View Full Version : C3 Tech/Performance
- Spring Question
- Frame Smoothing
- mouse power.!
- c3s going up in price.
- [General]$%@# Vaccuum Headlights
- First "project" done...Thanks LarryB, Joe73, TRW & Brystheguy
- Got My Big Block Today!
- what best to upgrade trans or rear
- Engine Mount Question
- 600 edelbrock w/ XE268cam?
- Blown fuse problem
- Woohoo look what DHL brought.
- Anybody know anything about Pro-Products manifolds?
- Single wire Alt. ?
- Lost in paint...
- Convertible top when down (help securing rattles)...
- Anyone have Vintage Air AC on a 69-76.
- Mahwah, NJ Corvette Show
- Pics Of Seat Removal
- Suspension: When to rebuild?
- Transmission pan question? for an 80' vette
- Power surge when cold
- question on oil pans, steering linkage and ball joints.
- Driver Seat lean
- 196hp Bye-Bye
- Gasket or not?
- What should I do with the old suspension parts
- OT: Darn it I didn't make the list. Again.
- How do these emissions numbers compare?
- Holy Bananazzz!! How NOT to autocross !!
- another *$!#@ hurricane
- need help choosing accent color for Brandshatch Green
- WWW (Water Wetter Works)
- Need help setting clock on 81 CB radio.
- Winter storage tips?
- [OT] The nuts I share the road with!
- Distributor vacuum
- Mass at it again! HB 1722 is on it's way to becoming law.
- What grade of gas do you use on an 82
- need help with air dam
- Manifold sealing, how do I make sure this time?
- {how to:}More air flow from the vents
- Looks like i'll be getting a new wiring harness installed.
- My spare tire weighs......
- A/C Conversion--alternatives to R134a?
- LARS -Speed Demon 750
- Brake caliper rebuild/powder coat
- "Factory style" sidepipe tubes w/STS baffles
- Dist & Carb off to lars
- My car is also featured in Corvette Enthusiat, November issue.
- A sad story with a safety reminder!
- New pics of BlackRat what'ya think? (Dial up beware)
- Need help...Speaker install on my 73 vert.
- Radiator advice
- How do you remove the big bushings from the rear crossmember
- Pulling a vacuum for a/c conversion
- Van Steel T Arms and Muskegan Brakes finished
- Who makes a good stainless exhaust system for 69sb
- I tried to start my engine tonight.
- Governator signed AB2683 today :(
- tach problem on my 78
- White exhaust smoke coming from the right side only
- Distributor Removal Question
- Spring and pocket alignment
- A/C Vacuum Switch Testing
- [San Antonio] Hills & Dales Classic Corvette Night redux
- BB owners using stock exhaust manifolds please enter.
- Clutch Return Spring??
- Haynes or Chilton?
- electric fan question
- Legislative Alert, Final Countdown
- '68 Dist. and an HI-6
- What to do with exhaust grounding straps.
- My car got the Cover and a feature story in the December issue!!
- 1968 427 390HP Convertable Value? Help
- What are the quietest performance mufflers?
- 82 Glove box partitions, removable?
- 75 Vert Body-off Resto underway!!
- FYI - Valve Timing
- I met the annihilator this morning
- Paging Lars......
- prt 2 of my other post on my stingray
- Has anybody bought an engine from these guys???
- How do I take the body off?
- Value Of 68 Convterible 427 390HP??? Help
- Anyone have or used this manifold?
- check out my new rims & tires
- Help with stereo wiring
- How soon to prime the engine?
- Wierd buzzing sound at high speeds.
- Greenwood C3 Corvettes at Carlisle
- rear crossmember modification
- what is best carb/manifold for 427 L-71 435hp??
- New Corvette owner needs help with rear sway problem
- Dual Snorkel Air Cleaner for '76
- Any good way to measure cam lift?
- Pagging Jughead BBC question
- water pump problems
- AR RACING 383 stroker---sound clips-just started
- Door Panel Replacements
- Extra parts for '72
- Your opinions on these please
- Newcomer Needs Help w/Tach
- Have you had to rotate Alternator cover?
- Early Cutouts for Hooker Sidepipes
- Air Pump 1981
- Speedo Cable
- Cam swap gone wrong
- Pics from the funfest
- spark wire placement
- Painting interior parts ?
- interior is here
- Distributor Help/Suggestions/Recomendations
- which transmission do I have?
- I think today my engine is finished.
- How Do You Think This AR-Racing Engine Compares to...
- 69' BB Tri-Power bogs @ take-off
- how much HP will the stock IRS hold.
