- C3 Rear Storage Compartmentq
- Building an LT1 equivalent
- Burping cooling system taking a long time
- Swapped 700r4 lockup problems
- What transmission to use in 80 corvette with 454 ci proseries swap
- Crate engines for 80 vette
- 72 LS-5 upgrade
- Glass collapsed seat mount
- Do you guys buy "Re-Built" parts? If so.....
- L-82 fan blades
- Is there a low profile air filter that fits a 750 holley double pumper?
- Air intake (under hood)
- Not running
- Does Borgeson box move the steering shaft foreward?
- Belt change 78 L48
- Alternator question
- 1972 Suspension Performance Questions
- Posi setups
- Tach signal from gen V lt1 harness
- 78 Temp sending unit connector?
- Turbo 400 Trans Fluid
- Need a radiator
- Fuel tank compatibility for 74'
- '75 L48 Backfire through carb/dies when you push the gas pedal...and now won't start
- Thermostat change on 82 pros - cons
- 1972 c3 corvette ls swap ..
- Check engine light
- '69 Headlight Conversion Kit Comparison
- Why close old threads?
- 1970 Ignition Question
- Muncie Identification
- Brake experts: please provide insights
- OE Aluminum Intake Mnifold - Does It Flow Enough?
- Install help for new distributor
- No carburetor vacuum
- Smoking starter
- Should I delete the EGR on my 80 L82?
- C3 Corvette bug catcher hood scoop
- Front rotor Run-Out
- Rear Main Sear Leak
- Harmonic balancer
- Combination valve query
- Question for engine builders.
- Which speakers would you use?
- Borgeson steering - Advice needed
- Vacuum Hose issues
- Radio signal booster
- Cleaning ceramic headers
- 68 427/390 Fuel Filter
- Check your ring gears closely
- 427 BB Engine Knock advice
- C3 LS swap lower rad hose options?
- C3 diff yokes
- GF-432 non OEM filter leaks
- Idle stop cable needed?
- front brakes 1981 Delco disasssembly.
- Autometer Ultra-lite Two gauges
- Strange Request, old NCCC Window Sticker Real Men Drive 'Em
- 68 pedal assembly
- Timing cover seal (not gasket)
- ‘76 TH350 Steering Interlock Bracket?
- Is my tach board fried?
- Heat Shields for True-duals on 1976 L82
- Rebuild 1972 engine & possible upgrades for HP gain?
- Exhaust Sleeve
- Any 60R15 tire with a higher speed rating than T?
- Replacing Cylinder Heads
- 1971 Corvette Wiper Problems
- Hood heat extractor
- paint
- '82 A/C doesn't work at low RPMs
- Unrepairable differential
- Speedometer gear
- Quadrajet comparison
- Windshield Washer Mystery Gadget
- Hurt camshaft. Best way to proceed?
- Scott's quiz of the day.. Name that part
- For us Avon tire users
- Replacing Distributor - wiring question and cause of fault?
- What would you expect the top speed to be w/the following specs?
- 77 AC system replacement
- 68 Muncie Removal
- Help with intake manifold and mysterious metal plate
- Will olds 4 spoke wheel fit my c3 with tilt
- Detroit speed wiper switch
- Jungle HEI
- Cam button, timing cover and short water pump clearance
- 72 C3 gauge issues
- Trouble Installing New Fuel Pump on 1975 Corvette C3: Pushrod Positioning Issue?
- Differential hole
- LS Swap - Exhaust System?
- bench bleeding new OEM master Cylinder
- 1980 Passenger side power door lock/window replacement?
- 1974 A6 Compressor Metric Bolt Size
- Strangle electrical problem.
- Disty full counter clockwise but only 0 degrees
- Cylinder head question
- 69 corvette 427/435 transistor ignition issues
- First time owning a ‘vette, first time having an engine die
- Rochester carb
- 69 corvette upper/lower rocker installation
- Best places for dwell meter ground
- remove plus vacuum hose when set dwell 1971?
- No spark.
- Plug Both Vacuum Disty Diaphram and Tube
- Spark plug wire removal tips and dielectric grease
- Turn signal indicator on
- U joint install
- Repair and painting a small area
- 77 Throw out bearing question
- Losing Brake Fluid in Master Cylinder
- Quadrajet Jetting for Dual Exhaust on 1976 L82
- Leaks galore
- Engine mount fun.....
- Perfomance headers and exhaust system C3 BBC
- PCV problems
- C3 Exhaust noise
- C3 tow hook.
- Retune dwell and timing after changing coil
- 1969 C3 turn signal malfunction
- Where does this spacer go?
- 78 Vette, rides like a skateboard - Rough as hell
- Has BFG Corrected Their 'Brown Letter' Tire Issue Yet?
- Door ajar stripped
- Doug's Headers d3330: Gasket Options
- Low Arch vs Shortened Leaf Spring?
