View Full Version : C3 Tech/Performance
- Engine break in no exhaust
- Front Suspension rebuild question
- Clutch inspection cover - bolt size?
- High idle - no kick down
- 1976 corvette advise on what to look for on purchase
- Oil Pressure Anamoly ???
- Wheel-Studs and Spacer Question?
- EFE Thermal Vacuum Switch Finally Works
- Where is the Fuel / Gas Filter on a 70 LT-1?
- Wiring harness replacement
- Thinking about adding a blower...need help?
- 82 Starter Problem
- rear wheel hop
- well here it is
- Holley 650
- U-Joint Caps Stuck
- Temp Sensor not working
- Just rebuilt my heads
- Still trouble with the new 383
- I need some help to diagnose engines "ticking" noise.
- Wiped lobes
- Engine build, Pully alignment issue
- Intake manifold gasket question
- Syracuse NY tuning
- Please help me before I torch my Shark!
- Hopefully my last Spal Fan wiring question
- Is modern synthetic oil OK for our old Vettes?
- Front Suspension Rebuild
- Resin Mix Ratio?
- M14 bolt to verify TDC
- What's the best way to tackle a short With Common Tools?
- Bouncing fuel gauge fixed
- Any Tricks on Water Pump Install?
- Phoenix brake tool
- Trailing arms turned into while I`m at it.Pixs
- Anyone using Dakota Digital gauges, tach and speedo?
- Clicking trying to start after dying, any suggestions?
- Allen's 69 Side Exhaust
- Help with exhaust manifolds
- Brake Line Distribution Block / Switch
- Front clip problem
- power steering just quit...
- Calling all 77 owners: Need pic from AIM
- Colour wiring diagram?
- Jim shea 68 vette steering column lowering
- Interior Panel Repair
- Delphi 600 Series Steering Box
- Power Steering Control Valve Help
- Prepping/painting slots in 82 aluminum wheels
- New SHP short block
- headlight/temp gauge problem
- seat back release latch
- Jack Point on an 81
- 76 oil pressure sending unit
- How To : Valve stem seals replacement... PICTURES
- pcv help please
- Anyone had a new balancer seal leak?
- Supersoft weatherstripping
- Pinion Nut??
- door sill plate screws rusted or stripped
- Nose support rod on 69
- rocker panel questions
- Radio fuse blows ever 5 min!
- Which rods for L98 heads with screw in studs?
- stripping powder coating
- WET VETTE.......Yeah Baby Yeah!!!!
- exhaust system question
- Transmission leaking
- tilt front end with electric head lights?
- Emergency Hood Cable
- Speeddirect Clutch Linkgae - Install pics and a few critiques
- Which jets
- more l-88 questions
- Problems with 79 speedometer
- TPI Help
- which differential for 5OOhp
- Dana 44
- 76 windshield removal
- Torq-Thrust D Again
- Still Stumbling..
- Transmission cooling line splice
- C3 Wheel bolt pattern
- Tranny radiator location?????
- 6 or 12V
- two grounds on 68 speedometer, why and where
- Convertible top\frame rehab.
- Rear bump stop clearance
- cost for 5 speed transmission
- led tail lights
- Windshield washer system on 69 Corvette
- reproduction fan belts
- headlight switch knob removal
- 82 consol plate wont fit!!!
- 68 vert Headlamp switch nut
- Decking questions
- JEGS timing cover questions
- 1980 auto driveshaft/ 2 different joints
- ***Motor Rebuild Tips***
- Removing hood insulation on 76?
- QJet Issues? What's Wrong With This Picture...
- Napa Temp Switch
- fitting 5" BS wheels on rear?
- Steering pulls after being worked on.
- body back on 4in. to tall
- Have you found your transmission VIN?
- piston to bore clearance spec......
- Alarm Idea??
- Electric power steering questions
- Seat Belt Warning Buzzer Going Off
- Fasten Seatbelt Light
- How to get rid of speaker noise
- Brakes-All is well
- Upper Radiator Hose Replacement for Idiots - 78
- Transmission ?
- Front brake rotors and hubs, great info here.
- pulled the plugs this evening... something doesnt look right
- 1978 windshield washer motor
- Can you check my 383ci shopping list, please
- need help deciphering these wires (1980)
- Connecting e-brake cable
- Acceleration difference with diff ratio's?
- duel quad demons?????
- Very Mild 270hp 350 Performance Improvements: 1.6-ratio rockers
- what is the cause of cam "lope"
- Parking Brake Seal
- Washer pump - does it need to be primed?
