View Full Version : C3 General
- North Dallas Gas (highest octane)
- Size of speakers.....Quicky
- Who Has The Best Prom?
- Help with part name
- 68 427/400 Tank Sticker
- Where to Buy C3 Parts In Canada???
- what's this called ?????
- 95 Camaro trany in a 79?
- Differential Fluid ??
- This is probably obvious,BUT----
- Time you finally met some forum members?
- Not a Corvette BUT YOU GOTTA BE KIDDING ME!!!!
- Need Vendor for "corvette rubber weatherstripping
- Rear filler panel Question
- Interior dye???
- Vader Vette
- Vacuum fitting
- temp guage
- Clock, or no clock
- 74' wheel options
- por 15 questions
- Carb ID
- Outter door handle adjustment
- Corvette Show in Albany N.Y. area
- POR15....swap colors??
- C3 owners-never go anywhere with out your t-tops
- Weekly Car Care
- In the market for a C3 and I'm just guessing...
- 1969 Fuel Line Question
- P/S Pump Core
- Question of 1969 Production Numbers
- Carlisle; if you're attending this year...
- Winter Storage/Vette Shows
- Hmmmmmmm
- Performer RPM intake
- Old Door Panels cleaned up pretty good.
- Changing AC freon
- cleaning my vette after a drive...
- Front end sag on a 1974
- Check out these shocks I just replaced
- Need advice on restoration
- My first Vette
- Engine Before & After
- Another victory for men everywhere
- where is the best to jack back of C-3?
- Steering Column Painting
- 1970's for sale
- VBP front coil spring replacement question
- Need pic of properly installed dust shields (front suspension)
- dull 82 front bumper
- How do you install the jack spring brackets?
- I am back with a Vette
- One year ago on the 28th...
- 80-82 vett with sidepipes
- 1970 - Mulsanne Blue - is it a stock color??
- Help me pick engine bearings and rings
- Whats Wrong with this picture
- clocks
- Motor mounts?
- Side mirror question,..correct phasing of the mirror
- I found a couple of pics from back in the day......
- non corvette resto advise
- My '71 Spare Tire
- Pictures From The NCRS National Convention
- Turn Signals?
- Looking for information on 71 big block
- [PICS] 69' L71 body-off resto progress update
- Installed new calipers...
- Where does this go??
- All I could do was laugh.
- anybody out there with a trailor! near me lmk union nj
- Corvette Show and Go!! 8/4 Englishtown NJ
- Valve Cover Question
- Help decoding Differential
- what solvent is best to clean interior with?
- Hard Fuel Line - Sealer on fittings?
- XP-856 Aero Coupe
- &3 Bumper Cover
- U-joint and vendor ??s
- Heat shield/sound deadener??
- The brown truck makes me mad
- Location of horns on 71 coupe
- MSD Ignition
- 73 corvette center grill
- Chrome thermostat housing
- My T&L finally came (sort of) and trans pics
- Let's see your exhaust!! Post some pics!
- Steering column
- Maybe a future project ? (pics - 56K beware)
- My first time
- Should I wait?
- moyock muscle, Moyock NC
- One down one to go, trailing arm install pic.
- 1973 454 engine
- Fiberglass T-top paint question.
- Brand New 78 Pace Car
- Look what was headed to my house today!
- Need Help from 1972 convertible owners
- Poly snubber bushings recommended....?
- Seat mounting bolt - what size is it?
- 79 fender replacement.
- What year vette are these wheels from?
- 70 LS5 Timing Cover timing tab
- changed to removable rear window
- If you had a business involving C3's, what would it be?
- Cowl/wiper cover
- Let me see your 74-77 with sidepipes!!
- Mickey Thompson S/R radials
- How to remove needle from small gauges (Voltmeter)?
- Temporary Paint?
- Carbon deposit cleaning
- Lexan windows and carbon fiber hood?
- Just installed my Andover Seat Belts.
- Turn Signal Flasher
- Pics Of New Bonspeed Huntington Satin Finish Wheels
- 82 crossfire pictures.
- Engine or Suspension - which one
- Time for brakes
- 383 Blueprint sheets. 8 Pics
- Another 73 with turn signal problems
- Rear spring (detective work) problem
- Dash light problem
- 70 Vacuum canister removal question
- kick pannel removal
- Transport recommendation wanted
- Buyer Beware, You get what you pay for.
- another question on insurance
- Looking aftermarket gauge pictures - 78 up
- 1997 Mid America Funfest dates??
