View Full Version : C3 Tech/Performance
- 69. Exhaust
- Can someone tell me how my temp gauges were still working after I found this?
- Vacuum block to organize vacuum lines
- 68 Vac lines
- Play in Borgesson Box
- 1979 Corvette 383 Stroker
- Death wobble
- Converting welded crossmember to removable
- 1980 Vacuum routing for recurve
- No block stamping
- Time for some performance upgrades,75 L-48 questions........
- Valve adjustment and backfires
- Parking brake question - 1980
- (PICS) I need help with rocker arm issue
- 1 wire Alternator and Gauge hookup
- blueprint engine
- A really ignorant question but I need to know
- T top latch rear bolt plate
- Willcox Christmas Special Sale is now on and in full swing.
- 1968, 1969-72, and later radiator support interchange
- 1977 C3 Push to Start Help
- 9 inch ford setup whole 68 frame.
- 82 Diff - Gasket Only?
- Engine Oil and Transmission oil type 1969 vette
- No start 79
- Evap canister
- Multi Point EFI
- No vacuum in system after sitting overnight. Problem?
- 1978 Side pipes
- center gauges issues
- Photo(s) of 19" rims on a c3 ?
- TH400 Soft Shifts
- Body mounts Pre/Post 1972
- Gauge cluster install
- Intake manifold bolt removal quesiton
- Piston to Cylinder Wall Gap.
- C3 Shocks
- Fuel Hose Replacement Question
- Installing Vintage Air HVAC System C3 1977 Corvette Part 4 - Vents, Control Panel & I
- Valve spring height and shims for exhaust valves
- What to do to my 1980 Corvette today?
- in-line fuse fron alternator
- 1969 427 Ignition Timing Suggestions
- Carburetor Identification
- Harmonic balancer installed and timing mark question
- Replacing pump to carb fuel line
- Hole in front rotor
- Questions about windshield frame and A pillars
- Adjusting Hydraulic Lifters- Jebby was right...again
- As long as I’m in there - engine replacement
- Engine block coolant capacity
- Speedometer advice
- 1978 corvette rebuild
- Inter axles
- Buy or Build?
- Engine Head Surface Cleaning en vivo.
- Kinda a off topic post but this would the most traction here
- BBC tri power restoration
- 73 convertible odd water leak
- Dash and tail lights out
- Newly purchased 1980 L82, several questions
- 1973 coils
- Another horn diagnostic question - 1982 vette
- time for a new distributor cap?
- Aftermarket rear swaybar question
- All Resin: Have you used it?
- 68 Front underbody insulation quality
- Need help finding Valve Seals for a 454HO GMPP
- Short throw shifter for BW T-10
- How accurate is the water temp gauge?
- rear glass all the same
- 79 c3 rear speaker wiring question
- Does anyone have a list of springs?
- 1980 C3 gauge problems
- Engine oil and it's additives question
- Trailing arm bushing symptoms and advice
- Replacing Body Mounts on an 80-82 - Does The Front Bumper Need To Come Off?
- 79 L82 A/C Upgrade - Binary Switch Installation Help Needed
- 1979 C3 rear speaker installation
- Non AC blower motor resistor.
- Your coolant is probably good longer than you think. Here's how I tested mine
- IGN Source for Fans
- What is on your Christmas List 2021
- What will she do?
- Steering box
- Project 625 - Do I need this hatchet?
- LS swap rad hose questions
- 1981 vette hard starting
- Fan clutch Replacement
- Carb recommendation for a 383
- 1981 Tech and Electronics Removal
- Trailing Arm Bushing Tool For '74 Vette
- 1972 LT-1 A/C compressor
- 18x9 rear wheel
- 1982 air cleaner vacuum lines
- GM Type 2 remote reservoir with Steeriods
- Thump when backing up?
- Looking for a Q-Jet or two?
- duplicate post
- 1975 backfire through carb
- L81 performance
- Blower motor low speed resistor
- Help, Where Does This Go?
- Filler cap question.
- 68 Washer Fluid Tank
- Water pump
- Quadrajet High Idle
- Rear wheel position L/R in relation to body. Need help.
- Adjustable strut rods with rubber bushings?
- 77 Project
- 80 Vette Dana 44 clutch retainer destroyed
- L82 8" Harmonic Balancer Confirmation
- Trailing Arm movement front to back on rebuilt arms?
- 1974 Eaton Posi
- Stewart Warner tach has me stumped
- Transmission swap, strange times
- Help to ID 1964-65 Muncie 4 speed
- For anyone considering a GM crate engine right now....
- Holley 4bb Baseplate Code
- 72 LT1 thumping sound
- 81 corvette questions
- LED flasher ground
- Tilt wheel for 1968
- Can I bypass the A/C compressor
- Trim Tag Rivets
- Trailing Arm Question
- Anyone have a favorite dyno sim program?
- TKO/TKX SWAP Manual to manual 1981… Crossmember ???
