View Full Version : C3 General
- Funfest 2017
- Stripped caliper bolt hole
- Steering Column - 69-E, 69 Late, Or?
- EVERYTHING NEED TO WORK : Interior courtesy light
- EVERY THING NEED TO WORK : Today Washer pump and nozzle
- what am I ...missing ?
- original 4 speed mounting upgrade
- Willcox Weekend Sale Starts Now Weatherstrip Wiring, Frt/rr Suspen Interior and More
- Belts advertised as GATES may not be
- What radiator is this?
- a little bird told me something
- Hard Top is the @(#*
- Change 2 point seat belts on a 69
- Stupid interior color question.
- 1981 factory footage
- Wiring Harness Question 1970 resto
- 1971 LS5 Birdcage Replacement Progress
- 1971 Holes in Fiberglass Jack Storage Bucket
- Looking for Corvette shop in Va
- Block numbers
- what gas
- Tempature Impacts on Corvette Body
- headlight problem
- Painting Shock Absorbers?
- Orignal "Keep your GM car all GM" sticker mangled keep it or replace with a repro
- Unusual door tag !!!
- Seat question
- 74 - Gymkhana Suspension Shock Question
- HageHagerty gets 45 inquiries for C3 Corvettes a day!
- Brake console
- 72 Covertible Body Removal
- Crushed It, Literally
- Check This Fast N' Loud Find!
- 73 Tachometer Help
- 68 Leaky Carb
- backup lights
- Anyone with Quickjack Experience
- Radio support bracket- 1981
- Launching the LS5 Short Video
- Car Show Twist
- troubleshooting
- idiots question have 1979 best chrome bumpers kit
- Anyone near Northville, MI
- Applebee's
- 1972 Carlisl Auction Special Paint Code ?
- how do you remove radiator? '71
- Exhaust manifold to pipe gasket
- 1971 egg crate louvers
- Question about bidding on a car at (live) auction
- Disco Days
- 1977 rocker panels
- Carpet replacement
- C3 Through the eyes of a millennial - enjoy
- 1972 Heater Core
- ((( testing a radio )))
- Valve Cover sticker source
- Federal Agents Seize a 1969 Corvette L88
- Will this intake fit under a stock hood? 1973
- ANOTHER sway bar thread..
- Pop out window latch
- Door lock - I cant seem to find the long one
- Need Help: Front springs on my '71
- Willcox Weekend Special 20 off Sale Starts Now!
- Quiet Ride Solutions
- core support ,68 bbc.vette,air ,4spd.
- Well now the seats are becoming a pain in the butt.
- Stainless steel brake and fuel hard lines
- Aim
- Speedo/Tach housing
- Tell me more about this car..
- Garage Heaters
- Thoughts On This 1971 Coupe !!!
- Door ajar wiring
- Production # of 1970 454 conv. 390 hp auto.
- 1971 ls5
- vacuum diagram
- Another SEMA Picture
- C3 Resurrection and Upgrade
- November in Seattle
- Aerovette
- 1981 C3 engine removal
- 74 Corvette question
- 78 CORVETTE - Ignition Switch and GEN light
- Help! 78 Vette Engine issue
- Excuse me, is this spot taken,?
- Fire Extinguishers
- Weird question
- Parking brake anchor pin
- Info on c3 fabric seats
- Restore or upgrade
- Bought my first Corvette! What do you think of my to-do list?
- Need some help on a small issue
- engine swap for a 65 Corvette 327, 4spd car
- Big Block Valve Covers. Recommendations?
- If you need a shipper, this is a good guy!
- Exhaust, oil leak?? and Riser questions
- Intake and Carb Hieght
- 3933163 Intake ? Date Code ?
- Radiator Fan Shroud>
- MuscleRodShop 68 Corvette 'Twister'
- WTF is up with my gas hole???
- T-top
- Need Help Identifying Fan
- Dessicant for winter storage
- Cheapest way to swap auto to manual?
- 1980 black texas corvette
- Married guy shop vs. Single guy shop
- GM Restoring C3 Corvette's at the factory ?
- 69 427 ac lower fan shroud mounting nut size?
- P02 + valve extensions
- new 3 door compartment
- On her way south to See3
- 77 AC Heater Shutoff Valve?
- 1972 corvette big block engine parts
- Unpainted fiberglass in the elements
- My SEMA C3 Favorite
- Anyone recognize this 71 from Annapolis, College Park area? See pics
- Bad fuel pump??
- FINALLY BOUGHT my C3!!!
- This got me mad.
