View Full Version : C3 Tech/Performance
- 77 Vett headlights
- True dual exhaust bracket
- New intake and carb 1980
- Holley choke plate air cleaner lid clearance
- Corvette 350 engine sheilding pictures
- Need alternator help....
- Fuel Pump Replacement - If its not one thing its another
- Trailing arm bushings what trailing arm bushings.
- Remove seats from clam shell
- Cross Flag Emblem stick on tape or a better way?
- Car will not idle
- H Pipe Kit?
- Circuit board ?
- Fuel injection vs carb
- Pulling engine/trans, leave driveshaft in car?
- Timing question . 76 350 Ci automatic
- Holley 4150 on a 1968 big block with L88 setup
- Found my ls3 need help
- 65-82 parking brakes to rotor hat
- Power window door glass adjustment
- 79 camaro 305 in a 79 corvette
- TH400 transmission question.
- Problem starting 79 corvette
- suspension ideas
- new oil line from vendor came with a new fitting?
- AMSOIL break-in oil AFTER break-in
- Rear wheel bearing advice
- 73 Stock AC Question
- No reading on temperature gauge
- Proper oil pressure for C3
- 3/8 water temperator sensor
- Rag Joint, Any Ideas how this happened?
- Build or crate?
- 1969 Gas pedal linkage question
- Do I have a bad starter solenoid? Video in post.
- 71 power windows.. are they supposed work with the key off??
- HEI Ignition weirdness
- 1969 350 350 oil consumption
- Electric Fan Strangness
- 69 Speedometer Rebuilding Service
- Awakening the beast
- Speedo/tach removal
- car won't start
- Just bought a 69 and there is no power to the heater blower fuse
- Water Pump Belt
- Poor performance when warm, vapor lock? Fuel Pressure?
- High cranking compression pressure
- 1st Time using timing light
- Power Steering Stopped Working
- C3 Carpet installation
- Vacuum under dash elbow leaking (69)
- Installing Allen's exhaust system
- C3 keyless entry
- Speedometer
- Disconnecting vac a big no no?
- Manual Shifter Reverse Jammed
- Dyno results with 350 HO and suggestions
- Drops out of fast idle too soon.
- 1968 ignition switch noob question
- 2019 24 hours Le Mans on MotorTrend
- Sniper EFI gas tank filler neck issue in 75
- over thinking rear suspension. Inner strut rod heim position
- Upgrade Points Distributor to HEI
- Willcox Summer Weekend Sale Starts Now!
- Change cam in sb 406
- Free for one day... offer ends 06-12
- Another side pipe insert thread!
- mystery bolt
- thermostat water outlet
- Console dash pad alignment issue.
- 12V cranking tap point
- Help ID this part!
- Valve covers
- LS3 Swap
- Quadrajet Choke Won't Close
- Z28 Elgin springs
- 1968 body mounts
- 1981 corvette not getting gas into the carburetor
- 1969 Starter Wiring ID
- 200-4R w/QuadraJet
- Still chasing cause for failing points and condenser
- Best vacuum for troubleshooting light system
- Couple questions about timing curve, mileage, and octane
- Suggestion for Torque Wrench@ a reasonable price?
- Front Brake Bracket To Spindle Torque Specs
- ? distributor vacuum pod
- OEM Torque Converter
- OBX Sidepipes with Big Block, 4 Speed and Borgeson Steering Box?
- 82 fuel issue must pump gas to start
- Pics from local Corvette show this weekend
- Will a Q-Jet Idle Rich & "Load Up" if Power Piston is not Seated at Idle? I Test it..
- SBC 350 Oil Prime: No oil to passenger's side
- Front Coil Spring = Rear Ride Height?
- 2 1/2" exhaust manifolds
- ready to install new gauge bezel/ shift console but..
- Installing a lt1 into a c3 71 corvette
- '70 LT-1 Holley Carb ...
- slight whirring sound in power steering right turns
- Sorry if this has been asked here before.
- AC Parallel Condensor for 1972 Corvette
- Engine ground cable
- T56 Bellhousing alignment questions
- Hei mech tacho distributor replacement
- Running rich on A/F gauge with edelbrock 1406
- Spindle refurbish and repair
- Coupe door weatherstrip Nghtmare
- Poly trailing arm bushings ?
- Float level adjusting nut nylon washers
- Wiper door help please
- More Holley woes, struggling with the float adjustment
- Gas cap.
- Keep 5 mph bumpers or not?
- Shaft bushing on wiper door assembly
- 75 fuel filter
- Spot Repair on Body
- 1981 Battery DRAIN in 1 day
- My new 1979 hot rod C3!!
- '69 Big Block Ground Strap/Cable
- Shift Cable Help
- TIP Swap - Throttle Cable
- help. running rough
- Need a read on my spark plugs
- 2500 stall torque converter good choice for this combo?
