View Full Version : C4 General Discussion
- Emission testing on 96 Vette
- Poll 87 Kaminari Rims
- VATS Bypass: Install? Keep or return?
- 1987 L98 water pump question
- Need Help Identifying This Wheel
- How much should I pay for a 1996?
- Whine: Is it diff or trans, how to know which
- 87' Convertible project updates
- Came across this sick c7 z06 on the freeway
- Finally pulled trigger. New to me 96 C4 owner
- Bent Frame or Bad Latch?
- help identifying ERC plug in 1990
- Mobil 1 rebate time
- Clutch master cylinder and slave
- 1989 Driver Side Window Adjustment tips
- Good deal for a New Englander?
- 1996 PKE FOB Wanted
- Body Kiy
- 1996 T.V. Cable adjustment
- 85 Rear Suspension Rebuild, full adjustable worth it?
- Fittipaldi wheels, made in Italy
- Where are all the ls swaps ???
- Wipers do not complete cycle
- Inner door seal replacement woes
- C4 car wrap vs repainting
- 1984 PROM (memcal) automatic. Which one?
- Help please
- 93 radio replacement
- Cool corvette c4 video in the Dessert!
- '96 PKE Fob replacement
- JW Speaker 5x7 LED headlight-93
- 1992 cowl screen removal
- minimum size enclosed trailer for C4 - will 16 foot do it?
- Willcox Weekend Special Sale 10-15-20 And a Interior Package shipping Special
- 1993 Wiper Switch
- No A/C... Compressor won't turn on!
- 93' Door Lock Switch Wiring Harness Problems
- Blender door on hvac
- 1984 voltage drop from battery to gauge
- Look How Different a C4 is to a C7
- Quantum Fuel Pump?
- Power Seat gearing cleaning and lubrication
- Looking for dash trim paint 90-91 Radio Bezel and console
- C4 key fob testing
- Fog lights
- Head lights
- Lowered C4 Corvette slight rub passenger fender
- Help With Scanner for 1986 c4
- How much has your C4 changed during your ownership
- Original Carpet Adhesive
- 1989 Electric Seat Switches Removal
- Does this sticker indicate a Z51 on an '84?
- tach error?
- Who knew? I didn't! NOW I KNOW..what you all know
- Fuel Gauge Issue
- Repairing cracks in SMC at door hinge?
- 1987 C4 L98 Fuel Issues
- Hovey Motorcars in San Antonio - Anybody close?
- My 1985 how I came to be a C4 owner
- What ever happened to Vettaid?
- Before and after shorty header install on LT1
- License plate installation kit
- Another C4 to the collection........
- Smog Pump converted into a crank case vacuum pump
- need paint advice for c4
- Is This a Good Deal? Snap-On Scanner MT2500, GM Cartridge, Fast Track Troubleshooter
- My $2500 1990 rescue
- C4 bumper bodywork information request (not much action in paint/body general section
- What causes this carpet problem?
- ac r12 or r134 on 88 c4 ? Help!
- 1995 Auto no crank
- New Blue Tag ZF
- 96CE (LT1) may pull the trigger...
- Shinoda body kit
- 94 Key FOB
- What model number AC Delco Battery do I need?
- Adapter brackets for j55 calipers
- Beauty and the Beast
- May 2020 Calendar
- Brake Problems
- Lowest dust brake pads
- molding on targa top coming off. why? and how to fix?
- cowl screens
- How long would it take to replace tailshaft bushing?
- Forum member to inspect a car near Syracuse
- What is the name of this Gasket and where to purchase one.
- Choosing Between a C3 or C4
- Udders
- C4 valve covers on a different chevy 350??
- Will a 91 front bumper cover fit an 84?
- Michael Jordan C4
- Could someone help with manual fan switch?
- Dumb tire question
- Does C4 Parts Scarcity Make Owning a LONG TERM C4 a Pain??????
- Vehicle Speed Sensor for FX3
- L model type
- How fast will it be?
- Thoughts on an LT4
- Need a part number
- Seat options
- Latex vs EDPM, the great debate
- The new door panels are here!
- 1986 Corvette rough idle when cold
- Fog Light Switch Replacement
- Does a vacuum line go here? If so, where does it go to?
- Verification 18" Tire/Wheel Size Fitment
- C4 Wheel Fitment
- 1984 Corvette & 1987 BMW M6
- What's your preferred RPM city & hwy? 1500? 2000? 2500?
- LH mirror backing.
- Transmission 87 Automatic Leak/Bumps (?)
- Rocker arm upgrade
- Low air output
- convertible luggage rack
- Need 2 Keyfobs for 1996, are they easily programmable?
- Suspension rebuild pics and a brake question...
- New B pillar Weatherstrip-Now Windows Gapped
- 93 sport seats
- Barely idles/won't stay running after battery install (or coincidence)
- My 96 is coming along. Thank you C4 community
- 96 Wagner headlight HP6054 rebuild (plastic)
- New C4 Owners- please look and save yourself some future headaches!