- carb power valve question
- Radiator Shroud 79 L82
- ZL1 Corvette Info
- Factory Frame Coating / Paint
- What's an 82 Claret Red Coupe with 8750 Miles worth?
- How is HP measured on crate motors?
- Another Timing Question
- Stopped and looked at a '73 coupe...
- Pwr door lock actuator - 1980
- Good By Old Brownie
- In all seriousness how much could I get for this
- Anyone with a mini-blower(142, 144 or 177)? What hood?
- You gotta know these are show cars we drive
- Fuel Pump Recommendation
- Cylinder head dilemma....
- Water temp sensor replacement?
- what's a good price for this 68?
- Just ordered my cam swap parts
- 1975 rear bumper that looks like 68-73 rear?
- Aluminum radiator questions
- Pwr Steering
- Question about chassis dynos
- Battery light and choke light stay on.
- Why do people feel the need...?
- OLD vs. NEW My review of my 61&72 vs. 05
- Anybody have experience tuning Edelbrock carbs?
- Need help identifying this car
- No fuel,No spark, No start.....No fun.
- How to locate TDC without a timing pointer?
- Trouble getting freeze plug to seal???
- Any Funfest pictures out there?
- c4 seats
- Need your advice for radiator replacement
- Stripping clear coat..
- CF Freebie!
- Done early?? I've got extra parts
- Cam swap disappointment - mismatched heads
- aftermarket seat advice needed
- Picture of '68 corvette backup light switch?
- Camshaft Installation question
- Motor oil spec/info chart
- "Bulb Retainer Replacement"
- need some aftermarket seat advice
- Engine pics from car show, interesting (and Cheap!!) underhood mod
- Gage Panel
- Performer won't work with Q-jet?
- Upper ball joint poly dust boot
- original engine paint
- Someone had a bad day....
- 69 motor 350-350, whats the worth?
- Found a cool article on engine balancing
- [General] What holds a 80 - 82 bumper on at the bottom
- Hooker sidepipes and ls1 or ls6 heads
- Suggested Rebuild Kits
- SBC Header Questions
- BB by-pass hose to water pump.
- Whereabouts of Clutch Safety Switch...
- Strange brake issue
- Trivia Question of the Day
- Front Bumper
- new radiator-lower temp
- Is There A Relationship between These??
- Greenwood no longer sells c3 parts?
- Stock Radio Upgrade ????
- What rear-end gearing does a 1980 L-88 have?
- finally got new motor
- Wide 15" tires
- Come out and see The Stingray Shark Girls !!
- Engine Lowering?
- Anyone looking to buy a 625 Demon Jr.??
- Head Chamber 64 or 72cc
- Valve cover screw in baffles?
- Gas Tank Alignment (1980)
- E Type Jugular
- Front Spring Install with body off.
- Gutting Cats....
- A few engine questions, simple repairs and cleanup
- question on door panels ?
- cragar ss's fit
- Stereo Ideas please.
- Rear side markers
- Jughead's startup?
- Medium saddle interrior all different shades
- what color???
- Timing and Ignition Issues..Please Help
- Exhaust System
- Early-C3 Big Block Serpentine Conversion
- Secrets to adjusting T-Tops
- HEI spring kit
- How to put threads on a rod.
- How to store a spare gas tank?
- Chrome Back End?
- I want to buy a C3, need help
- ODDservations and notes from Interior Job
- Please help me diagnose new problem with AFR 195s
- 68 L-71 Heads - Square port or Rectangle??
- Wheel Opinions Please
- Readers Rides in Corvette Fever...
- Drag Racing Picture
- Quick Question...what are vacuum secondaries?
- Front Wheel Bearing Seal - Orientation?
- Triple grove Pulley...?
- How do you get a home page on Corvette Forum?
- Frame Reinforcement ????
- What Can be done to an 82
- Fan blade size
- installing my COBALT tach---wire placement?
- starting problems
- Removing wiper door
- Fiberglass floor repair question
- WILCOX Corvette, Good Vendor???
- Performance: C3 vs Imports
- I don't see body shims
- Can the kick-down switch be adjusted?
- 5/6 Link Update
- Jay Leno's angry response to AB2683
- 80 - 82 Seat ?
- Question on plastic oil line
- Is this tach circuit board toast? (PIC) Can I test it?
- [Tech] Explain the difference to me.
- Pics of Interior Completion-NO DIALUP!!
- BB aluminum head gaskets?
- Body Drop Tomorrow
- TH350 Will Not Shift at Low Rpm's
- Q-jet choke assm
- Octane Boost that works!?!
- lower A-arm bolt frozen!!
- JC Taylor for Insurance???
- gear head eng stand
- Roller Rocker/head to valve cover spacers?
