View Full Version : C4 General Discussion
- 1993 NY - found window sticker & some purchase papers.
- New to the C4
- 86 yellow convertible Pace Car
- C4 wheel sizes for aftermarket wheels
- Need Help Identifying Nut
- Is clutch tied into brake booster in 96?
- de-ugly the radiator hoses
- 1996 Collectors Edition
- DeWitts October Flash Sale!
- 84 corvette cranks no start. Temp sensor part number?
- 1984 Throttle bodies giving off strong gas fumes
- Questions re: FX3 shocks
- Car Covers---Buyer Beware !!
- tpms senors 1995 vette
- Street and performance Tunnel Ram
- Radiator hose support location
- L98 Engine Recomendations
- 17x9 +12offset
- New C4 owner needs help
- Metallic clinking noise when transmission shifts
- 1st Corvette 4+3 ?
- C4 owner
- Storage unit for winter
- C4 Seat Cushions Interchangeable?
- Tire safety, date code question
- Race door cards?
- 1984 Corvette cross fire injection
- Aluminum L98 128 casting heads questions
- Overheating problem
- C4 Corvette!
- Fuel injectors
- C6 Seats into a C4
- New user with a trashy C4
- Intermittent no crank at first, then intermittent fuel pump?
- Fall colors and my '92
- Outdoor Car Cover
- Random electrical harness and mysterious ground
- Looking For An Upholstery Shop For New Top - Ohio
- seat question
- Looking for Seat Upholstery
- Heat question
- Transmission
- L98 computer
- Spooky
- 85 Corvette heater core box
- My 1st. Corvette Questions
- Feel like Johnny Cash today.
- Clear top - stock or aftermarket?
- getting a CE rim repaired.
- Battery vs. Alternator
- Driver side window switch questions
- heatercore question —was rtv installed from factory?
- Help with finding tires
- Digi Dash Electrical Gremlins
- 3rd Brake Light for an 86
- Another C4 40TH Anniversary
- What a difference a ceramic coating makes!
- What is your opinion on this ZR-1
- Egr delete? Headers
- Insurance quotes and usage
- LED Help!!!
- CORVETTE TODAY #130-Win A Copy of Corvette 70 Years, The One And Only On The Show!
- unstable idle and smokes very dark
- Ceramic coating
- To hell and back…
- suggestions on painting 93 smoked top
- No Power plus Strange noise
- Silly problem with 84 headlight replacement
- C4 Restoration in Houston, TX
- Hood alignment
- tire question
- 1989 Corvette Aftermarket Radiator
- LT1 pulses when cold
- Is this repairable?
- '89 vert: bow won't release; top "stuck" in down position.
- Wind noise
- Convertible Top fix or replace?
- Dyno tune in Massachusetts
- 1996, Heat only works when temperature is set to 90 degrees.
- Rebuilt throttle bodies
- Engine Cleaning with P 21 S
- Vats help!!
- Grand Sport twins
- Milwaukee 2767 impact wrench defect.
- C-4 Milage ?
- Speaker covers
- Sound system
- Who's Car Did A Youtuber BUY???
- 89 not running
- Power Window Motor Quit Working
- Cooling fans not coming on
- Is It a Real ZR1
- Hagerty article on Corvette race cars
- Parts Availability
- Quickjack
- New Member in GA
- wiper blades
- C4 Corvette ZR1 Is a Proper Bargain These Days
- Front Suspension Update
- Pulling ZF6 Trans and Intake Manifold combo?
- Transmission Shifting points
- Battery Tender Pigtail
- Insulation
- Patching trans tunnel?
- Auto Cross
- 1991 base model C4 belt tensioner bolt question
- .020 Ma draw from an unexpected source.
- Door panel install?
- Rattle on hard bumps rear hatch area ? tighten hatch ?
- Opinion on value of a 1990 ZF6 car.
- 1989 stock
- 1985 Clutch Bleeding
- 1992 outer window seals
- Best heater core?
- found inside an old c4, parts id help
- Farewell to my LT4
- 92 Cooling Fan Issue
- Sticking climate control buttons
- Key Fobs
- Help! Missing piece
- Help on getting rid of exterior door trim haze
- Headlight trouble
- Florida Forum Members
- 1984 Corvette - Mystery Blue Box
- 85’ Fuel injector connector
- 1993 coolant drip under pass seat outside ?
- Nitto Tires
- Help on value of a poster
- 1989 oil pressure sensor(s) question: Pictures?
- Bad inner tie rods?
- Thoughts on this 86 4+3 vette
- Cooling System hoses
- Gas pedal mount
- Anyone ever buy these headers?