- Does anyone know about what this will cost?
- last year for Manuel steering
- Exhaust assistance
- Steering wheel lock pin/ bolt?
- 1970 Seats, Vinyl? or Vinyl + Leather?
- Turn signal problem
- Exhaust systems
- Thinnest head gasket to safely use on undecked sbc 400 block?
- roller lifter locations?
- Head Gasket or Intake Gasket Leak?
- Is corvettepartsworldwide.com out of business
- A good engine builder in the Harrisburg PA area
- Blower motor question
- Willcox Weekend Sale Has Started
- Thermostat Housing Leak
- 1970 Correct Air Cleaner Decal
- PG260 Starter Users Question
- Front Spoiler vs Front Air Dam
- Need good brake parts reccomendation
- Need pictures of 75-77 ignition shield upper mount brackets
- Finally solved my Quadrajet Problems
- Is the Spare Tire the same as the ordered Tires? ?
- Installed my rebuilt trailing arms
- Paragon Corvette Interactive Schematics
- Best intake / Sniper combo
- Removing the radiator shroud on a 75
- O-Rings for Caliper Halves
- Tach Not Working
- Leaking Caliper - What am I doing wrong?
- Pulley PN A3770245CC
- Stalling
- Oil out the zoomie pipe
- American Sports Car (The company)
- 2101 with original q-jet, which gasket?
- C3/79/No Power/Grayish Smoke
- Making progress on my brothers 68, but ran into a few snags
- BMW wheels on my 73.
- Anyone recognize this spring?
- 76 C3 Brake Caliper O-Rings
- Who is running Global West front tubular A Arms?
- Parking Brake Actuator Lever
- 1980 c3 quadrajet and timing question
- Heater control valve vacuum line
- AC spark plugs 44TS what do they fit ?
- 68 Firewall Grommets
- Need a shorter Accelerator Cable
- 68-72 Corvette L88 FIA Front Spoiler
- Master Clinder Bore Size
- Anyone use Blackstone?
- 406 SBC Problems to Resolve This Winter
- How to install Glass T-Tops onto 68-77 Corvettes
- My Cam Kit is Now ILLEGAL For Use on Street?!? - Federal Clean Air Act
- Eckler's Wiper Door Kit
- Where does the brake light switch go on a 79?!
- 77 coup bird cage >> 69 roadster??
- LT4 exhaust manifolds
- Grinding Noise in steering column when steering
- Engine upgrades
- Is M20 Damage Possible?
- back up light wiring
- Corvette Central Magnaflow Dual Exhaust (Sound Clip Inside!)
- C3 Stock Damping Ratio
- Flaming River Electric Steering with Steering Column
- Heater Box (inside) hole ID
- Power Steering cylinder
- Simple mods to L82 C3
- 3 inch stainless exhaust
- Anyone Using Malwood USA C3 Hydraulic Clutch Conversion Kit
- Hydratech Brakes?
- C3 To C4 Brake Booster Conversion?
- Edelbrock’s new mixer
- Small Diameter Brake Booster?
- No start
- Best insurance for modified corvette
- 1975 c3 exaust
- Wheel Spacers
- Upgrading rear driveline or stock rebuild?
- 383 flywheel and ballancer
- Bellhousing Dowel Pin Removal
- what tire pressure for 454?
- Carb issues tribpower 69 l71
- Door lock cylinder turns with correct key but wont unlock or lock
- Holley Secondary Linkage Adjustment
- Strut rod size C3
- 1968 327 spark plug shielding
- 74 points distributor to HEI
- WIX oil filters 11/27/21 Some China, Some USA
- Tilt/telescoping
- What do I have here? Camaro motor in my 75.
- 82 Vette Shaky Idle
- 1971 Raido Power Wire HELP
- Two Rear IRS Measurements Requested
- New Motor: Strange Oil Leaks w/ Pics
- Replacing the radiator in a 75.
- TH350 shifter cable linkage not fitting right
- Replacement for 330lb rear fiberglass spring from VBP
- Radiator recommendation needed.
- C3 Half Shaft
- Willcox Black Friday sale 2021 has started
- Wiper Door Material
- Almost Burnt Down
- Wipers
- 350 CE Block casting date
- This carb worth 20 bucks?
- Rear strut rodsc3 1977
- Half Shaft Reinstall
- M20 Reverse Shift Issue
- Lowering springs question
- KYB lower bushing gas adjust shock
- 75 original fan setup
- New Member
- 427-454 engine id help
- AC 45 plug question
- Window Adjustment/Binding Problem
- 5 + 7 Cylinders No Spark
- Sniper, distributor with mechanical tach drive ?
- Correct routing of TH400 metal modulator line???
- Testing EFI Fuel System for Leaks
- Door problem after installing weather stripping
- ID'ing Holley Carb
- 1982 fuel tank vent line
- Modifying a 1976 frame to work on a 1968