- Speaker Enclosures
- 85 and later rear end spring???
- "94 C4 Passenger Window adjustment
- 89 makes rubbing sound when turning
- Attention 1st time C4 owners!
- LH under hood lamp not working. can i replace with LED?
- 1989 want to pain underside of the hood
- Battery dead in 8 hours?
- Kinda pissed at myself and the seller as well
- Stupid vhs video that came with 1993 corvettes
- C4 LED Underhood Lights
- First Non-Lt1 C4!
- Unknown part
- 84 C4 CFI questions
- Pushpins for A-pillar weatherstrip
- Well dang..........
- Cheap '86 to '92 red interior paint
- C4 for sale comments
- C4 newbie, ASR ABS lights
- Floorboard Fiberglass/Aluminum Section
- Mufflers
- Carpet and speaker swap in my 86
- !996 GS WITH ALL BLACK interior??
- 1993 master cylinder emptied - system bleeding instructions/tips
- New door panels I guess....
- Anyone ever put an early c4 rear, on a 91+ model?
- Can this panel be aligned?
- Subwoofer Options For Rear of 1992 Base Corvette
- Leak down test question
- Does anyone know what front spoiler/air dam is this and where can I get one?
- Amp Relay - 1989 C4
- C4 LT4 or C5 Z06
- Targa top rubber pieces on back side
- C4 Convertible Rear Wind Screen
- 1992 Automatic T-Top ......Opinions?
- C4 engine question
- 19mm bolt
- Ramps
- 1990 L98 Support Brackets
- Replaced evaporator
- Speaker Grille attachement
- Enclosed Shipping
- C4 Enthusiast Wisdom Requested.
- Back to OEM radio?
- 84 corvette air cleaner cover original paint
- Z07, 3.54 with Z51 spring???
- 96 C4 Cruise Control problem
- 85 lost keys
- 1994 Camaro Z28 LT1 Engine vs. the 1994 Corvette LT1
- 90's Corvette with 80's Dashboard?
- Recommend 6.5" speakers for Alpine head unit and amp
- Looking at a 35th Anniversary and I have questions
- Classic Car Insurance
- Dewitts SP461 install
- 1990 Vette_Can't find Bose Amp for wire connection
- Delco Radio basic cassette player
- Jacked up interior
- Need help reinstalling seat cushions, can't latch them.
- Theoretical cam question. (Thought experiment)
- 84 Corvette #0071
- Power Seat Controls
- Looking for input for wheel fitment
- National Corvette Museum People's Choice contest
- Giving away a 1993 C4
- 1989 Rear Brake Caliper Springs
- 91 misfire
- Got this in the mail this week. Anyone remember this show/event?
- 1986 Convertible Carpet
- Hood scoop
- Production Numbers by int /ext combo
- 91 coolant hoses
- 6spd manual tranny leak, is this labor intensive?
- Underhood decal
- suggestions on seat covers?
- New ecm 91
- '85 C4 removable steering wheel
- New Owner
- Fixing progress
- Please help misfire !!1991 l98
- Cleaning
- Fixing my steering column...
- 94 dash rattle
- Master Cylinder Mystery
- Great video explaining the 1984-1996 C4s
- C4Pi Project | Comvette for a late model C4
- Need door / door panel ID on my '92
- Willcox.... Tired of bogus sales, this one is for real!!!!!!!.Special Sale is on!
- Wheel Tire Package, Opinions ???
- 84 Convertible Aircon Fans not working
- Iggee seat cover for sport seats fitment issue?
- Exhaust modification question
- Motor Mount covers?
- 1994 convertible sun visors
- NCM Virtual Car Show
- 94 Won't start
- 1990 purchased and intro
- wire harness repair
- Can I run 18" Wagon Wheels all around?
- Runner question
- Those of you with aftermarket seats...what brackets are you using?
- Discount Tire Direct flash sale
- Help with 1992
- Looking at a C4. Need advice from owners
- Radiator cooler fan suddenly runs all the time
- Interior Lights Flicker/Won't Turn Off
- Help me find the ground wire for my DIC
- correct way to install a headliner?
- Rare Copper C4 on eBay
- Blue 1994 C4 LT1 - Project
- Mystery plastic bit
- Roof panel adjustment
- 93 lt1 starts runs but won’t stay running.
- Bose Amp Replacement
- New guy has a question
- How Many C4'S Built
- C5s under 100k mi under 10k common in Socal
- Retrosound to Delco/Bose C4
- 1989 Convertible
- Shift points
- Drilling Hole in Radio Bezel-93
- Help with 1992 stuttering but not starting
- need help with security (i think)
- C4 need your help guys
- LT1 block ID
- Free 1993 Corvette given away on YouTube. No purchase
- vibration, shaking C4 87/112 t
