- Two part question and happy friday!
- Replacing Exhaust manifold
- Water pump about to explode...
- Tranny question
- LT1/LT4 EFI into vette?
- Electric Fan Relay Sticking on?
- Differential leak with pics
- Scortcher T/A
- 1980 Overheating.
- What shifter for my M-20?
- Help me build my small block
- 80 front clip
- Venting the Hood on a '79
- Clock check - Working??
- changing tach cable for 72
- Power steering pump question
- Can't find the shut off for the air bags on the 73 vette
- headlights
- need help mounting grills on 69
- Best bit to drill a hole in eng. block?
- Acceleration hesitation
- Mating new exhaust to shorty headers?
- Something binding in scatter shield?
- Is this dangerous ?
- Cooling a Blown small block
- Electric Seat Problem
- '69 Convertible Top Replacement
- Driveshaft diameter
- UPDATE - Electrical Problem Help
- Engine Rebuild Advice Needed
- Know anything about struts? alignment problem
- need help with horn contacts
- How Much HP am I Giving Up With the Stock Hooker Side Exhaust Mufflers?
- Vacuum pumps
- Good shops in southern WI?
- Where does this wire go?
- Would appreciate some help with headers
- idle problem
- A/C compressor (r4 type) what year did these come on
- HP and torque ratings
- Car Cover Recommendation?
- Leaking Transmission (TH400)
- Engine rebuild
- Points to Electronic Conversion HELP!
- P/S Control Valve Adjustment
- New type of Spal fan controller
- Haedlight Actuator Replacement, PITA or what?
- VBP - Complete Front and Rear Composite System
- Cam failure - symptoms?
- 82 C/E window on ebay
- Nitrous??
- Need help from your 69 AIM!
- Heater/defroster switches
- Spark plug diagnosis
- fuel pump ticking
- BB Heater hose routing?
- Unbeleivable.
- L48 or L82
- Replacing the accelerator pump
- Need Help with A/C !!
- Just completed my first vette mod!
- New 383 Ticking Noise
- Smog Question
- LT1 Guys - Need to see your belts
- 71 rear marker light
- Fan belt routing
- 1979 A/C Duct problem
- Installing a Small Block 409 in a '64 - pics
- Power to the Spal
- 1970
- 80 L82 heads
- Hidden nitrous system revealed
- Ignition Leads
- BG Carb -- RPM Airgap ??
- Mechanical to Electric Tach
- A link for all you carburetor-heads...
- Differential paper
- a pillar guages on 77 is it possible????
- Date Code on Motor
- alignment question
- Whats is the difference between 650 and 750cfm?
- tranny swap
- will MSD help
- trans and rear fluid and other help
- Torque Converter Lock-up wiring
- Finished the NOS fuel side on my 63 race car
- "Capping" the speedo cable drive...???
- Can you find the nitrous hidden on this motor ?
- How hard to switch to a BB
- Bright Flakes In The Oil
- C6 seats in a C3?
- Intake Manifold Question
- Whats different?
- Good 5speed shifter?
- Pulling engine out of my 82
- Piston sideways????.. hope the world is not ending
- Alternator mounting brackets when using headers
- Anybody know how an o2 sensor works?
- Front Diff Bushing
- Valve Stem Seals Replacement Whith Out Removing The Heads ?
- Insulation for aftermarket hood...
- Custom gauge setups
- Tranny rebuild
- rear end type (tech questionable)
- 6 point Roll cage Hey George!
- Equivalent spring rate due to bushing flex? Low velocity damping?
- Newbie question on 82CE air intake
- pull when braking
- 73 rear window install
- Alignment shims vs. washers
- Serpentine benefits?
- Shifter throw hitting counsole R,1,3
- Saginaw M20...Can it handle 400 HP?
- Increase in Turning Radius
- 1982 Ignition Switch Installation Tips
- Front wheel bearings... How often do you adjust???
- Cooling System Question
- Looking for a donor engine
- looking for tire height for 75 vette with mags
- Create your own window sticker - Free
- Free mods?
- Headlights not working :(
- What is this electrical connection on a Quadrajet?
- Found rot - yikes!
- 79 wiper problem
- brake filter?
