View Full Version : C6 Corvette General Discussion
- Im in a bind - Failed CA smog test for "Modified Software"
- Help with pricing my C6 for sale
- C6 Seat Frame - What Material???
- Ac compressor failure/ replacement
- C6
- 2005 C6 Steering Wheel Controls
- Vararam will be back at Carlisle 2021
- Washer Bottle removal
- Limp Gas Pedal
- Z51 option
- Above and Beyond Service - Sharplight Innovations / Radio Flyer
- Reputable Vendor
- "Service Fuel System" light.
- Sensor inside the fuel tank-Help
- 2007 C6 automatic shift problem
- C6
- Insulation in high beam housing
- Replacing to original factory mufflers and cat system
- Help identify mystery part ?
- Rattle/Clunking Noise.....2013 Convertible
- Sound/heat insulation - C6 ZR1
- C6 headlight gasketing . . . Any around ?
- C6 Leather center arm rest cover
- CORVETTE TODAY #70-Meet The Retired Assistant Chief Engineer, John Heinricy
- Transmission Woes - WTF No Fluid
- MSD Airforce Question
- New to me 2007 Corvette Z06
- Ideas for trickle charger location
- 2009 C6 ZO6 seat back limiter question
- Momo steering wheel install help
- 06 headlight and gauges going crazy
- C6 2010 gs coup other window sweeps
- Drivers Information Center (DIC) plugs in where?
- Your opinion please
- Blue Ridge Parkway Trip
- OBX long tube headers 02 Extensions
- New stereo head unit
- Changing Vent Control Solenoid
- How many went from a C7 back to a
- Spoiler
- headlights?
- New wheels arrived for the IO Z07!
- Coming back/price discussion
- Don't Buy Another Exhaust .. I Just Found the Best Exhaust on the Planet >
- Check oil level message with young oil life
- Aluma Star front runners
- Difference between Corsa Extreme and Sport?
- Idling rough
- Exhaust system removal
- Just Bought a 2009 LS3 and I want to know the first mods to make
- When To Change Tires?
- Finally back
- New toys
- Just put new tires on... Wow.
- Our First SALE in 2021 - SAVE up to 50% !!!
- BATTERY - Charging - RED Top
- C6 vert seat back
- Tail light removal
- NCM Insurance (Agreed Value) Policies
- Looking for some insight on installing a sounds system
- Burnt fuel relay wire
- Looking for the gentleman who works for Borla
- Smoking alternator
- C6 Harmonic Balancer
- Oil Filters, How tight do you go ?
- A New Battery
- Harmonic Balancer Bolt and Seal Failure
- Replacing Crystal Red Trunk Lid/Lift Gate
- Recommendations For New Tires
- C6 deader than JFK
- Lingenfelter or RK Hood
- Quick Jack
- Price question
- Brakes Squealing - Need Advice
- My c6 has no spark!! And won’t start.
- I need help I’m trying to locate a new slave cylinder
- Finally got my C6 running!
- Can I disable passive locking?
- All Fluids
- Experiment on Wheels
- LS2 known to have power steering pump failure
- Shocks
- A&A Making Progress...
- Steering rack bushing loose causing front end noise - with pic
- Looking for someone on the westside of Atlanta to install C6 headlights
- Favorite Low Shine UV Protectant?
- Buying dilemma C5 Z06 or C6 Z06 ???
- First oil change on my 2011 GS Dry Sump
- Door Switch
- Shave inside of wheel wells for taller tire?
- C6 Corvette Rear Valance Trim removal
- Corsa Sport Exhaust System for C6 Corvette 14169
- '06 still making me smile after 3 years (Homelink)
- Car Inspection Wilmington, DE 19807
- GS wheel options not black or chrome
- C6 TPMS Sensors
- Michelin A/S tire shortage
- C6 NPP Valves Remain Closed except when fuse pulled
- I Cruise Control
- Widebody Hardware?
- Want to find/buy my old car….how to find current owner?
- Brake roar
- C6 might be the best sports car ever
- ZR1 dash cover
- 200MPH ✅ C6 09 Base LS3 SBE, Stock Clutch and Rear
- Should I move to a C7
- PlastiDip Wheel Coating
- Removing Side Skirts on Aero Package?
- Garage Car Cover
- NPP exhaust sound
- Road America
- Fender Stripes
- Xtreme sound level (21077) 3.0 in axle-back twin 4.5 in tips 2006-2013 corvette c6 z0
- Jacking the front up via front most cross member??
- New to me 06' Automatic 3LT Z51 - A few questions
- Weird Noise issue!
- C6 radio no sound
- Wide body kits
- 2013 versus 2014?????
- Thanks for all the help
- 3 piece front spoiler/air dam
- C6 rear speaker question
- Sticky for C6 Convertibles
- Battery Drain with Range Device Installed
- 102mm lsx intake manifold upgrade!
