View Full Version : C3 Tech/Performance
- SB 400 Heads
- bolt holes in the engine
- rear end yokes
- Older Crossmemebr for a 1980 with a muncie spd?
- 76 w/power brakes master cylinder question
- T-Top Question
- Truck Vortech head swap- parts?
- Lowering a 82 c3?
- Fuel Line/ Lower Radiator Hose
- Squeal coming from Power Steering Pump under load
- EGR valve
- Big engine related mess..
- o2 Sensor Guru Needed
- Does anyone have a breakout of the headlight switch?
- Friday night diagnosis come on in let's start
- What kind of sway bars should i put on a 72?
- C6 Wheels on a C3
- GM Performance Parts Serpentine in 1970 BB with A/C
- To Flush or not to Flush that is the question???
- Newbie needs help with leaky carb (350 '72)
- Electric choke. wiring. on 77'
- BBC XE274 Cam Question
- Need Help! Installing 350 HO in my 80'
- Trans Fluid Lines
- URGENT HELP: problem installing distributor
- F-Body Seats?
- Port Match Intake to Head Worthwhile?
- Rams Horn manifold vs Headers
- Swapping L-48 with 350 HO 330HP in my 80'
- Will this work to paint inside my frame?
- Starter Wires and Fusible Links
- Carb advice needed....
- power brake booster
- Exhaust manifold to engine stud removal-STUPID QUESTION
- driven speedo gear for THM400 with new 3.73s
- 400sb
- ATF Confusion
- 1971 350ci 270hp
- Window Question
- Slowly but surely
- tire wheel combo with offset trailing arms
- vert top replacement
- Exhaust System-Corvette Central ?
- Alignment - Converting inches to degrees
- Sending Unit Location for TH400?
- C3 Ground(s) how? where?
- wot fuel cut off
- Engine dies at idle
- how much HP will my 73 drive train handle?
- Interior Brake light on
- 81 headlights won't retract
- What would be a good side pipe
- Air intake question....
- Returning to C3 Aerodynamics
- ls6 intake match oval ports head?
- fuel line....how big?
- what are these 2 relays?
- want to confirm if this is a master cylinder problem?
- heater hose hookups
- 72 BB, A/C hose ruptured
- Black wire from Thermal Limiter
- What is this purple wire from A/C harness
- Power Steering still not right
- Engine Missing
- Front Alignment-Puzzled
- Tranny oil dipstick on 72 manual?
- Pace Car front spoilers re-painted
- Help rebuild PS control valve on car
- Speed Bleeder Valves
- How good is the bottom end of a L82?
- Stock 350 2 bolt or 4?
- Desktop Dyno says +47hp with piston swap, possible?
- cast or forged
- Speedometer rebuild
- Can't get enough neg camber on frontend . . . HELP!!!
- Mystery Breakes
- Random Power Loss
- Back spacing
- Test Wiper Switch in Car?
- Brake Bleeder Valve
- Car is pulling very slightly to the left, more with brakes applied.
- What is the best Multi Spark Discharge system?
- Question: 350SBC Torque vs HP
- Two quick tach questions
- A/C Removal only leaves one belt?
- New Radiator & Fans for 1980
- Rally Wheel Caps
- diff rebuild - 800lb spring pressure?
- Replace Vacuum Storage Tank
- alternator plug?
- one wire alternators ?
- What causes this?
- Sat for 1+ year(s) and I can't get it going
- Racing pedals for your C3
- vacuum canister question
- engine running cold imo
- '73 Sway bar, missing or RPO?
- Fuses
- How Secure is a Rad Re-core Done Competently?
- how important is oilpan windage tray?
- Distributor with Tach drive????
- "Vettes Doin' Charleston" C3 and C4 Class Pics
- Rewebbing camaro/firebird seat belts
- How safe is 0.060 overbore on a SBC?
- Need Help with Vintage Air
- 700 foot pounds of torque 4 speed??
- electric fan probe?
- 69 Coupe Rear Storage Compartment
- 1978 Vette pouring white smoke after WOT
- 82 vette collectors edition - problem
- Motor mount source??
- buzzer warning wiring hook up pictures WHERE?!?!?
- Rocker Mouldings too long?
- Anybody Used This Thinging Before???
- roller rockers and stock BB valve covers
- Clutch adjustment - a bit different ??
- 72 horsepower
- shark bite rear end? how do they hook up
- Breaking in engine....
- What's it worth?
- Newer rear end in older model?
- Gaskets
- C5 interior?
- 200r4 Yoke/driveshaft problem
- brake problem, C3
- Holley single convert to double pumper?