- Offshore parts interesting read
- Aggressive Cam and ignition timing
- Engine dilemma
- spark plug supports
- Good News after body off frame!
- A permanent cure for leaking T-tops ... maybe?
- Remove Rear Brake Dust Shield?
- Repairing a "Rebuilt" Q-Jet
- 1969 cross member for TH350 confused
- Cal Custom Air Cleaner Scoop Element
- Window switch question
- Scat 9000 crankshaft vs forged
- AFR 180 Heads
- 69 Deck Lid Lock Removal
- Alignment issues.. straighten frame? Offset crossbars?
- 77 vette instrument cluster shortage fix ??
- 1982 Corvette Starts but after a coupe of seconds it dies
- Did a dumb thing - Brake question
- Lifting front end for hood reinforcement rplcmnt
- how to oil prime new engine without removing distributor
- Convert gauges to can bus display
- Front Spring Edge
- 1980 Ignition Connectors Question
- what paint for 72 LT 1 A.I.R. tubes
- Lars: From junkyard carb to perfection
- 1969 L36 Starting Issues
- Fuel Pump lever travel
- Added Ford ATF type F oil to gearbox, ok?
- Si to cs alternator upgrade
- Soft top installation on my 71 C3
- tri power woes
- R/r brake power booster
- Wiper Wiring For Dummies Questions - 1972
- Door Windows on a 71 in Texas
- Free shipping
- Do these gaskets need a sealant?
- Getting frustrated
- NOS 3883986 Camshaft?
- Brake problems
- Fuel gauge incorrect
- Won't stay running
- Question For Phoenix AZ Members
- Front Spindle affinity
- 1980 wiper issue
- idle low several minutes then comes up and smooths out
- Erratic fuel pressure
- Steering Column Fitment!
- The problem was something very weird.
- power brake booster vacuum line
- considering a 454.. tall block work?
- AC Issue- Very High Low Side on a 73
- 68 Corvette door hinges
- 68 L71 rear sway bar
- Engine/trans mounts
- Battery went dead....recommendations?
- SAM Tech + LS motor + Rotella
- 1982 wont idle after cam swap
- Tire size help!
- front lights and wipers not working?
- Holley Torque Specs
- BluePrint 383 is here!!
- Throttle Cable too long??
- Rec on what trans oil to use w M-21
- Headlight problems
- Which is best Roller or Solid Pilot Bearing
- 69 427 coil replacement question
- High idle all the time and unwanted acceleration/accelerating by itself
- Carburetor ?
- IDEA! Spiral baffle “quick change” noise adjuster
- ANYONE - Old Delco Big Block Fuel Pump Specs??
- Wheels and Tires
- A/C repair
- What is the "low hanging fruit" on the '73 C3?
- Does this gap need to be sealed ?
- Power Antenna stuck in up position 1981
- 1980 Brakes overheating all of a sudden
- Quadrajet Help please
- dry brake line
- Parking brake problem
- how much HP loss from crank to rear axle
- Darn Brakes Again
- Help identifying cable
- What is your technique for painting this ?
- If it's not one thing, it's another!
- Easiest way to remove a big block from a junk car?
- 81 electric fan always on
- Is 220° a normal operating temp?
- Fundamental difference between steel bumper C3's & later C3's?
- Is the Spare Tire Tub bare fiberglass? Or painted?
- New clutch, bad pressure plate runout
- 1969 Big Block Fuel Pressure Issue - With Return Line Setup - WTF?
- Stink'n turn sig fuse.
- Best Power Steering Pump With Remote Reservoir
- Which fluid change to: 1978 CHEV CORVETTE C3 - PACE CAR
- Quadrajet Problem
- Borla Muffler as a Side Pipe.
- best non leaking performance valve stem seals?
- 1968 interior lights don't shut off
- Rechroming luggage rack ?
- 68 Stiff Pedal, No Front Brakes
- LS1 install - GM hotcam or newer tech?
- Strut rod bushing question
- 1970 California Vette With Evap Emission Option
- Heater water shutoff valve
- Question on wheel spacers for front of 76 w/18"
- Fan clutch
- Rear main seal drives me crazy!!!
- Fuel gauge pegged puzzler...
- Points and Condenser Again
- Capping the STS baffles - one way
- What’s this on my 81
- Distributor help
- Getting aluminum out of brass temp sensor threads?
- Which Hooker?
- Cam selection (hydraulic or solid lifter)
- Fuel Additive
- Want to "switch" front spindles 1969 to 1968
- Tachometer Reading High w/ replaced circuit board
- Front coil spring question
- Keeping a starter cooler
- 79 tilt/tele column questions
- '70 LT-1 stalling
- identify driver and pasenger upper cotrol arm
- Brake issues
- Help, do these go on a 1969?
