View Full Version : C3 Tech/Performance
- 5.3 lm4 with vette pan-problem!
- Mallory Unilite vs. MSD or Stock?
- Seat Belt help needed
- 81 auto, ujoint part numbers for acdelco
- air cleaner assembly
- Is everyone still comfortable with 9.5:1 on Iron heads?
- bUMPER REPLACEMENT
- Starter motor removal with headers
- New tires and wheels?
- 350/383 engine build advise requested
- Is the choke pulloff
- Wire soldering problem
- Carb Recommendation?
- corvette central exhaust
- 76 to 78 rear bumper
- Brake pedal removal
- Body mount replacement on 1980
- Broken Bleeder in Front caliber - HELP
- Mid to high 11's on BFG street tires? 500hp 406?
- 72 Steering Column Shroud Rebuild
- '71 Body Resto - Primer time
- Did a little 1/8th mile racing last night...
- 76 exhaust
- cam options for 78 w/base engine
- Actual Tri-Power Carburetor CFM Flow
- strange find on front spindle
- headlight question for 68' coupe
- Quick Question
- I need some help, guys...
- Performance upgrade options when building a 1969 L46?
- using an auto as a manual
- I think timing chain and or gear
- Pedalin Around
- Quick brake question
- Bellhouse vs Flywheel
- Rear main seal leak
- Power steering pump pulley help!
- Rear suspension bushings which ones
- Both wipers and air quit
- New guy exhaust question C3
- stock radio with vintage air?
- Largest cam I can safely install in a completely stock '70 L46?
- 80 Strut rod Removal.
- Sema 2008
- Y'all asked 4 pictures of my brake bleeding
- 76 C3 Newbie rear end question
- 74 rear bumper license lights
- What could be wrong?
- Roll Cage Fabricator Recommendation in Phila Area?
- 383 Build
- Strange Power Steering Leak Question
- Rear-End Ideas?
- Protect-O-Plate mystery
- 1978 Corvette Spitting/Sputtering When Gas Pedal Is Stomped?
- Polishing journals
- Engine-heads input appreciated
- Help fitting front valence panel on a 1980
- My power steering pump pulley is loose HELP!
- looking for member
- Dropping Tranny
- 290 HP Chev crate motor ACDelco/Mexico?
- any tips on replace heat core
- choosing cam and heads?
- Big Block Alternator Set UP
- Removal of power cylinder
- hot start flooding
- rear sway bar bushing question
- Steering column movement
- Anyone else having problems with the comp cams/FAST system?
- trans pan bolt on 76, auto 350
- Composite spring Rubber vs Polly
- silicone for vacuum hose seal?
- rubber bumpers
- Whats the correct way to cneck th350 oil level?
- 275 and 255 Tyres to C3
- noise from driver rear wheel? need help
- A/C Compressor Specs
- 355ci build (opinions needed)
- 1969 Fender Louver trim installation
- Under dash vacuum hoses for headlight over-ride
- 327 id
- C3R Retro - could be cool!
- Vacuum Line Schematic
- removing interior for heat/noise insulation
- having some electrical troubles, may be self inflicted
- Is my tranny shot / tired / in need of rebuilding? (77 th350)
- Will it fit or will it rub?
- R. Hamilton In the Dallas Area
- Front coil/control arms
- Questions about a 454 swap from a 350
- Vibration on 1978 vette
- Almost no vacuum @<1000rpm & erratic idle after head gasket change?
- 200r4 w/D5 converter stall question
- 68 rear brakes?
- New 406 Build
- Astro Vetilation Help. adive, tips!!
- Air compressor problem
- transmission cross member for 69
- Composite Spring ? What's good & What's crap?
- Tripower update
- muncie 4 speed
- SBC AFR 195 Eliminator and Hooker Sidepipe Headers - Will this work?
- new rebuilt dist. also brand new carb for sale
- Big, big, BIG BROWN TRUCK just left!
- 68 Steering Column Firewall Bolts?
- Extend Your "Maintenance-Free Battery" Life
- clicking sound when turning to the right
- Building a body dolly
- valve adjustment
- Distributor for '69 424/400 wanted
- Suggestions for complete rear bearing assemblies?
- Collapsed steering column?
- What has happened to my titanium rotors
- E-brake light coming on when braking
- transmission rebuilding video
- Move body on frame?
- ID moly rings - Difference in appearance
- VB and P Suspension
- Driver seat replace...
- carb leak
- #2 and 3 body mount question
- ride height baseline 79
- Starter question
- Fan Belts on 73 Big Block - do I Have a kludge set up?