- Ignition system problems
- 85’ HVAC issue
- Is proper fuel sock (on pump) orientation sideways, or fore-aft?
- CA Exhaust Question
- Guess what - they DON'T melt in the rain!
- MN collector plates
- I think my headlight motors are slowly draining my battery....
- Where does this go?
- What part is this . (What would it be called in ‘Ecklers’?)
- Route 66 trip completed
- Parking Brake Woes
- What are they called, and where can I get some?
- Help!!
- 1990 VIN Question
- C4 Fuel Heater Delete
- 1985 C4 Z51 vs. 1990 C4 ZR1 Interior Space
- A question about caliper rebuild.
- 96 wont cold start
- Targa top separation
- Did they make any two-tone convertibles 86-88?
- rear clicking noise
- Fuel injectors
- Power Antenna Realy?
- My 1992 Electrical Woes
- Track Cooling Mod Results?
- '95 Coupe Coolant Leak
- What's the market really like right now?
- '96 Misc Interior Cleaning and Repairs
- 88 C4 lumbar bladder
- Oil change motor method
- Fast Clicking when attempting to start - please let me know your thoughts.
- Rear popping noise
- 1993 Door Panel Issues
- Help identifying vacuum components
- MPH readout on 91 c4
- WINTER, Bed Time ?
- 1988 C4 Wont Start
- Buds in San Diego
- Interior lights flash on and off while driving at night?
- Messing with the exhaust...
- Accessory Belt
- 1993 drivers side power door lock ‘slow’ have to hold the lock button
- Bronze gears for the headlights. WTF these things must weigh 1 lb each per gear
- Sacramento, CALIFORNIA C4 drivers on here?
- Is the current best plug for 87 coupe still AC5 ?
- Re-Installing half shafts. The most impossible task. HELP. Help.
- Help reduce my exhaust volume
- 1984 auto shift knob retainer install instructions
- 93 C4 Vett ALT
- Replacement/aftermarket seats for a 1990 convertible
- 1995 Corvette making odd noise
- Plenum 1989 vette
- C4 Mechanic in San Antonio
- 1990 stock sound system
- C4 Mechanic
- Headlight knob falls off
- Your expertise on fuel pumps please,
- 1992 Red/Blk Coupe 6-Speed, Value Assesment?
- Is this piece of rubber available?
- CORVETTE TODAY #127-It's The 2 Year Anniversary Of The News & Headlines Show!
- Inner dash frame replacement
- Choke light on 84 corvette
- Odd noise when turning on 86
- 93/94 Shifter plate. What's the difference? Interchangable?
- 1990 information display 1-37 using AC fan speed buttons
- Any idea on what these wires are for?
- 1991 New Owner 34k.
- Looking for Convertible top installer
- Retired
- 1989 C4 stalling at idle intermittently
- New problem 1918 convertable
- What is this part called?
- 89 Blue leather
- Clean/Salvage/Rebuit Title question
- A/C blowing Smoke
- Need tires for '84 C4
- Need help with I'd on plugs
- Harmonic balance problem
- 86 Corvette With a carbureted 350 swap
- You Decide - 2022 C4 of the Year - Modified
- Engine Codes-No Start
- You decide -- 2022 C4 of the Year -- Unmodified
- need help with 383 stroker build and block prep!
- Seat back
- Help regarding engine sound
- service ride select
- Is the rear hatch solenoid or not?
- B8 Bilstein shocks for front of z51?
- Screeching AC compressor or clutch
- Why didnt my 84 come with overdrive?
- 94 - Wiring for remote keyless - Clarifications
- C4 Rim and Tire Guidance
- A/C vacuum sources
- Anyone heard of the 1987 C4 EV?
- Transmission and Overdrive Fluid and Capacity
- EPROM replacement for C4
- C4 Radiator: Shop damaged trans/oil cooler line when replacing radiator.
- Vented opti spark install
- 84-90 wheel interchange ability
- Weatherstripping: Roof, Windshield, rear Hatch
- Moving to a C4
- CORVETTE TODAY #126-Learn About The Muscle Cars & Corvette Nationals
- 87 coupe. What color is the outside black trim around your windshield
- 1988+ heads
- 1996 Convertible Jack Storage Tray
- Crank position sensor
- Too much fuel ?
- Am I missing something here ?
- How do I tell if my '86 is early or late?
- As popularity of the C4 grows are parts prices skyrocketing?
- 1993 Corvette scan tool Innova 3170RS
- Carpet help
- What is a used LT1 worth to you?
- Completed some project maintenance items.
- C4 Cooling Improvements
- C4 Corvette Indoor Stretch Car Cover w/Corvette Flag Logo In Stock!
