View Full Version : C3 Tech/Performance
- Comp Cams CamQuest and Deskto Dyno Accuracy
- just getting started
- 427 head gaskets
- Look of stock 427/435 pistons
- rear end side yokes
- C3 DIN Radio
- Voltage reading
- using stock 73 cowl induction with a holley....
- diy TH350 SWAP FOR NEW TH350...
- Rocker arm broke clean off
- Ls1 swap wiring harness question
- Piston Install(Caliper)
- Rally wheel question
- crud in motor
- Idler arm bushing...missing?
- initial timing on 73 350
- Intermittent Turn Signals
- Stripped Distributor screw mount.
- Just one more fuse question pleeese !
- Parking brake tool
- Intermittent ignition problem
- need a quick answer- m22 in an 81 model?
- 68 transmission swap
- Bilstein Shock Not Compressing
- '77 wiper blade length
- Carb Rebuild
- In Dash Headlight Wiring - Baffling Wiring
- Brown Wire - Baffling Wiring
- Steering Column - Baffling Wiring
- 74 L48 Distributor Help
- 1969 427/435 ignition and timing questions
- 427 Tri-Power tuning help
- 1980 Steering Control Valve Play
- throttle cable bracket for performer airgap
- not able to close side window
- Bell housing for an 81 4 speed car-where to find?
- Lars chart
- pinion seal change diff out.
- Best GM intake manifold?
- Silly little lighter question...
- 79 Horn & Tach
- Help with GM induction coil please.
- 68-70 Remanufactured Stereos
- oil capacity for 454 - 1971
- fixed a couple issues ...now a third comes up..
- Need help with my 82 Corvette:
- left front tire clearance problem -pics
- Question on Dyno Results
- Fastburn 385 fit in a '73?
- Seat hinge cover,,(help)
- Help with A/C system
- 1969 Horn
- 82 wiring diagram needed
- Is 3200 RPMs too much?
- removed third member today
- Fast Idle and Engine Run on
- Ignition / starting problems...HELP!!!
- Temperature switch in my 1982 700R4?
- Speedo calibration
- Rear camber question
- Aluminum Radiator
- Steering feels notched
- tires? where to find
- suspension upgrades?
- Carb issues on my new to me 1974 L48.
- Choke on a Carter Quad
- brake warning light flashs on/off
- C3 aftermarket headlights?
- stainless steel parking brake shoes
- 1978 Differential - Repair Help & Advice
- 200r4 tranny
- My Personal Paint Thread
- backfire through carb
- Dual Points to Pertronix, Crane, or full MSD
- OnStar Mirror
- backup lights staying on in 72 vette
- 134 amount to recharge?
- `1979 Cruise issue...
- Another Guage Bezel Question
- 350 zz4- fuel pump push rod- whats the trick?
- Suggestions on how to change plugs on a 454 with AC?
- What should u-joints feel like?
- 74 radio removal
- alternator amps
- 68 Hood Alignment Issue
- anybody recognize this part?
- Spark Plugs heat range for 10.5 CR engine.
- pulled the rear main bearing cap, is this a problem?
- Turn Signals - 68
- Do I need to install curve kit, springs and weight?
- '72 W/W switch console plate attaching screws?
- While I'm at it...water pump?
- Eliminating vacuum head lite system from c3 1971 corvette?
- Floor pan nuts
- Rear OE corner speaker Layout - Pictures Please - 1979
- Quick Fuel or Holley carb for 144 blower
- Alternator only setups?
- Help Needed - Step by Step Vacuum Leak Diagnosis/Repair
- short or long water pump?
- Engine/Transmission Swap
- Holley street avenger, 570 or 670cfm
- Momo steering wheel
- where does this nut go?
- Here's where I'm at.....
- fuel metering connector?
- Hood hinge
- Suspension Options - Would like opinions
- died and now will not start
- Wheel Bearing
- New weatherstrip sealant suggestions
- Noob trans question..
- using TA on 9" swap
- 79 a/c question
- #1 body mount reinforcement bracket
- Adapting a late C3 steering column in a early one
- Where is the horn relay for a '70 'Vette?
- Just gettin warmed up..
- When to change tie rods and ball joints?
- Tire Revolutions versus Driveshaft?
- Bellhousing alignment
- Front Steering Help
- Wiper Door
- Vent cables below/above/on side of OEM radio?
- 72 radiator q.
- 68 steering column connector - snaps in where?
- Hood Lift
- 1970 m22 to 6speed
- If I replace my 74' vacuum headlight openers with...
