- 1987 Vert Hood Support
- Sticky Ickys...
- DeWitts Flash Sale!
- Electric seat motor
- Digital Dash
- 96 cargo shade
- 1995 C4 No Audio from Front Passenger Speaker
- 1984 corvette rear hatch bumper
- 1989 Convertable
- Safelite windshield
- Under hood lights not working
- 86 digital dash issue...
- Name that clunk!
- Fikse wheels on your C4
- 1987 corvette clutch master cylinder pushrod bushing
- '93 Build sheet/window sticker question... charge to CPC Group Engineering Center??
- Loooong tube Headers
- Did you have good results painting steering wheel?
- Early C4 disc brake hardware kit, "H-clip", where doe sit go?
- Corvette C4 - Looking for some general feedback
- Help Needed: New Headers Causing Heat Issues and Reliability Issues
- 1996 C4 LT4 Manual Australia
- C4 L98 Ticking Noise
- Help-Why are the headlights coming on when turning on parking lights?
- Good aftermarket steering wheel
- Wave The Flag and Take Pride in Your Ride!
- My new HW corvette
- Console Lid Hinge to Console Repair
- Modifying automatic c4
- 4.10s and Canyon Carving
- Things to check when looking at a 1990 C4?
- Emblems removal C4
- C4 Mechanic KY
- C68 Automatic Climate Vacuum Feed Line Broken
- 86 Vette- whats better aluminum or iron heads
- Is it worth it? Advice Please!
- Interview with Dave McLellan
- 462624 heads
- 89 convertable
- keeping serpentine on crank pulley when working on drive system
- Any tensioner pulleys lasting? Rock Auto new low
- Mild 2 Wild Spare Tire Delete Brace
- 92 vette convertable top replacement
- LT1 D port headers on iron head L98
- 1991 sos
- Canada, BC emissions regulations for Collector's Cars
- Well this is unwelcome surprise..
- United radio for digital instrument panel
- Car being choked
- Comprehensive C4 info
- DIY brake pads/rotors questions
- 1995 vette, help needed !
- How much would you expect to pay?
- Can't find an ECM
- looking for perhaps my last Corvette !. . . but
- Early C4 Console Stickers/Symbols
- Anyone remember if a washer is behind idler pulley?
- Unclogging charcoal canister purge hard (plastic) line on a 1993
- 1987 C4 Corvette
- Rockauto Discount Code
- 93 Coupe R12/R134a
- I need Tech1a help for my 96
- C4 LT1 exhaust / best place for remote- operated cut-outs
- 87 bose stereo replacement
- C5 side skirts
- Is $15k too much?
- Belt tensioner pulley too tight?
- 94 fuel pressure issues
- 93 LT 1 metallic noise at 2000 RPM
- 1994 Corvette Overflow Tank Line Clogged
- '96 convertible top parts
- Horns - Is this all there is?
- steering column broken in two? anyone seen this?
- Convertible top leaks a little ('87 C4)
- 84 antenna disconnect in rear
- Replacement Sunvisors - Two questions.
- Best lubricant for door lock cylinders
- Should a brake caliper (front brakes) be filled with fluid beforeinstall/bleed?
- Newbie questions
- C4 Shift Knob Adapter
- 84 Corvette headlight motor question
- What’s This C4 Worth ???.
- Value Of C4 For Sale:
- DeWitts Tax Sale
- 89’ L98 Exhaust Pipe Size
- 1991 L-98 CO2 Emission data
- 1991 C4 L-98 Engine VIN and FFVE Registration in France
- Search Function - C4 - ABS
- Garage door damaged fiberglass
- Repairing burnt engine harness ID 2 wires please
- Some codes..
- 1987 L98 oil pan trouble
- "Shop Vac Flush" - 84
- Clank noise when starting 96lt4
- Wondering what part is missing for driver side vent?
- 1984-1996 Corvette C4 Gas Tank Filler Neck Boot X2263
- C6 wheels on a C4
- Help IDing front spoiler. Greenwood???
- Crank no start - FIXED!!!!
- 1986 Dana 44 Ring size confusion? Help!
- Spare tire
- Turning in the towel..
- Interior
- Bath Time
- cool early 84 vette i met. vin 875 has plate on pass side hood latch
- 85 Corvette No injector pulse HELP!
- Looking for somebody with late 1996 - 1988 to test brace.
- Smog air inlet valve hose routing issues
- Clutch Pedal travel after installing Wilwood master cylinder.
- Tech1a OBD2 cable replacement?
- Targa top fit(s!)
- How much original motor hp can handle
- 1992 Corvette Coupe Window Adjustment
- C4 timing issue please help!
- OEWHEELS Replica Silver Paint vs. Factory CE Wheel Silver Paint
- Does anybody know what this connector gors to?
- Headlights
- SES codes wont display
- Intermittent starts??
- Hood release re-design. What is your best idea ?
- Sun Visors
- Thornton Tuning Chip. Real Deal or Not?
- Doug nash 4+3 troubleshooting
- LT4 Crank Seal Replacement with question
- Ready for Pflugerville Tx car show
- Coolant temp sensor location(s)
- 1984-1993 Corvette C4 Interior Screw Kit K1190
- I need some tire help!!!