- 79, sat for 12 years
- PS Control Valve Setup Pictures
- 1972 Engine block
- No wipers at all - Help!
- how much does just the body weigh?
- Damn....Just trashed Diff fill plug
- Help With Hydroboost/Steeroids Connections Please
- Power window help
- 6speed Richmond gearbox problem
- water contaminating fuel system
- Stock Interiors Carpeting
- A Little More Timing Help Please
- Grounding strap question
- Vizard on 106* LSA vs 112* LSA in a BBC
- VIN number and engine
- 1979 Gymkhana suspension 7 or 9 leaf and how wide is it suppose to be?
- New 3.5" Exhaust and Pypes Mufflers
- Seam in the front door jambs
- Tuneup help in Milwaukee
- ??? on 68 Differential Crossmember w/ pics
- quick carb question
- dumb noob horn question please
- Need Help Replacing Window Regulator Gear
- 75 Telescopic Wheel doesn't lock
- Lokar cable alignment
- I say 10.2 they say 9.4. It must be the new math at Popular Hot Rodding!
- Crown & Pinion
- More about LED bulbs
- Electric fan conversion guys - check this
- Help with body mounts please...
- Reverse Light Harness Hook Up
- Headlight Headache..
- Fuel gauge problem
- hurst shifter
- Control Valve Question
- Painting with or without bumper covers installed
- th400 kickdown quit
- Water Pump removal - Krud removal
- Engine Oil Gauge Pressure Line, Small Block, 1968-1973
- Hood clearance?
- What is this?
- Hardtop install
- WOT Off Idle Acceleration
- Easy way to put in new door hinge pins
- Alternator ID Please
- is this the original engine
- How to disconnect parking brake?
- Do I need longer pushrods? (Pics)
- 72 sb oil pressure problem
- Time to order new gears, diff guys help please...
- Engine knocking
- Throttle linkage clip
- Heater Hoses conections and belts after ac removal
- Correct rear differential lube for 76
- E Brake Fixes?
- Its slow, leaky, noisy but its got class :)
- HEI no spark to plugs
- another speedometer question
- 1981 Wiper Harness Diode Size?
- head gasket
- sloppy 4 spd shifter
- Hydraboost High Pressure Line Question....
- Proud owner of a 1973 Stingray conv. Just need help with a few minor details...
- Triangular air cleaner modification
- Anyone put 70-77 Rocker Panels on a 68/69?
- Carroll Shelby for ZMAX
- Installing new core support in 76 w/air, need opinions on technique
- What size spacers? 1982
- Power Door Lock wiring in my '79
- Power Window Problems
- Couple of Problems..
- Adjusting shifter linkage (again)
- Best headers for the $
- Cross Shaft Return Spring
- You know its Dos Equis Time when;
- ground strap
- Which terminal on the dimmer switch is for park lights?
- "The Big Block From Hell"
- Does anyone here have a set of these rims?
- Need someone to rebuild rear end.
- Cam swap without pulling engine?
- Performer intake
- How to check / replace diff lube?
- Weird electrical/battery problem
- HELP!!!! coolant leak
- Vacuum Cannister plumbing
- Replacing fuel line....
- Fitting VBandP Smart Struts - Advice needed
- Home Alignment Results
- 1980 misses at about 1500 RPM: Help
- Coming to Dallas@Oklahoma
- Manifold / Exhaust Donut ????
- Starter help!
- Air Conditioning Advice Needed on early '77
- hydroboost install question
- Everybody likes dyno numbers
- New Holy Grail:Forged crankshaft US made
- Orange County CA engine part shops?
- 10% off Speed Direct, Steeroids, etc.
- 1969 fiber optic help please
- Recommended Timing on MSD 8572
- Summit SUM-EVAPORUST Rust Remover
- help changing alternator pulley
- Edelbrock intake
- Drain Cock for 81
- How much to shorten driveshaft for a TKO?
- Size 13s and the Brake Pedal (A/T)
- Turn signals
- Wanted: official GM specifications of the 454 LS-7
- First turn over.....
- a strange spark plug wire problem...
- 1969 Restoration Pix
- 454 number template 72 hood
- How much will a camber change, change toe in or toe out?
- no low speeds on AC fan
- The last Spal Wiring thread........
- shortblock opinion needed.
- BBC Dailey Driver Cam Recommendation
- 6-71 supercharger
- HEI Distributor
- fuel tank comment- chime in please
- What headers to use with ZZ4?
- Video- Mechanical to Electric Gauge Conversion
- side pipe covers
