View Full Version : C3 Tech/Performance
- Project No Flight Motor Selection - Ideas Wanted
- Requesting help on brake problem
- 14" vacuum on rebuild at idle up to 20" @ 3000 rpm
- Next Basic Question re Interior Door Panel
- 82' C§ Crossfire Engine
- I think I need to leave the C3 section
- Best Front Poly Bushing kit? Where?
- Tips on removing front suspension??
- No longer scared to paint.
- coming from a C5, maybe getting into a C3
- engine and cam break in proceedure?
- Just changed the little plunger thing that makes the brake ligths work AAARRGG
- Mako Registry?
- dumb question about splines
- Any West Coast drag racers in here?
- Were can I get the best prices on theese parts?
- Replacing antenna mast
- I bought the 81....finally
- Added up all my receipts for the Pace Car....
- L-88
- Will this head gasket work??
- Just changed the oil on the vette today.
- A Day at the Beach - NJ-9/22
- Anyone with a 70, 71, 72 shop manual and a scanner????
- Opperation Juggernaut: Big Block Update.....Getting close MANY Pics *Dial-ups Beware!!*
- Alarm pulse, what does it??
- Clutch problems Diagnosed - Warning - Large images
- whataya know about motor kits?
- Need vaccuum hose routing for the windshield wiper relay please
- Help, what Torque converter with this cam?????
- Good source for freon R12
- Have another plea for help on hanging the doors.
- New pipes including a crossover :o)
- Jacking up a C3 (to sit on stands)
- Need ID for plastic piece on the floorboard
- I think I bought the wrong window tray at Carlisle, any help?
- no build sheet...
- Need some input regarding a '77 L-82
- Performance planning! Advice needed (ZZ4 with mods)
- New girl in C3 forum...
- Selling my Corvette :(
- Should I replace my valve seals or not? HELP!
- Daily progress with the 70/75 - put my drivers door up.
- Need heads done... a few Q's
- Radiator fan setup - electric, clutch fan, or both ???
- Which O.D. Tranny should I buy?
- It's time to play...... Name That Noise!!!!!
- [Misfits] Check Out the Plans for this Saturday!
- What AC Delco Rad is This?
- 1980 Vette smog control question
- New Header question...
- Interior Dye ?????
- Original Decals On-line
- Who makes the best shop manual?
- Doug THorley Sidepipes
- Lost without you all!
- OT....Some Yugo fun:)
- Ignition key stuck in "on" position
- Need opinions on a possibly picking up a 79 C3
- When's that 5 speed Muncie coming?!
- What is it????
- Advice on high mileage purchase
- Oil Pressure Woes continue...
- Which Vette Magazine?
- Performer Air Gap under a "72" hood, will it fit?
- Found the vette.
- Sorry Ontario guys........this one's taken
- Which is the 'Easiest' Fuel Injection System to Install on my 1980?
- >>>>> Vette is FINALLY home!!
- Hanging doors back on and need some HELP!!!!!!!!!
- I know the answer to this but I'll ask anyway!
- Congrats to VetteFlame79!!!
- Leaking Fuel?
- Kevin McKay and '79 questions
- ZZ4 Torque Converter
- Edelbrock BBC RPM Cam: Idle?
- car cover to keep dust off
- Which socket is best to remove u-joint bolts on an 80?
- '80 Air Conditioning Problems... help?
- 1975 Convertible Top Replacement
- '77 Rear Main Oil Seal Replacement
- Need Correct Tool to Remove Front & Rear Transmission Seals (main shaft)
- Trip to the pre-school / Office Max
- 1980 Vette, cruise control question
- Somebody wanna tell me about putting a 700r4 under my 79?
- Correct tire pressure of radials
- Oil pump question?
- Holley carb ID help
- Easy ? for Guys W/BB's and Hooker Sides.
- Mechanical Vacuum Advance - 1978 L48
- Small Block Timing Help
- Engine cut off a few times, now it won't start...HELP!
- Interior Console & Panel
- C-3 Interior Parts
- FOR ALWYN: Michael Vic...Meet Mr. Urlacher
- is this the crank i need?
- Road2XS, I'm curious about your 69 project
- Interior door panels
- What is the electronics in the battery compartment?
- chrome bumpers on a 1977 vette?
- which vette attracts women the most?
- which color is best for a 77 vette
- Ordering a ZZ4 This Morning
- 1969 buying scenarios, realistic?
- quick 383 timing ???
- hei distributor
- where can i buy a complete auto transmission for a 69 vette?
- Been looking but cant find
- Cool pic I found, kinda BIG!
- where can i find frames for 69 - 77 vettes?
- What do I switch to?
- Big Block Power Steering ... the right bracket?
- im selling my vette!!! its all your fault!! :~(
- In gear idle a little too low...
- 1980 LG4 - Lots of questions
- O/T 02' Trailblazer Ing Lock
- Glasurit Auto Finish (a.k.a. paint)
- Beautiful Day & The Wave
- Question about offset trailing arms.
- Cruise Control Anomolies
- Power Radio Antenna in a 71 ??????
