View Full Version : C4 General Discussion
- Did I put the wrong stuff in my rear-end?
- Fiberglas top questions
- Drivers door won't open
- Suspension limit too low
- New first time owner, 1985 w/ 36,000 miles
- Remove hard top if car is on hoist/lift ?
- ZF6 Oil
- vette2vette Frame Stiffener
- 93 no horn
- Seat swap question
- oil pressures and oil weight
- North NJ polishing/powder coating shop
- Please read and help
- help please
- Blue Tag ZF6 questions
- 92 Valve Cover Paint
- license plate
- Novus #2 seems to remove a fair amount of surface scratches on targa tops
- Another All Girls Garage & Corvette
- 92 LT-1 intermitently looses ignition power
- Any ABS brake guru's out there?
- New starter, no power!
- St. Jude Auction #51! C5/C6 Harness Mounting System from Marrad Industries LLC
- Suggestions/Help on paint damaged from the sun
- figured my problem out
- Need help finding specific set of wheels
- Courtesy lights in doors staying
- Early Morning Cruise
- Changing backup bulb in curb side quarter panel
- C4 1989 Convertible top
- Willcox Weekend Special 20 off Sale Starts Now!
- Some pictures of my new to me admiral blue '94
- St. Jude Auction 50! Mail Order Tune 97-17 NA Engines - tekhombre, Auction Extended
- 92 LT1 Code 43 and 55
- New Emblems before/after
- Who had their c4 go 200MPH ?
- What we already know...
- O-ring for cold start pipe
- Checking out a C4: Service history?
- Hurricane Irma Florida Checkin
- 1985 corvette dies turning right.
- 84 cross brace
- Location cooling fan relay
- Door adjustment
- Igee Seat Covers
- window regulators
- C4 sill protectors
- C4 underhood paint
- St. Jude Auction #49! 2005-2013 C6 Headlight Lens and Gasket Set from RLSebring
- St Jude Auction #48! $100 Gift Certificate from Forum Vendor TCE Performance
- Frame Cross Brace Bent on Convertible
- 1990 Hard to Start
- cool video on a C4 race car
- Willcox Weekend Sale Starts Now Weatherstrip Wiring, Frt/rr Suspen Interior and More
- C4 owners in the Calgary Alberta Canada area meetup?
- Will running 87 octane hurt my 94 LT1?
- Anybody live in Chilicothe Mo.
- FSM for a 1991
- Need ideas for new set of wheels
- Information learned from the CarFax on my '94 coupe
- Is the ZF 6speed supposed to be super smooth?
- 1986 power steering cap
- DIY 1989 Seat bolster repair
- Tire sizes
- Correct vacuum fitting?
- fender hash strips
- Targa top repair
- shaking when accelerating
- Front end thud
- convertible top
- New article on C4 corvettes
- 85 Side Markers??
- St. Jude Auction#47! LS7 C6Z06 Crank Scraper & Windage Tray Kit from Improved Racing
- Interesting....
- 94 Sport Seat issue
- 96 convert finder bender .ins may total
- Burgandy fuel rail covers
- I have found my project car - `92 convertible
- StreetSport Targa Top
- Might have found the clunk
- rear hatch will not open
- new gas tank installation
- 1990 Corvette no power to the fuel pump
- Coolant leak that is killing me.
- Sticky steering wheel problem solved
- 1992 Corvette convertible
- Possible bad Knock Sensor
- Low coolant light
- When heat is on, it only blows out of floor vents.
- Sound Deadening!
- 95 tranny problems
- What Chrome wheels fit 1995 C4
- How do I sell overseas?
- List of other year Corvettes factory wheels and tires that's a direct fit to C4?
- ** St. Jude Auction #46 signed hats by UFC Fighter Tim Boetsch 6 available **
- High and low horn notes
- New Stable Mate for the Vette
- Gas leak
- Best location for 12V power?
- Is it normal for a C4 to run hot?
- help with CEL codes
- ★Quiet Down Your Interior in Seconds!! / Blockit Sound Deadener - FORUM SPECIAL
- 1996 sensor panel issues
- Corvettes at Westport Show Photos
- My stock C4 Vs My Big Mouth Cousins 95 Mustang Cobra..
- Cant Get My LT-4 To Start-Help!
- Lumbar Support 92 'Sport Seat' no workie
- Need to purchase a car cover. Any recommendations?
- cluster 85
- 87 Corvette Base
- New to corvettes
- Finally got the new roof panel
- Willcox Labor Day Weekend Special 20 off Sale Starts Now!
- 88 fuel lines
- Clutch Master & Slave
- Help Please with Error Code 36
- Considering a second corvette...