- Door Ajar part
- tank sheet tire code
- 69 Corvette 427 4 Speed Restoration Update 11032017
- Another Limted Edition
- Decoding rear end ratio
- Hydraulic clutch fork clearance problem
- Mice in the car over winter.
- Aftermarket tilt question?
- Seatbelt Options
- 1971 corvette ls5
- Need advice from you guys who know paint!
- another small mystery part
- Seatbelts
- Any wide body , Can Am fans ?
- Carburetor for '68 HP 327/300
- Side impact intrusion Beams on 1982 C# CE
- Laminated documents
- KIDDE Recalling 40 Million Fire Extinguishers
- 1971 coupe Irma drown
- Trailing Arm Failure at National Meet!
- Is this '74 worth buying?
- Menace Corvette unveiled at SEMA
- Anyone ever purchase this bumper?
- Carfax
- Drivers Door Sticking
- 1971 Wiper Door Rivet Driving
- what part is this?
- Video of a local unofficial car show with a couple of cool Vettes!
- The New 2017 Coker Radial Firestone RWL Wide Oval Tires
- Horn rebuild kit suggestion diaphragm or no
- Transmission.
- What is driver quality?
- '71 Phoenix......... up from the ashes
- Time to get back at it.
- Broken Rocker
- header opinion
- Craziest engine mods
- button
- My '69 Convertible is 48 years old today
- New Drivers Door Ajar Switch Problem?
- Whats The Boards Take On This 71 454 ?
- Selling the C3
- Help Engine Corvette 1969
- Previous Owner
- Sticky situation
- Pitman arm and idler arm
- 1978 Body Lift Front End Detail
- Finally .. Officialy a C3 owner
- Finishing your project when the chips are down
- Theft prevention ideas.
- Would you restomod an original car?
- Convertible roof seal
- 1974 Shifter console and Heater/AC control panel rebuild
- 1971 L-88 engine ?
- 1969 Build Sheet
- 68-72 BB Hood
- Corvettes vs. the Ozone
- To tilt or not to tilt???
- Vent Door Removal
- It's a sad sad day, friends.
- Rear T-Top Carrier on a 1980 Vette
- Alu pulleys, what fits?
- Headlight conversion, sort of
- Enjoy Seeing Your C3's Original GM Brochure
- How to handle a long distance purchase
- LS Swap - Need to order something tomorrow
- Survivor Criteria ?
- Rack and pinion opinions please!
- Willcox inside door latch emblems? Any luck?
- 9 years later and I'm finally finished!!! (PICS)
- Coupe birdcage hoop attachment stackup
- Dump or Pump? Need your votes
- Brake light/ turn signal phenomena
- Dealer info for Stookey Chevrolet Sheridan, IN
- 81 rear diff fill plug
- 1981 Frame VIN Stencil
- Power Steering Pump
- Firewall hole under master cylinder
- Headlight bezel repair?
- Found my leak steering box
- Lost then Found
- 1981 Auto Trans
- First C3 and C2
- Dealer Info
- Good morning everyone have a question
- Green Mamba 1968 Corvette Build
- 1969 big block A/C expansion tank
- EFI conversion option(s)
- Here in Australia, we are just starting to have our car shows
- Which is correct seat foam?
- What Snap ring pliers canremove ac clutch magnet?
- Original docs on eBay for 1970 Convertable
- Tampa Bay Vettes' Ultimate Corvette Show - PICS
- Hate to look a gift horse in the mouth, but
- Hydraulic clutch 79 vette
- Monza hatch back C3
- 1969 corvette
- door a jar
- Should I buy this car? (C3)
- Muncie G'box Drawing
- Electrical Gremlins are Haunting my Headlight Switch
- Rear Tilt
- 1968 Leather or Leather-Like seat covers with the basketweave inserts?
- Thank you smookfoot55 for the C3
- LS Swap - Fuel Filter/Regulator
- Name this part get $10. Via PayPal
- Storing a Corvette in SW Florida during the Summer
- 69 rear leaf spring - Paint Black or Original Gray?
- Having trouble lineing up the door
- Add Fiber Optic Lamp Monitoring to a '79 ?
- Checking the Cage
- 1969 427 390 vs 1970 Lt1 on value
- not # matching
- 1975 Corvette Door handles
- Heater core rebuild, need some help
- ZL-1 Stripe
- Valve cover fitment
- Best place for current values of C3 Corvettes
- 68 Corvette coupe interior trim question
- VIDEO: How to tell if your C3 corvette is NUMBERS MATCHING
- It's time , I did it
- Tire life
- Exhaust Systems
- Do you foot the bill when . . . . .
- Climate control light not shinnning thru on my 72
- Quadrajet Carb