- Solar Sale
- '92 fuel fill dish becomes a swimming pool
- 1984-1996 C4 Corvette Roof And Window Front Weatherstrip
- Electrical start up problem 1992 lt1 manual.
- 89 convertible
- Wheel fitment
- ATI Harmonic Balancers 917274
- Unknown Relays
- 93 with no high beam
- Traction control makes my engine stall out
- 1984-1989 C4 Corvette Interior Standard Door Panels
- 1984-1988 C4 Corvette Sport Seat Foam 4 Piece Set
- 1987 Corvette C4 engine number location
- C4 88 User Manual
- Said goodbye to my C4
- Rear Wheel Hub Washer - Part Number 14076924
- Overdrive or drive
- Interior lights are not working.
- Failure to start
- 1985 electrical manual
- 1994 C4 corvette convertible question
- 1984-1989 Corvette C4 Coupe Body Weatherstrip Kit 7 Piece X2284
- Plugged muffler
- Big Block C4
- missing gasket
- 1986 parking brake parts. Model year compatibility range?
- REMINDER: Billy Boat Exhaust Spring Sale Event!
- 1989 TPI Idle creeps up high
- Port matching bolt pattern mismatched intake manifold and heads
- windshield wiper fit
- 1984 Antenna stuck in up position
- Missing relay
- 35th Anniversary Corvette Challenge Cars at Carlisle!
- Dad's 96 c4
- C4 chassis power limitations
- What is this component under the hood?
- 1996 Corvette AC R134A Performance Chart
- 1985 Chevy corvette right indicator not working
- Spark plug wires
- 1988 4+3 Doug Nash Reverse Lockout issues
- Forced air induction
- Need a New Fikse FM5 center? Caution.
- Bose Gold Front Speaker Drop-In Replacement
- Mid America Motorworks's seat covers
- FLAT $25 Discount on Novigo NoviStretch Front Bumper Mask
- Pics/steps of the steering wheel replacement I did on my '94
- What Gas stations have the best premium gasoline?
- Idling Issue
- Octane Booster
- Is This New EGR Valve Vacuum Connection Right ?
- C4 Seat replacement options?
- New convertible top release cables too tight
- Malibu Corvette Boat
- Interior Lights Stay On
- Back into a C4
- Help with removing coolant cap needed
- ZF6 typical noises (or not) / questions
- 1993 icm
- Aftermarket carpet and sound dampening - 94
- Can anyone help
- Is this Corvette not priced too cheap?
- ‘96 Base Fuel Pump Hanging Assembly
- 94 C4 Convertible Tirying to find Tires
- Cluster Not powering up
- Misfire From Hell
- Wheel speed sensor issue?
- Has anyone test blown an airbag from a c4 to check how well they function ?
- Aftermarket steering wheel swap question - clock spring
- Low side & high side A/C pressure switches
- Finally getting around to finishing paint project.
- Helped out a kinda local C4 owner.
- Targa Bolts Coming Loose
- April 28th 18th Annual The Greatest Show of Glass VETTESTER CORVETTE SHOW 2024
- Bose Speakers Only Kind of Working
- 20% Back On Corsa Exhaust! Get Up To $477.39 Back On Corsa For C4 Models
- Where are you selling your Corvette?
- C4 seat shells: 84-88 same as 89-93?
- I need help identifying a wire
- 93 auto shifter assembly
- Brake bleed issues!
- Value of LT4 Collectors Edition (Looking at buying)
- Chevron Techron Concentrate Plus
- Wiring 95 c4
- Front spring shims?
- 1984 Corvette v. University Student build thread
- Parts indentifying and price check
- Stuck seat belt receiver 1995 red button
- Cup holders, what do you use?
- How fast will it go?
- 1986 owners manual
- 3.45 Rear Gear to 3.73 ZF6 Worth $450?
- 85 corvette lights don’t turn on or come up
- Replacement Tires for Base 1996 Corvette Coupe
- Unidentified part 89 Corvette
- Electric door locks
- Looking for help whit back window release hatch
- One step closer
- 1989 C4 intermittent no start (possibly only after getting hot/driven hard)
- Lowering front suspension on a 1994
- Third Break Light
- C4 Only Autocross at Carlisle (C4 CHALLENGE)
- Show me your aftermarket steering wheels
- Falken Azeris FK 460 A/S
- 89 C4 First fuel pressure regulator swap any tips?
- should the dipstick tube have an 'o' ring on it between the engine block and tube?
- 84 headlight motor symptoms
- piece missing
- Throttle Body Cleaning 1996 Corvette
- Rims
- Rear hatch defrost lines- pic request
- down the emerald c4 rabbit hole
- Can you take ‘88 from soft top to hard top?
- Coolant Recovery Line (10262504)
- 84 crossfire Tunerpro RT definition file? Can we get the tuning section back?
- 89 Vette Replacing AC Evaporator Advice Needed
- C4 1991 door lock
- Lt1 crank hub bolt length
- Brake warning Lit goes off when pedal depressed?
- ABS ASR code 31 1992 corvette
- Greetings From the Rabbit Hole- Battery Replacement