- Timing for a 383 w 350/350 cam, vortec heads quadrajet...
- Battery Tender hook-up
- Auto Trans shift linkage
- P-Valve Removal & Spongy Brakes
- Looking for EGT data
- Shocks ! How can u tell they're done ?
- Pushrod Length for Vortec and roller lifter mod.
- Power booster noise
- stress sound on my steering
- 74 vatte resto
- Oil temp gauge
- Gas mask as a paint respirator
- 69 Clutch Linkage -HELP
- Brodix IK 180 ?
- Why would I need a double roller timing chain?
- heater vac. hose
- 1976 vette weight
- Qauter inside trim... Repro or used.. Advice needed!!!
- 74 carpet and seatbelts install
- 600+ cubic inches ?
- [dominator on a 355 chronicles] Got my intake
- GMPP Fast Burn Aluminum Heads?
- Tubular strut rods w/spherical rod ends
- OMFG how do you get to the rear drive shaft ujoint bolts 81 auto
- Pull It Out or Leave It In...
- Which muffler would you prefer or recommend for a great V8 Sound?
- Looking for Local Help
- 69 Fuel Tank Question
- How To Tell If PCV Valve Is Bad
- holley spreadbore gm replacement carb..
- stuck float?
- CRC Throttle bracket
- What's up with distributors
- CRC throttle cable
- 72 seatbelt warning ?
- Vintage Air and Ls1 suggestions!
- Vette mechanic - Western Md or Tri-state area?
- smog diverter valve
- Pressure in gas tank
- 74 Exterior Black
- Safety wired fasteners
- smog help
- BMW wheels on C3
- ZZ4 crate motor ?
- 73 4sp.linkage alignment
- air cleaner hell
- Carpet installation help please
- Anyone do an LT-5 swap?
- Flat Top Pistons
- Torque spec for leaf spring center bolt
- heater hose routing on 76, 350
- Will the factory tach in an '81 work with MSD?
- possible 383 in the makes
- Opinions on clear coating frame
- carburetors
- Throttle Cable Repair Kit??
- Motive brake Bleeder
- Steering Box Question - '79 Vette
- help lifter sound
- ignition stuck ON! i.e. can't turn the vette off
- anyone using grant anti theft?
- Plastic Clam seat Repair?
- Fiberglass and floor pan repair question
- Vibration only at highway speeds
- Acting like Battery is dead
- Rear end scraping noise on 77
- New Intake Man Can't Close Hood
- detent ? cable
- C3 HP Kings
- greasable u joint failure pics
- 1976 underbody + Seatbelts
- help setting the idle on my Qjet
- ported vacuum and pcv
- Last drive before storage and strange noise..
- Headlight Operation Question
- jet coating
- THD400 to Tremec 5 spd final results
- Another V.I. R. thread
- power steering help needed
- My heater hose shutoff's
- Block # 14015445, bad or good?
- 72 idle stop selonoid ...explain how this works
- Motor start up, new cam, etc.
- Do you have this on your 72?
- Does your's do this??
- big block swap
- Having some heads rebuilt and need advice.
- oil consumption
- Pillar-post weatherstip woes
- npp c8 zo6 dual mode mufflers mounted on 77 c3
- fuel filter on Edelbrock 8867?? On 72 vette
- OK - I'm stupid - where's the headlight breaker/fuse?
- stainless headers f/s on ebay
- T&T column: repair lock shoes while column is in car?
- Problem with reinstall of door handles-lost in door
- seat replacement opinion for 1974
- Guru's please analyze cylinder pressures!!
- exhaust manifold help
- Rubber bushings on front of Radiator
- Carb heat shield installation
- C3 New Frame
- Leave Stock or Rack and Pinion??
- Question for www.vansteel.com
- Could broken piston rings cause engine over-heating?
- Shifting too hard - help
- headlight madness
- shifter seal
- 72 kickdown wiring
- Cam I.D. please?
- Steel cap for Dana 44
- GM C3 Alignment specs vs Performance specs
- restoration project day two - it runs
- What next?
- harmonic balancer question 427
- Buying a C3, Advice?
- Bracket Racing results - repost - Is it working?
- Carpet replacement options
- Vortecs. measure clearance with stock aircleaner.
- Drive shaft removal on a 1980
- pvc valves
- Bodywork update from my little mishap.....
- speedometer error
- Any Supercharged C3's out there?
- Iac 1982 cf
- Who home powder coats here?
- Carb parts
