View Full Version : C3 Tech/Performance
- Removing Air Conditioner...Need Help
- 76' C3 & no heat
- Went for a drive with my brother today - photos
- Wiper Actuator Hose Routings
- Restoring Sharks
- Ordering Performer 1406
- Calling All Great White Sharks
- fugly
- Anyone looking for a 75 Roadster ?
- Finally a pic of my car!
- Hey vettefixr .... recommended reading ?
- I have a question about 6 speed transmissions and ZZ4 Engines.
- More QJet help - gas everywhere
- Harmonic balancer wear
- Latest on LT-1 w/282S cam rebuild
- Muncie leaks after overhaul
- Strange noise from front of motor:
- Test
- 700r4 convert help
- POSTING PICS
- whats with the people who did this?
- whats involved with changing u-joints
- Headlight problem
- Who has actually taken their entire dash cluster and all related parts out?
- Help, Hidden Wiper Door Rattling.
- 30 seconds to get into a locked C3
- Pic of me and the car!
- Wiper Shut Off Relay Adjustment ?????
- Help, I need a cure.
- Beefing Up A Big Block Bottom End?
- Cruise Control
- Really great deal from Zip products !
- FG Spring Weight
- paint it mice elf?
- OK..Anyone need any ideas for a makeover :-)
- March underdrive pulleys
- maaco pics from razz
- 427 Build-up ideas
- possibly 454?need help.
- roll bar pics
- C3 leads the way
- Lars -- got the parts...
- SEMA C5, do you like?
- Exhaust System for a '74??
- sorry Nissan Sentra question
- maaco up-date
- old picture of a 1978 Corvette on steroids....
- frame deminsions
- Corvette seat question
- Monza mufflers
- Aluminum or steel wheels for dragging?
- How to learn the limits of cornering.... the hard way!
- Setting 700R4 Shifting Firmness
- Okay New gas lines,new fuel pump
- LS5 Specs - 1972 version ...anybody
- I think I may have just sealed the fate of my crank and rebuild!
- Need Seat Belt Help!
- Bair's Corvette
- For you lower compression guys...What octane gas do you run??
- tapping in new engine
- Fresh out of the paint booth
- my car does not run that well untill it gets up to around 180 degrees
- Fender Protectors
- How to Determine which 69 model design
- Paint code
- Stinger hood for an 80
- Interior Staples (inner glass seal)
- Why Winterize?
- ZF6 in a C3
- Anyone install Ecklers Daytime Running Light Kit on a 80-82???
- Stress test on T TOP framing...Daughter wants to have the KING @ QUEEN sit on it???
- When I stomp down on my car..It shifts too early
- Air Pump on 82 CE
- Build & Race em online!
- Help! Quick advice before I order my suspension kit.
- 502 lives
- Six tail lights on a stingray?
- 20"whs. on C3
- How did the Maaco Paint Job ever turn out?
- Question on casting numbers from a newcomer.
- Will the aluminum center caps fit this rim?
- how the heck does a computer iliterate post pics ??
- How about a nice purple chrome bumper?
- Running gears!!???
- TACH is dead
- MSD Probillet installation pics
- Well, I'm an engine novice, but I think these pistons and valves are bad...
- Should I keep the Harmonic Balancer on my 350-rebuild?
- KYB GR2 shocks
- The Last Detail-still in business??
- Anybody got some used or good L-82 hood emblems around?
- Software to test & see different wheels on my car?
- New Edelbrock 600 Carb and intake but big problems...Help please Lars
- Jumping Speedometer
- Exhaust heat riser bolts
- Virginians take note! We need your vote!
- Need picture of headlight washer locations.
- Placement of vacuum canister
- wiper door hinge question
- [REPRINT] Our Corvette Heritage #12: Road test of 1969 Factory L-88 Hydramatic!
- Building up Holley 600 vac sec
- Rag Joint Question
- Geeky question... What are some of the quickest streetable Smallblock C3's
- Rocker panels notched for Hooker sidepipes?
- rebuilt engine woes
- Trick Paint Job
- Normal operating temperatures????
- My '70 Vert still for sale
- Out of state Corvette purchase help
- Light bulb number for the rear view mirror map light???
- Anyone convert c3 to c4 suspension?????????
- Can anyone give me some Light bulb help?
- ZZ4 (HOT CAM) SHIFT 4 SPEED@ ? RPM
- ONLINE PARTS LOCATOR IN DEALERS STOCK
- LARS/TOM 454: POWER VALVE RECOMMENDATION FOR TRI POWER
- Who has aftermarket tach's?
- gas mileage? tunning?
- Front End Suspension Rebuild, last minute questions!
- Need advise of mufflers
- 1 piece rear main seal vs two piece
- 3.70 gears in a 4.11 case?
- Pic of friend's recently purchased Pace Car.
- Metal floor pans
- headers in general..
- Who is this "Apache"?
- shipping a hood?