- Update on line EPA certification test
- I'm buying this car Tuesday morning!!!!!
- AC - Fix or replace?
- Shifter Console, Speedometer panal Removal
- Rallye/Autocross pics from yesterday [29 shots]
- The Loudness of Spiral Turbo Baffles Revisited
- Roller rockers?
- Nostalgia-Just a C3 Thought on Reflection-They are Nice
- Hood Stuck
- it finally runs,kind of
- motor tear down done...more pix
- Engine Mounts won't line up... looking for advice
- Quizz- What was the most powerfull small block ever make by GM pre 1982 ?
- Saw a cool Camaro on the way back home from Clearwater...
- More pictures from Dimmit Corvette Show in Clearwater!!(dialup beware)
- Ebay funny
- heads, cam kit parts overlap?
- Lets see under the hood!
- Radiator Cleaning
- 1979 for $17,900? 15,000 miles?
- edelbrock ovals and stock manifold
- offset trailing arms
- Long distance trade-car for motor-need advice
- A/C clutch replacement
- 1979 odometer not working
- A/C Low pressure side service port leak
- Yellow Jackets Shirts & Stuff - Who wants one?
- Help finding Top Dead Center
- [Misfits] Please Read, Upcoming FL Events!
- We won after driving 200 miles to enter our car in its first show!
- 1971 Rear axle yoke endplay
- Just got back from an NCRS event.. WeeeHaaa!!
- Interior Detail/Repaint
- Water pump squeak---need advice please
- AC Delco oil filters on clearence
- Jumping speedometer needle
- Preserving a Placard/Poster
- Yesterday was a near perfect vette day in NH ... forum members get together
- Where is mountainmotors oil post?
- B&M Blower for sale
- Kinda OT....But these are sooo D*mn cool
- Not only have I driven the AeroVette and Bill Mitchell's Stingray Racer...
- Custom Plate ideas inside:
- Which head and/or cam??
- K&N Extreme air cleaner lid?
- What happen to the Valvoline thread?
- Turn turbocharger into supercharger?
- I would love to has this vette
- wiped cam lobes on XE274H?
- OK Everyone. I Need your opinions... Am i an idiot?
- Maiden voyage !!!
- 2 tone C3s
- SPARK PLUG/WIRE REPLACEMENT QUESTIONS
- belt noises......argggggghhhhh!
- fiberglass springs vs sway bars
- Looking for a clean '68-71 big-block C3 convertible
- What's this 73 roadster worth?
- On line test for EPA certification to Purchase R12
- 1980 headlight support bar
- Check out this dummy
- "winkie"
- Hood insulation
- Anybody going to Silver Springs?
- SOMEONE STOLE MY JACK BALL
- Need number for lower radiator hose BBC
- How many amps does it take to run tpi???
- 1975 Seat Belt
- Looking at a '74 T-Top
- More help with window...
- Carb Question - High Idle
- trick flow heads ?
- 74 Cam install update
- Stuck carb float?
- last question headlight vacuum
- WILL I EVER FIND ANOTHER…(Long Post)
- Need a little help with the timing chain removal
- Retard or Advance? I'm confused--
- Results of New Braunfels TX Vette Show--
- 50th Anniversary Edition
- door lock still broken
- ready to change gears and finally raced at tracked
- got the motor out...heres what i found...
- windshield washer bottle leak
- Reason to buy new heads came early.
- vin info regarding a CP
- Back from the track........MANY Vettes at No Problem raceway. Dial-up's beware!!
- What a BJ!!!!
- Vibration in A/C Belt at Idle
- Dimitt Corvette Show, Thoughts and Pics!
- Replacing axle stubs for BB?
- Paint Time - Metallic or Pearl
- will this fit
- Wiper/Blinker arm snapped
- Dieseling/Valve float whats the diffrince?
- what 383 crank to get? better then this 355(long)
- Update to Cam swap out
- Luggage Rack
- Sneak preview of "Project VetteFinders"
- Changing The Steering Wheel
- Sanderson Headers
- Will TPI fit under a stock hood
- Door panel removal and power window help needed
- 1978 Pace Car Documentation
- is a rebuilt stock shifter as good as a hurst?
- Cappy sets new speed world record!!!
- Another "How many miles driven?" Survey
- fuddruckers in turnersville/nj car show anybody on here go?
- cjk in 71 rare ????
- Oil leak above fool filter ??
- 383 idle ?
- 1992 LT-1 Engine transplant
- Is your Vette stock?
- How do I grease the rear wheel bearings?
- I finally tried my stock alarm
- Started Cam change in 74 tonight
- new braunfels swap meet
- Need Advice on Connecting an Original 1969 Delco Radio
- Ricer convention
- Need help w/ build sheet
- LT1 1969?
- Is this a bad idea?? Big Block Intake question......
- Just got a new digital camera......Pics coming soon!
- Radio
- any tips before i drop the transmission
- 4-Speed Shift Knobs
- Passionate article about Corvettes!
- TKO 5 speed??
- 32 years and they did what they were designed to do!
- Time to change my valve covers.
