View Full Version : C3 General
- What is this thing called???
- C3 Headlight switch compatibility
- Rearview Camera
- Question Regarding Tachometer Removal And Replacement
- No Power Past solenoid
- Rebuilt my 74’ 454 into a 496 Stroker..
- Leaving your car to family members
- Ncrs
- 1971 LS6 convertible at Mecum
- 72 Center cluster "gauges"
- Outside Mirror Location?
- No Power
- 1978 L48, Champion plugs?
- Used Rubbers
- prove that N14 option (sidepipes) on 1969 was optional
- Exhaust manifolds "paint"
- Question about upper radiator hose on 68/427
- Where does this part go?
- Turbocharged C3
- The often considered but impossible. I am doing it - full custom interior & dash
- American Racing VN501 '500 mono cast'?
- Shifter cable: rubber boot replacement? (TH350)
- Throttle Linkage Question
- Longtime Lurker, First Time Member
- Comp cam 268h vs stock
- Gratitude
- Stupid Hubcap question
- Provide Superior Durability and Reliability with these C3 Corvette Radiator Supports!
- Center Cap Restoration Source?
- Inspiratiional Vette Porn
- problem with headlights
- Stuck rag joint?
- Corvette Rental Near Savannah, GA
- Can you recommend a Battery Tender for 1978 Corvette
- Mixed Bag today, Photo shoot, Swan Photo Bomb, and a Tow home
- 70 LT-1 convertible value
- Question about 1971 production #’s
- Fresh Air Control Arm
- Dead spot in the wheel
- New corvette owner, new to the forum
- 79 corvette roll up window blues....
- paint for engine bay?
- Great Snow Day Read - C&D 1971 Corvette w/ Duntov
- Am I missing something on this auction???
- Trying to find a recent post
- Steering columns overhaul
- Hey I'm New,
- '70 LS5 Vert value
- Corvettes of Dallas....open?
- 69 front lowering springs
- Corvette will not start
- 1982 CE Horn Button
- ** 23rd Annual CF St. Jude Children's Research Hospital Fundraiser **
- tire sizes for 20 inch rims/pics?/68 vette
- tire sizes for 29 inch rims on rear of 68 veette/pics?
- ‘71 dash cam install
- Custom (3d printed?) hood badge?
- 1972 convertible, frame part number
- 1978 corvette stingray
- Heat Shield Question
- Coolant level for a 1969
- '68-'75 Removeable Hardtop Differences?
- ShouldI buy this 427?
- Restoration Shops in Missouri
- Numbers matching or bigger engine.
- I know a guy selling some Vettes
- 1982 Steering Wheel options
- Seat covers
- 1970 Corvette wheel color.
- Hood liner pins
- Little help identifying this body kit.
- Alternator wiring questions.
- Happy New Years C3 Brothers
- Last ride of the year
- refurbished hardware on chassiss
- '78 Corvette - Value?
- '82 Crossfire Intake?
- Chuck Miller's Own Corvette Sport Wagon Is Back in the US
- door glass adjusters
- Turn signal flasher location
- Toggle switch in the wheel well
- 20 inch tire for rear/68 vette
- Starting 81 Restomod Project - Some questions
- LS swap engine temps
- VIDEO: Rescuing a Hurricane Flood Damaged 1972 Corvette
- What does this oldschool relay do? 1977
- Wider stock rims?
- Just How Problematic Are '68-'72 T-Tops (Leaks, Rattles, etc.)?
- Body dolley
- LS swap how to convert tach
- Pictures of 235/60-15 tires on 15x8 wheels
- putting c3 on jack stands
- What did you get for Christmas?
- Arizona driving weather
- New ball joints very stiff
- goofy question for the day
- Spare Tire Carrier Bolt
- Best Carpet and Underlayment?
- New carpet for interior (1977) + insulation
- Poll: '68-'69 vs. '70-'72. What's Your favorite and Why?
- Nice video that explains why you want high-zinc oil on push-rod engines
- 50 years today
- 1969 radiator?
- Reputable Repair Shops near Clearlake Houston, TX
- Contemplating The '81's Future
- 81 rpo 50/74m
- NCRS forum 12/27: planned upgrade
- Any interest in a "refurb an engine at home" thread?
- Bizarre 1970 Power Window Problem
- Frame Rust Question
- After Christmas Sale Here! Save 7% at Southern Car Parts Now!
- Paint
- Can i disable the torque converter lockup on a 82?