- Mpg
- Mpg
- Paint code question
- Clutch C4 1989
- Need Tires
- New Callaway Cars apparel line now available online:
- Disconnected vacumn line
- Aftermarket 700r4 pan clearance?????
- How to make C5 Wagon wheels look the best they can?
- September 2017 Calendar
- Some of the Coolest C4 Corvette Wheels Ever
- Fs: 1991 zr1
- Good easy to reach ground point under the dash?
- Clutch
- rattle fix, header roof mounting bracket with sun visor
- Anyone get to corvettes at carlisle this year? Post pics!!
- CEL light comes on when warm
- winter maintenance
- St Jude Auction 45! Personalized Rendering/Print by Monaco Auto Design/NebraskaTrevor
- St. Jude Auction #44! C6 Fangs from forum vendor SacCityCorvette
- new headlights
- Just took delivery of my first Corvette!
- anyone have dash mats?
- 63 Vert.......
- Lexan mask ...
- 1994 Center Console Wiring
- 1994 Center Console Lid Light
- Door locks
- Oil light
- Contemplating a C4 Project
- Need help mentally.
- Any feedback/ reviews on this top?
- Hello from Houston
- Toronto Mechanic
- 92 LT1 no start
- I am the real owner.
- RE: Potential buyers Q, What do you say?
- Car fax report appreciated
- will not fire 92 c4
- Tried to start..not a peep
- Leaking
- Rear hub washer
- Where to get Custom Bilstein Shocks
- Adding grease zerks
- Sway bar measurement needed
- Decent mechanic/interior Tech
- St. Jude Auction #43! C6 Z06 & GS Hawk Ceramic F/R Pads from Xplosive Performance
- Callaway Twin Turbo vs C4 ZR-1
- 1992 Corvette Door Lock Cylinder Retainer Clip
- *** 2017 St. Jude Fundraiser Official Check Presentation ***
- car seat side pocket key catcher
- Northern California Bay Area Help!
- C3 manual clutch ignition switch
- Flashback to 1986 and my 85' Corvette
- Electric tick ?
- Tail light / turn signal
- Cooling system vacuming
- Factory CD player error
- Antenna
- L98 differences?
- Can you identify this part?
- Production Figures
- New Spreadsheet
- A bitter sweet goodbye...
- Considering something almost impossibly dumb. (Road Trip)
- Nice "Rag Top" morning
- Exhaust recommendation for '88 w/383
- ZF 6 Speed, What Oil to use?
- Fuse block
- Injectors.... what do I have and what do I need?
- A/C advice
- Another good day
- Shift RPM
- Wrap headlights
- Stereo different idea
- A Few C4 Pictures From Friday at Carlisle
- Identify this part?
- Rattle from top?
- instrument panel insulator LH
- C-4 Coupe FOB purchase
- Dimmer switch questions
- Horn contact tower
- Hello everybody
- Convinced I need QuickJack for a C4
- Radiator fan shroud decals
- Erratic Speedometer 1992 Corvette
- Pennsylvania Antique Plate fiasco
- ASR,Service Engine,Air Bag, Low Coolant Lights are on
- Turn signal
- Center Console Cleaner?
- Pin Stripes on our C4's? Photos...
- St. Jude Auction #42! Yellow C5 T-Shirt from forum member ~Stingray
- Eclipse Road Trip
- Detailing
- pics of my corvette
- Valve Cover Emblem Color
- New emblems question.
- C4 European launch [video] from 1983
- Auto to manual conversion
- 1989 Corvette stripped oil pan threads
- '92 6-speed, car makes weird clunking noise when clutch is disengaged in neutral.
- Coolant leak somewhere, did pressure test and they said I didn't have a coolant leak?
- Ars cover bolt
- 1985 Corvette stock motor question
- Ruby Red 1993 Carpet
- TB to air cleaner hose lsx?
- 7/16 rocker
- Bose Rear Speaker Problem?
- Blend door
- New front spoiler from Corvette Central
- 92 door panel
- TPiS Air Pump Delete failed
- Advice needed
- fuel pressure
- Aftermarket R4 Compressor - Scroll Design ???
- 1984 Corvette LKQ Daytona Beach
- My First Corvette
- Missing Part
- led b/u bulbs
- what is this trim piece and where to find it
- ask a question pop up
- Jacking front of C4 with a floor jack
- Q8Knight79 SWEEEEET youtube video. Are you on this forum?
- Bleader valve, colling system
- Probably not going to Believe this.
- St. Jude Auction #41! C5 Fangs (Skid Plate Protection) from SacCityCorvette
- St. Jude Auction #40! 2005-2013 C6 Headlight Lens and Gasket Set from RLSebring
- Zip C4 Catalog
- OEM windshield for an 84?