- Engine stops randomly
- Electrical gadgets
- 82 700R4 rebuild recommendations
- Urgent: Rattling noise immediately after new clutch.
- Best Cciil and Tips
- Ignition switch alignment??
- 1978 Corvette Recommendations Water Pump -Advice
- Quietest side pipe muffler insert
- Benefit of Borgeson Steering Box?
- I need to access wires for running lights for keyless entry.
- SST TKX Conversion Info please .
- Oil everywhere!!!
- Way to tell if refrigerant has been converted?
- Quadrajet Fuel Line???
- 1971 running bad, and motor shut off few times driving
- 1970 TH400 - No Downshifting Into 1st Only
- Who Makes the Best Repro C3 Rally Wheels?
- Mirrored T tops (Bronze)
- Pre-oil newly built engine?
- Ground Wire
- TH400 No Acceleration
- 496 with cold air intake.
- Windshield Installation
- Best Header Gaskets?
- Minimum Vacuum For Power Brake Boosters
- How I Modified My Hedman Hedders To Fit My 73 Big Block Corvette
- Do duals running through a cat flow any better than single exhaust?
- Which HEI Distributor Cap to run an external coil?
- Pulse wiper delete
- chrome rims for 68
- Chirp squeak from wheels at low speed
- 1981 Corvette Setting Timing
- Can I adjust my shifter out of the car?
- Is this fitting necessary to connect Hardline from carburetor fuel pump
- Cruise control
- 1982 Caliper Question
- What is going on with these fuel pumps?
- 1968 Wipers
- 1981 Corvette Coolant Temperature Sensor Ground Wire
- Dipstick tube
- installing rebuilt 350 and 4 peed
- 327 into 77 accessory mounting
- 60-130 mph times
- Starter Wiring on 71’ Vette
- Key-on power sourcing for CD box and Holley Sniper EFI
- 1982 Power Antenna
- What is the correct one piece oil pan gasket for L82 1980?
- BluePrint 502 is alive and running great
- Part number for speedometer cable
- Rebuilding the headlights vacuum relays
- '82 Fuel Sending Unit Wiring
- Car was starting, now it’s not
- Power Steering Cylinder Ball Stud Spins When I try to Tighten Castle Nut. Why?
- 1980 door window install
- 502 in 67 similar to what i'm doing with my 1979
- 70’ Vette 4spd header install help
- Another question for the overdrive guys.
- Valve cover significance?
- Drag builds
- Brake booster hardware
- Do 18x10 clear leaf spring edge and stock trailing arms on a 1980.?
- Exhaust Size on a 69 427
- Unknown wire connection and temp sensor
- Windshield wipers that fit!
- Question on rebuilding a Muncie 4-speed
- Just picked up a STD bore sbc 400 have questions...
- Power
- What would you do ?
- 74 BB Original Fuel Pump
- 1978 Center Cluster Gauge Restoration - Painted
- What is this capacitor and do I need it?
- Engine swap fuel filter
- Fire these clowns......
- Orientation of 5 blade fan on fan clutch
- Sealant for the Wiper Tray?
- Intellectronics cluster Speedo issues
- Anyone ever us a ZIP products chrome brake booster/MC ? push rod problems
- Sound deadning on a 73 coupe
- 1972 THM400 Shift Points
- New ping
- Wiring Headache. Might just abandon car
- Is this cam lift too close to spring failure?
- Hood pin solution
- 73 seat belt through seat installation questions
- 68 corvette starter wiring
- What are the idiot light s between the tach and speedo on a 1980?
- Cigarette Lighter Light bulb not working
- Engine sputtered and stalled after hard acceleration
- Clip/Retainer
- Polishing compound questions
- Stainless Steel heater hose fitting with AN fittings
- strange temp readings
- Vacuum gauge
- 1977 Engine Wiring Harness Replacement
- Comp Cams left me stranded 20 miles from home.
- Motor mounts
- Hurst => M20 mount
- Starter replacement.
- Center console lights flash with turn signal
- Bubba Strikes Again....HEI Wiring Issue.
- Bulb location for AC/Heater controls?
- C3 corvette hood repair
- 69 corvette wiper motor .. where does this connect?
- Looking For Something Better Than Rubber Heater Hose
- these NUTS are called? Where they are utilized?
- 69 sb Fuel Pump difference?
- Qjet question
- Valvolione VR 1
- 74 EFE TVS Extra Nipple
- Would you build a .060 small block?
- Neutral safety swith
- Headlight/wiper/AC vacuum system - Unidentified T junction
- C3 wheel well vents
- 1968 and early 69 power window conversion how to
- wiring 1975
- 82 speedometer jumps
- opinions on semicoil over spring rate
- Ls Swaps Ls1 and Ls3's LS owners Lets see yours
- Is there a way to slow down the power windows?
- C 3 Turn Signal Lever replacement
- Super T-10 Sealing Questions
- 2004r 700r4 TV cable and geometry
- Brake warning light