- vacuum system
- 1982 TBI rough idle wont run
- 42% front and %58 rear weight bias
- Carb Idle Mixture
- 78 pace car seat question (help)
- Right Turn signal indicator in dash not working
- Big Block exhaust
- Starter turning slow
- Head bolt tap size?
- How do I replace the brake booster?
- Need to replace Temp Gauge - 1977 Corvette
- running rich, and have spark knock
- How to adjust auto choke curb idle L82 Quad
- Intake help please
- Side Exhaust Pipes Flange leaking
- Relacing rear window seal
- oil pressure sender location. 79 L82
- brake fliud compatibility
- Keisler Kit: Should I switch to a mechanical clutch? What is involved?
- radio help
- TBI for engine
- 2 ohc (overhead cam)!!!!!
- T top seal question
- '69 L71 435 Tri-Power Question
- Wacky tach when cold
- Grinding Noise Please Help!!!!!!!!!!!!!!!!!!!!!
- Engine Replacement on my '79 Vette
- Decode Engine?
- pistons
- Engine Block Decode
- brake lights
- Pulsating Pedal
- Need Windshield Wiper help 1977
- 78 Steering wheel horn assembly - help please
- 82 running hot, stalling
- '72 hazard light problem
- Part II of Bruiser's 555" build in Corvette Enthusiast is on line now!
- Speedo dead in my '81. Is it electronic or cable driven?
- Got a nuisance oil leak from right rear of cylinder head.
- 72 AC Wiper Problems
- engine rebuild
- VBP upper control arms - loose?
- 73 Power Antenna
- 1972 ac
- Coolant Leak
- '78 Pace Car nose emblem R/I
- Automatic Tranny Pump Seal Replacement Cost
- Power window trouble?
- 70 Speedo Cable Routing
- Broken polly body mount
- Fixing dyed leather seats, now rough feeling
- 1980 heatercore replacement
- Ls2 ls3 ls7 the absolute combat
- mini starter
- Hungry fan eating fan shroud
- How long are 76 rocker panels?
- 78 power lock actuator plug
- Spark plug
- 69 Exhaust
- sunday tinkering questions...wiring, air con, heating and air pump! 79 L82. Pics!!
- What is this part called?
- WATER from the EXHAUST - HELP
- 1971 bb rear composite spring rate?
- Taking car to have top replaced. What should I order from Al Knock?
- Transmission torque converter question
- degreeing the cam and initial timing questions
- New Shocks What works best
- No RPM indication from MSD Distributor
- Constant Pressure on Rear Brakes ??
- Major Oil Consumption
- Ati converter 700r4 3000 with lock up
- Some new stuff...
- Stumbling at idle...
- 78 wiper question
- 1980 L82/Lack of Driving Problems
- Steering problem
- Pre and Post 1986 block
- 73 Frame Replacment
- Dynoed my L48
- change in conventional oils????????
- Gravity Bleeding new system trouble
- Raising Vehicle/Jack stand Question
- Is my battery toast?
- 1970: Possible Bent Lower A-arm
- Front Bumper Just Won't Come Off!!!!
- New fuel pump no gas?
- Turn signals ok, hazards not working
- small hole found in right side of shifter column
- SBC head bolts
- COMP Magnum Roller Tip Rocker Question
- 68 Original Spare
- Starting quirk??
- gear pattern
- Power Steers Only Right
- Good Deal on a 71 t-top?
- Hey DeWitts people... how do I fix this??
- kinda stumped...car wont shut off
- differential opinions
- H E L P w / Compressor / paint etc
- Taking a different tack on flip-up vacuum lights
- LQ4 with super T-10
- need bracket for throttle and kickdown
- Video of my bad idle and stall into drive
- 79 ac??
- Modification frame 76 or 454ci 500hp!!!
- 4x6 Speaker trick?
- 72 headlight problem
- 68 327/350 correct valve cover bolt colors
- muncie problem
- need help with springs
- 79 tach bouncing and showing high revs.
- Brake cleaner... SAFETY CHECK!
- hard wiring gauges
- HELP - New owner - rebuild?
- 10% off your first order*
- 12-bolt-Estrada?
- Vacuum hose question
- Square bore on an EDL 2101
- 10% off a-arms and rear coil-overs, free shipping
- Carb Jetting Quetion
- Running problem with new engine
- Will an Edelbrock Performer Intake and Holly Carb clear the base hood?
- Loose steering column
- Q-Jet to Holley 4160 conversion kit? Q-Jet rebushing