- Tilt Steering Col for a 68 Shark
- 79 Steering column
- Car Craft Real Street Eliminator
- Who's running Borla (non-sidepipe) mufflers?
- Mallory Unilite?
- To paint the engine compartment or not?
- Tach and Brake Questions
- remove thermostat??
- OK, I did it....new slipper clutch on the way!
- can someone post pic of shock mount with correct washers
- 75 steering column
- Trans X for pump seal leakage?
- Actuator seal kit - What went wrong? (Pics)
- Steeroids user-what size nuts..
- Need help engine oil problems.
- Anyone ever pull apart the cruise control transducer?
- Air Conditioning Reinstall
- Center AC Vent on a 68
- Intermittent Electrical Problem - HELP!!!
- Pics Of EdzRed72
- How do I properly shim the body mounts ?
- Outside door handle not working
- Brake fluid leak......
- Cold air induction
- Took the mufflers off the '82 today
- LOOK at what happend in front of my house today!
- It has begun!
- Piston Rings Question
- New Dash
- Disassembling my M20 and need some help.
- Switching to a solid axel
- No Headlights
- 82 Horn problem
- 454 Oil Pick Up And Fuel Pump Questions.
- New Powermaster Alternator Died Already...
- I want to torture the designer of the door handles! HELP!
- best aftermarket gears
- Fuel gauge readings?
- Advice needed
- Distributor gears and roller camshafts
- One headlight stuck open?
- Can I see your rear-end? (err..I mean your vette's)
- Oil dipstick tube bolt ?
- G Timer , anyone using one?
- Anyone running a big block with a long water pump?
- How can I rebuild a power brake booster
- WHich intake manifold with the Vortec heads?
- C3 Exhaust System / Clue me in!
- Dual snorkel vs. open air filter
- Borg-Warner 4spd lube...
- Oil Pressure Question
- 72 starting problems.......sometimes!
- New Carb
- Removing the window regulators..
- ARP flywheel bolts
- points
- Quadrajet fuel leaking after new air horn gasket?
- flex fan hits shroud
- yes...another carb ?
- Replacing fuel gage What ohm???
- Vortec heads
- TH200-4R > AWESOME!!!
- Blower motor wont run
- Caulking Cowl Area?
- diff carrier bushings in 1980
- vacuum secondarys
- Front End Rebuild Safety
- Installing Interior Heat Barrier 1980
- 71' Fan and fan clutch?
- 81 Heat Shield removal
- Curiosity question....
- Engine/Transmission alignment woes
- Vacuum questions - 1970
- How difficult is a turbo 400 to 200R4 swap?
- carb casting makes NO SENSE HLEP
- IS the 77 meant to have constant vacuum?
- are the gm shortblocks a good deal?
- Re-chrome of '72 bumper guards
- Rear leaf sprung bent straight??
- Is 280 duration alot?
- Head light switch removal
- Rod knock or header leak?
- Milling Heads Effect on Airflow
- 6AL box and killin wires...
- noise interior
- brake booster 1982
- New frame/repairing current frame?
- car all over the road - steering? Bearings? Suspension?
- Gulstrand Safety Breaker? RedVetteRacer?
- heads question from a novice
- Lower the front end of my 76
- Gear Vendors under/over drive unit
- Brake problems.
- Cat Back Systems
- Back from the dyno
- Master Cylinder push rod
- A Good Link For T56 Swaps That Lmpalss Gave Me
- What Sealent Should I Use ?
- Crate Engine Dyno Tuning Help w/ Video
- More Intake gasket info
- Starter internal problems... any experts?
- Backspacing help for Cragar SS wheels
- Help..New GMPP Vortec Heads?
- gas tank leaking around sending unit. HELP!
- More valve noise when engine's warm
- Evaporitive cannister
- Temp Sending Unit
- Stock stance and wheel/tire questions
- any 68ers out there?
- 5 inches of vac at idle solved
- Replacing power window switch...
- 68 am/fm same as 69?
- Z06
- Keep smelling gas around the car.
- Seeping Gas Tank repair???
- Need CEL Code description for '81 from factory service man.
- Comp Cam XE series POll
- Is my headlight switch bad or can I fix it?
- Are you satisfied with your Comp Cams XE series Cam?
- stock gears?
- is air conditioning slowing me down?
