View Full Version : C3 Tech/Performance
- My Spark Plug Wires Are Getting Stiff. Too Much Heat?
- *** Custom C3 with DVD and PlayStation2!!! ***
- Vendor Price Comparison List
- 1979 wiring harness interchange question
- [ebay] nice chevelle
- [Electric Fans] who's got 'em, who wants 'em? i need brands and pics pleeeeez!
- Bubble tail, and back up lights...
- It 's off ,but I know I can get your help here.
- Califonia Smog BIll
- Vette specialist in Philadelphia area?
- Thanks sdixon! Super guy Super deal
- HEY..Is This The Same "Geopar" From The Forum??
- O/T - I made top Ten List with My Z28.
- 1974 Door "Hardware"
- Over-Exhaust Wire Looms or (Stock) Chrome Under-Header Shielding?
- OT - they shut down the highway (Rt3) that I take to work (terror suspicion)
- float adjustment on quadrajet
- Shipping a C3 cross country?
- To THe Military On THis forum
- Philly-NJ area rechroming shops?
- sex
- compression test --- how much should I be disappointed --- what next
- OK ready to pull the engine...what do i do to avoid bad things happenings???
- Water neck falacy ended
- WHAT..No Impact? I need some help group.
- Finding parts
- Seat Belt Question
- C4 guy needing help with C3 stuff....
- Lost??? Where is the block oil pressure sensor on a 72 block.
- Recomendations for a sealer for aluminum bellhousing and Muncie?
- OT Who's got family/friends in the middle east?
- Irag - Here we go.. the whistle has blown..
- Steeroids test drive...how do I like it?
- Shifter Adjustment
- Recieved my new parts today
- what's wrong with my car!?!?
- Not a good day to take the Vette out. Not a good day to take anything out -Pics-
- Anyone try installing a compent set in the rear instead of 6x9s??
- Door Interchange Question
- Help with Steering Pull Problem
- Wiring
- PT Cruiser Tail Lights
- Check my planned setup...is it correct?
- Help with vacuum hose routing
- can you identify these headers?
- How to remove the inserts
- How deep of an oil pan can be used?
- WILL IT FIT? yes again
- I'm Screwed
- Front Grill for only $1?
- BAD NEWS.....GOOD NEWS..
- Just spoke to trans shop ... ...
- How do I wire an amp?
- What is the correct number for a 1969 l-36 intake?
- 82 Collectors Edition Graphics cracking..pls adv.
- 383 Short Block for Around $1000 (plus shipping). Good Deal?
- Yooohooo!!! My motor is finished!
- Project Update: Stereo Install
- SMART STRUTS INSTALLATION
- After market shift kits??>>>>>
- Hood repair,need advice-a.k.a. "Stay the hell away from my car"
- 3.5 or 3.7 new gears questions
- BUILD SHEET
- Anyone with a ZZ4 and Holley 4150 Carb..... need some help tuning
- I know this has been here several times but.........
- UNDERCAR CHAMBERED EXHAUST
- I need pic. of the sidepipe shield from JCL.Please
- Picture request: nice door jams, other hidden areas
- Foam filling the frame?
- [ebay] rare '79
- World's worst corvette book - revisited
- my ebay ad. :)
- Don't you hate it when you buy something and it's missing parts?
- Fixed Vacuum Leak Now I Have Carb Problems
- To paint or not to paint aluminum intake?
- Rear GRILLS
- R-12 to r143a conversion?
- A"Rare" '69 LT-1 on Ebay
- Wasn't the water pump....
- Cam Break in
- Side pipes - Part 2 - Fair price
- Primer on Fiberglass?
- Going to Myrtle Beach, where is best steak & prime rib ?
- Rear Calipers, anyone ever experience this?
- Clutch options
- Zoop Seal, anyone ever try ?
- B & M Trick Shift fluid in TH350 - worth it or not?
- # locations in trans and rear
- # of bleeders on rear calipers
- OT Whats up with the POP-UPs?
- Gravity bleeding on vettes--less successfull?
- Big Block vs Small Block? What should I do?
- turbocharger
- Tranny trouble in my daily... 4L60E
- Brake Pads
- MSD Ignition question
- A couple issues, thermostat and pulley removal.
- 1979 "Z-Vette with LS-9"???
- Steeroids install pix...
- 2,000 miles!
- Compute your own Compression Ratio
- aftermarket steering wheel ?
- If You Could Be Buried In Your 'Vette After You Die, Would You?
- Trans work in Northern Delaware
- What water pump are you guys using???
- Wiper door vacuum system on a 72
- How many w/ fiberglass spring and 8" or longer bolts notice this?
- POR-15 questions
- Chevy High Performance - 200r4 article
- Carburetor parts
- Does anyone know where to get advance limiter bushings?
- Finish this project? Darn thieves are making it hard.
- AFR 5031 Polished Intake Manifold
- tach cable problem
- Finally got my first pic up!
- What valve springs to buy?
- Which mechanical pump to get!? Help.
- Overdrive trans ordered.
- C5 Brakes on a C3 ???
- Original 1979 Glass T-tops-Fair Price?
- Changing body mounts --- UGH!