- What's the best way to avoid tire lumps, and other winter storage questions.
- Keep losing oil plugs with aftermarket valve covers, any advice??
- S.S. hoses and lines... any tips on install??
- Nick in cylinder wall... should I worry??
- Can you use gapless rings with hypereutectic pistons??
- wiper water resivor removal..help
- I have 4 springs on my throttle return. Is that too much??
- [IGNITION] Pertronix, points, weights....
- Carpet from Romeo Engineering
- Hey Toronto guys! Got a few questions
- Any Turbo 400 Experts out there?
- Location of H-Pipe - How about X-pipe for C3?
- Vettes at the Rock Update!!!
- Just saw a 502 crate Ramjet in the crate....It's just beautiful
- official: what can fit under a stock corvette hood(what have you fit)
- Dyed my carpet today with RIT liquid dye.
- When they say "Street Ready Out of the Box..."
- Hooker side pipe headers and angle plugs
- i need a air cleaner than is shorter than 2.5 inches... any ideas??
- Engine Block Arrived Today!
- why is it the bolt always falls where u cant get it???
- stupid distributor question for a distributor bubba like me
- 1970 bang in rear suspension?
- Machine shop says it can bore out stock head to 1.60/2.02 can this be done?
- Tranny dispute with rebuild company.
- car lurched after braking?
- Valve Spring 101
- Just bought a NCM brick for my C3
- Brake Light Problem!
- Monty are you out there???? My e-mail won't go through to you.
- Help us name our new service [Vettefinders]
- Front Bumper for a '71
- Wiper Door Vacuum Issue...again
- Rear gears selection help needed.
- Forgive me, another Dynomax header question..
- What plugs are you guys running in BB's with HEI?
- Looking for a wheel
- How do you organize your tools
- Electric Fan Questions - Again
- Now HERE is a custom Vette !!!
- How do you know when your water pump is broken?
- Correct Trans Fluid Line Diameter/Flare for 700R4 (at trans)?
- CFI 82 Wiring Diagram & Code chart
- Tranny Removel
- Carb Questions (lars?)
- Monty: Can you run me a Dyno for my new 383?
- What does this do??
- Is there an easy way to replace a fuel pump?
- ZZ Cam Specs and aluminum radiators?
- whats a 1979 L82
- Shifty Shifter
- Modified my Stock Converter-->Great Launch!!
- Headers 82 Ce
- IS there such thing as a Camaro Chat?
- Glove box latch
- 2.73 Rear Gears?????????
- Anyone remember Allan71?
- Eureka Springs pics
- '79 radiator and seals....little help please
- **Toronto Area cruise this weekend??**
- What are the best tires for a C-3?
- Are there any Corvette "recyclers" in Florida?
- Rusty Pipes
- Muncie M21 trans question
- Dart heads versus World products sportsman
- help needed quick question
- AACA Members????
- Qjet question
- Battery Drain on my 75
- AIR Pump for 1970 LT1
- hooker headers & side pipe part #'s
- Best suspension setup for drag racing?
- FR-34
- Just ordered new wheels and tires
- A/C compressor brackets
- OUCH!
- Anyone ever bought Coker Tires?
- five thousand posts
- How do you clean Fiber optic lines?
- Torque converter doesn't fit??
- Posting photos
- Who lives in the NW?
- tormorrow is performer 2101 intake day!!!
- tunedport78 a question
- C3 body dolly anyone?
- frame straightening
- Anyone Extrude Hone a factory Aluminum Intake manifold
- Luggage rack, 6 or 8 bolts ?
- [NCM] I will shave my head if........
- Bitchin' Wheels
- Alwyn678..you don't like the Ravins?
- Socket for u-joint bolts
- Electrical cut-out
- Exhaust Configuration
- [NCM] Museum Raffles 2002 Red Corvette Coupe
- Timing (Lars)
- Need some opinions from my C3 big block brothers...
- Lower V heat shields
- Headlight Vacuum Routing
- Exhaust question
- Does anyone have that frontend on their vette?
- Zip saved me money!!!
- Xenon headlights
- How is a speedometer cable routed in a '68
- Must go faster....(times)
- Tranny bolt question.
- Hey Ed T
- New Tires for my 1969
- Is there a custom stereo I can hide in the back of my 69 427 Roadster?
- WTF...Mechanic says my Tranny is not original!?
- What would other C-3 Owners do?????
- Exhuast question on a 74
- Is my holly carb opening 100% when I press the pedal?
- Does anybody ACTUALLY buy L-48 hood emblems?
- has anyone got a remanufactured edelbrock qjet performer??
- Custom Rectangular headlamps...
- Thanks,for booster help
- 80 Front Spoiler (Baffled)
- Cost of Painting a Corvette-My Invoice
- Installing polygraphite bushings
- Two-tone Hooker Sidepipes?
- sway bar removal
- Opinions on what water pump to use in my new 383 buildup
- Can your vette do this ?? !! 458 MPH !!
