View Full Version : C3 Tech/Performance
- 69 vet rear
- Richmond 6 Failure? Adjustment Issue?????
- Racing harness?
- Keisler 5speed trans install trouble
- Ever come across any Holley 950 main bodies/throttleplates?
- Header Height
- Strong Gas Smell
- retorque necessary with felpro rubber/shim head gasket?
- How to troubleshoot temp gauge?
- timing conundrum
- 1968 327 Coil
- Just started motor, do bigger pipes make it run lean ?
- Weatherstrip Installation?
- Installing Van Steel front end rebuilt kit tomorrow. Any tips...
- Bad motor ticking 1971 sbc
- Anyone use Vintage Wheelworks?
- Frame twisting question???
- Do I need new rear leaf springs????
- Exhaust question
- ocatane level
- Intake question
- Gage console short
- Electrical question on '71
- Horn Cap Removal on a C3
- What rear gear to run?
- Follow up to fuel starvation. . .
- Spec for power steering fluid
- fuel restriction?
- Head and cam install
- K&N air filter in L88 hood,what part #?
- Seat belts
- Sagging rear end (in the vette that is)
- 1980 rear end
- 79 power steering cylinder grommet replacement
- 427 Valve Cover Question
- Help adjusting 69 ignition lockout with 4sp
- ac change over
- Z06 wheels
- Question Vacuum System - Please help
- Those with AFR heads
- Weatherstripping on Door (Pictures wanted)
- [video] Went to the track... Problems again...Need help..
- Where can I get an A.I.R. tube?
- Brake Bleeding, all bubbles- little fluid
- converting to lt1 tpf
- comp cam magnum roller rockers guide plats yes/no
- Understanding our lights.
- Transmission Shift Points
- Gear choice help
- Spring tune up
- tranny/torque converter problem
- Easy out question.....
- Reinstalling intake and have question......
- No wonder it wasn't running right
- Drag radials
- Brake Line Measurements QUICK!!
- 79 T-Top came apart. What should I use to put it back together?
- Pilot bearing/ roller bearing? also Gear Lube question
- Displacement Question
- door handle?
- rebuilt trailing arms
- Power steering is dead
- Any homemade alternator or power steering brackets?
- line lock switch
- HD rear components??? Who makes these?
- Door shims
- Powerdyne supercharger
- 3.73 gears
- Im starting to see some blue smoke at start-up.
- Air Cleaner/Carb clearance question
- 71 Door switch replacement
- valve seal change info
- Storage Compartment Carpet
- goodbye 2.25, 2 into 1 w/cat, hello 2.5 true duals
- Can you bench test a tach circuit board? Problems.
- [BG Speed Demon] issues at idle
- Recomend a replacement shifter 4-speed
- headlight washers on a 69
- New 3 inch exhaust is in !
- Magnaflow mufflers - Corvette Central
- 81 computer
- Instrument Lamps (Fuse) ?
- Jacking-up 69 with factory side pipes
- Clogged Carb seat/needle
- Will the Fuse Panel come out?
- Which Bilsteins?
- any interest in posi kits
- Replacement carb questions???????
- Roller Rocker Questions
- What's a good price for what I'm getting done?
- Problems w/ Stahl SBC headers?
- Corvette won't start.
- Passenger Side Power Lock issue
- steering issue
- Need Tire Pressure
- Cowl Induction hood?
- SDPC Vortec Kits: what's the diff in these 2?
- Fuel tank or external pump-TPI
- Body Mount Torque Specs
- older heads on a newer style motor
- centerforce tried...and failed
- Short shifter for a C3
- Torq.# for Valve Covers??
- OMG I got Unilite Shocked!!
- Removal of air pump on '82 crossfire, any problems?
- question
- adhesive for '78 'glass nose
- Shock mount not all the way in
- Brake bleeding-all fluid no bubbles-No Brakes
- MI Alignment Shop-Woodward Area?
- Manual transmission shifter rod adjustment
- Alignment Specs Opinions Please
- Can headlight switch in 79 leak vacuum?
- Tire sizes?
- sidepipe cover paint
- Can I put a block off plate in place of the EGR valve, any problems? This a '82 cross
- thinking of going back to ported vacuum
- What engine do I have ?
- Electric Water Pumps Redux.....
- Don't start anything...
- Bleeding Brakes - I know this has been beaten to death !!
- Cragar SS wheels with adapters.....
- I would like to start doing my own alignments.
- Q-jet power piston stop screw
- brake booster
- 70-72 owners...how did you modify your exhaust tips to fit 2 1/2" pipes?