- Low beam lights wouldn't work on my 2007 C6
- Rear End movement under compression
- Poll with Pictures! What caused this?
- 2007 Corvette Auto Shifter Assm'bly
- alignment for 2006 c6
- Brake pad break in
- Brake Bleed sequence
- Doggon stealerships
- Can someone please tell me what this connector goes to?
- Rewrap your worn steering wheel with us! For LESS!
- Ok, Corvette parts ?
- Best aftermarket NPP Exhaust for a C6??
- 2013 documents
- 2007 service light
- VIN lookup (free)
- Planted Passenger Seat Bracket
- Interior Upgrade
- Headlight moisture
- 2008 Z06 that dropped a valve
- Should I remove the plastic protectors from the carpet!
- 2008 base...trunk won't open with fob or button
- 2 C6 owners at a bar
- Noise on Driver Side Mid/Front Area
- New c6 birthday!
- Wheel & Tire Size Combo
- NPP Exhaust Fitment
- First Maintenance
- Daytime running lights- can you turn them on/off?
- Ignition Switch
- Notchy 6 speed?
- 13 Grand Sport service stability & traction... fixed
- Question about this site!
- C6 BASE wheel pics
- white powder on interior surfaces!
- Z06 manifold crack
- ZO6/Grand Sport Brake caliper question
- Are there any aftermarket floor mats with the post mount?
- 2006 - Fuel Gauge Issue - Thought we fixed it
- C6 LS2 dyno results
- Two Tone interior?
- Would you buy a 115k mile C6 ?
- Newb here...couple of questions on buying my first C6
- How to tell if a C6 has the Z51 package?
- Best engine swap for stock Vette?
- C6 versus C7
- I'm BAAAaaaack
- What should I do with my jalopy of a C6?
- 2007 C6 Base Will Not Crank. Tried Several Things…What Am I Missing???
- Oil pressure gauge reading zero
- Wanted…..Windjammer Reviews
- Head light assembly question ?
- Passenger Door hitting fender when opening
- Super odd hissing sound
- Clutch Master Cylinder Question
- NPP Not Working
- What do you think
- “Zo6” Front Air Scoop Bumper Kit
- Where should I list my C6?
- Corbeau Seats in C6 Convertible
- Weird shift point question.
- Rear Defogger Not Working
- OK, about that oil change flavors ?
- Anyone driven a C8?
- Speaker upgrade
- Stereo issue
- Dead battery
- Newbie looking at 2008 convertible
- Can’t turn off DRLs, fogs or tails
- Is This Anyway to Park a Corvette
- Changing plugs and wires on modded grand sport , whats tbe best brand to go with ?
- Test Drove a ‘10 GS today and…
- Dew on hood showing hood insulation emblem
- Differential Whine?
- Auto Zone
- Front Fender side cove screens, How difficult is this job ?
- What i think
- Battery Question
- Does the roof recall included 2007 base coupe
- Plugs
- I hope this is a simple quesiton
- Made a Trip to the Homeland Today
- Borla?
- Uh oh... C8 headlights for C6??
- Looking to upgrade the head unit to a Sony XAV-AX500.0
- Please let me know !
- Odd LS2 experience Valve rattle ?
- Do you have 05, 06 Lemans Bl convertible?
- 2005 Callaway - New look is (almost) complete.
- easyrider
- Fog Lamps please help..
- In-vehicle Bluetooth system
- Z51 Option
- Chevy Dealership is telling me they can't see full service history performed?
- 2007 Coupe Unlocking Issues w/ Fob
- Considering this C6, anybody know what type of wheels these are?
- Non Run Flat Tire Recommendation for my 2006 Base C6 Coupe
- Source for NPP actuators ?
- C6 for an old guy
- Fog light upgrade, Bulbs ???
- High Milage vettes
- Apsis: Anyone wants to take this 2012-13 C6 UltraSport Steering Wheel...No Waiting...
- Interested in a 2010/11 GS. Questions.
- C6 Low beam d1s headlight hold down
- Seat Upholstery
- Another stereo question
- Winston-Salem, NC
- I give up !!!
- 05 Intermittent starting issue
- Cheapest site for C7 style headlights?
- Confused on C6 Vin Code Breakdown
- 2005 Corvette C6
- Fuses and finding the right one ?
- Kenwood Head Unit Installation
- Who makes a 17x10 for a Base?
- I swore I would never do this, but....
- Removable hardtop C6
- V8 6 4
- Paddle Shifter Delay
- Replacement underwood label wanted for Z06 / 427CE
- Marks Corvette Cruse Night
- What’s this 2008 z06 worth
- Diablo Tuner?
- 05 rear taillights
- My New Grand Sport
- Car Buying Services--Pro or Con?