- A question of exposure :)
- Aluminum valve cover help
- Any interest in a speedo gear swap
- Control arm bushing install $$$$ ?
- Interior trim cleaning questions
- Who owns this car.
- strange noises
- Need Chassis specs for 79-82
- T Top Installation Question
- Looking to buy a C3
- FNG Saying Hello.
- Antenna?
- al knoch seats
- Vinyl Paint perfornmance
- 74 rear bumper
- VIN 36113 1978 SA Dealer Invoice
- ive just find this Batvette
- Need help to identify vintage 15" cast wheel
- Color Mixing Formula - Chevy Orange
- Anyone own a Daytona Sunset Orange 3g??
- overdrive swap
- Wheel Code AZ vs. AW, what is the difference?
- Quick VB&P Question.
- El Cheapo stereo upgrades..... suggestions?
- Changing heater Fan, 77??
- WooHoo The Rats interior is coming along!!!
- For a non AC car-what's the best way to add AC?
- Looking for 2 1/2" Stainless Exhaust
- some C3 pics from BHCC........enjoy!
- Any Pics of Black Hills Corvette Classic?
- Can someone Identify this part?
- How does this body mount rust look?
- How do I get this heater box out?
- Cure for stiff seat belts?
- Wooo! Hooo! I can keep my Vette!
- stainless hood hinges
- Alternator Codes 1971
- Thoughts on removing the lower seat belt retractor bolt?
- Those Pesky New Vette owners get theirs...
- Weatherstriping for 73 conv.
- 12.99 HL Switch dimmer repair.- Part of our 'Vett on a budget series...
- Headlight adjustments
- Vette emblems
- new member with a 77
- yet another a/c/heat replacement, "classic auto air"?
- I'm Back!!!
- Doing business again...Rocketman
- Doing business
- Stainless vs. Carbon bolts and Diff. gasket ??'s
- anyone in Greensboro, NC?
- Just introducing myself...
- Dual Exhaust for an 80
- ZZ383 is Born Tomorrow!
- Mid-Atlantic Vette Fest, Petersburg, VA July 28-29
- Delco-Air decal
- 85 Mustang wheels on a 68 vette?
- air conditioning
- Muscle car engine shootout (BS)
- Classic Chevy 5 Speed Group Purchase
- Starting the work on my 76 (pics)
- Sensor location/info
- Would you buy a car off of these ying yangs?
- starter help on a 70 lt-1 1107293
- I need to win the lottery!
- Turn Signal
- Trailing Arm Dimensions
- Tracking 1968 VIN
- Need some sugestions
- OT Checking out for a while
- Ride difference between early & late C3's
- need to check some numbers
- rear compartment molding and carpet
- Buying the TKO-600..purchase advise needed
- Interior code 64I
- What does NOM and NOS stand for?
- How Is the A/C on the 70-72's ?
- Who likes Vette & rain driving?
- things I notice in Hot rod magizine.
- What are some of the signs of excessive mileage vs. not as much?
- Need new car cover....help spend my money
- new seats
- Somerset Kentucky car show
- 7-leaf vs. 9 leaf
- 1971 454/365 (LS5) Value?
- J56 brake pads - where to get them?
- Gas Prices & Saving Money (Venting)
- What wheels are on my car?
- Muffler insert options for 4" Hookers
- ACC Carpet install
- trying to remember who this was?
- 68 ignition switch
- coolant sensor location
- Pic of installed 79 tach filter please
- need a wiper door actuator for a 72 coupe
- looking for paint/body shop
- Pinks All Out
- Patriot H1060 sidepipes installed ride height
- [PIC] Another what is this and where does it go
- Rear Speakers
- A Question about my 69 coupe front fender trim
- C3 JBL Amp Car Stereo Help
- Can't wait. Too excited
- Great Parts from Vettesbydesign!!
- Anyone mod their antenna?
- do all c3 door jambs look like hell?
- nice '72 Stingray I saw today
- L88 Hood mods, how to drain water?
- No luck in OT...please help.
- '69 prices?
- San Francisco Bay Area
- Best L88 Hood Manufacturer
- rear deck grill drain tubes???
- '79 Corvette what do you think?
- Hood lift, maybe OT but I don't read that section.
- Source for quality mirror for '73.
- No wave from the C5 I passed
- Biggest Tires
- 78 Restore - No body shims?
- C5 wheels on a C3
- Patriot side exhaust question