- problems finding side yokes for 1980
- Hood Support HELP
- fiberglass repair
- Help!!! Rear Suspension
- Fuel Filter Location
- Any one in Indy have a shock mount removal tool?
- Anyone try these trickflow heads?
- Front Suspension R&R procedures
- Fuel Delivery
- New CD Player
- Found my electrical gremlin!!!
- t56 Transmission with original 350 small block
- 502 CARB (continued from 3"-2/12" exhaust thread)
- How does my Printed Circuit Board look?
- Holley carb & Edel intake I.D. help??
- Adjusting solid rollers.
- Casting number for 73 BB Bellhousing?
- CD player illumination wire
- LT1 Six speed C3
- LT1 Six speed C3
- Fuel Tank Question
- Thick or thin front seal?
- '81 Computer removal
- fuel tank
- Tach Filter
- Lean popping at cruise ??...
- Need to get my antenna down
- 4 hole spacers and vacuum leaks
- Thinking of running this clutch. Suggestions?
- Open intake ports or leave them stock?
- Tilt/Tele in a 68
- Odd problem
- Removing ignition shields for 69
- Clutch decision?
- Big Boom!! Help
- Steering Damper
- anyone have a factory trailer hitch installed ??
- problem with low speed A/C fan
- Rear Diff Posi Fluid Question. Please help
- Need hood clearance to carb What hood
- Best way to fix rusted / rotten floor pan
- Temp sender going bad?
- Door gap filling?
- Speedometer cable broke today. Help, please?
- Headlight pop-up fix
- Going "nuts"...
- Will Moroso Oil Pan fit on 502 / 70 Vette?
- Problems with my new 700r4, help please!!
- 71 Tilt/Tele Steering Column has a lot of play
- Stupid Strut Bracket Question
- Back up lights wiring question
- 75 Distributor concern
- Radiator support pics and Danger Dave PSA
- Unknown geared box on speedo cable at tranny ?
- cheapest rear wheel bearing ass..
- Car won't start when hot.
- 2 column questions need a little help
- What should I replace/check while I have the transmission and clutch removed
- Vents behind rear windows???
- Help with 82 door mirrors?
- What din for welders mask??
- govenor on 82?
- headlight relay valves
- Straightening "wrinkle" in frame?
- shifter console repair
- Loud sucking/vacuum sound at carb
- Dies at idle
- Low-Dust Brake Pads
- Transmission Spacer for sidepipes
- GM 502 Crate Motor --> 2.5 inch or 3.0 inch exhaust pipe?
- C3 Tech, your input is requested...
- Frame prep...
- Anyone with their radiator support handy ?
- ZZ4 Spark plugs. Two options available... any differences?
- 81 Steering very "Darty" help
- Q-Jet Problem
- Carpet installation question
- Power Window Problem
- Installing an MSD distributor
- Idler Arm removal
- Edelbrock performer intake and hood clearance?
- Cam and fuel economy
- Mallory Unilite wiring..am I right?
- 427 ci small block = fun and good MPG
- New SLP 17" 5-spoke ZR-1 wheels for us!
- C5 seats in a C3
- Side sag??
- Removed transmission, worn splines?
- Need Help! Almost lost a wheel!
- Help please
- Rookie Question: Upper A-Arms, which is which?
- Another Alternator ? on Volt Sense Wire.
- Windage Tray?
- BBC Harmonic Balancer
- Engine S/N Decoding
- Distributor troubles
- Will it Fit???
- Can someone plug this into Desktop Dyno?
- body alignment dilema
- Replacing Exhaust on my 81, Need help
- Paintable Water Sealant for Cowl Area?
- How can I tell if it is a fuel starvation or ignition problem?
- What brand/kind of spark plugs?
- Newbie question...
- 1980 Dana 44 reinstall questions ?
- washer fluid motor/tank
- bleeding...overlooked issues
- Headers & Side Pipes ???
- Trailing arms
- Power steering Valve rebuild
- Steering questions?
- Wiper motor help
- Radio
- Need a quick measurement, help?
- What happened to my clutch! ^*%$#@*!
- How many cc's??
- Fitment issues for 18" wheels?
- Reuse Head Gaskets??
- Rear Wheel Lean In
- Ceramic coating combustion chambers?
- Started assembling power locks and keyless entry for my 69
- Anyone know anything about 14101128 '86-'87 aluminum heads?
- Tricks for Removing Seal in PS Hydraulic Piston
