superchargers, exhaust, suspensions, up to 20% off!
- Extra Boost PSI with 2.30 Upper Pulley
- Anyone had a LT4 2300 HeartBeat apart?
- Callaway 627 Runs Rough but Idles Fine
- Procharger open bypass valve
- More C7 trunk tank's in production!
- C7 Procharger P1x and stock injectors?
- Would you suggest I upgrade my ProCharger to the F1A-94 or would it be too much?
- Stock c7 a&a supercharger.
- High lift (.700) cam make alot of valvetrain noise?
- C7 cam build
- C7 LT1 Stock Fuel System Upgrade - Help
- Lt1 Magnuson 2300 75mm pulley how much boost
- Supercharged at 60k?
- Nitrous Setups
- Stock C7 Intake to Jake Box Question
- LT4 supercharger install on LT1 instructions
- ECS Novi Kit differences between 2014 and 2015+
- Maggy Upper Pulley Size VS Boost Chart
- Hood Insulator (GM 84016133) Fitment with 2650 SC
- Supercharging stock heads
- Anyone able to beat these 1/4 mile numbers?
- LMR Build
- K&N on forced induction
- 02 Sensor Problems
- C7 LT4 Toohighpsi port injection
- World's first supercharged C8 Corvette
- Your #1 Parts Dealer for your Corvette!
- Open air box got me 25whp!!! but Why?!
- Centri recommendations for GS
- Procharger Dyno Tune PCM OF NC
- 2014 Stingray, lt4 supercharger conversion kit minus s/c?
- Crawford Racing Picturess
- Another 2650 Post
- Heat Exchanger Fan NON-Existent?
- Best tire for a 1,200 hp turbo c7 z06 that I will use on road courses
- What aftermarket intake fits the Edelbrock Supercharger?
- Is 18% lower pulley too much ?
- A&A Head Unit
- Primary Cats are Toast
- Pulley Size
- Review Edelbrock Supercharger Stage 1 Canned tune dry sump
- BTR Stage 1 Gen V LT Supercharger Cam Thoughts for Daily Driver
- Superchargers DSP Performance Motorsports has Them!!
- Methanol in the DFW area?
- Any issues running green cats with a supercharger?
- Edelbrock or A&A supercharger?
- Can Edelbrock SC Handle Track Day?
- Intake tube collapsing…
- Mantic Triple Disc,,, who has one in stock
- 2023 New Year SALE!
- Step Down Colder Spark Plugs
- C7 GS Edelbrock Stage 1 Dyno Canned Tune
- LPE injectors/pump or Port Inj?
- Looking for a Z06 / LT4 crankshaft
- Twin Turbo original bottom end c7z beats them all.
- ECS shipping times?
- What issues can a broken BOV spring cause?
- Magnuson Heartbeat SC install
- Catch Can w/Edelbrock SC MAP/PCV FIXED!!!
- Christmas Sale-Twin Turbo Supercharger Headers, Wheels, Brakes, Wide Body Kit, & more
- CatchCan T up to Brake booster Line?
- Alky Kit
- C7 Lt4 and 2650 Maggie Battle it out for the win
- TPS Black Friday Sale-Coilovers/Headers/Supercharger/Body Kit/Wheels & more...
- Big Bubba BOV adjustment?
- Let the smoke out!
- Whipple 3.0
- Step Down Spark plugs w/o tune
- Step Down Spark Plugs install after tune?
- Procharger Box needed
- Another ECS build by AMP
- Digital boost gauge vs Mechincal
- TPS RPM Headers Inflation Buster Free Ceramic Coating $1199.99
- Performance Heads with Procharger
- Looking for Prior Owner SC Stingray
- C7 twin turbo
- NEW MMS C7 Fuel tank tap
- C7 Corvette ESS Supercharger
- Adding a Maggy TVS2650 Kit to Stock C7
- Supercharged c7 hesitates at higher rpm blows oil out supercharger breather
- Which cam covers for 2650?
- What wheel and tire can handle 1000whp c7 corvette for roll racing
- Paging A&A supercharger pros to the white courtesy phone...
- 2.175 pulley belt size & part #? LT4
- AA Ti Blower Whine Noise
- Magnuson 2650 Worth it for a street car?
- magnuson 2650R questions
- Is a Catch Can Necessary With Super Charger Install?
- Spark Plug & Air Filter for SC Mod
- Labor Day Sale-Superchargers, Headers, Monster Clutch, Wheels, Coilovers, Body Kits..
- Dual nitrous bottles
- ProCharger overheating issues
- To Supercharge or Not to Supercharge?
- Magnuson TVS2650R - C7 LT1 Conversion From Dry To Wet Sump
- Synergy cooling tanks - any reviews?
- 2014 z51 A&A, oil leak after recent oil change
- Spark plug Replacement
- Tps signal/ tach signal
- Procharger Intake Manifold
- Weld Beadlock Rear Set Sale $1195 shipped (Corvette C7 Z06/ZR1 18x12 R Iron Brakes)
- 2014 MZ51 Procharger Numbers
- Change snout on Maggie 2300?
- Nitrous hook up please help
- Magnuson 2650 LT1 & LT4 Z06 Superchargers-Free Shipping!
- Should I upgrade to Magnuson 2650 on my stock C7 Z06 A8?
- Throttle Bodies 103 vs. 112?
- Difference in 103mm snouts
- Can’t add timing to tune
- CPR C7 trunk ice tank install video
- Carb legal turbo ?
- E-Force 1 upgrade to 2
- LT1 Edelbrock Boost Reliability on Track
- Magnuson 2300 questions
- Thermal lag / heat soak after shutdown
- The White Devil is almost done...
- 2 step with ECS Novi
- CPR 5'' CAI install video.
- Edelbrock Supercharger Drivability Issue MAP Sensor/PCV
- 2014 C7 Meth AND e85
- 2017 Grand Sport with A&A
- Best head gaskets for a sleeved 416ci stroker
- Edelbrock Superchargers at DSP Performance Motorsports
- Magnuson Superchargers at DSP Performance
- Where to mount Alky controller/ gain
- Build question
- Procharger Units Now at DSP Performance Motorsports
- Procharger race valve
- Maggie 2300 Pulley question & IPW
- Robert Miller
- C7z F1a94 pulleys 1000+
- Isn't there vendor sale section?
- How to install a Mighty Mouse with magnuson 2650 with speed engineering valve covers
- A&A Installed - How are these numbers (with pics)?
- C7 CARB issues - how to get smogged?
- Water/fluid sloshing sound after A&A
- Pro charger pulley tensioner Replacement?
- Magnuson 2650 C7 Z06 In Stock Ready to ship !!
