View Full Version : C3 General
- Rims
- Starting my winter projects early this year
- Assembly Line Photo
- Power Steering Control valve Torque Spec
- Trying to locate this syle cup holder
- Sport mirror - control cable routing
- Battery Cables Are Here - Lectric Limited Is Amazing
- 68 427 auto rebuild
- 1974 top questions
- A new one for me!
- Clk, ltr,crtsy fuse
- 1979 Owners with Spoilers
- 1977 Corvette Odometer in Miles or Kilometers
- Tool Organization
- fuel gauge and light
- well nuts
- New Door Panels Arrived
- engine???
- Metal Fuel Filter
- 1978 Silver anniversary car
- Trouble Light
- Fuel Filter Question
- Vin 10277 Daytona Yellow 1969 T Top 350 / 4 Speed - Sold To France In 1995
- New member from Sydney, Australia
- New Member
- C3 rear differential clearance
- I really love my 72, but only one thing really bothers me
- mysterious clip
- mysterious clip
- More desireable
- 76 floor pan question
- I dare you...
- Whole new interior or convert auto to manual?
- Lars is Da Q-Jet Man
- Drive shaft
- HL wires
- BBE at Hendrick Motorsports for QCCC show!
- Looking to buy C3...Newbie Asking For Help
- Help me diagnose my weird suspension stance
- 73/74 requesting pictures of front license plate bracket
- Is soundproofing worth it?
- Oil pan Issue
- 2023 C3 of the Year (Modified) -- You decide
- 69 Convertible Seatbelt Question
- Crawling under the 74'
- 79 corvette headlights quit working
- Car moves forward too much in drive
- Custom Console Data Plate
- 2023 C3 of the Year (Unmodified) -- You decide
- Trailing arm measurement needed
- Can you guys tell me what part this is? (Center Gaugel Cluster)
- Son Drives Corvette Solo First Time
- 69 early gas pedal problem - I know the story but
- Dream restorations???
- vin number c3
- Spacers for the front coil springs
- Fuel pump, remove and replace gasket
- Radio antenna cable for 78 w/power antenna
- A working Odometer on a ‘72 vette
- Looking for the history of a warbonnet 71 convertible Ohio/MI area
- Wiring harness
- Messing with a vid
- C2 vs c3
- Pics of underbody from sides/top
- 72 front bumper adjustment
- 68 center cluster light wiring questions
- Intro & Vacuum Question
- Wire harness ID
- New to Me
- 1980 C3 Fuse Box Diagram
- Power Steering Control Valve - best place to buy from
- VGG Corvette Rescue
- Too good to be true? Anyone know this guy?
- Friday Night, Born to Fight
- Mystery Green Fluid 77’
- Who Has Finished Their C3 Corvette?
- Looking for Bluetooth speakers for my 75 convertible
- Brake light stricter bracket
- Early’68 washer bottle
- 51497 HEI w/Tach Drive from Top Flight
- 1978 Silver Anniversary - Carpet Color advice
- A new hot wheels
- Garage decor?
- Thoughts on
- Apparent delamination , fibre glass from front end header bar
- 1975 Coupe Window sticker
- Hatch Vette - Cars & Concepts
- Carpet Adhesive
- 72 Wiper motor wiring question
- Dash/Tail light circuit blowing fuses
- Power Brake Conversion
- Why no Stingray emblem on ‘68?
- Post photos of America’s sports car with American flag
- It looks like the time has come....
- Prepurchase inspection 1979 corvette
- 1978 A arm dust covers
- door panels
- What is worth selling?
- Custom Corvette from The Wraith movie.....
- Matching numbers
- 69 Seatbelt Question
- Lifting car for winter
- 1973 radio convector mount location help
- What is it steering
- 1969 Corvette Dilemma
- C3 – 1968 Engine bad surprise. Upgrade needed…
- is there a way I can tell if i have posi traction on my 69 stingray
- Electrical gremlin
- trim rings
- 1969 New Exhaust
- one blinker out
- Looking for new tires
- This the original spare tire for my 78?
- Door panel vinyl mounting hole repair
- Has anyone put C5 seats in a early C3
- Has anyone upgraded there lap belt to the newer over the shoulder
- Help with door alignment please
- Gas Smell
- C3 of the year is open if you havent seen the sticky
- Fitting fiberglass front bumper / Impact bar in the way
- 76 c3 dead in the water.
- C3 Corvette of the Year entries - enter now!