- Trying to find my grandpas corvette
- got a 1968 L88 for Christmas
- Thoughts on these engine stamps
- Best way to keep mice away during winter storage
- Merry Christmas
- Twas the night before Christmas'
- Not liking the new LIKES
- Have a Wonderful Christmas Time 😍
- 1982 crossfire injector tick?
- How Time Flies By
- Aluminum wheels - options
- Corvette Pace Car Jacket
- Car Stuck on lift
- 1969 L46 pricing
- Engine & 4 speed trans removal
- 71 coming back.
- 1968 corvette value
- ‘71 base small block axle ratio
- Sudden Transmission fluid leak
- Possible to keep the underbody/underhood show pretty while still driving it?
- Install New Engine or Rebuild Current
- Holiday Scam Alert
- 82 CFI possible purchase
- Explain these to me.
- How to swap rear storage lid information stickers?
- What’s The Best Way To Grease The Seat Slides
- '69 Clutch Cross Shaft Restoration
- What should I watch out for
- Looking for 69 427 convertible
- Vacuum lines from switch
- Aftermarket seats for C3s
- Door Key
- Best Interior Kit?
- Body back on frame - things seem misaligned
- Rust on birdcage
- Rust on birdcage
- Upgrade gages
- Shortened steering column
- Spicer U-Joint
- Strong gas smell
- Aftermarket wheels - hub centric spacer or centering lugs?
- Starting the car bypassing ignition/key switch
- Need your collective guidance to make my 73 Convertible Look better
- Question
- Rear quarter panel problem!
- 1969 427 engine code question
- Missing Muncie ID letter
- 69 Conv Top adjustment
- PPI near Pittsburg, PA
- HeLp....headlite relay diagram needed....
- Brake Issue
- Available Here: C3 Corvette Front Suspension Rebuild Kit!
- 1980 L82 or 1981 L81 4 speed
- Need new headlights for my 80
- interior lights '74
- Has anyone ever seen a Stock Lock on gas cap bezel on a 1971
- 1969 Owner's Manual
- Rechroming bumper
- greasy, sticky steering wheel intervention-cleaning
- 1968 Wiring Diagram
- C3 Collector Leather and Vinyl Dye Colors
- 1978 help needed - lenses between the speedo/tach
- Unknown connection under dash
- Windshield Damming Foam
- wheels
- 73 front bumper filler strip
- 1976 Wiper Bay
- Quick Jack, Still Like It?
- Noise from rear somewhere
- Intro and Wipers
- Running a non ecu controlled dizzy in a stock. 81
- 1973 EGR Delete
- Over Radiator Air Intake
- 1971 OEM deluxe door question
- Leaking Valve Covers
- Help Wanted for Corvette C3 Australia
- Carburetor Stamps
- Fuel Tank Vendors?
- 77 replacement bumper options
- Side fender emblems
- 1971 Corvette window sticker
- Wheel and tire question
- Home garage exhaust fan/hoses?
- Hood swap
- Dash lights are dim
- ignition coil question
- Who drives 'em rain or shine?
- Front Soft Top Guides/Striker plate
- Christmas Funnies
- Tire size question
- 1968 Rear Window lock/latch
- Chassis Wash?
- Drivers door mirror
- AC delete vs. upgrade
- Lug Nuts
- 69 original what to do
- Replace number two body mounts
- 68 Safari Yellow BB Tri Power Manual?
- Steering wheel options
- How many horns on your C3?
- Posi rebuild
- New to Cs
- Rear storage compartment frozen shut
- 48 today
- '69 Gas Smell
- Mystery Connector
- Help with 1971 Heat Control in Console Installation
- Is Corvettecarplace.com Legit?
- Additional question to previous post
- U Joint bore prep
- Rally Wheel Paint
- Oxblood paint
- 2024 Pay It Forward thread
- Dash rant
- LT-1 Holley build date
- Header back exhaust for 78 vette
- 1963 Wiring Diagrams
- LED Instrument Lights
- Threads on heater core replacement for '74 non-AC
- Sticky 15" tires
- Black Friday Sale - SAVE up to 50% !!!
- original factory hood verification
- Frt suspension suggestions
- 1979 won’t turn over
- Manual or automatic with a big block?
- Warped 68 door panels
- SMC help
- 1980 L48 LG4 Confusion
- '77 L-82 Where Do I Start?
- Need some help
- Flawless repaint or very nice original paint
- Father-son 1976 LS1 build thread
- Power Valve Size
- New harness but no power!
- VIN # check
- LS1 with BW 4 speed guidance
- PFYC Huge Black Friday/Cyber Monday Deals - 12-20% Off and More! Exclusive Discounts!