- Bellhousing Foam Collar
- removing third member
- Who is using manifold advance on a 350ci ?
- 73 OEM carb ?
- New Cover right?
- 427 How much HP?
- "K" series primary rods for Q-jets?
- Q-Jet Primary Throttle Shaft
- So here's a mystery for everyone. 78's and black trim
- Can you help with 383ci engine build?
- Headlights on when key is in ignition.
- Since summer is almost here.. Hayden 2799 Fan Clutch.. love it
- front coil springs
- Power Steering Pump Questions....
- Spreader bar install
- Fuel Problem
- Need diagram for vacuum hoses (interior)
- wiper motor replacement 1981
- Can someone please measure this?
- AMSOIL Releases new high ZDDP Classic Car Synthetic Z-ROD Line
- C4 Seats in C3 question
- Adjustable Strut Rod Thread Size
- Help, Oil Filter blew out at start up
- Question about body work
- Can anyone in Indianapolis area help me? 81
- Erson cam, Which one is this?
- Cam change, Now Gears?
- kicking myself..hood liner install
- What gears am I running?
- Distributer advance recomendations
- My Corvette project (The Wounded Warrior)
- The Quest
- NGK Spark Plug Gap - 427 w/Brodix Heads
- Got a nice 200r4 core today for $40....
- 1975 Center Gauge Cluster Installation
- New rag top install. Confidence shattered.
- 68 vent balls - only outside air?
- Pressure Brake Bleeder My Way
- Carb Question?
- Wiper wiring problem
- Borgenson install
- how do you remove the lock cover?
- side yokes
- Moog parts
- Minor electrical issues
- Should i be widening these holes in the gasket for my Head to block?
- What are we using to seal diffs these days?
- Tach Filter
- Another Brake Thread (Long)
- HELP Rough idle / Hesitation when starting out
- #5 Cylinder Rocker arm hitting Valve Cover...
- Spark Plug Wire Question
- 90 Coupe, weird issue with the O2 sensor
- 79 Anti Theft Door Lock
- the dreaded rear CLUNK !
- Rear Wheel Bearing Question
- 1979 Resto-Mod HVAC Gremlins
- Exhaust Wrap Feedback ?
- Source for stainless headers/sidepipes
- March UD pulleys
- annular booster is loose?
- 79 Antenna
- 70 454 Broken Piston
- T56 swap need a bracket.....
- Holley Adjust-a-jet thoughts
- What in the world is this thing?
- trailing arm shims
- Q for those with dedicated fuel tank for nitrous
- Replacement radiator options
- Camber adjusting bolts won't stay tight
- M21 Rear Bushing Replacement
- Transmission Rebuild Advice
- 1974 Intermittent Starting Issue
- 82 corvett lowering suspension
- Wiring help needed, going crazy!
- Best Battery Disconnect
- 81 help
- what bolt?
- 70 thru 72 LT-1 Carb. insulator ?
- Rear Bearing Failure
- Vbp's "spring" into summer sale
- Carb repair help
- MSD 6AL Power line fused?
- 1982 Centre bezel removal
- New Distributor Install
- Willcox New Sale.. You asked for it... Details Inside!
- ground locations on a 1979
- 1975 L48 Corvette Tune-up?
- will be looking ar 78 vette in two days advices needed
- 69 stingray
- control arm removal pass side?
- Front End Rebuild
- 78 No heater, wipers or windows!
- O2 sensor carb tuning
- 454 into a 1968 SBC Coupe
- Figuring Intake Valve Closing Point for Cam selection and DCR calculation.
- Need help to troubleshoot 69 magnetic pulse ignition.
- Spreader Bar help?
- Brake information
- is there a header gasket that wont leak?
- Brake overhaul questions for my 78' Silver Anniversary
- Engine help
- Universal radiator hoses question
- Saginaw 4 speed in a 76
- fixture plate for u-joints, where to buy?
- 79 Tilt/Telescoping Steering Column
- Gasket for Aluminum Heads?
- anyone use sealant on a 1pc oil pan gasket?
- Battery Warning Light 82 CE
- Master Cylinder Bleed Procedure
- Engine Run-on
- repairing fiberglass cracks
- Corvette Central carpet heat barrier kit - front and rear 7 pieces
- BB valve cover gaskets leak.........
- Can clip and firewall be removed together?
- BRAKES -- What to check next?
- Engine Compartment Paint
- Buy 383 crate engine
- TH350 wont shift at WOT
- Need good A/C shop in Winston Salem NC area
- 79 Vette Air Conditioning Troubleshooting
- dip stick question