- 2023 C3 Corvette of the Year, Modified. ENTER NOW
- 2023 C3 Corvette of the Year, Unmodified. ENTER NOW
- C3 electrical question
- My first body off
- Vintage Air Vs Classic Air
- pictures of C3s next to planes
- 1968 Corvette Is a Cool Former Road Racer for the Street
- C3 vin
- Anyone with silver interior use SEM interior paint?
- wholesome or interesting stories about your C3 Corvette!
- 1978 corvette Door Lock Pillar Weatherstrip
- Billy Boat Exhaust, Top Notch Quality!
- Sill plates
- Incredible Barnfind...
- New leak behind transmission- ‘79 C3
- Who knows about this car?
- 71 rear leaf spring mounts
- Need an alternator bracket
- Tach stopped working
- Weak Power Assist
- Tachometer stops at 1200rpm
- New sanden ac compressor bracket
- Extra wide car dollies.
- Clutch height question.
- What are these?
- New 383 is in!
- T top trim moulding
- Shielding tin and dizzy cap fit
- Wilcox
- What's the word on those Chinese Quadrajet carbs?
- 1981 corvette front bumper not aligning
- Is this normal?
- Well, that's a wrap
- Does anyone know what goes in the upper far left corner of this Guage cluster?
- Question on early C3 wiper door edge near windshield
- Fan Hi Speed
- 1980 5.7L V8 Coupe Courtesy Light Timer question
- Would you work underneath this?
- Who makes the best vinyl top?
- Itching while working under a C3?
- Tie Rod Ends position for LH/RH thread
- Identify muncie
- Frustrated! Can't install new brake pedal switch!
- 1971 upper dash (fix) cheaper
- $100 on FB. Worth it??
- I have a 70 and am looking at changing seats. What will fit
- 69 loose antenna cable at radio
- Finally running
- repair cost for body work
- Discussion about C3 market values
- '72 Windshield frame date stamp
- CARB compliant exhaust system for 75?
- How much fluid in a turbo 400.
- Banned / Spammer members ?
- Cooling tube for AC blower motor
- Transmission rebuild
- 1974 3 wire alternator colors
- Newb looking to buy and need advice.
- C3 in a hit and run
- 1970 LT-1 Market price
- Here’s Why the 454 CI V8 Is Such an Important Part of Corvette Culture
- '70 Corvette Wagon...
- 10-4 Good Buddy: October 4 trim tag day!
- Broke something during engine install, what is it?
- Line Question
- Seat Belt won’t Retract 78
- magnaflow 16482 exhaust kit Pictures
- Push rods or roller tip rockers
- 81- what are these
- 72 front wheel bearing replacement
- Battery Change??
- Three Wire Alternator
- Distributor Cap Hits Coil
- What Grease Is Best?
- 1970 LS-5 Van Nuys Built PCV hose routing?
- Diff Rebuild
- Wiper Door broken bolts
- Goodbye for now.
- New to me 73...
- Rare C3 Split Window!!! LOL....
- Need help with electic issue.
- Looking for E-coater in Northeastern Ohio
- Under dashboard knobs
- Headlight Troubleshooting.
- Battery Readings?
- Differential Repair near Phila. PA
- 76 corvette project update +hellcat
- Help 1980 engine bay experts
- 1978 Rear Taillight issue - Advice please
- C3 looses throttle response
- 78 Pace Car
- Later than mid-life crisis engaged!
- New exhaust 77 car
- What's the cost of a vinyl hardtop job?
- New Caliper Question.
- Help with Distributor Vacuum Advance Control
- Cell phone holder recommendations?
- C3 heat when headlights turned on. FROM REDDIT
- 78 SA Edition
- Will these fit? 16x9.5 w/ 6.75 back spacing?
- Black vinyl hardtop
- Inspection orlando fl
- Tire Size (new owner)
- Lower ball joint
- T-Top headliner
- 68 to 69 door lock conversion
- Starting Issues '81
- 1968 Seat Prices?
- What’s underneath?
- 1972 LT-1 / air car...
- Dash Brake Light Issue.
- Snubber bushing question- how tight?
- hanging from your mirror?
- Oh my Brakes
- 1975 built by George Barris for John Belushi?
- 1969 Engine starter color?
- C3 Horn grounding
- Wow, cannot believe she is 50 years old today
- It's Tail-End Tuesday!
- Power Windowes.
- Race ramps
- wiper door
- 72 LT-1 Replacement Carb
- Anyone here every buy a 'fake' 78 Pace Car?
- Alternator mounting problem
- What hood and where to buy?
- Got a great deal on a differential yesterday
- 1981 Bronze