- New member with general Q's
- Stroker or better heads?
- Desktop Dyno guys. Curiosity is getting the better of me.
- 1970 Convertible door striker
- I HATE CARBS! They hate me too. Dumping gas.
- #'s Guys...What Do I Have?
- New Cover for Steering Wheel
- [OT] Fuel efficiency by strapping this device on your fuel line - Is it possible?
- I can link to the post ,but not the pic.
- Sidepipes vs regular mufflers
- Mr. Bence are you out there??
- New RAM 400 Flywheel
- John Lingenfelter Recovery Fund
- '74 fuel gauge does not read accurately, where to start checking for faults
- How do I post pics?
- Cleartastic Paint Protectors
- Can anyone run a CARFAX for me??
- What is supposed to seal, hold in the rear window on a '75?
- Does Anyone Know.........
- 1969 SB exhaust manifold question
- Putting a blower on my 79 L48 350
- Anyone know the difference between early/late C3 doors ?
- W/B CORVETTE L88 HOOD FOR 80 VETTE
- Finally putting things back together ... step 1
- Any dyno sheets on 70 454 LS5 engines ???
- Royal Purple oil, any users?
- ANSEN bell housings
- LQQk here to see what I found, my 72
- Ansen blowprouf bell housing
- universal alu radiator modified.
- (OT) Audi Forums?
- Roller lifters... worth the money?
- I recently acquired a 1980, l48 vette
- are chevy fuel pumps the same? BBC guys needed
- 882 heads......
- What is a Hemi engine?
- camaro 5 speed transmission
- How to get to the birdcage for welding and painting
- Engine compartment decal for oil recommendation(CANADA)
- Did anyone see Two Guys Garage this weekend?
- YAY for steering!
- HELP! Who's got the link to ASTRO TOPs?
- Wheels and Tires - FYI
- Radio shuts off when at idle with all power accessories on and if playing very loud.
- New Guy with a question.
- Wilcox Chervy
- EngineFactory 383 Stroker?
- Why the derision for C3's?
- Engine gurus.... another question
- 82 CE on ebay at $5700 with NR
- help decipher block #
- Piston to valve clearance question?
- Myrtle Beach Run to the Sun show
- Underhood cable on an 82
- 1970 Manual Brakes
- [Misfits] Event this Sunday!!!
- Does anyone know where I can find out...
- Color of headlight actuators
- Thread files on sale
- Rare parts.....wow!
- Spotted a Callaway C12 today!!
- Lower radiator hose on a 76 fu@*!ng pita !!!!! help?
- hooker sidepipe install
- Stall converter - More torque = more stall?
- Pilot Bushing installation question
- Does anyone have "Corvette, Weekend Projects", by John Pfanstiehl
- will it fit ?
- Door won't open ???
- What is this?
- Intalled Sidepipes- most disappointing day EVER
- Fiberglass rear spring experience... anyone got a spare right rocker panel?
- More horn craziness!?
- synthetic oil - blend - (homebrew)
- Poor boy serpentine belt conversion - Pic inside
- OK, The hardest thing to do is "?" on a vette.
- Opinion on KBD Targa muflers?
- New Monospring on the Front End
- I am helping a buddy search floor pan parts-1979 coupe
- offical Corvetteforum preesence at the 50th in Bowling Green?
- Help with Poly control arm bushings
- Just curious -- chat?
- Torker II Intake vs. Weiand 7546
- Factory side exhaust keeps loosening. Any suggestions?
- Good color to compliment the body color?
- Center Grill for 73-74 on Ebay
- For those interested in turbochargers........
- Talk about stuffing wheels on a car.....
- Tach or speedometer Question
- Isn't $1,000 too much to install rubber body mounts on my '71
- Does your car have "French" on it?
- Got my antique plates..
- Where to Find Dealer Code and Dealer Zone for '72???
- Fasteners for 81 grills
- What kind of Pistons should I get???
- OT: Supporting our soldiers
- 68-75 Owners-- Did you know?
- RE: Brake Project
- Clutch Experts please. Need to help my son on his 79 Camaro
- spring in ignition lock?
- new Belgian member
- locating special '72 vette
- Dang this is an expensive hobby
- Loose Steering???
- Everything Works--What should I "Fix" next?
- I got sc**wed by Corvette Central today-sorry for the vent
- Is there an advantage to getting Historical plates in Ontario?
- Flowmaster or Walker SuperFlo's
- '68 Front Grills
- I just ordered my Hydratech power brake assist unit
- Should I buy a new block?
- xmsn help
- 1970 Convertible Ebay
- Torque converter lock up
- Oil Gage Line Sealing???
- Does a 1979 Vette (L82) have a long or short water pump?
- Show us your Headers...
- All Corvette swap meet ... Lima, Ohio
- Where were 454's built?
- Sale!!!! (OT)
- Entire exhaust system is welded together.
- Is tach affected by a hot HEI setup?
- New pics of BlackRat. (Carpet install and misc)
- A little police humor
- Weight reduction diet?
- Rear caliper mounting plate
- Question about numbers matching
- Timing Retard - How much lost horsepower?
- Early C3 Stereo Install Questions
- Crooked Engine?
